Posts
503 -
Joined
Last visited
Calendar
Gallery
Everything posted by Daniel
Привет, Арбуз Работает это след. образом. Допустим ты что-то скульптанул на левой или правой части и теперь хочешь симметрично это скопировать. Включаешь симметрию (до этого она была выключена, разумеется) и жмешь Symm copy. Она скопирует ту часть, которая была модифицирована последней. Пробуй! Удачи!
Hi SMcQ, we are checking it right now! Thanks for posting it.
If you mean masking in AUTOPO process then it turns automatically after the first prompt window. If you mean masking as standalone feature, then it can be found in voxel surface tools, and is called Freeze
Hi papagersi, You can paint masking (which is actually areas which will have more dense quads) right after you click OK in the first prompt window where you set amount of polys that will be on resulting mesh. Try it out! Good Luck!
I didn't understand about your Graphic card. Is it integrated? Did you try to paint with simple brush (with red color, for example) on 4096x4096 map? How is it? Do you make UV-sets yourself, or automatically in 3D-Coat (that may explain "low res" feel). What size are those images that you are projecting color from? Maybe post them here with your model in OBJ
Hey laborpilot, Can you tell us some more info, e.g. your hardware, 3D-Coat version (DX or GL), painting mode that you use... That might help! Thanks
Yep, Palex, you definitely should start to learn blender. You can't live with 3DC only, you absolutely need a 3D modeler app. Blender is free and powerful enough. So get in to it!
Hey Palex, Two words before I go to bed - GET BLENDER (blender.org)
See attached image! That's all you need to do P.S. You can name the folder to store the sequence whatever you like (not necessarily "TURNTABLE" )
I tried to merge your mesh as thin skin with thickness value 6.00 Then added density areas and edge guides (with symmetry, of course) Gotta pretty good results! P.S. Better to do it manually, and then add thickness to the mesh in 3D modeler.
Hi, Try to play with these (see image) Use ALT+LMB when cursor is over model.
Hi Vincent, Could you specify what are you doing exactly and where the problem starts: 1) Does it work fine inside 3DC? 2) What mode are you working in (per-pixel, microvertex)? 3) What export settings do you use? 4) What happens inside LW exactly? And finally, try the latest build from here Thanks, and welcome aboard
Hey Wozzie! Welcome here!!! Look at the attached image. That may help. I often use "Rotate around world center" or "Rotate around current pick point". Navigation with ALT+LMB if the cursor is over the mesh.
Hi, What exactly do you need? Doesn't the Opacity slider make the effect?
Супер! Хорошая новость Продолжай творить на радость людям! И нам не забывай показывать работы...
В принципе, по экспортированной текстуре видно нормально ли все запеклось. Можешь попробовать что-то запечь, экспортнуть и выложить сюда нормал мапу, а мы поглядим на нее Еще совет: всегда при экспорте ставь галочку "create padding" (окантовка)! Буду ждать ответа!
Я использовал последнюю версию, 3.5.22, кажеться Может попробуешь в этой версии? Если что, вернешься к 3.5.19
Приветствую! А попробуйте в Настройках посмотреть что стоит в графе Normal map export. Должен быть 3DS Max в вашем случае. Быть может, один из каналов получается инвертированным (зеленый, кажись). Хотя не факт! EDIT: Только что попробовал запечь без локал оклюжена. Импортнул и настроил в блендере. Все вышло.
There is on important thing to remember: Currently, AUTOPO works ONLY with Voxels(!) That means that you have to merge your mesh into Voxel Room. Another nuance here is that the mesh should be "water tight" (no holes). You may post some test mesh and will show you what you can do with it.
Hello Winterly, Welcome aboard!!!
You're always welcome!
Memory and processor to overload
Daniel replied to Kargall's topic in SOS! If you need urgent help for 3DCoat
Hello Kargall! Does it happen right after 3DC launches? What version do you use? What OS? Did that happen before? Maybe some steps to reproduce? -
Do you mean "rotated"? If so, then try to use "(" ")" keys! Good luck!
ВАУ! Класс!!! Может стоит дерево чуть темнее или коричневее..? (субъективное мнение)
