SebastianLeon
Posts
16 -
Joined
Last visited
Calendar
Gallery
Posts posted by SebastianLeon
Dude thank you all for sharing your knowledge! stusutcliffe that was classy bro Thank you for helping out!!
- 1
Hmm I mean like when you use the Curve tool to make tubes/cables etc.. Is there a way to make it a flat object instead of a circle?
HI Guys, I've been trying to figure out how to make a Spline for the Spline menu. I need a flat object to go in there so I can make straps for my gun.
Does anyone have any suggestions as to how I could approach this?
Thanks guys!
On 6/4/2016 at 2:02 AM, ajz3d said:
It's a notorious bug. First back up, and then remove %USERPROFILE%\Documents\3D-CoatV45\ToolsPresets directory and see if it helps. Restore the directory if it doesn't.
I did do that and it worked for about a week. But now the lag is back and I tried to repeat what you suggested and it's not working :(. I wonder what could be causing this issue for my 3DCoat.
I just did a fresh install of the latest version and I still get the 3-5 second lag whenever I change tools :(.
Hi guys,
I've been using 3d-coat for a while now and I've come to learn alot about how it works and figured out most of the issues I've encountered. Now the only issue I've got left is that whenever I change tools from Grow to Cut or Transform or any other tool, I get a 4 or 5 second delay and it's really disruptive to my workflow. I was wondering if anyone knew how to fix it? I'm using space bar (quick change menu) to swap tools.
The only solution I've come up with so far is deleting my documents folder (the 3D-Coat folder) and re-entering my serial key.
Please help! (I've also tried about 50 different client versions.. so that's really not the issue here)
Hi guys,
Does anyone know why 3d-coat is giving me the wrong layers inside the Paint room? I exported my Obj and then imported it into the Paint room. I've tried restarting the program and selecting other meshes but nothing seems to solve this issue. It's very frustrating not being able to handle my material layers
I hope someone knows the answer
Guys any chance of getting this in english please? Got the same issue! Thanks
I thought it was the symmetry aswell. But it wasn't turned on whilst using the pose tool. Let me check the ground plane suggestion though!......
and.....
Omg you genius Thank you for helping me!! I moved the whole object above the ground plane (sat on it) and it fixed the issue!
Hi Guys just wondering if anyone knows why I get this dark line in my geometry when using the pose tool? If I try to pose/move the selected area, it just poses one side of the geometry and not the other.
Hi guys,
I've recently started using c4d for rendering my environments and I was wondering if anyone knew how to reduce the polycount of my models in 3dCoat before exporting? I know you can decimate but it loses ALOT of edge quality and perhaps theres another way? I tried "make a shell" and it just doubled in size.. (???)
Any help would be much appreciated!
Sorry for the late reply! It's 45,000
Hi guys,
I was just wondering if anyone knew how to create splines from models that you make? I tried to import a simple "tape" looking mesh into my splines and it lagged my whole system, making it impossible for me to use my mesh to make some simple tape. for my environment piece.
Would love to get some help on this issue as I really want to make some splines for character work and spaceships.
Thanks!
Hi guys recently I upgraded to the 4.5.19 version of 3dCoat and whenever I change my tool of use, wether I click on the voxel tool or press my shortcut, it has a delay of around three seconds to change to my desired tool. Does anyone else have this problem in 4.5 and more importantly, does anyone know how to fix this?
Thanks!
Sebastian.
Currently have tried all 4 different 3DCoat exe's and they all seem to be doing the same thing.
Hi guys, I've recently attended industry workshops London and Jama Jurabaev did a super awesome presentation with 3D Coat and so I find myself trying to figure out how to use this new software.
I love the fact that you can draw in 3D with 3DCoat. I think its the most awesome thing in the whole universe. But What I'm having issues with is importing an OBJ of a Daz model into 3DCoat. Whenever I do it, I get a hugeeeeeee lagg and my cores are going crazy at 100% but nothing happens.. it just kind of freezes.
I'm just wondering if anyone has worked out how to get the Daz model into 3D Coat in a really basic way and if you wouldn't mind sharing your step by step process? I think it'd be a great help to all those who are newbies to 3D!
Thanks! I'll be introducing myself in the intro thread soon
Importing FBX from 3ds Max to 3Dcoat Paint room.
in General 3DCoat
Posted · Edited by SebastianLeon
Hi Guys,
I've recently started learning fusion360 and I've figured out a workflow to export the mesh from there to 3dsMax and convert into an FBX. The problem I'm having is when I import the FBX to 3dCoat nothing shows up. Substance Painter has no issues so I'm wondering if it's just that 3dCoat doesn't read FBX files? ver: 4.7.06
ps: I can import OBJ files just fine, I would just rather have my object separated as it is in my FBX file
