Alco3d
Member
  • Joined
  • Last visited
Everything posted by Alco3d
  1. Today i tried 4.5 beta15 . Very pleasant PBR. But when i try to export model with PBR to 3ds max, i recieve empty texture. When i try File/export to 3ds max i got .obj and many blank .png. When i try File/Export object & texture - .obj and .mtl which i couldn't export to max. Also i try to export separately Textures and Layers but the same. After that to reinstal 3DC but nothing. ((
  2. Looks amazing! PBR is a great shader, but i don't understand how to export this wonderful to 3ds max? I try different combination of setting export, but receive empty texture in 3ds max. (((
  3. Few times i try to install Applink for my 3dsmax 2014. I try different version Applink but it doesn't work. When i click on Manual update occur nothing. Can it be, because i have cyrillic letters in the path to Exchange folder? I know some programm (Alias studio, Keyshot) doesn't work for this reason. Thanks!
  4. I don't understand what happened. I just reinstalled and everything became ok. May be it was bug or i changed something in the presets, i don't know. When i switch between Smooth and other, it seems like 3d coat is remeshing or something like that, thinking for half a second and switching back. 0_0
  5. Thanks ajz3d for response! I tried to back to default hotkeys in preference and tried to remove Options_Hotkeys.xml in the folder specified by you , but it doesn't work. ((( If i switch by mouse all be allright. Problems appear in shortcuts. I met with problem of stacks before but it looks another. That problem appeared suddenly on work. I didn't change anything before. I was just working. (( After reset to default the same - struggles gennerally with Smooth tool.
  6. I have one more problem. Seems that's bug with shortcut. When i work with model i notice when i switch tools on keyboard it doesn't. More exact, it's switching but for 1 second and switching back. Tools are switching if i click two times at the same time. I try to restart 3d coat or PC but it doesn't help. (( Version 4.1.17D UPD That is happing only with Smooth tool and Draw tool. Computer struggling to switch that tools.
  7. That not to create new thread i will add a small question here. I've one parent object and some sub objects in tree. I want to pose main object together sub object, otherwise i want to tilt a head with ears, eyes and etc together. How i can do that? I try to add objects in pose tool but they are posing separately.(( Thanks!!!!
  8. Oh! Thanks so much! You are right, It disturbed me!
  9. Hi, Carlosan! Seems i solved this problem. I don't know how exactly, but against problem layers i noticed small arrows. When i clicked this, the coat restore to earlyer state and i could do to switch to voxel, and to make resample. This message looks simple - "CantGetBackToVoxel' by one word and button OK. Now i don't get this message, and don't know what i did)))
  10. Once i got this message when trying to switch to voxel. At once another layer - same, but another works fine 5 minutes ago it was be perfect. Also can't make resample for this layers. What's going on? I am user 4.1.17d (CUDA), had 1,5 mil poligons, objects is quite simple. Thanks!
