Posts
45 -
Joined
Last visited
Calendar
Gallery
Everything posted by altix
The sketch I made using 3D Coat and Vray render. I wanted to create a simple summer composition with geometrical elements.
From the album: Somewhere in Greece
The same picture with some dirt added. -
Hair and Fur mesh seen in 3Ds Max -
Color map backed in 3D Coat and then tweaked in Photoshop -
Dear Taros, I model the cat in 3D Coat and made several retopology layers depending on colors of the fur. Say if my layer was intended for black fur, I delete from it all polygons that should be of different color. The fur was simulated in 3d Max. And after transfer it into mesh I hide the fur layers. The main body layer I painted in 3D Coat and then backed its color map. This color map I slightly tweaked in Photoshop using the textures of real cat fur. On the final stages I add the white contours on the cat in Photoshop. So I used 2D elements on some stages of my work, but I think this is Ok and many do this during map preparation and post-processing. I added some pictures to this album to illustrate this.
zoomed part -
A sketch inspired by a photo of A. Gnatush that I made in 3D Coat and rendered in Vray.© D, Vasylyev
I'm very glad that you like this work, guys. I used V-ray renderer. Unfortunately the capabilities of my home computer are limited and I was unable to set up V-ray perfectly. There is still some noise in the shadows .
Dear All, I've finished my last project done mostly in 3D Coat. It is a story about one place in Scotland I visited several years ago and that does not exist any more. It was called 'Ducks Crossing' because of ducks that used to gather near its entrance gate. I placed some pictures in the gallery of finished works http://3d-coat.com/forum/index.php?app=gallery&album=96. The booklet that tells this story you can find following the following links: https://www.dropbox.com/s/j7505ygsib7yhek/DucksCrossing.pdf?dl=0 https://yadi.sk/i/xqaEPmDScga4B and some technical details about the project and extras are collected here: https://www.dropbox.com/s/xllpf6z46avuxib/DucksCrossingTechnical.pdf?dl=0 https://yadi.sk/d/cnWm7Fe5cigEh During this work I really enjoyed the use of 3D Coat. I think it is very powerful add when you need to create quickly many items with the nontrivial topology. Fascinating program! Some pages used in the booklet: with best regards altix
It is a story about one place in Scotland I visited several years ago and that does not exist any more. It was called 'Ducks Crossing' because of ducks that used to gather near its entrance gate. I prepared a booklet with a short story about Ducks Crossing with the graphics I created with the help of 3D Coat. The whole story about Ducks Crossing you can read here https://www.dropbox.com/s/j7505ygsib7yhek/DucksCrossing.pdf?dl=0 and the technical details and extras you can see here https://www.dropbox.com/s/xllpf6z46avuxib/DucksCrossingTechnical.pdf?dl=0
From the album: Ducks Crossing
This is the dinning room of 'Ducks Crossing'. -
Sorry, but occasionally I deleted the files the links to which I gave above. Here are the new links to the booklet and the explanation: https://yadi.sk/i/rjLIDE9nZZsNp https://yadi.sk/i/Q9nHnTLvZZsic with best regards altix
Dear all, I think I understood how to upload the gallery. Previously I tried to upload the screenshots. Now the set of pictures is in my gallery. Cheers
An attempt to create a commercial booklet of some retro product. I chose Kiev (Contax) camera since I consider that it has timeless design. It looks really cool even 78 years after its first release. The booklet and some explanations to it you can find here https://yadi.sk/i/rjLIDE9nZZsNp and here https://yadi.sk/i/Q9nHnTLvZZsic
