Showing results for tags '3d coat'.
  1. lala14
    Guardian of North
    From the album: Lamnho
    Trying to focus on bringing out the emotion Turntable via link https://www.artstation.com/artwork/2XmAv
  2. Hello, I'm new to 3d coat and i've been doing some retopology to my head mesh which i've imported from my scanner. while doing the retopology I used the symetry option and when i've unwrapped it it was just half of the face and when I tried to export it to blender it was the same. what should i do in order to get a full head unwraped either in 3d coat or blender? does it have to do with using symetry? if it does how can i avoid it and still not retopology the all mesh by hand? would appreciate any advice . Thank you.
  3. I have a new MacBook Pro 2017 (meets system specifications and running Sierra OS), but 3D Coat version 4.7.23 keeps crashing at startup. I installed version 4.5.xxx but these either crashed, froze, or gave me red-screens. What do I do? I already purchased a license. Thanks for any help! Andrew copy/pasted my error crash log here on Sierra OS, 3D Coat version 4.7.23 -- Loading Xml file "Xmls/Settings.xml"... Can't load file "Xmls/Settings.xml" ------------------------------------------------------------ OpenGL | Version: 4.1 ATI-1.51.8 OpenGL | Vendor: ATI Technologies Inc. OpenGL | Renderer: AMD Radeon R9 M295X OpenGL Engine OpenGL | Supported features: OpenGL | Multitexture (fragment shader units: 16) OpenGL | Anisotropic filtering (level: 16) OpenGL | Texture Compression DXT OpenGL | Vertex Array Object OpenGL | Vertex Buffer Object OpenGL | Vertex Attributes (count: 16) OpenGL | Vertex Uniform Vectors (count: 1024) OpenGL | OpenGL Shading Language OpenGL | Frame Buffer Object (max size: 16384 X 16384) OpenGL | MRT (targets: OpenGL | Extensions (46) : GL_ARB_blend_func_extended GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_ES2_compatibility GL_ARB_explicit_attrib_location GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader5 GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_occlusion_query2 GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_subroutine GL_ARB_shading_language_include GL_ARB_tessellation_shader GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_texture_storage GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_vertex_attrib_64bit GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_texture_compression_s3tc GL_EXT_texture_filter_anisotropic GL_EXT_texture_mirror_clamp GL_EXT_texture_sRGB_decode GL_APPLE_client_storage GL_APPLE_container_object_shareable GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_texture_range GL_ATI_texture_mirror_once GL_NV_texture_barrier ------------------------------------------------------------ Registering vertex formats... 3Dconnexion framework found cMeshIO::AddCodec(): Added "Obj" mesh codec. cMeshIO::AddCodec(): Added "Lwo" mesh codec. cMeshIO::AddCodec(): Added "Fbx" mesh codec. cMeshIO::AddCodec(): Added "Stl" mesh codec. cMeshIO::AddCodec(): Added "Ply" mesh codec. cMeshIO::AddCodec(): Added "dae" mesh codec. cMeshIO::AddCodec(): Added "wrl" mesh codec. cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Sphere.obj". cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Ring.obj". cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Cube.obj". cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Sector.obj". cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Cone.obj". cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Cylinder.obj". cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets/icosa240.obj". Added "TIF" image codec. Added "TIFF" image codec. Added "EXR" image codec. Added "HDR" image codec. - Loading font "Calibri 11"... Can't load file "Fonts/Calibri 11.cFont" - Loading font "Calibri 16"... Can't load file "Fonts/Calibri 16.cFont" - Loading font "Calibri B24"... Can't load file "Fonts/Calibri B24.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma B8"... Can't load file "Fonts/Tahoma B8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" Can't load image file "Textures/WindowsStandard/ToolBar.bmp" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" Version : 3D-COAT 4.7.23(GL64) Can't load file "Shaders/hud2t.glsl" Can't load file "Shaders/Low/hud2t.glsl" Can't load file "Shaders/VeryLow/hud2t.glsl" Can't load file "Shaders/hud_smooth.glsl" Can't load file "Shaders/Low/hud_smooth.glsl" Can't load file "Shaders/VeryLow/hud_smooth.glsl" Can't load file "Shaders/hud.glsl" Can't load file "Shaders/Low/hud.glsl" Can't load file "Shaders/VeryLow/hud.glsl" Can't load file "Shaders/LinesPointsUI.glsl" Can't load file "Shaders/Low/LinesPointsUI.glsl" Can't load file "Shaders/VeryLow/LinesPointsUI.glsl" Can't load file "Shaders/Colored.glsl" Can't load file "Shaders/Low/Colored.glsl" Can't load file "Shaders/VeryLow/Colored.glsl" Can't load file "Shaders/RenderSystem.glsl" Can't load file "Shaders/Low/RenderSystem.glsl" Can't load file "Shaders/VeryLow/RenderSystem.glsl" Can't load file "Shaders/RenderSystem.glsl" Can't load file "Shaders/Low/RenderSystem.glsl" Can't load file "Shaders/VeryLow/RenderSystem.glsl" Can't load file "Shaders/text2.glsl" Can't load file "Shaders/Low/text2.glsl" Can't load file "Shaders/VeryLow/text2.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_sel.glsl" Can't load file "Shaders/Low/obj_sel.glsl" Can't load file "Shaders/VeryLow/obj_sel.glsl" Can't load file "Shaders/obj_render_color.glsl" Can't load file "Shaders/Low/obj_render_color.glsl" Can't load file "Shaders/VeryLow/obj_render_color.glsl" Can't load file "Shaders/obj_render_normals.glsl" Can't load file "Shaders/Low/obj_render_normals.glsl" Can't load file "Shaders/VeryLow/obj_render_normals.glsl" Can't load file "Shaders/obj_render_mrt.glsl" Can't load file "Shaders/Low/obj_render_mrt.glsl" Can't load file "Shaders/VeryLow/obj_render_mrt.glsl" Can't load file "Shaders/tex_preview.glsl" Can't load file "Shaders/Low/tex_preview.glsl" Can't load file "Shaders/VeryLow/tex_preview.glsl" Can't load file "Shaders/tex_preview_nrm.glsl" Can't load file "Shaders/Low/tex_preview_nrm.glsl" Can't load file "Shaders/VeryLow/tex_preview_nrm.glsl" Can't load file "Shaders/tex_preview_alpha.glsl" Can't load file "Shaders/Low/tex_preview_alpha.glsl" Can't load file "Shaders/VeryLow/tex_preview_alpha.glsl" Can't load file "Shaders/tex_preview_all.glsl" Can't load file "Shaders/Low/tex_preview_all.glsl" Can't load file "Shaders/VeryLow/tex_preview_all.glsl" Can't load file "Shaders/obj_preview_pen2.glsl" Can't load file "Shaders/Low/obj_preview_pen2.glsl" Can't load file "Shaders/VeryLow/obj_preview_pen2.glsl" Can't load file "Shaders/inrect.glsl" Can't load file "Shaders/Low/inrect.glsl" Can't load file "Shaders/VeryLow/inrect.glsl" Can't load file "Shaders/obj_preview_pen2.glsl" Can't load file "Shaders/Low/obj_preview_pen2.glsl" Can't load file "Shaders/VeryLow/obj_preview_pen2.glsl" Can't load file "Shaders/preview_rect.glsl" Can't load file "Shaders/Low/preview_rect.glsl" Can't load file "Shaders/VeryLow/preview_rect.glsl" Can't load file "Shaders/draw_pic_over_curve.glsl" Can't load file "Shaders/Low/draw_pic_over_curve.glsl" Can't load file "Shaders/VeryLow/draw_pic_over_curve.glsl" Can't load file "Shaders/draw_pic_over_curve.glsl" Can't load file "Shaders/Low/draw_pic_over_curve.glsl" Can't load file "Shaders/VeryLow/draw_pic_over_curve.glsl" Can't load file "Shaders/preview_fill.glsl" Can't load file "Shaders/Low/preview_fill.glsl" Can't load file "Shaders/VeryLow/preview_fill.glsl" Can't load file "Shaders/uv.glsl" Can't load file "Shaders/Low/uv.glsl" Can't load file "Shaders/VeryLow/uv.glsl" Can't load file "Shaders/wires.glsl" Can't load file "Shaders/Low/wires.glsl" Can't load file "Shaders/VeryLow/wires.glsl" Can't load file "Shaders/wires.glsl" Can't load file "Shaders/Low/wires.glsl" Can't load file "Shaders/VeryLow/wires.glsl" Can't load file "Shaders/sphere.glsl" Can't load file "Shaders/Low/sphere.glsl" Can't load file "Shaders/VeryLow/sphere.glsl" Can't load file "Shaders/obj_preview_pen.glsl" Can't load file "Shaders/Low/obj_preview_pen.glsl" Can't load file "Shaders/VeryLow/obj_preview_pen.glsl" Can't load file "Shaders/CurrentMcubes/mcubes.glsl" Can't load file "Shaders/Low/CurrentMcubes/mcubes.glsl" Can't load file "Shaders/VeryLow/CurrentMcubes/mcubes.glsl" Can't load file "Shaders/sphere.glsl" Can't load file "Shaders/Low/sphere.glsl" Can't load file "Shaders/VeryLow/sphere.glsl" Can't load file "Shaders/mpreview.glsl" Can't load file "Shaders/Low/mpreview.glsl" Can't load file "Shaders/VeryLow/mpreview.glsl" Can't load file "Shaders/mpreview1.glsl" Can't load file "Shaders/Low/mpreview1.glsl" Can't load file "Shaders/VeryLow/mpreview1.glsl" Can't load file "Shaders/Font.glsl" Can't load file "Shaders/Low/Font.glsl" Can't load file "Shaders/VeryLow/Font.glsl" Can't load file "Shaders/mcubes_rt.glsl" Can't load file "Shaders/Low/mcubes_rt.glsl" Can't load file "Shaders/VeryLow/mcubes_rt.glsl" Can't load file "Shaders/mcubes_nrm.glsl" Can't load file "Shaders/Low/mcubes_nrm.glsl" Can't load file "Shaders/VeryLow/mcubes_nrm.glsl" AppLink search path registered: /Users/Andrew1/AppLinks/3D-Coat/Exchange/ AppLink search path registered: /Users/Andrew1/3D-CoatV4/Exchange/ AppLink search path registered: /Users/Andrew1/3D-CoatV3/Exchange/ AppLink search path registered: /Users/Andrew1/3D-CoatV47/Exchange/ Can't load file "Shaders/LinesPointsUI.glsl" Can't load file "Shaders/Low/LinesPointsUI.glsl" Can't load file "Shaders/VeryLow/LinesPointsUI.glsl" Can't load file "Shaders/Colored.glsl" Can't load file "Shaders/Low/Colored.glsl" Can't load file "Shaders/VeryLow/Colored.glsl" Can't load file "Shaders/RenderSystem.glsl" Can't load file "Shaders/Low/RenderSystem.glsl" Can't load file "Shaders/VeryLow/RenderSystem.glsl" Can't load file "Shaders/RenderSystem.glsl" Can't load file "Shaders/Low/RenderSystem.glsl" Can't load file "Shaders/VeryLow/RenderSystem.glsl" Can't load image file "Levels/Uv/Uv_d" Crash occured. Trying to save object...
  4. Hi guys! I have a project I am working on and the bit I have gotten to now is really making my head hurt haha! So I am trying to make terrain pieces that can fit together side by side and be seamless and flow from one to the other. The idea is that I can sculpt a number of pieces and they can be used multiple times in different positions and rotations to create a potentially infinite number of terrain boards. http://i.imgur.com/NGRCrqg.jpg That is my rough concept where there are pieces like straight rivers, curved rivers, rivers with crossings, cliffs, cliff corners inner and outer, cliffs with slopes, lakes and grass plains and they can then be used multiple times to create varied landscapes. My issue is that I am unsure how to make them tileable! Ideally I am looking for a way of sculpting a perfectly square mesh that repeats at the edges so each module can fit next to another module with relative ease. I have tried doing it via photoshop creating heightmaps but the results are not great and it takes far too long to make a heightmap by hand, with detail without having a reference as to what it looks like when applied to a model. I would appreciate any help that I can get with the matter! I am struggling! Thank you!
  5. CharlieT
    Reveil matin
    From the album: CharlieT visual design
    Un visual d'un réveil matin
  6. Hi everyone, a new user is here! love 3D Coat! So I wanted to try new brushes and materials in download section, and they are like 15 GB! after I unzip them, and boy I don't have that space in my C drive, so I moved them to my external hard drive and created a shortcut and pasted it to my document where 3d coat textures and patterns are, but unfortunately 3D Coat is not reading it, it only reads when I paste the actual file, not the shortcut version, is there anyway to make this work? I learned this trick working with Zbrush, it would be nice if we can do this in 3D Coat as well! if not I can't use these awesome brushes I don't have enough space! The below image shows the shortcut version where didn't work and the actual file which works! tnx.
  7. I've been having a problem with the transform tool, in the Sculpt room. Whenever I put more than one mesh objects and use the transform tool, it is "focused" on both of them. How am I able to get it "focused" on one mesh object, rather than two mesh objects. Please respond ASAP, thank you!
  8. I Finally have some free time to start learning 3D Coat. really fun program to use. can't wait to learn more about the tools.
  9. When i use the option to "import image as mesh" in the 3d coat and enter my picture there, and click enter.. The picture i choosed to transform into mesh, is in there, but there is a white backround i can't get rid of. I've have tried using a trasparent picture, but the white backround is still there. I've also have tried the "cut off tool" But it's hard to cut off the white backround off from the picture with it. Please help, thank you.
  10. Been trying all night to get this Autoretopo to work. Ive followed tutorials and Im doing nothing different. When the mesh finishes retpologizing I just get this. https://gyazo.com/8ceae1baacdac46f8104539bde0c6aad No polygons or anything. Ive tried resizing, adjusting the base mesh, saving it in different names. OBJ or FBX nothing seems to work. I go through all the steps of assigning the flow of geometry and nothing happens. Anyone have any tips? Thank you.
  11. Hey guys, i dont understand what he did in the minute 10:03 with the gun`s nozzle. i pick the grow tool but my brush is circular and it apply a circular stroke. He seems to have like a rect brush. And then he use the same brush to carve in the nozzle 10 seconds later. Can anyone point me out how he did it? Thanks!!
  12. Ey guys, i have liceses for Substance painter,Designer and B2M. Becouse of my art style i dont really use PBR or the other features Substance comes with. I would love to know if it is possible to exchange my 3 liceses for 3D coat with other user. Thanks and sorry for my dumb question
  13. Hi guys! So i have some small issues, where ever i try to retopologize these meshes, some weird shit happends and it doesnt do it well! So i have used it a bit, and it has worked fine for other less complex stuff. So i know i would get some work here, at some point i got it fine, non the less, alot of bad topology! So, its probably just me doing something wrong! I tried jucing up the different settings, and yeah, but the thing is this: I took it into maya (3d model animation software) and seperated all meshes, removed them, closed holes and took it back, got then the result from the seconds picture! Which was better.
  14. Here is a tutorial I made on 3D coat curves
  15. Sorry guys. I realised I should have posted to this board. I hope you find this useful. Please also check my website for more tutorials. http://www.creativewithjaakko.com
  16. Hello All! For those of you already on Pluralsight/Digital Tutors or those of you who might want to be, I recently had a 4 1/2 hour course covering some techniques in Character Sculpting published. If you want, please take a look at the course overview below: 3d-coat-character-concept-sculpting-techniques One thing that is different about it is that it covers a way of taking the voxel/surface sculpt directly to Cura to 3D print. In my case it is a Lulzbot TAZ 5 3d printer, but the techniques could apply to other printers as well. Excelsior! Eric Kunzendorf
  17. I am working in the paint room on my second project, and I have been having nothing but troubles with 3d coat crashing when using the polygonal paint selection brush. I am not sure if this is a bug with the polygonal paint brush, or it is a file corruption, as I did not use this brush in my first project. However, as soon as I make longer polygonal strokes, that is when I would get a warning, stating that the program has become unstable and is recommended in saving your work. Once that is complete the program crashes. Here is my last crash report, and I am including my project file. Version:3D-COAT 4.7.06(DX64) Memory status: OK pointers: 53386 Video: Intel(R) HD Graphics Family Intel(R) HD Graphics Family Intel(R) HD Graphics Family nproc: 4 (1)object: (C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub_painting.3b) vert: 128 poly: 0 rt:256x256 undo: (5) LPUS LPUS LPUS LPUS tool: StdPen NumMeshLoads: 1 Time since mesh loading: 872 s VoxelTool: 0 RetopoTool: 3 UV_Tool: 1 D2ABF11A c:\3dcoat\3d-coat\3d-coatv4\3d-coat\penshape.cpp line 6709 [+25], CurveBuffer::CreateCurveBuffer+2058 D2CDD3DD c:\3dcoat\3d-coat\3d-coatv4\3d-coat\surfacemodificator.cpp line 1246 [+22], SurfaceModificator::CreateRectPick+2653 D2CCD109 c:\3dcoat\3d-coat\3d-coatv4\3d-coat\stdpen.cpp line 127 [+0], StdPenTool::OnRectSelectionEnd+73 D241AD1E c:\3dcoat\3d-coat\3d-coatv4\3d-coat\basictool.cpp line 3182 [+0], BasicTool::ProcessTools+4430 D2B3FCA8 c:\3dcoat\3d-coat\3d-coatv4\3d-coat\polymesh.cpp line 15174 [+0], MainCycle+10584 D300ACEE c:\3dcoat\3d-coat\3d-coatv4\main.cpp line 137 [+5], comms::cMain_OnRender+718 D2FAD7F4 c:\3dcoat\3d-coat\3d-coatv4\comms\cwinmain.cpp line 534 [+0], cWinMain_OnRender+180 D2FB4A07 c:\3dcoat\3d-coat\3d-coatv4\comms\cwinmain.cpp line 2438 [+0], cWinMain_OneIterationOfMessageLoop+199 D2FB68B9 c:\3dcoat\3d-coat\3d-coatv4\comms\cwinmain.cpp line 2720 [+14], WinMain+6521 D30301F8 f:\dd\vctools\crt\crtw32\startup\crt0.c line 251 [+17], __tmainCRTStartup+328 0C348102 line 0 [+0], BaseThreadInitThunk+34 0E60C5B4 line 0 [+0], RtlUserThreadStart+52 0E60C5B4 line 0 [+0], RtlUserThreadStart+52 General information: Exception code:C0000005 3D-COAT 4.7.06(DX64) Memory status before run: Memory load: 36 TotalPhys: 2074238976 AvailPhys: 4020043776 TotalPageFile: 1000497152 AvailPageFile: 2947485696 TotalVirtual: 4294836224 AvailVirtual: 4100616192 Memory status after crash: Memory load: 45 TotalPhys: 2074238976 AvailPhys: 3439591424 TotalPageFile: 1000497152 AvailPageFile: 2285056000 TotalVirtual: 4294836224 AvailVirtual: 3210690560 AvailVirtual: 3210690560 Module found C:\Program Files\3D-Coat-V4.7.06\3D-CoatDX64C.exe (\3D-CoatDX64C.exe) Handle: 00007FF6D17F0000 Base address: 00007FF6D17F0000 Module found C:\WINDOWS\SYSTEM32\ntdll.dll (ntdll.dll) Handle: 00007FFB0E5B0000 Base address: 00007FFB0E5B0000 Module found C:\WINDOWS\system32\KERNEL32.DLL (KERNEL32.DLL) Handle: 00007FFB0C330000 Base address: 00007FFB0C330000 Module found C:\WINDOWS\system32\KERNELBASE.dll (KERNELBASE.dll) Handle: 00007FFB0B400000 Base address: 00007FFB0B400000 Module found C:\WINDOWS\system32\USER32.dll (USER32.dll) Handle: 00007FFB0BB60000 Base address: 00007FFB0BB60000 Module found C:\WINDOWS\system32\GDI32.dll (GDI32.dll) Handle: 00007FFB0CC20000 Base address: 00007FFB0CC20000 Module found C:\WINDOWS\system32\COMDLG32.dll (COMDLG32.dll) Handle: 00007FFB0BA50000 Base address: 00007FFB0BA50000 Module found C:\WINDOWS\system32\msvcrt.dll (msvcrt.dll) Handle: 00007FFB0B9B0000 Base address: 00007FFB0B9B0000 Module found C:\WINDOWS\system32\combase.dll (combase.dll) Handle: 00007FFB0BEB0000 Base address: 00007FFB0BEB0000 Module found C:\WINDOWS\system32\RPCRT4.dll (RPCRT4.dll) Handle: 00007FFB0BD70000 Base address: 00007FFB0BD70000 Module found C:\WINDOWS\system32\bcryptPrimitives.dll (bcryptPrimitives.dll) Handle: 00007FFB0B920000 Base address: 00007FFB0B920000 Module found C:\WINDOWS\system32\shcore.dll (shcore.dll) Handle: 00007FFB0B340000 Base address: 00007FFB0B340000 Module found C:\WINDOWS\system32\SHLWAPI.dll (SHLWAPI.dll) Handle: 00007FFB0CAF0000 Base address: 00007FFB0CAF0000 Module found C:\WINDOWS\system32\SHELL32.dll (SHELL32.dll) Handle: 00007FFB0CE20000 Base address: 00007FFB0CE20000 Module found C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.10586.494_none_a2d8b04ea53e3145\COMCTL32.dll (WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.10586.494_none_a2d8b04ea53e3145\COMCTL32.dll) Handle: 00007FFB000A0000 Base address: 00007FFB000A0000 Module found C:\WINDOWS\system32\cfgmgr32.dll (cfgmgr32.dll) Handle: 00007FFB0B8D0000 Base address: 00007FFB0B8D0000 Module found C:\WINDOWS\system32\windows.storage.dll (windows.storage.dll) Handle: 00007FFB0AC60000 Base address: 00007FFB0AC60000 Module found C:\WINDOWS\system32\advapi32.dll (advapi32.dll) Handle: 00007FFB0BCC0000 Base address: 00007FFB0BCC0000 Module found C:\WINDOWS\system32\sechost.dll (sechost.dll) Handle: 00007FFB0C2D0000 Base address: 00007FFB0C2D0000 Module found C:\WINDOWS\system32\kernel.appcore.dll (kernel.appcore.dll) Handle: 00007FFB0AC50000 Base address: 00007FFB0AC50000 Module found C:\WINDOWS\system32\powrprof.dll (powrprof.dll) Handle: 00007FFB0ABF0000 Base address: 00007FFB0ABF0000 Module found C:\WINDOWS\system32\profapi.dll (profapi.dll) Handle: 00007FFB0ABD0000 Base address: 00007FFB0ABD0000 Module found C:\WINDOWS\system32\FirewallAPI.dll (FirewallAPI.dll) Handle: 00007FFB0B2B0000 Base address: 00007FFB0B2B0000 Module found C:\WINDOWS\system32\NETAPI32.dll (NETAPI32.dll) Handle: 00007FFB0B990000 Base address: 00007FFB0B990000 Module found C:\WINDOWS\system32\ole32.dll (ole32.dll) Handle: 00007FFB0E3B0000 Base address: 00007FFB0E3B0000 Module found C:\WINDOWS\system32\OLEAUT32.dll (OLEAUT32.dll) Handle: 00007FFB0C3E0000 Base address: 00007FFB0C3E0000 Module found C:\WINDOWS\system32\WS2_32.dll (WS2_32.dll) Handle: 00007FFB0CDB0000 Base address: 00007FFB0CDB0000 Module found C:\WINDOWS\SYSTEM32\DAVHLPR.DLL (DAVHLPR.DLL) Handle: 00007FFB05D90000 Base address: 00007FFB05D90000 Module found C:\Program Files\3D-Coat-V4.7.06\tbb.dll (\tbb.dll) Handle: 0000000180000000 Base address: 0000000180000000 Module found C:\WINDOWS\SYSTEM32\VERSION.dll (VERSION.dll) Handle: 00007FFAFEAB0000 Base address: 00007FFAFEAB0000 Module found C:\WINDOWS\SYSTEM32\d3d9.dll (d3d9.dll) Handle: 00007FFAE9460000 Base address: 00007FFAE9460000 Module found C:\Program Files\3D-Coat-V4.7.06\d3dx9_38.dll (\d3dx9_38.dll) Handle: 00000000644A0000 Base address: 00000000644A0000 Module found C:\WINDOWS\SYSTEM32\WININET.dll (WININET.dll) Handle: 00007FFAFA450000 Base address: 00007FFAFA450000 Module found C:\WINDOWS\SYSTEM32\dwmapi.dll (dwmapi.dll) Handle: 00007FFB07F10000 Base address: 00007FFB07F10000 Module found C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9177_none_08e695a3a83b6ce3\MSVCR90.dll (WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9177_none_08e695a3a83b6ce3\MSVCR90.dll) Handle: 00000000655B0000 Base address: 00000000655B0000 Module found C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9177_none_08e695a3a83b6ce3\MSVCP90.dll (WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9177_none_08e695a3a83b6ce3\MSVCP90.dll) Handle: 00000000643C0000 Base address: 00000000643C0000 Module found C:\WINDOWS\system32\IMM32.DLL (IMM32.DLL) Handle: 00007FFB0C130000 Base address: 00007FFB0C130000 Module found C:\WINDOWS\SYSTEM32\fwbase.dll (fwbase.dll) Handle: 00007FFB09A50000 Base address: 00007FFB09A50000 Module found C:\WINDOWS\system32\uxtheme.dll (uxtheme.dll) Handle: 00007FFB09730000 Base address: 00007FFB09730000 Module found C:\WINDOWS\system32\MSCTF.dll (MSCTF.dll) Handle: 00007FFB0C170000 Base address: 00007FFB0C170000 Module found C:\WINDOWS\SYSTEM32\igdumdim64.dll (igdumdim64.dll) Handle: 00007FFADA270000 Base address: 00007FFADA270000 Module found C:\WINDOWS\system32\SETUPAPI.dll (SETUPAPI.dll) Handle: 00007FFB0C4B0000 Base address: 00007FFB0C4B0000 Module found C:\WINDOWS\SYSTEM32\igdusc64.dll (igdusc64.dll) Handle: 00007FFB052F0000 Base address: 00007FFB052F0000 Module found C:\WINDOWS\system32\clbcatq.dll (clbcatq.dll) Handle: 00007FFB0E500000 Base address: 00007FFB0E500000 Module found C:\WINDOWS\system32\dataexchange.dll (dataexchange.dll) Handle: 00007FFAF4400000 Base address: 00007FFAF4400000 Module found C:\WINDOWS\system32\dcomp.dll (dcomp.dll) Handle: 00007FFB08C80000 Base address: 00007FFB08C80000 Module found C:\WINDOWS\system32\d3d11.dll (d3d11.dll) Handle: 00007FFB07C60000 Base address: 00007FFB07C60000 Module found C:\WINDOWS\system32\dxgi.dll (dxgi.dll) Handle: 00007FFB07BB0000 Base address: 00007FFB07BB0000 Module found C:\WINDOWS\system32\twinapi.appcore.dll (twinapi.appcore.dll) Handle: 00007FFB09630000 Base address: 00007FFB09630000 Module found C:\WINDOWS\system32\bcrypt.dll (bcrypt.dll) Handle: 00007FFB0AB00000 Base address: 00007FFB0AB00000 Module found C:\WINDOWS\system32\mswsock.dll (mswsock.dll) Handle: 00007FFB0A4A0000 Base address: 00007FFB0A4A0000 Module found C:\WINDOWS\system32\napinsp.dll (napinsp.dll) Handle: 00007FFAF88D0000 Base address: 00007FFAF88D0000 Module found C:\WINDOWS\system32\pnrpnsp.dll (pnrpnsp.dll) Handle: 00007FFAF88F0000 Base address: 00007FFAF88F0000 Module found C:\WINDOWS\system32\NLAapi.dll (NLAapi.dll) Handle: 00007FFB08BA0000 Base address: 00007FFB08BA0000 Module found C:\WINDOWS\SYSTEM32\DNSAPI.dll (DNSAPI.dll) Handle: 00007FFB09550000 Base address: 00007FFB09550000 Module found C:\WINDOWS\system32\NSI.dll (NSI.dll) Handle: 00007FFB0BEA0000 Base address: 00007FFB0BEA0000 Module found C:\WINDOWS\System32\winrnr.dll (winrnr.dll) Handle: 00007FFAF9B30000 Base address: 00007FFAF9B30000 Module found C:\Program Files\Bonjour\mdnsNSP.dll (Bonjour\mdnsNSP.dll) Handle: 0000000065660000 Base address: 0000000065660000 Module found C:\WINDOWS\SYSTEM32\Iphlpapi.DLL (Iphlpapi.DLL) Handle: 00007FFB083F0000 Base address: 00007FFB083F0000 Module found C:\WINDOWS\System32\fwpuclnt.dll (fwpuclnt.dll) Handle: 00007FFAFFE10000 Base address: 00007FFAFFE10000 Module found C:\Windows\System32\rasadhlp.dll (rasadhlp.dll) Handle: 00007FFAFE770000 Base address: 00007FFAFE770000 Module found C:\WINDOWS\system32\propsys.dll (propsys.dll) Handle: 00007FFB08860000 Base address: 00007FFB08860000 Module found C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll (Common Files\microsoft shared\ink\tiptsf.dll) Handle: 00007FFAF7A30000 Base address: 00007FFAF7A30000 Module found C:\WINDOWS\SYSTEM32\edputil.dll (edputil.dll) Handle: 00007FFAF44C0000 Base address: 00007FFAF44C0000 Module found C:\WINDOWS\SYSTEM32\policymanager.dll (policymanager.dll) Handle: 00007FFAFD510000 Base address: 00007FFAFD510000 Module found C:\WINDOWS\SYSTEM32\msvcp110_win.dll (msvcp110_win.dll) Handle: 00007FFAFD130000 Base address: 00007FFAFD130000 Module found C:\WINDOWS\system32\explorerframe.dll (explorerframe.dll) Handle: 00007FFAF2E40000 Base address: 00007FFAF2E40000 Module found C:\WINDOWS\system32\DUI70.dll (DUI70.dll) Handle: 00007FFAE92A0000 Base address: 00007FFAE92A0000 Module found C:\WINDOWS\system32\DUser.dll (DUser.dll) Handle: 00007FFAF9320000 Base address: 00007FFAF9320000 Module found C:\WINDOWS\SYSTEM32\WindowsCodecs.dll (WindowsCodecs.dll) Handle: 00007FFB076E0000 Base address: 00007FFB076E0000 Module found C:\Windows\System32\thumbcache.dll (thumbcache.dll) Handle: 00007FFAEFDF0000 Base address: 00007FFAEFDF0000 Module found C:\Windows\System32\Windows.Globalization.dll (Windows.Globalization.dll) Handle: 00007FFB00B00000 Base address: 00007FFB00B00000 Module found C:\Windows\System32\Bcp47Langs.dll (Bcp47Langs.dll) Handle: 00007FFB02480000 Base address: 00007FFB02480000 Module found C:\WINDOWS\SYSTEM32\globinputhost.dll (globinputhost.dll) Handle: 00007FFAF7450000 Base address: 00007FFAF7450000 Module found C:\WINDOWS\system32\xmllite.dll (xmllite.dll) Handle: 00007FFB06230000 Base address: 00007FFB06230000 Module found C:\WINDOWS\system32\OLEACC.dll (OLEACC.dll) Handle: 00007FFAFE840000 Base address: 00007FFAFE840000 Module found C:\Windows\System32\uiautomationcore.dll (uiautomationcore.dll) Handle: 00007FFAE9D50000 Base address: 00007FFAE9D50000 Module found C:\Windows\System32\USERENV.dll (USERENV.dll) Handle: 00007FFB0A330000 Base address: 00007FFB0A330000 Module found C:\WINDOWS\SYSTEM32\sxs.dll (sxs.dll) Handle: 00007FFB0AA00000 Base address: 00007FFB0AA00000 Module found C:\WINDOWS\SYSTEM32\atlthunk.dll (atlthunk.dll) Handle: 00007FFB05FA0000 Base address: 00007FFB05FA0000 Module found C:\WINDOWS\System32\StructuredQuery.dll (StructuredQuery.dll) Handle: 00007FFAFC1A0000 Base address: 00007FFAFC1A0000 Module found C:\Windows\System32\ActXPrxy.dll (ActXPrxy.dll) Handle: 00007FFAFAA50000 Base address: 00007FFAFAA50000 Module found C:\WINDOWS\system32\Windows.Storage.Search.dll (Windows.Storage.Search.dll) Handle: 00007FFAFBD80000 Base address: 00007FFAFBD80000 Module found C:\WINDOWS\system32\IconCodecService.dll (IconCodecService.dll) Handle: 00007FFAFC280000 Base address: 00007FFAFC280000 Module found C:\WINDOWS\system32\coml2.dll (coml2.dll) Handle: 00007FFB0CB50000 Base address: 00007FFB0CB50000 Module found C:\WINDOWS\SYSTEM32\MPR.dll (MPR.dll) Handle: 00007FFAFC8E0000 Base address: 00007FFAFC8E0000 Module found C:\WINDOWS\System32\drprov.dll (drprov.dll) Handle: 00007FFAF9B20000 Base address: 00007FFAF9B20000 Module found C:\WINDOWS\System32\WINSTA.dll (WINSTA.dll) Handle: 00007FFB0AAA0000 Base address: 00007FFB0AAA0000 Module found C:\WINDOWS\System32\ntlanman.dll (ntlanman.dll) Handle: 00007FFAF9B00000 Base address: 00007FFAF9B00000 Module found C:\WINDOWS\System32\davclnt.dll (davclnt.dll) Handle: 00007FFAF89A0000 Base address: 00007FFAF89A0000 Module found C:\WINDOWS\SYSTEM32\LINKINFO.dll (LINKINFO.dll) Handle: 00007FFAF6EC0000 Base address: 00007FFAF6EC0000 Module found C:\WINDOWS\System32\wkscli.dll (wkscli.dll) Handle: 00007FFB024F0000 Base address: 00007FFB024F0000 Module found C:\WINDOWS\SYSTEM32\cscapi.dll (cscapi.dll) Handle: 00007FFAFCBE0000 Base address: 00007FFAFCBE0000 Module found C:\WINDOWS\System32\netutils.dll (netutils.dll) Handle: 00007FFB09FE0000 Base address: 00007FFB09FE0000 Module found C:\Windows\System32\twinapi.dll (twinapi.dll) Handle: 00007FFAF5850000 Base address: 00007FFAF5850000 Module found C:\WINDOWS\SYSTEM32\apphelp.dll (apphelp.dll) Handle: 00007FFB093C0000 Base address: 00007FFB093C0000 Module found C:\Windows\System32\dlnashext.dll (dlnashext.dll) Handle: 00007FFAFCA60000 Base address: 00007FFAFCA60000 Module found C:\Windows\System32\PlayToDevice.dll (PlayToDevice.dll) Handle: 00007FFAF7900000 Base address: 00007FFAF7900000 Module found C:\Windows\System32\DevDispItemProvider.dll (DevDispItemProvider.dll) Handle: 00007FFAFC2E0000 Base address: 00007FFAFC2E0000 Module found C:\WINDOWS\System32\MMDevApi.dll (MMDevApi.dll) Handle: 00007FFB00740000 Base address: 00007FFB00740000 Module found C:\WINDOWS\System32\DEVOBJ.dll (DEVOBJ.dll) Handle: 00007FFB09600000 Base address: 00007FFB09600000 Module found C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.10586.545_none_d3c4a617ffcfbffc\gdiplus.dll (WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.10586.545_none_d3c4a617ffcfbffc\gdiplus.dll) Handle: 00007FFB02580000 Base address: 00007FFB02580000 Module found C:\Windows\System32\PortableDeviceApi.dll (PortableDeviceApi.dll) Handle: 00007FFB08A60000 Base address: 00007FFB08A60000 Module found C:\WINDOWS\system32\WINTRUST.dll (WINTRUST.dll) Handle: 00007FFB0B5F0000 Base address: 00007FFB0B5F0000 Module found C:\WINDOWS\system32\MSASN1.dll (MSASN1.dll) Handle: 00007FFB0AC40000 Base address: 00007FFB0AC40000 Module found C:\WINDOWS\system32\CRYPT32.dll (CRYPT32.dll) Handle: 00007FFB0B650000 Base address: 00007FFB0B650000 Module found C:\Windows\System32\EhStorShell.dll (EhStorShell.dll) Handle: 00007FFAEE3B0000 Base address: 00007FFAEE3B0000 Module found C:\Windows\System32\EhStorAPI.dll (EhStorAPI.dll) Handle: 00007FFAFA790000 Base address: 00007FFAFA790000 Module found C:\Windows\System32\WTSAPI32.dll (WTSAPI32.dll) Handle: 00007FFB089F0000 Base address: 00007FFB089F0000 Module found C:\Windows\System32\MrmCoreR.dll (MrmCoreR.dll) Handle: 00007FFB02D40000 Base address: 00007FFB02D40000 Module found C:\Windows\System32\iertutil.dll (iertutil.dll) Handle: 00007FFB010B0000 Base address: 00007FFB010B0000 Module found C:\Windows\System32\Windows.UI.dll (Windows.UI.dll) Handle: 00007FFB02730000 Base address: 00007FFB02730000 Module found C:\WINDOWS\System32\provsvc.dll (provsvc.dll) Handle: 00007FFAEE870000 Base address: 00007FFAEE870000 Module found C:\Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\FileSyncShell64.dll (Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\FileSyncShell64.dll) Handle: 00007FFAEE6D0000 Base address: 00007FFAEE6D0000 Module found C:\Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\MSVCP120.dll (Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\MSVCP120.dll) Handle: 00007FFAEE620000 Base address: 00007FFAEE620000 Module found C:\Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\MSVCR120.dll (Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\MSVCR120.dll) Handle: 00007FFAEE530000 Base address: 00007FFAEE530000 Module found C:\Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\LoggingPlatform64.DLL (Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\LoggingPlatform64.DLL) Handle: 00007FFAEE4F0000 Base address: 00007FFAEE4F0000 Module found C:\WINDOWS\SYSTEM32\WSOCK32.dll (WSOCK32.dll) Handle: 00007FFAF6C00000 Base address: 00007FFAF6C00000 Module found C:\Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\ClientTelemetry.dll (Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\ClientTelemetry.dll) Handle: 00007FFAEE400000 Base address: 00007FFAEE400000 Module found C:\WINDOWS\system32\mssprxy.dll (mssprxy.dll) Handle: 00007FFAECA50000 Base address: 00007FFAECA50000 Module found C:\WINDOWS\SYSTEM32\ntshrui.dll (ntshrui.dll) Handle: 00007FFAEFEA0000 Base address: 00007FFAEFEA0000 Module found C:\WINDOWS\SYSTEM32\SspiCli.dll (SspiCli.dll) Handle: 00007FFB0A850000 Base address: 00007FFB0A850000 Module found C:\WINDOWS\SYSTEM32\srvcli.dll (srvcli.dll) Handle: 00007FFAFEA10000 Base address: 00007FFAFEA10000 Module found C:\Windows\System32\WorkfoldersShell.dll (WorkfoldersShell.dll) Handle: 00007FFAF9270000 Base address: 00007FFAF9270000 Module found C:\WINDOWS\SYSTEM32\dsreg.dll (dsreg.dll) Handle: 00007FFAFF410000 Base address: 00007FFAFF410000 Module found C:\WINDOWS\SYSTEM32\WINHTTP.dll (WINHTTP.dll) Handle: 00007FFB082B0000 Base address: 00007FFB082B0000 Module found C:\WINDOWS\SYSTEM32\cryptsp.dll (cryptsp.dll) Handle: 00007FFB0A550000 Base address: 00007FFB0A550000 Module found C:\WINDOWS\SYSTEM32\DPAPI.DLL (DPAPI.DLL) Handle: 00007FFB0A220000 Base address: 00007FFB0A220000 Module found C:\WINDOWS\System32\shacct.dll (shacct.dll) Handle: 00007FFB08B10000 Base address: 00007FFB08B10000 Module found C:\WINDOWS\System32\IDStore.dll (IDStore.dll) Handle: 00007FFAF8760000 Base address: 00007FFAF8760000 Module found C:\WINDOWS\System32\SAMLIB.dll (SAMLIB.dll) Handle: 00007FFB08A30000 Base address: 00007FFB08A30000 Module found C:\WINDOWS\System32\wlidprov.dll (wlidprov.dll) Handle: 00007FFAF3480000 Base address: 00007FFAF3480000 Module found C:\WINDOWS\SYSTEM32\samcli.dll (samcli.dll) Handle: 00007FFB05D00000 Base address: 00007FFB05D00000 Module found C:\WINDOWS\system32\igfxOSP.dll (igfxOSP.dll) Handle: 00007FFAEC940000 Base address: 00007FFAEC940000 Module found C:\WINDOWS\system32\igfxDTCM.dll (igfxDTCM.dll) Handle: 00007FFAF78B0000 Base address: 00007FFAF78B0000 Module found C:\WINDOWS\system32\igfxDH.dll (igfxDH.dll) Handle: 00007FFAEF920000 Base address: 00007FFAEF920000 Module found C:\WINDOWS\system32\igfxLHM.dll (igfxLHM.dll) Handle: 00007FFAEF720000 Base address: 00007FFAEF720000 Module found C:\WINDOWS\system32\igfxDI.dll (igfxDI.dll) Handle: 00007FFAEF6C0000 Base address: 00007FFAEF6C0000 Module found C:\WINDOWS\system32\OPENGL32.dll (OPENGL32.dll) Handle: 00007FFAEF590000 Base address: 00007FFAEF590000 Module found C:\WINDOWS\system32\d3d10_1.dll (d3d10_1.dll) Handle: 00007FFAF8040000 Base address: 00007FFAF8040000 Module found C:\WINDOWS\system32\GLU32.dll (GLU32.dll) Handle: 00007FFAEF560000 Base address: 00007FFAEF560000 Module found C:\WINDOWS\system32\DDRAW.dll (DDRAW.dll) Handle: 00007FFAF8640000 Base address: 00007FFAF8640000 Module found C:\WINDOWS\system32\DCIMAN32.dll (DCIMAN32.dll) Handle: 00007FFAF8630000 Base address: 00007FFAF8630000 Module found C:\WINDOWS\system32\d3d10_1core.dll (d3d10_1core.dll) Handle: 00007FFAF7FD0000 Base address: 00007FFAF7FD0000 Module found C:\WINDOWS\system32\PhotoMetadataHandler.dll (PhotoMetadataHandler.dll) Handle: 00007FFAF7820000 Base address: 00007FFAF7820000 Module found C:\WINDOWS\system32\WINMM.dll (WINMM.dll) Handle: 00007FFB08C20000 Base address: 00007FFB08C20000 Module found C:\WINDOWS\system32\WINMMBASE.dll (WINMMBASE.dll) Handle: 00007FFB08BF0000 Base address: 00007FFB08BF0000 Module found C:\WINDOWS\system32\NetworkExplorer.dll (NetworkExplorer.dll) Handle: 00007FFAF89C0000 Base address: 00007FFAF89C0000 Module found C:\Program Files\3D-Coat-V4.7.06\tbbmalloc.dll (\tbbmalloc.dll) Handle: 0000020923000000 Base address: 0000020923000000 Log.txt: Loaded image file "Splash\Background2.jpg" Loaded image file "Splash\0.bmp" Loaded image file "Splash\1.bmp" Loaded image file "Splash\2.bmp" Loaded image file "Splash\3.bmp" Loaded image file "Splash\4.bmp" Loaded image file "Splash\5.bmp" Loaded image file "Splash\6.bmp" Loaded image file "Splash\7.bmp" Loaded image file "Splash\8.bmp" Loaded image file "Splash\9.bmp" Loaded image file "Splash\Dot.bmp" Loaded image file "Splash\Version.bmp" Loading Xml file "Xmls/Settings.xml"... Can't load file "Xmls/Settings.xml" ------------------------------------------------------------ Graphics card and driver info ------------------------------------------------------------ Direct3D Renderer Adapter: Intel(R) HD Graphics Family Driver: igdumdim64.dll Supported: Vertex shaders 3.0 Pixel shaders 3.0 MRT (targets: 4) Non power of two ------------------------------------------------------------ Registering vertex formats... Loaded image file "factures\grass_color1.png" Loaded image file "factures\grass_gloss.jpg" Loaded image file "factures\grass_nmap2.png" Loaded image file "Shaders\PbrShaders\Bone\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Clay\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Clay2\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Copper\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Default\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\FrogSkin\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Gold\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Gold2\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\GreenClay\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\MatCap_Clay\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\MatCap_RedWax\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\OldCopper\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\OldSilver\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\RedWax\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\RustedMetall\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Scratched\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Skin\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Steel\mcubes_64.tga" cMeshIO::AddCodec(): Added "Obj" mesh codec. cMeshIO::AddCodec(): Added "Lwo" mesh codec. cMeshIO::AddCodec(): Added "Fbx" mesh codec. cMeshIO::AddCodec(): Added "Stl" mesh codec. cMeshIO::AddCodec(): Added "Ply" mesh codec. cMeshIO::AddCodec(): Added "dae" mesh codec. cMeshIO::AddCodec(): Added "wrl" mesh codec. cMeshIO::LoadMesh(): Loaded mesh file "C:\Program Files\3D-Coat-V4.7.06\ToolsPresets\\Sphere.obj". * Loading shader "Shaders/mpreview1.hlsl"... Compiling VS... Compiling PS... cMeshIO::LoadMesh(): Loaded mesh file "C:\Program Files\3D-Coat-V4.7.06\ToolsPresets\\Ring.obj". cMeshIO::LoadMesh(): Loaded mesh file "C:\Program Files\3D-Coat-V4.7.06\ToolsPresets\\Cube.obj". cMeshIO::LoadMesh(): Loaded mesh file "C:\Program Files\3D-Coat-V4.7.06\ToolsPresets\\Sector.obj". cMeshIO::LoadMesh(): Loaded mesh file "C:\Program Files\3D-Coat-V4.7.06\ToolsPresets\\Cone.obj". cMeshIO::LoadMesh(): Loaded mesh file "C:\Program Files\3D-Coat-V4.7.06\ToolsPresets\\Cylinder.obj". cMeshIO::LoadMesh(): Can't open file "C:\Program Files\3D-Coat-V4.7.06\ToolsPresets\icosa240.obj". Added "TIF" image codec. Added "TIFF" image codec. Added "EXR" image codec. Added "HDR" image codec. - Loading font "Calibri 11"... Can't load file "Fonts/Calibri 11.cFont" - Loading font "Calibri 16"... Can't load file "Fonts/Calibri 16.cFont" - Loading font "Calibri B24"... Can't load file "Fonts/Calibri B24.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma B8"... Can't load file "Fonts/Tahoma B8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" Can't load image file "Textures\WindowsStandard\ToolBar.bmp" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" Version : 3D-COAT 4.7.06(DX64) * Loading shader "Shaders/hud2t.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/hud_smooth.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/hud.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/LinesPointsUI.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/Colored.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/RenderSystem.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/RenderSystem.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/text2.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ENV Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ENV #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_COLOR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_RELIEF Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_RELIEF #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPECULAR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPECULAR #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_render_color.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/obj_render_normals.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/obj_render_mrt.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview_nrm.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview_alpha.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview_all.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/obj_preview_pen2.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/inrect.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/obj_preview_pen2.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/preview_rect.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/draw_pic_over_curve.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/draw_pic_over_curve.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/preview_fill.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/uv.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/wires.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/wires.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/sphere.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/obj_preview_pen.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/CurrentMcubes/mcubes.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/mpreview.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/Font.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/mcubes_rt.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/mcubes_nrm.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... ------------------------------------------------------------ WinTab Device Name: Max Pressure: 0 ------------------------------------------------------------ AppLink search path registered: C:\Users\FamilyPC\Documents/AppLinks/3D-Coat/Exchange/ AppLink search path registered: C:\Users\FamilyPC\Documents/3D-CoatV4/Exchange/ AppLink search path registered: C:\Users\FamilyPC\Documents/3D-CoatV3/Exchange/ AppLink search path registered: C:\Users\FamilyPC\Documents/3D-CoatV47/Exchange/ AppLink search path registered: C:\Users\FamilyPC\Documents/3D-CoatV3/Exchange/ Loaded image file "textures\Fasterns\threadsicons.png" Loaded image file "textures\Fasterns\sliticons.png" Loaded image file "textures\Fasterns\headicons.png" Loaded image file "textures\Fasterns\underheadicons.png" Loaded image file "textures\Fasterns\tapheadicons.png" Loaded image file "textures\Fasterns\tapsliticons.png" Loaded image file "textures\Fasterns\tapscrewicons.png" Loaded image file "textures\Fasterns\nuticons.png" Loaded image file "textures\Fasterns\washericons.png" Loaded image file "textures\pens\rock.tga" Loaded image file "textures\icons64\Grow_Vox_02.png" Can't load image file "textures\tooltips\Grow_Vox_02.png" Loaded image file "textures\icons64\smooth_Vox.png" Can't load image file "textures\tooltips\smooth_Vox.png" Loaded image file "textures\icons64\Fill.png" Can't load image file "textures\tooltips\Fill.png" Loaded image file "textures\icons64\Clay_Vox.png" Can't load image file "textures\tooltips\Clay_Vox.png" Loaded image file "textures\icons64\Carve.png" Can't load image file "textures\tooltips\Carve.png" Loaded image file "textures\icons64\Blob_Vox.png" Can't load image file "textures\tooltips\Blob_Vox.png" Loaded image file "textures\icons64\Cutoff_Vox.png" Can't load image file "textures\tooltips\Cutoff_Vox.png" Loaded image file "textures\icons64\Airbrush_Vox.png" Can't load image file "textures\tooltips\Airbrush_Vox.png" Loaded image file "textures\icons64\Build_Vox_02.png" Can't load image file "textures\tooltips\Build_Vox_02.png" Loaded image file "textures\icons64\Extrude_Vox.png" Can't load image file "textures\tooltips\Extrude_Vox.png" Loaded image file "textures\icons64\Sphere_Vox.png" Can't load image file "textures\tooltips\Sphere_Vox.png" Loaded image file "textures\icons64\2D_Piant_Vox.png" Can't load image file "textures\tooltips\2D_Piant_Vox.png" Loaded image file "textures\icons64\Plane_Vox.png" Can't load image file "textures\tooltips\Plane_Vox.png" Loaded image file "textures\icons64\Scrape_Vox.png" Can't load image file "textures\tooltips\Scrape_Vox.png" Loaded image file "textures\icons64\Pinch_Vox.png" Can't load image file "textures\tooltips\Pinch_Vox.png" Loaded image file "textures\icons64\Smudge_Vox.png" Can't load image file "textures\tooltips\Smudge_Vox.png" Loaded image file "textures\icons64\Measure.png" Can't load image file "textures\tooltips\Measure.png" Loaded image file "textures\icons64\Pick.png" Can't load image file "textures\tooltips\Pick.png" Loaded image file "textures\icons64\Pose.png" Can't load image file "textures\tooltips\Pose.png" Loaded image file "textures\icons64\Move.png" Can't load image file "textures\tooltips\Move.png" Loaded image file "textures\icons64\Hide.png" Can't load image file "textures\tooltips\Hide.png" Loaded image file "textures\icons64\Cell.png" Can't load image file "textures\tooltips\Cell.png" Loaded image file "textures\icons64\Copy.png" Can't load image file "textures\tooltips\Copy.png" Loaded image file "textures\icons64\Transform.png" Can't load image file "textures\tooltips\Transform.png" Loaded image file "textures\icons64\Instancer.png" Can't load image file "textures\tooltips\Instancer.png" Loaded image file "textures\icons64\Warp.png" Can't load image file "textures\tooltips\Warp.png" Loaded image file "textures\icons64\Axial.png" Can't load image file "textures\tooltips\Axial.png" Loaded image file "textures\icons64\Bass-Releif.png" Can't load image file "textures\tooltips\Bass-Releif.png" Loaded image file "textures\icons64\Vox_Layer.png" Can't load image file "textures\tooltips\Vox_Layer.png" Loaded image file "textures\icons64\LOGO.png" Can't load image file "textures\tooltips\LOGO.png" Loaded image file "textures\icons64\Clone_Copy.png" Can't load image file "textures\tooltips\Clone_Copy.png" Loaded image file "textures\icons64\Clone_VOX.png" Can't load image file "textures\tooltips\Clone_VOX.png" Loaded image file "textures\icons64\Split_Vox.png" Can't load image file "textures\tooltips\Split_Vox.png" Loaded image file "textures\icons64\Merge.png" Can't load image file "textures\tooltips\Merge.png" Loaded image file "textures\icons64\Sketch_Tool.png" Can't load image file "textures\tooltips\Sketch_Tool.png" Loaded image file "textures\icons64\curves.png" Can't load image file "textures\tooltips\curves.png" Loaded image file "textures\icons64\Snake.png" Can't load image file "textures\tooltips\Snake.png" Loaded image file "textures\icons64\Spkie.png" Can't load image file "textures\tooltips\Spkie.png" Loaded image file "textures\icons64\toothPaste.png" Can't load image file "textures\tooltips\toothPaste.png" Loaded image file "textures\icons64\Muscle.png" Can't load image file "textures\tooltips\Muscle.png" Loaded image file "textures\icons64\Primatives.png" Can't load image file "textures\tooltips\Primatives.png" Loaded image file "textures\icons64\Text.png" Can't load image file "textures\tooltips\Text.png" Loaded image file "textures\icons64\Cloth.png" Can't load image file "textures\tooltips\Cloth.png" Loaded image file "textures\icons64\Draw_Surf.png" Can't load image file "textures\tooltips\Draw_Surf.png" Loaded image file "textures\icons64\Pinch_Surf.png" Can't load image file "textures\tooltips\Pinch_Surf.png" Loaded image file "textures\icons64\Shift_Surf.png" Can't load image file "textures\tooltips\Shift_Surf.png" Loaded image file "textures\icons64\Flatten_Surf.png" Can't load image file "textures\tooltips\Flatten_Surf.png" Loaded image file "textures\icons64\Clay_Surf.png" Can't load image file "textures\tooltips\Clay_Surf.png" Loaded image file "textures\icons64\Rapid_Surf.png" Can't load image file "textures\tooltips\Rapid_Surf.png" Loaded image file "textures\icons64\Increase_Res.png" Can't load image file "textures\tooltips\Increase_Res.png" Loaded image file "textures\icons64\Resample.png" Can't load image file "textures\tooltips\Resample.png" Loaded image file "textures\icons64\Clear.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Smooth_All.png" Can't load image file "textures\tooltips\Smooth_All.png" Loaded image file "textures\icons64\Chisel_Surf.png" Can't load image file "textures\tooltips\Chisel_Surf.png" Can't load image file "textures\tooltips\Build_Vox_02.png" Can't load image file "textures\tooltips\Fill.png" Loaded image file "textures\icons64\Inflate_Clay_LC.png" Can't load image file "textures\tooltips\Inflate_Clay_LC.png" Loaded image file "textures\icons64\Extrude_Surf.png" Can't load image file "textures\tooltips\Extrude_Surf.png" Loaded image file "textures\icons64\Gum.png" Can't load image file "textures\tooltips\Gum.png" Loaded image file "textures\icons64\Absolute.png" Can't load image file "textures\tooltips\Absolute.png" Loaded image file "textures\icons64\Freeze_Surf.png" Can't load image file "textures\tooltips\Freeze_Surf.png" Loaded image file "textures\icons64\Hide_Surf.png" Can't load image file "textures\tooltips\Hide_Surf.png" Loaded image file "textures\icons64\Rapid1_Surf.png" Can't load image file "textures\tooltips\Rapid1_Surf.png" Loaded image file "textures\icons64\Rapid2_Surf.png" Can't load image file "textures\tooltips\Rapid2_Surf.png" Loaded image file "textures\icons64\Scratches1_Surf.png" Can't load image file "textures\tooltips\Scratches1_Surf.png" Loaded image file "textures\icons64\Scratches2_Surf.png" Can't load image file "textures\tooltips\Scratches2_Surf.png" Loaded image file "textures\icons64\Mud1_surf.png" Can't load image file "textures\tooltips\Mud1_surf.png" Loaded image file "textures\icons64\Mud2_surf.png" Can't load image file "textures\tooltips\Mud2_surf.png" Loaded image file "textures\icons64\Decimate.png" Can't load image file "textures\tooltips\Decimate.png" Loaded image file "textures\icons64\TSmooth_LC.png" Can't load image file "textures\tooltips\TSmooth_LC.png" Can't load image file "textures\tooltips\Draw_Surf.png" Can't load image file "textures\tooltips\Build_Vox_02.png" Loaded image file "textures\icons64\CreaseClay_LC.png" Can't load image file "textures\tooltips\CreaseClay_LC.png" Loaded image file "textures\icons64\Reduce_Clay_LC.png" Can't load image file "textures\tooltips\Reduce_Clay_LC.png" Loaded image file "textures\icons64\Extrude_Clay_LC.png" Can't load image file "textures\tooltips\Extrude_Clay_LC.png" Loaded image file "textures\icons64\Snake_Clay_LC.png" Can't load image file "textures\tooltips\Snake_Clay_LC.png" Loaded image file "textures\icons64\Tube_Clay_LC.png" Can't load image file "textures\tooltips\Tube_Clay_LC.png" Loaded image file "textures\icons64\Smudge_Clay_LC.png" Can't load image file "textures\tooltips\Smudge_Clay_LC.png" Can't load image file "textures\tooltips\Inflate_Clay_LC.png" Loaded image file "textures\icons64\Swirl_Clay_LC.png" Can't load image file "textures\tooltips\Swirl_Clay_LC.png" Loaded image file "textures\icons64\Ripple_LC.png" Can't load image file "textures\tooltips\Ripple_LC.png" Can't load image file "textures\tooltips\Flatten_Surf.png" Loaded image file "textures\icons64\Wrincle_Clay_LC.png" Can't load image file "textures\tooltips\Wrincle_Clay_LC.png" Loaded image file "textures\icons64\Remove_Clay_LC.png" Can't load image file "textures\tooltips\Remove_Clay_LC.png" Loaded image file "textures\icons64\General_LC.png" Can't load image file "textures\tooltips\General_LC.png" Loaded image file "textures\icons64\Add_Clusters.png" Can't load image file "textures\tooltips\Add_Clusters.png" Loaded image file "textures\icons64\Mark_Seams.png" Can't load image file "textures\tooltips\Mark_Seams.png" Loaded image file "textures\icons64\Mark_Seams_Edge_Loop.png" Can't load image file "textures\tooltips\Mark_Seams_Edge_Loop.png" Loaded image file "textures\icons64\Select_Path.png" Can't load image file "textures\tooltips\Select_Path.png" Loaded image file "textures\icons64\Clear_Clusters.png" Can't load image file "textures\tooltips\Clear_Clusters.png" Loaded image file "textures\icons64\Clear_Seams.png" Can't load image file "textures\tooltips\Clear_Seams.png" Loaded image file "textures\icons64\Auto_Seams.png" Can't load image file "textures\tooltips\Auto_Seams.png" Loaded image file "textures\icons64\Sharp_Seams.png" Can't load image file "textures\tooltips\Sharp_Seams.png" Can't load image file "textures\tooltips\Sharp_Seams.png" Loaded image file "textures\icons64\Unwrap.png" Can't load image file "textures\tooltips\Unwrap.png" Loaded image file "textures\icons64\Pack1.png" Can't load image file "textures\tooltips\Pack1.png" Loaded image file "textures\icons64\Pack2.png" Can't load image file "textures\tooltips\Pack2.png" Loaded image file "textures\icons64\Auto_Scale.png" Can't load image file "textures\tooltips\Auto_Scale.png" Loaded image file "textures\icons64\Update_Islands.png" Can't load image file "textures\tooltips\Update_Islands.png" Loaded image file "textures\icons64\Restore_UV.png" Can't load image file "textures\tooltips\Restore_UV.png" Loaded image file "textures\icons64\Apply_UV.png" Can't load image file "textures\tooltips\Apply_UV.png" Loaded image file "textures\icons64\Export.png" Can't load image file "textures\tooltips\Export.png" Loaded image file "textures\icons64\Import.png" Can't load image file "textures\tooltips\Import.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Invert.png" Can't load image file "textures\tooltips\Invert.png" Loaded image file "textures\icons64\Rotate_Clock.png" Can't load image file "textures\tooltips\Rotate_Clock.png" Loaded image file "textures\icons64\Rotate_AnitClock.png" Can't load image file "textures\tooltips\Rotate_AnitClock.png" Loaded image file "textures\icons64\Flip_U.png" Can't load image file "textures\tooltips\Flip_U.png" Loaded image file "textures\icons64\Flip_V.png" Can't load image file "textures\tooltips\Flip_V.png" Loaded image file "textures\icons64\Relax_UV.png" Can't load image file "textures\tooltips\Relax_UV.png" Can't load image file "textures\tooltips\Relax_UV.png" Loaded image file "textures\icons64\ABF.png" Can't load image file "textures\tooltips\ABF.png" Loaded image file "textures\icons64\LSCM.png" Can't load image file "textures\tooltips\LSCM.png" Loaded image file "textures\icons64\Planar.png" Can't load image file "textures\tooltips\Planar.png" Loaded image file "textures\icons64\Hide_UV.png" Can't load image file "textures\tooltips\Hide_UV.png" Loaded image file "textures\icons64\Invert_Hidden.png" Can't load image file "textures\tooltips\Invert_Hidden.png" Loaded image file "textures\icons64\UnHide.png" Can't load image file "textures\tooltips\UnHide.png" Loaded image file "textures\icons64\Unhide_All.png" Can't load image file "textures\tooltips\Unhide_All.png" Loaded image file "textures\icons64\Copy_UV.png" Can't load image file "textures\tooltips\Copy_UV.png" Loaded image file "textures\icons64\Paste.png" Can't load image file "textures\tooltips\Paste.png" Loaded image file "textures\icons64\Add_Split.png" Can't load image file "textures\tooltips\Add_Split.png" Loaded image file "textures\icons64\Select.png" Can't load image file "textures\tooltips\Select.png" Can't load image file "textures\tooltips\Mark_Seams.png" Loaded image file "textures\icons64\Quad.png" Can't load image file "textures\tooltips\Quad.png" Loaded image file "textures\icons64\Pointand_Faces.png" Can't load image file "textures\tooltips\Pointand_Faces.png" Loaded image file "textures\icons64\Cap.png" Can't load image file "textures\tooltips\Cap.png" Loaded image file "textures\icons64\Strokes.png" Can't load image file "textures\tooltips\Strokes.png" Loaded image file "textures\icons64\Brush.png" Can't load image file "textures\tooltips\Brush.png" Loaded image file "textures\icons64\Delete_Polygons.png" Can't load image file "textures\tooltips\Delete_Polygons.png" Loaded image file "textures\icons64\Delete_Edges.png" Can't load image file "textures\tooltips\Delete_Edges.png" Loaded image file "textures\icons64\Collapse_Edge.png" Can't load image file "textures\tooltips\Collapse_Edge.png" Loaded image file "textures\icons64\Split_Ring.png" Can't load image file "textures\tooltips\Split_Ring.png" Loaded image file "textures\icons64\Select_Verts.png" Can't load image file "textures\tooltips\Select_Verts.png" Loaded image file "textures\icons64\Slide_Edge.png" Can't load image file "textures\tooltips\Slide_Edge.png" Can't load image file "textures\tooltips\Mark_Seams.png" Can't load image file "textures\tooltips\Mark_Seams_Edge_Loop.png" Loaded image file "textures\icons64\Retopo_Transform.png" Can't load image file "textures\tooltips\Retopo_Transform.png" Can't load image file "textures\tooltips\Import.png" Can't load image file "textures\tooltips\Export.png" Loaded image file "textures\icons64\Snap.png" Can't load image file "textures\tooltips\Snap.png" Loaded image file "textures\icons64\Subdivide.png" Can't load image file "textures\tooltips\Subdivide.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Relax.png" Can't load image file "textures\tooltips\Relax.png" Loaded image file "textures\icons64\Symmetry.png" Can't load image file "textures\tooltips\Symmetry.png" Loaded image file "textures\icons64\Sculpt_Move.png" Can't load image file "textures\tooltips\Sculpt_Move.png" Loaded image file "textures\icons64\Sculpt_Select_Move.png" Can't load image file "textures\tooltips\Sculpt_Select_Move.png" Loaded image file "textures\icons64\Sculpt_Drag_Points.png" Can't load image file "textures\tooltips\Sculpt_Drag_Points.png" Loaded image file "textures\icons64\Sculpt_Collapse.png" Can't load image file "textures\tooltips\Sculpt_Collapse.png" Loaded image file "textures\icons64\Sculpt_Expand.png" Can't load image file "textures\tooltips\Sculpt_Expand.png" Loaded image file "textures\icons64\Sculpt_Smudge.png" Can't load image file "textures\tooltips\Sculpt_Smudge.png" Loaded image file "textures\icons64\Sculpt_Smooth.png" Can't load image file "textures\tooltips\Sculpt_Smooth.png" Can't load image file "textures\tooltips\Sculpt_Move.png" Can't load image file "textures\tooltips\Sculpt_Select_Move.png" Can't load image file "textures\tooltips\Sculpt_Drag_Points.png" Loaded image file "textures\icons64\Sculpt_Draw.png" Can't load image file "textures\tooltips\Sculpt_Draw.png" Can't load image file "textures\tooltips\Sculpt_Collapse.png" Can't load image file "textures\tooltips\Sculpt_Expand.png" Can't load image file "textures\tooltips\Sculpt_Smudge.png" Can't load image file "textures\tooltips\Sculpt_Smudge.png" Loaded image file "textures\icons64\Sculpt_Flatten.png" Can't load image file "textures\tooltips\Sculpt_Flatten.png" Can't load image file "textures\tooltips\Sculpt_Smooth.png" Loaded image file "textures\icons64\Spin.png" Can't load image file "textures\tooltips\Spin.png" Loaded image file "textures\icons64\Spin_back.png" Can't load image file "textures\tooltips\Spin_back.png" Loaded image file "textures\icons64\Extrude.png" Can't load image file "textures\tooltips\Extrude.png" Loaded image file "textures\icons64\Split.png" Can't load image file "textures\tooltips\Split.png" Can't load image file "textures\tooltips\Collapse_Edge.png" Can't load image file "textures\tooltips\Clear.png" Can't load image file "textures\tooltips\Mark_Seams_Edge_Loop.png" Loaded image file "textures\icons64\Edge_Ring.png" Can't load image file "textures\tooltips\Edge_Ring.png" Can't load image file "textures\tooltips\Sharp_Seams.png" Loaded image file "textures\icons64\Bevel.png" Can't load image file "textures\tooltips\Bevel.png" Can't load image file "textures\tooltips\Apply_UV.png" Can't load image file "textures\tooltips\Clear_Seams.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Clone.png" Can't load image file "textures\tooltips\Clone.png" Loaded image file "textures\icons64\sfCutnClone.png" Can't load image file "textures\tooltips\sfCutnClone.png" Can't load image file "textures\tooltips\Subdivide.png" Can't load image file "textures\tooltips\Hide_UV.png" Can't load image file "textures\tooltips\Invert_Hidden.png" Can't load image file "textures\tooltips\Unhide.png" Loaded image file "textures\icons64\ExtrudeNormal.png" Can't load image file "textures\tooltips\ExtrudeNormal.png" Loaded image file "textures\icons64\ExtrudeFree.png" Can't load image file "textures\tooltips\ExtrudeFree.png" Loaded image file "textures\icons64\Undercuts.png" Can't load image file "textures\tooltips\Undercuts.png" Loaded image file "textures\icons64\PaintHoleTool.png" Can't load image file "textures\tooltips\PaintHoleTool.png" Loaded image file "textures\icons64\CloseHole.png" Can't load image file "textures\tooltips\CloseHole.png" Loaded image file "textures\icons64\Fit.png" Can't load image file "textures\tooltips\Fit.png" Can't load image file "textures\tooltips\Decimate.png" Loaded image file "textures\icons64\PinHoles2.png" Can't load image file "textures\tooltips\PinHoles2.png" Loaded image file "textures\icons64\Reconstruct.png" Can't load image file "textures\tooltips\Reconstruct.png" Loaded image file "textures\icons64\Bridge.png" Can't load image file "textures\tooltips\Bridge.png" Loaded image file "textures\icons64\VoxExtrude.png" Can't load image file "textures\tooltips\VoxExtrude.png" Loaded image file "textures\icons64\VoxIndent.png" Can't load image file "textures\tooltips\VoxIndent.png" Loaded image file "textures\icons64\ToLine.png" Can't load image file "textures\tooltips\ToLine.png" Loaded image file "textures\icons64\Equidistant.png" Can't load image file "textures\tooltips\Equidistant.png" Loaded image file "textures\icons64\Horizontal.png" Can't load image file "textures\tooltips\Horizontal.png" Loaded image file "textures\icons64\Vertical.png" Can't load image file "textures\tooltips\Vertical.png" Loaded image file "textures\icons64\Edgeloop.png" Can't load image file "textures\tooltips\Edgeloop.png" Loaded image file "textures\icons64\Edgering.png" Can't load image file "textures\tooltips\Edgering.png" Loaded image file "textures\icons64\ShuffleUV.png" Can't load image file "textures\tooltips\ShuffleUV.png" Loaded image file "textures\icons64\settings.png" Can't load image file "textures\tooltips\settings.png" Loaded image file "textures\icons64\SplitNJoints.png" Can't load image file "textures\tooltips\SplitNJoints.png" Loaded image file "textures\icons64\Lute.png" Can't load image file "textures\tooltips\Lute.png" Loaded image file "textures\icons64\SuperPinch.png" Can't load image file "textures\tooltips\SuperPinch.png" Loaded image file "textures\icons64\SubdivideVoxSurf.png" Can't load image file "textures\tooltips\SubdivideVoxSurf.png" Loaded image file "textures\icons64\InfSmooth.png" Can't load image file "textures\tooltips\InfSmooth.png" Loaded image file "textures\icons64\CopyClay64.png" Can't load image file "textures\tooltips\CopyClay64.png" Can't load image file "textures\tooltips\Relax_UV.png" Loaded image file "textures\icons64\GU.png" Can't load image file "textures\tooltips\GU.png" Loaded image file "textures\icons64\Noise.png" Can't load image file "textures\tooltips\Noise.png" Loaded image file "textures\icons64\ScaleCL.png" Can't load image file "textures\tooltips\ScaleCL.png" Loaded image file "textures\icons64\StoreSel.png" Can't load image file "textures\tooltips\StoreSel.png" Loaded image file "textures\icons64\RecallSel.png" Can't load image file "textures\tooltips\RecallSel.png" Loaded image file "textures\icons64\ClearSel.png" Can't load image file "textures\tooltips\ClearSel.png" Loaded image file "textures\icons64\PixelArt.png" Can't load image file "textures\tooltips\PixelArt.png" Loaded image file "textures\icons64\QuickPose.png" Can't load image file "textures\tooltips\QuickPose.png" Loaded image file "textures\icons64\FillHoles.png" Can't load image file "textures\tooltips\FillHoles.png" Loaded image file "textures\icons64\VoXRay.png" Can't load image file "textures\tooltips\VoXRay.png" Loaded image file "textures\icons64\Supports.png" Can't load image file "textures\tooltips\Supports.png" Loaded image file "textures\icons64\hdExpand.png" Can't load image file "textures\tooltips\hdExpand.png" Loaded image file "textures\icons64\hdContract.png" Can't load image file "textures\tooltips\hdContract.png" Loaded image file "textures\icons64\MeshDoctor.png" Can't load image file "textures\tooltips\MeshDoctor.png" Loaded image file "textures\icons64\AutoMap.png" Can't load image file "textures\tooltips\AutoMap.png" Can't load image file "textures\tooltips\Measure.png" Loaded image file "textures\icons64\rtFlipFaces.png" Can't load image file "textures\tooltips\rtFlipFaces.png" Loaded image file "textures\icons64\rtClearPoints.png" Can't load image file "textures\tooltips\rtClearPoints.png" Loaded image file "textures\icons64\SmoothLines.png" Can't load image file "textures\tooltips\SmoothLines.png" Loaded image file "textures\icons64\DelStroke.png" Can't load image file "textures\tooltips\DelStroke.png" Loaded image file "textures\icons64\ClearLines.png" Can't load image file "textures\tooltips\ClearLines.png" Loaded image file "textures\icons64\Lazer.png" Can't load image file "textures\tooltips\Lazer.png" Loaded image file "textures\icons64\ExtrudeVerts.png" Can't load image file "textures\tooltips\ExtrudeVerts.png" Loaded image file "textures\icons64\ExtrudeFaces.png" Can't load image file "textures\tooltips\ExtrudeFaces.png" Loaded image file "textures\icons64\Intrude.png" Can't load image file "textures\tooltips\Intrude.png" Loaded image file "textures\icons64\RtpShell.png" Can't load image file "textures\tooltips\RtpShell.png" Loaded image file "textures\icons64\SelExpand.png" Can't load image file "textures\tooltips\SelExpand.png" Loaded image file "textures\icons64\SelContract.png" Can't load image file "textures\tooltips\SelContract.png" Loaded image file "textures\icons64\CutEdges.png" Can't load image file "textures\tooltips\CutEdges.png" Loaded image file "textures\icons64\ConnectVerts.png" Can't load image file "textures\tooltips\ConnectVerts.png" Can't load image file "textures\masks\Arrow_01_prv.tga" Loaded image file "Temp\Arrow_0135782.tga" Can't load image file "textures\masks\fr_prv.tga" Loaded image file "Temp\fr23483.tga" Can't load image file "textures\masks\Grid_prv.tga" Loaded image file "Temp\Grid27501.tga" Can't load image file "textures\masks\honeycomb_prv.tga" Loaded image file "Temp\honeycomb41697.tga" Can't load image file "textures\masks\Misk_01_prv.tga" Loaded image file "Temp\Misk_0132829.tga" Can't load image file "textures\masks\Misk_02_prv.tga" Loaded image file "Temp\Misk_0232851.tga" Can't load image file "textures\masks\Misk_03_prv.tga" Loaded image file "Temp\Misk_0332873.tga" Can't load image file "textures\masks\Noise_01_prv.tga" Loaded image file "Temp\Noise_0135493.tga" Can't load image file "textures\masks\Noise_02_prv.tga" Loaded image file "Temp\Noise_0235516.tga" Can't load image file "textures\masks\Noise_03_prv.tga" Loaded image file "Temp\Noise_0335539.tga" Can't load image file "textures\masks\Noise_04_prv.tga" Loaded image file "Temp\Noise_0435562.tga" Can't load image file "textures\masks\Noise_05_prv.tga" Loaded image file "Temp\Noise_0535585.tga" Can't load image file "textures\masks\Rhombs_prv.tga" Loaded image file "Temp\Rhombs32885.tga" Can't load image file "textures\masks\Triangle_prv.tga" Loaded image file "Temp\Triangle38162.tga" Can't load image file "textures\masks\Cracks_prv.tga" Loaded image file "Temp\Cracks32689.tga" Can't load image file "textures\masks\OT_DiagGrid_straight01_prv.tga" Loaded image file "Temp\OT_DiagGrid_straight0182532.tga" Can't load image file "textures\masks\OT_DiagGrid_straight02_prv.tga" Loaded image file "Temp\OT_DiagGrid_straight0282569.tga" Can't load image file "textures\masks\OT_DiagGrid_straight03_prv.tga" Loaded image file "Temp\OT_DiagGrid_straight0382606.tga" Can't load image file "textures\masks\OT_mask_dented01_prv.tga" Loaded image file "Temp\OT_mask_dented0160138.tga" Can't load image file "textures\masks\OT_mask_dirt02_prv.tga" Loaded image file "Temp\OT_mask_dirt0253715.tga" Can't load image file "textures\masks\OT_mask_dirt03_prv.tga" Loaded image file "Temp\OT_mask_dirt0353744.tga" Can't load image file "textures\masks\OT_mask_dirt04_prv.tga" Loaded image file "Temp\OT_mask_dirt0453773.tga" Can't load image file "textures\masks\OT_textureFX_dirt13_prv.tga" Loaded image file "Temp\OT_textureFX_dirt1371421.tga" Can't load image file "textures\masks\OT_textureFX_dirt14_prv.tga" Loaded image file "Temp\OT_textureFX_dirt1471455.tga" Can't load image file "textures\masks\OT_textureFX_dirt15_prv.tga" Loaded image file "Temp\OT_textureFX_dirt1571489.tga" Can't load image file "textures\masks\OT_textureFX_fingerprints03_prv.tga" Loaded image file "Temp\OT_textureFX_fingerprints03107056.tga" Can't load image file "textures\masks\OT_textureFX_grimy01_prv.tga" Loaded image file "Temp\OT_textureFX_grimy0175631.tga" Can't load image file "textures\masks\OT_textureFX_scratches05_prv.tga" Loaded image file "Temp\OT_textureFX_scratches0592168.tga" Can't load image file "textures\masks\OT_vents05_prv.tga" Loaded image file "Temp\OT_vents0541613.tga" Can't load image file "textures\masks\SkinCracks_prv.tga" Loaded image file "Temp\SkinCracks43680.tga" Can't load image file "textures\masks\SkinCracks1_prv.tga" Loaded image file "Temp\SkinCracks145321.tga" Can't load image file "textures\masks\StoneDirt1_prv.tga" Loaded image file "Temp\StoneDirt142742.tga" Can't load image file "textures\masks\OT_dirt_prv.tga" Loaded image file "Temp\OT_dirt35306.tga" Can't load image file "textures\masks\OT_dirt02_prv.tga" Loaded image file "Temp\OT_dirt0238352.tga" Can't load image file "textures\masks\OT_dirt_bulletHolesDepth01_8_prv.tga" Loaded image file "Temp\OT_dirt_bulletHolesDepth01_8107726.tga" Can't load image file "textures\masks\OT_mask_rust01_prv.tga" Loaded image file "Temp\OT_mask_rust0154470.tga" Can't load image file "textures\masks\OT_random6_prv.tga" Loaded image file "Temp\OT_random642608.tga" Can't load image file "textures\masks\OT_tech3_prv.tga" Loaded image file "Temp\OT_tech336495.tga" Can't load image file "textures\masks\OT_texturefx_dirtmask01_prv.tga" Loaded image file "Temp\OT_texturefx_dirtmask0189802.tga" Can't load image file "textures\masks\OT_texturefx_dirtmask02_prv.tga" Loaded image file "Temp\OT_texturefx_dirtmask0289840.tga" Can't load image file "textures\masks\OT_texturefx_riddled_prv.tga" Loaded image file "Temp\OT_texturefx_riddled80237.tga" Can't load image file "textures\masks\OT_textureFX_scratches05_nmap_prv.tga" Loaded image file "Temp\OT_textureFX_scratches05_nmap116172.tga" Can't load image file "textures\masks\StoneDirt1_nmap_prv.tga" Loaded image file "Temp\StoneDirt1_nmap59368.tga" Loaded image file "patterns\auto_mtl_preview_01D146FE.png" Loaded image file "patterns\auto_mtl_preview_0F7812D6.png" Loaded image file "patterns\auto_mtl_preview_1E13B66C.png" Loaded image file "patterns\auto_mtl_preview_59D42B5F.png" Loaded image file "patterns\auto_mtl_preview_72531A71.png" Loaded image file "patterns\auto_mtl_preview_1A7D71ED.png" Loaded image file "patterns\auto_mtl_preview_02D37DBF.png" Loaded image file "patterns\auto_mtl_preview_27F28888.png" Loaded image file "patterns\auto_mtl_preview_4EFD75C1.png" Loaded image file "patterns\auto_mtl_preview_4BBBF90A.png" Loaded image file "patterns\auto_mtl_preview_3983605C.png" Loaded image file "VoxStamps\Objects\Capsule_preview.png" Loaded image file "VoxStamps\Objects\column_preview.png" Loaded image file "VoxStamps\Objects\Cone_preview.png" Loaded image file "VoxStamps\Objects\Cube_preview.png" Loaded image file "VoxStamps\Objects\Cylinder_preview.png" Loaded image file "VoxStamps\Objects\dodecahedron_preview.png" Loaded image file "VoxStamps\Objects\Icosahedron_preview.png" Loaded image file "VoxStamps\Objects\Sphere_preview.png" Loaded image file "VoxStamps\Objects\Star_preview.png" Loaded image file "VoxStamps\Objects\Torus_preview.png" Loaded image file "VoxStamps\Splines\chain_preview.png" Loaded image file "VoxStamps\Splines\Dragon1_preview.png" Loaded image file "VoxStamps\Splines\Dragon2_preview.png" Loaded image file "VoxStamps\Splines\Dragon3_preview.png" Loaded image file "VoxStamps\Splines\Dragon4_preview.png" Loaded image file "VoxStamps\Splines\Dragon5_preview.png" Loaded image file "VoxStamps\Splines\pipe_segment_preview.png" Loaded image file "VoxStamps\Splines\shlang_preview.png" Loaded image file "VoxStamps\Splines\spring_preview.png" Loaded image file "VoxStamps\Splines\spring2_preview.png" Loaded image file "VoxStamps\Splines\spring3_preview.png" Loaded image file "VoxStamps\Splines\Tentacle_preview.png" Loaded image file "VoxStamps\Splines\WildTeeth_preview.png" Loaded image file "VoxStamps\RtpModels\C_Extension_preview.png" Loaded image file "VoxStamps\RtpModels\Capsule_LowPoly_preview.png" Loaded image file "VoxStamps\RtpModels\Capsule_MidPoly_preview.png" Loaded image file "VoxStamps\RtpModels\Cone_preview.png" Loaded image file "VoxStamps\RtpModels\Cube_01_preview.png" Loaded image file "VoxStamps\RtpModels\Cube_Chamfer_preview.png" Loaded image file "VoxStamps\RtpModels\Cube_Fillet_01_preview.png" Loaded image file "VoxStamps\RtpModels\Cube_Fillet_02_preview.png" Loaded image file "VoxStamps\RtpModels\Cube_Fillet_03_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_01_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_Capped_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_Chamfer_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_Chamfer_Hollow_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_Fillet_01_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_Fillet_02_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_Short_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_Short_Fillet_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_Short_Rounded_preview.png" Loaded image file "VoxStamps\RtpModels\Disc_01_preview.png" Loaded image file "VoxStamps\RtpModels\Disc_02_preview.png" Loaded image file "VoxStamps\RtpModels\GeoSphere_01_preview.png" Loaded image file "VoxStamps\RtpModels\Hedra_01_preview.png" Loaded image file "VoxStamps\RtpModels\Hedra_02_preview.png" Loaded image file "VoxStamps\RtpModels\Hedra_03_preview.png" Loaded image file "VoxStamps\RtpModels\Hedra_04_preview.png" Loaded image file "VoxStamps\RtpModels\Hose_Ribbed_preview.png" Loaded image file "VoxStamps\RtpModels\L_Extension_01_preview.png" Loaded image file "VoxStamps\RtpModels\NGon_01_preview.png" Loaded image file "VoxStamps\RtpModels\NGon_02_preview.png" Loaded image file "VoxStamps\RtpModels\Patch_Rounded_preview.png" Loaded image file "VoxStamps\RtpModels\Patch_Square_preview.png" Loaded image file "VoxStamps\RtpModels\Pyramid001_preview.png" Loaded image file "VoxStamps\RtpModels\Sphere_preview.png" Loaded image file "VoxStamps\RtpModels\Torus_preview.png" Loaded image file "VoxStamps\RtpModels\Torus_Knot_02_preview.png" Loaded image file "VoxStamps\RtpModels\Torus_Knot_02_01_preview.png" Loaded image file "VoxStamps\RtpModels\Torus_Thick_preview.png" Loaded image file "VoxStamps\RtpModels\Tube_preview.png" Loaded image file "VoxStamps\RtpModels\Tube_02_preview.png" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Can't load image file "textures\preview_pen0.tga" Can't load image file "textures\preview_pen5.tga" Can't load image file "Shape1" Can't load image file "Shape1" Can't load image file "Shape1" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Can't load image file "Shape" Can't load image file "Shape" Can't load image file "Shape1" Can't load image file "Shape1" Can't load image file "Shape1" Can't load image file "Shape" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_artman greeble2 strip_HardSurface_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_artman greeble2 strip_HardSurface_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_manyspots_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_manyspots_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_manyscratches_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_manyscratches_mclp.dds" Loaded image file "Unicode\Font00.dds" Locale: English_United States.1252 Loaded image file "Textures\stdimage.dds" Loaded image file "Temp\pano4.dds" Loaded image file "Temp\pano4d.dds" Loaded image file "textures\white.dds" Loaded image file "textures\light\baseicons.tga" Can't load image file "textures\default.dds" Loaded image file "textures\2knopki.tga" Loaded image file "textures\smallwhiteicons.dds" Loaded image file "textures\dark\property.tga" Loaded image file "textures\RightArrow.dds" Loaded image file "Textures\light\Navigation.tga" Loaded image file "textures\icons\newfolder.png" Can't load image file "textures\preview_pen1.tga" Can't load image file "textures\preview_pen2.tga" Can't load image file "textures\preview_pen3.tga" Can't load image file "textures\preview_pen4.tga" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_000_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_000_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_capsula_118D_horizontal_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_capsula_118D_horizontal_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Can't load image file "Levels\Uv\Uv_d" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_chain_227B_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_chain_227B_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_cheshuja_7BF3_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_cheshuja_7BF3_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_003_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_003_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_004_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_004_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_005_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_005_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_007_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_007_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_008_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_008_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Fabric0001_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Fabric0001_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Gem1_70C8_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Gem1_70C8_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Gem1_EC21_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Gem1_EC21_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_hair03_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_hair03_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_hair14_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_hair14_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_knopka_03_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_knopka_03_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_kosichka_20A7_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_kosichka_20A7_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_OT_corroded_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_OT_corroded_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_OT_Speckled03_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_OT_Speckled03_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_OT_Speckled04_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_OT_Speckled04_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Patron_C89D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Patron_C89D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_pen4_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_pen4_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_pen5_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_pen5_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Piramida_8AF9_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Piramida_8AF9_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_pugovka_CC7C_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_pugovka_CC7C_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_quad_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_quad_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_randomscratches_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_randomscratches_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Ringmail2_3BD4_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Ringmail2_3BD4_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Ringmail_0C3E_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Ringmail_0C3E_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rings_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rings_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_003_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_003_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_007_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_007_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_011_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_011_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_013_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_013_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_014_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_014_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_005_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_005_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_008_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_008_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_009_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_009_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_sq_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_sq_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_sqgrad_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_sqgrad_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_sqgradstrip_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_sqgradstrip_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_taty_2_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_taty_2_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_004_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_004_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_009_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_009_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_012_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_012_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_wire_9832_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_wire_9832_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Blob2_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Blob2_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Blob_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Blob_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Cloth_Fabric01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Cloth_Fabric01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Cloth_Fabric02_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Cloth_Fabric02_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Fissure2_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Fissure2_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Fissure5_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Fissure5_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Gear06_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Gear06_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Skin01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Skin01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Skin02_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Skin02_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Skin08_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Skin08_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Tech02_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Tech02_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Tech_Circle01_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Tech_Circle01_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Tech_Circle06_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Tech_Circle06_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Wrinkles01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Wrinkles01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Wrinkles02_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Wrinkles02_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_Capsule_A87D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_Capsule_A87D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_chain_BE26_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_chain_BE26_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_Edge1_8F5C_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_Edge1_8F5C_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_fabr_kromka_01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_fabr_kromka_01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_Patron_09C2_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_Patron_09C2_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_pen4_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_pen4_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_strip1_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_strip1_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_strip3_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_strip3_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_strip5_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_strip5_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_wire_44D3_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_wire_44D3_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_XMD_Cloth_Zipper01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_XMD_Cloth_Zipper01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_XMD_Cloth_Zipper02_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_XMD_Cloth_Zipper02_mclp.dds" Loaded image file "PickData\sky.jpg" Loaded image file "PickData\sky.jpg" Loaded image file "PickData\sky.jpg" Loaded image file "textures\grey3.dds" Loaded image file "textures\dark\stdbutton.tga" Loaded image file "Textures\dark\Navigation.tga" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Loaded image file "textures\enum\LrCondition\Always.png" Loaded image file "textures\enum\LrCondition\MoreOnConcave.png" Loaded image file "textures\enum\LrCondition\MoreOnConvex.png" Loaded image file "textures\enum\LrCondition\LessOnConcave.png" Loaded image file "textures\enum\LrCondition\LessOnConvex.png" Loaded image file "textures\enum\LrCondition\MoreOnFlat.png" Loaded image file "textures\enum\LrCondition\MoreOnCurved.png" Loaded image file "textures\enum\LrCondition\MoreOnLit.png" Loaded image file "textures\enum\LrCondition\MoreInShadow.png" Loaded image file "textures\enum\LrCondition\MoreOnTop.png" Loaded image file "textures\enum\LrCondition\MoreOnBottom.png" Loaded image file "textures\enum\LrCondition\MoreOnSides.png" Loaded image file "textures\enum\LrCondition\MoreOnBright.png" Loaded image file "textures\enum\LrCondition\MoreOnMidtone.png" Loaded image file "textures\enum\LrCondition\MoreOnDark.png" Loaded image file "textures\enum\LrCondition\MoreOnCurrent.png" Loaded image file "textures\enum\LrCondition\MoreOnHigh.png" Loaded image file "textures\enum\LrCondition\MoreOnDeep.png" Loaded image file "textures\dark\Icons16.tga" Loaded image file "Textures\dark\Locks.tga" Loaded image file "textures\taper32.png" Loaded image file "StartMenu\images\MainLogo4.png" Loaded image file "textures\icons64\Blob_Vox.png" Loaded image file "textures\icons64\Sketch_Tool.png" Loaded image file "textures\icons64\Repair.png" Loaded image file "textures\icons64\im2mesh.png" Loaded image file "textures\icons64\vertexpaint.png" Loaded image file "textures\icons64\ppp.png" Loaded image file "textures\icons64\mv.png" Loaded image file "textures\icons64\ptex.png" Loaded image file "textures\icons64\Cap.png" Loaded image file "textures\icons64\Mark_Seams.png" Loaded image file "textures\icons64\Bass-releif.png" Loaded image file "textures\icons64\Recent.png" Loaded image file "Temp\panoramas_ggx2\1969697_thumb.tga" Loaded image file "textures\dark\Navigation_ext.tga" Loaded image file "Temp\panoramas_ggx2\25A3A386_thumb.tga" Loaded image file "Temp\panoramas_ggx2\2FFFFFD_thumb.tga" Loaded image file "Temp\panoramas_ggx2\3848487_thumb.tga" Loaded image file "Temp\panoramas_ggx2\3B383803_thumb.tga" Loaded image file "Temp\panoramas_ggx2\3FD2D2ED_thumb.tga" Loaded image file "Temp\panoramas_ggx2\499091D9_thumb.tga" Loaded image file "Temp\panoramas_ggx2\51A9A9F8_thumb.tga" Loaded image file "Temp\panoramas_ggx2\5C0C0C5_thumb.tga" Loaded image file "Temp\panoramas_ggx2\95E5E57_thumb.tga" Loaded image file "textures\dark\LayersIcons.tga" Loaded image file "textures\dark\stdbutton2.tga" * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_ALL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ENV Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ENV #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_ENV Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_COLOR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_COLOR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_RELIEF Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_RELIEF #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_RELIEF Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPECULAR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPECULAR #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_SPECULAR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ROUGH Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ROUGH #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_ROUGH Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPCOLOR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPCOLOR #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_SPCOLOR Compiling VS... Compiling PS... * Loading shader "Shaders/shadow_sel.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/shadow_tbn.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL #define SHADOWS Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL #define VERT_NORMAL #define SHADOWS Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_ALL #define SHADOWS Compiling VS... Compiling PS... Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Loaded image file "textures\chess.dds" Loaded image file "textures\black.dds" Loaded image file "textures\dashes.dds" Loaded image file "textures\dashes2.dds" Loaded image file "textures\snow.dds" Loaded image file "textures\borders\viewport.tga" * Loading shader "Shaders/hud_smooth.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... Loaded image file "textures\borders\input_field.tga" Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Loaded image file "Textures\icons\arrowright.tga" Loaded image file "Textures\icons\arrowdown.tga" Loaded image file "textures\icons\move_area_16.tga" Loaded image file "textures\borders\dock_delimiter.tga" Loaded image file "textures\light\tabbutton_line.tga" Loaded image file "textures\dark\tabbutton_inactive.tga" Loaded image file "textures\dark\tabbutton.tga" Loaded image file "textures\borders\buttons.tga" Loaded image file "textures\dark\checkers.tga" Loaded image file "textures\BothSideArrows.tga" Loaded image file "textures\vista3.dds" Loaded image file "Textures\dark\DownArrow.tga" Loaded image file "textures\borders\combo_inner_frame.tga" Loaded image file "textures\borders\combo_arrow_frame.tga" Loaded image file "textures\borders\dialog_header.tga" Loaded image file "textures\borders\dialogs.tga" Loaded image file "textures\borders\toolset_internal_buttons.tga" Loaded image file "textures\\light\\Navigation_ext.tga" Loaded image file "textures\light\Navigation_ext.tga" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Loaded image file "textures\icons\larrow.tga" Loaded image file "textures\switchcolors.tga" Loaded image file "textures\borders\docked.tga" Loaded image file "textures\icons\wicons.png" Loaded image file "textures\borders\top_menu_highlight.tga" Loaded image file "textures\borders\menu.tga" Loaded image file "textures\dark\dock_header_plane.tga" Loaded image file "textures\borders\menu_highlight.tga" Loading file: C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub_painting.3b 00000000 : RNDR : 8 bytes 00000010 : NSYZ : 0 bytes 00000018 : NBLN : 0 bytes 00000020 : NWCL : 0 bytes 00000028 : MSSK : 20 bytes 00000044 : PAUV : 16 bytes C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub_painting.3b: Unknown block found in 3DB file: VUAP! 0000005C : MEAS : 8 bytes 0000006C : CAM1 : 88 bytes 000000CC : LNRM : 4 bytes 000000D8 : SSPC : 0 bytes 000000E0 : VERS : 21 bytes C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub_painting.3b: Unknown block found in 3DB file: SREV! 000000FD : LR01 : 1936 bytes 00000895 : MTLS : 341 bytes 000009F2 : MTEX : 129 bytes 00000A7B : OBJS : 227 bytes 00000B66 : RNTS : 372 bytes 00000CE2 : UVST : 368 bytes 00000E5A : SUBD : 0 bytes 00000E62 : VMAP : 4 bytes 00000E6E : VMTP : 49 bytes 00000EA7 : POS0 : 1536 bytes 000014AF : UVS0 : 8 bytes 000014BF : SAR8 : 27133 bytes Faces: done SetupUVIds: done SetAllDirty: done 00007EC4 : MAQ3 : 2462616 bytes 00:00.079 PreCreateFromMesh: 0 00261264 : CMSC : 61 bytes 002612A9 : STIL : 2295 bytes Loaded image file "..\..\Users\FamilyPC\Downloads\Hydraulic Excavtor.jpg" 00261BA8 : RTP1 : 185 bytes 00261C69 : SYMM : 8 bytes 00261C79 : UVM1 : 177 bytes 00261D32 : METU : 16 bytes 00261D4A : VOL3 : 4 bytes 00261D56 : VCSH : 4 bytes 00261D62 : WMSV : 10 bytes 00261D74 : EXOP : 2510 bytes 0026274A : GRIS : 56 bytes 0026278A : SSTR : 20 bytes 002627A6 : MVSV : 4 bytes 002627B2 : CVSV : 4 bytes 002627BE : EСS1 : 12 bytes 002627D2 : OLCO : 4 bytes 002627DE : RFSV : 4194388 bytes 0066283A : FITT : 116 bytes 006628B6 : MSRT : 452 bytes 00662A82 : SCPT : 52 bytes 00662ABE : SP&J : 1077 bytes 00662EFB : VOSS : 4 bytes 00662F07 : HLSV : 4 bytes 00662F13 : RTGV : 4 bytes 00662F1F : OBJV : 4 bytes 00662F2B : MATV : 4 bytes 00662F37 : BPSS : 343 bytes 00663096 : VCUR : 29 bytes 006630BB : SELP : 120 bytes 0066313B : REND : 1130 bytes 006635AD : PTEX : 944 bytes 00663965 : URC1 : 20 bytes 00663981 : APSV : 12 bytes 00663995 : SYNP : 430 bytes 00:00.157 CreateBackEdges2: 0 00:00.157 InitFace: 0 PutFacesInCells: done * Loading shader "Shaders/rt_copy.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... UpdateDirtyFaces: done Loaded image file "Textures\grey.dds" Loaded image file "Textures\whitet.dds" Loaded image file "Textures\emptygrey.dds" CreateMeshes: done CreatePaddingInfo: done CreatePointsCorrespondence: done CreateTangentSpaceFromBasicNormals: done Loading: done Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Undocked: Undocked: Undocked: Undocked: Deleted: Pen Deleted: PenOpt Deleted: STRIPS Deleted: Blending Deleted: Layers Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "textures\borders\layers.tga" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" * Loading shader "Shaders/tex_preview.hlsl"... #define SCREEN_SPACE #define FORDP Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview_nrm.hlsl"... #define SCREEN_SPACE #define FORDP Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview_alpha.hlsl"... #define SCREEN_SPACE #define FORDP Compiling VS... Compiling PS... Loaded image file "textures\borders\combo_dropdown_frame.tga" Loaded image file "textures\dark\dock_header.tga" Loaded image file "textures\borders\undocked.tga" Can't load image file "textures\enum\SoftwarePreset\Unknown.png" Can't load image file "textures\enum\SoftwarePreset\3D-Max.png" Can't load image file "textures\enum\SoftwarePreset\Blender.png" Can't load image file "textures\enum\SoftwarePreset\Maya_2013_and_later.png" Can't load image file "textures\enum\SoftwarePreset\Maya_2015_and_later.png" Can't load image file "textures\enum\SoftwarePreset\Maya_prior_2013.png" Can't load image file "textures\enum\SoftwarePreset\Substance Designer & Painter.png" Can't load image file "textures\enum\SoftwarePreset\Unity.png" Can't load image file "textures\enum\SoftwarePreset\UnrealEngine.png" Can't load image file "textures\enum\SoftwarePreset\ZBrush.png" Can't load image file "textures\enum\SoftwarePreset\Add_preset.png" Can't load image file "textures\enum\NORMMETHOD\Coat_normals.png" Can't load image file "textures\enum\NORMMETHOD\Maya_normals.png" Can't load image file "textures\enum\NORMMETHOD\nm_AngleWeighed.png" Can't load image file "textures\enum\NORMMETHOD\nm_SquareWeighed.png" Can't load image file "textures\enum\NORMMETHOD\nm_AngleSquareWeighed.png" Can't load image file "textures\enum\NMAPEXPORT_ENUM\NM_3DMAX.png" Can't load image file "textures\enum\NMAPEXPORT_ENUM\NM_MAYA.png" Can't load image file "textures\enum\TRIMETHOD\DelaunayTriangulation.png" Can't load image file "textures\enum\TRIMETHOD\NaiveTriangulation.png" Can't load image file "textures\enum\TBNMETHOD\MikkTSpace.png" Can't load image file "textures\enum\TBNMETHOD\LengyelSpace.png" Can't load image file "textures\enum\TBNMETHOD\LengyelAngleWeightedSpace.png" Can't load image file "textures\enum\TBNMETHOD\LengyelAreaAngleWeightedSpace.png" Can't load image file "textures\enum\TBNMETHOD\Maya.png" Can't load image file "textures\enum\RT_PADDING\InterpolatedColorPadding.png" Can't load image file "textures\enum\RT_PADDING\NearestPixelPadding.png" Can't load image file "textures\enum\RT_PADDING\NaivePadding.png" Can't load image file "textures\enum\FILLBORDER_ENUM\FILLB_ASK.png" Can't load image file "textures\enum\FILLBORDER_ENUM\FILLB_FILL.png" Can't load image file "textures\enum\FILLBORDER_ENUM\FILLB_NOFILL.png" Loaded image file "textures\borders\class_tab_passive.tga" Loaded image file "textures\borders\class_tab_active.tga" Can't load image file "textures\stdbutton.tga" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Undocked: Undocked: Undocked: Undocked: Deleted: Pen Deleted: PenOpt Deleted: STRIPS Deleted: Blending Deleted: Layers Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "textures\close.tga" Loaded image file "textures\borders\hints.tga" Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "FillPatterns\leather2.bmp" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Undocked: Undocked: Undocked: Undocked: Deleted: Pen Deleted: PenOpt Deleted: STRIPS Deleted: Blending Deleted: Layers Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Undocked: Undocked: Undocked: Undocked: Deleted: Pen Deleted: PenOpt Deleted: STRIPS Deleted: Blending Deleted: Layers Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Can't load image file "textures\enum\SoftwarePreset\Unknown.png" Can't load image file "textures\enum\SoftwarePreset\3D-Max.png" Can't load image file "textures\enum\SoftwarePreset\Blender.png" Can't load image file "textures\enum\SoftwarePreset\Maya_2013_and_later.png" Can't load image file "textures\enum\SoftwarePreset\Maya_2015_and_later.png" Can't load image file "textures\enum\SoftwarePreset\Maya_prior_2013.png" Can't load image file "textures\enum\SoftwarePreset\Substance Designer & Painter.png" Can't load image file "textures\enum\SoftwarePreset\Unity.png" Can't load image file "textures\enum\SoftwarePreset\UnrealEngine.png" Can't load image file "textures\enum\SoftwarePreset\ZBrush.png" Can't load image file "textures\enum\SoftwarePreset\Add_preset.png" Can't load image file "textures\enum\NORMMETHOD\Coat_normals.png" Can't load image file "textures\enum\NORMMETHOD\Maya_normals.png" Can't load image file "textures\enum\NORMMETHOD\nm_AngleWeighed.png" Can't load image file "textures\enum\NORMMETHOD\nm_SquareWeighed.png" Can't load image file "textures\enum\NORMMETHOD\nm_AngleSquareWeighed.png" Can't load image file "textures\enum\NMAPEXPORT_ENUM\NM_3DMAX.png" Can't load image file "textures\enum\NMAPEXPORT_ENUM\NM_MAYA.png" Can't load image file "textures\enum\TRIMETHOD\DelaunayTriangulation.png" Can't load image file "textures\enum\TRIMETHOD\NaiveTriangulation.png" Can't load image file "textures\enum\TBNMETHOD\MikkTSpace.png" Can't load image file "textures\enum\TBNMETHOD\LengyelSpace.png" Can't load image file "textures\enum\TBNMETHOD\LengyelAngleWeightedSpace.png" Can't load image file "textures\enum\TBNMETHOD\LengyelAreaAngleWeightedSpace.png" Can't load image file "textures\enum\TBNMETHOD\Maya.png" Can't load image file "textures\enum\RT_PADDING\InterpolatedColorPadding.png" Can't load image file "textures\enum\RT_PADDING\NearestPixelPadding.png" Can't load image file "textures\enum\RT_PADDING\NaivePadding.png" Can't load image file "textures\enum\FILLBORDER_ENUM\FILLB_ASK.png" Can't load image file "textures\enum\FILLBORDER_ENUM\FILLB_FILL.png" Can't load image file "textures\enum\FILLBORDER_ENUM\FILLB_NOFILL.png" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Undocked: Undocked: Undocked: Undocked: Deleted: Pen Deleted: PenOpt Deleted: STRIPS Deleted: Blending Deleted: Layers Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "textures\lineprofile.png" Loaded image file "textures\spot12.png" Loaded image file "textures\spot12_empty.png" Options.xml: <AppOptions> <PenInterface::DisplaceObject>false</PenInterface::DisplaceObject> <RtpObj>true</RtpObj> <SoftwarePreset>Unknown</SoftwarePreset> <NormalsCalculationMethod>Maya_normals</NormalsCalculationMethod> <TriangulationMethod>DelaunayTriangulation</TriangulationMethod> <TBNMethod>MikkTSpace</TBNMethod> <SwapTB>false</SwapTB> <DenormalizedTB>false</DenormalizedTB> <NMAP_EXPORT_TYPE>NM_MAYA</NMAP_EXPORT_TYPE> <FlipPtexQuads>false</FlipPtexQuads> <ShowFocalShift>false</ShowFocalShift> <ShowFalloff>true</ShowFalloff> <StorePenShapeForTools>true</StorePenShapeForTools> <StorePenRadiusForTools>true</StorePenRadiusForTools> <WHEEL_ACTION>WHEEL_CHANGE_RADIUS</WHEEL_ACTION> <CTRL_WHEEL_ACTION>WHEEL_CHANGE_PRESSURE</CTRL_WHEEL_ACTION> <SHIFT_WHEEL_ACTION>WHEEL_CHANGE_SMOOTH</SHIFT_WHEEL_ACTION> <ALT_WHEEL_ACTION>WHEEL_CHANGE_OPACITY</ALT_WHEEL_ACTION> <WheelZoomPerspSpeed>1.000000</WheelZoomPerspSpeed> <WheelZoomOrthoSpeed>1.000000</WheelZoomOrthoSpeed> <WheelZoomUVSpeed>1.000000</WheelZoomUVSpeed> <MainColor>FFE8E72B</MainColor> <BackColor>FFA40D11</BackColor> <EnableChannels[0]>true</EnableChannels[0]> <EnableChannels[1]>false</EnableChannels[1]> <EnableChannels[3]>false</EnableChannels[3]> <NearPlane>1.000000</NearPlane> <PivotType>1</PivotType> <PenInterface::SaveSpecInNM>false</PenInterface::SaveSpecInNM> <PenInterface::SaveDispInNM>false</PenInterface::SaveDispInNM> <PenInterface::DontUseAnphaInNM>false</PenInterface::DontUseAnphaInNM> <PenInterface::DontUseAnphaAtAll>false</PenInterface::DontUseAnphaAtAll> <SymmSnapValue>0.400000</SymmSnapValue> <SnappingMethod2>1</SnappingMethod2> <Global_DontSnapSubdVertices>true</Global_DontSnapSubdVertices> <ProjectionThrough>false</ProjectionThrough> <FreezeViewMode>0</FreezeViewMode> <FreezePScrollSpeed>1.000000</FreezePScrollSpeed> <UsingProcessors>32</UsingProcessors> <UseMultiCore>true</UseMultiCore> <UseMulticoreForSaving>true</UseMulticoreForSaving> <UseMRT>true</UseMRT> <PickFromAllLayers1>true</PickFromAllLayers1> <PickDepthToo>true</PickDepthToo> <PickFromCentralPoint>true</PickFromCentralPoint> <PivotType>1</PivotType> <SwapYZ>false</SwapYZ> <EditorPath>photoshop.exe</EditorPath> <MeshViewQuality>0</MeshViewQuality> <Choose></Choose> <RealtimePaddingMode>InterpolatedColorPadding</RealtimePaddingMode> <FILL_BORDERS_MODE>FILLB_FILL</FILL_BORDERS_MODE> <BorderEdgesWidth>256</BorderEdgesWidth> <LightDirX>-0.562900</LightDirX> <LightDirY>-0.279500</LightDirY> <LightDirZ>0.279500</LightDirZ> <MillionsOfPolygons>1.000000</MillionsOfPolygons> <TexSizeX>2048</TexSizeX> <TexSizeY>2048</TexSizeY> <LightContrast>0.000000</LightContrast> <ShowThumbs>true</ShowThumbs> <ShowIThumbs>true</ShowIThumbs> <ImgPath> <_str>PickData\sky.jpg</_str> </ImgPath> <PickerType>2</PickerType> <PickColorMode>0</PickColorMode> <PenSensivity>1.000000</PenSensivity> <Symmetry_point_opacity>40.000000</Symmetry_point_opacity> <CamZoomSpeed>1.000000</CamZoomSpeed> <CamRotSpeed>1.000000</CamRotSpeed> <SlidersStates> <SliderState> <ID>SMOOTH_STROKE</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_RADIUS</ID> <State>true</State> </SliderState> <SliderState> <ID>FALLOFF</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_DEPTH</ID> <State>true</State> </SliderState> <SliderState> <ID>SMOOTH_DEG</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_MASK</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_SPEC</ID> <State>true</State> </SliderState> <SliderState> <ID>Roughness</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_METAL</ID> <State>true</State> </SliderState> <SliderState> <ID>ERASE_DEGREE</ID> <State>true</State> </SliderState> <SliderState> <ID>$preset_section_Surface</ID> <State>true</State> </SliderState> <SliderState> <ID>MASK_OPACITY</ID> <State>true</State> </SliderState> <SliderState> <ID>*VoxelTools4</ID> <State>true</State> </SliderState> <SliderState> <ID>*Adjust4</ID> <State>true</State> </SliderState> <SliderState> <ID>*Objects4</ID> <State>true</State> </SliderState> <SliderState> <ID>*Surface4</ID> <State>true</State> </SliderState> <SliderState> <ID>*Commands4</ID> <State>true</State> </SliderState> <SliderState> <ID>*Sculpt1</ID> <State>true</State> </SliderState> <SliderState> <ID>RetopoExtrusion</ID> <State>true</State> </SliderState> <SliderState> <ID>ViewBias</ID> <State>true</State> </SliderState> <SliderState> <ID>RtpOpacity</ID> <State>true</State> </SliderState> <SliderState> <ID>SymmSnapValue</ID> <State>true</State> </SliderState> <SliderState> <ID>*Basic2</ID> <State>true</State> </SliderState> <SliderState> <ID>*Tweak2</ID> <State>true</State> </SliderState> <SliderState> <ID>*UV2</ID> <State>false</State> </SliderState> <SliderState> <ID>*Commands2</ID> <State>true</State> </SliderState> <SliderState> <ID>*LC4</ID> <State>false</State> </SliderState> <SliderState> <ID>SegmentsNum</ID> <State>true</State> </SliderState> <SliderState> <ID>*Modes3</ID> <State>true</State> </SliderState> <SliderState> <ID>*Commands3</ID> <State>true</State> </SliderState> <SliderState> <ID>*Selected3</ID> <State>true</State> </SliderState> <SliderState> <ID>FREEZE_DIFF</ID> <State>true</State> </SliderState> <SliderState> <ID>FREEZE_DETAILS</ID> <State>true</State> </SliderState> <SliderState> <ID>FREEZE_SM_DEGREE</ID> <State>true</State> </SliderState> <SliderState> <ID>FREEZE_SMOOTH</ID> <State>true</State> </SliderState> <SliderState> <ID>SplitBorderWidth</ID> <State>true</State> </SliderState> <SliderState> <ID>PlaneSoftness</ID> <State>true</State> </SliderState> <SliderState> <ID>NrmSampling</ID> <State>true</State> </SliderState> <SliderState> <ID>MoveDegree</ID> <State>true</State> </SliderState> </SlidersStates> <FoldersStates> <FolderState> <ID>OPENOBJ</ID> <Folder>C:\Users\FamilyPC\Documents\Blender\projects\Hydraulic Excavtor\export\Prep for 3d Coat voxel\</Folder> </FolderState> <FolderState> <ID>ObjLwoStlPlydaewrl</ID> <Folder>C:\Users\FamilyPC\Documents\Blender\projects\Hydraulic Excavtor\export\Prep for 3d Coat voxel\</Folder> </FolderState> <FolderState> <ID>ObjLwoStlPlydaewrl3b</ID> <Folder>C:\Users\FamilyPC\Documents\Blender\projects\Hydraulic Excavtor\export\Prep for 3d Coat voxel\</Folder> </FolderState> <FolderState> <ID>LOADTEX</ID> <Folder>C:\Users\FamilyPC\Documents\Blender\projects\Characters\Females\Assets\</Folder> </FolderState> <FolderState> <ID>tgabmppngjpgddstiftiffexrhdr</ID> <Folder>C:\Users\FamilyPC\Downloads\</Folder> </FolderState> <FolderState> <ID>SAVEMESH</ID> <Folder>C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\</Folder> </FolderState> <FolderState> <ID>3b</ID> <Folder>C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\</Folder> </FolderState> <FolderState> <ID>SAVETEX</ID> <Folder>C:\Users\FamilyPC\Documents/3D-CoatV47/UserData/</Folder> </FolderState> <FolderState> <ID>psd</ID> <Folder>C:\Users\FamilyPC\Documents\Adobe\Excavator\</Folder> </FolderState> <FolderState> <ID>3b3b.jpg</ID> <Folder>C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\</Folder> </FolderState> <FolderState> <ID>save:*.Obj;*.Lwo;*.Fbx;*.Stl;*.Ply;*.dae;*.wrl;</ID> <Folder>C:\Users\FamilyPC\Documents\Blender\projects\Characters\Females\Assets\Final\3dCoat export\outfit\</Folder> </FolderState> <FolderState> <ID>MASKSHAPEDIR</ID> <Folder>C:\Users\FamilyPC\Pictures\cg_textures\metal\</Folder> </FolderState> <FolderState> <ID>tgabmppngjpgabrtiftiffexrobjlwo</ID> <Folder>C:\Users\FamilyPC\Pictures\cg_textures\metal\</Folder> </FolderState> <FolderState> <ID>PENSHAPEDIR</ID> <Folder>C:\Users\FamilyPC\Pictures\cg_textures\metal\</Folder> </FolderState> <FolderState> <ID>tgabmppngjpgabrobjlwopsdmclptif</ID> <Folder>C:\Users\FamilyPC\Pictures\cg_textures\metal\</Folder> </FolderState> <FolderState> <ID></ID> <Folder>C:\Users\FamilyPC\Documents\3D-CoatV47\patterns\</Folder> </FolderState> <FolderState> <ID>tgabmppngjpgddstiftiffexr</ID> <Folder>C:\Users\FamilyPC\Documents\3D-CoatV47\patterns\</Folder> </FolderState> <FolderState> <ID>SEL_TEXT</ID> <Folder>C:\Users\FamilyPC\Downloads\</Folder> </FolderState> <FolderState> <ID>exrhdr</ID> <Folder></Folder> </FolderState> <FolderState> <ID>save:*.tga;*.bmp;*.png;*.jpg;*.tif;*.tiff</ID> <Folder></Folder> </FolderState> <FolderState> <ID>tgabmppngjpgtiftiff</ID> <Folder></Folder> </FolderState> <FolderState> <ID>*.obj;*.fbx,*.lwo</ID> <Folder></Folder> </FolderState> <FolderState> <ID>objfbxlwo</ID> <Folder></Folder> </FolderState> <FolderState> <ID>SAVEOBJ</ID> <Folder>C:\Users\FamilyPC\Documents\Blender\projects\Hydraulic Excavtor\export\</Folder> </FolderState> <FolderState> <ID>tgabmppngjpgdds</ID> <Folder>C:\Users\FamilyPC\Downloads\</Folder> </FolderState> <FolderState> <ID>PICKIMG</ID> <Folder>C:\Users\FamilyPC\Downloads\</Folder> </FolderState> </FoldersStates> <AllowRmbProp>true</AllowRmbProp> <AllowMaterialNavigaion>false</AllowMaterialNavigaion> <LockPanorama>false</LockPanorama> <PanoRotation>1.750000</PanoRotation> <PanoBlurEx>3.880000</PanoBlurEx> <ShadersPreviewSize>1</ShadersPreviewSize> <GreyscalePano>false</GreyscalePano> <RareGrid>false</RareGrid> <NormalGrid>true</NormalGrid> <DenseGrid>false</DenseGrid> <CustomGrid>false</CustomGrid> <GridStep3D>1.000000</GridStep3D> <GridSubSections>1</GridSubSections> <GridStepsCount>10</GridStepsCount> <ShowAxisX>true</ShowAxisX> <ShowAxisY>true</ShowAxisY> <ShowAxisZ>true</ShowAxisZ> <MovementSensitivity>1.000000</MovementSensitivity> <ZoomModulator>1.000000</ZoomModulator> <PanUDModulator>1.000000</PanUDModulator> <PanRLModulator>1.000000</PanRLModulator> <RotationSensitivity>1.000000</RotationSensitivity> <SpinModulator>1.000000</SpinModulator> <TiltModulator>1.000000</TiltModulator> <RollModulator>1.000000</RollModulator> <M3D_ActivationKey>Key 1</M3D_ActivationKey> <PenIconSize>1</PenIconSize> <StripIconSize>1</StripIconSize> <MaskIconSize>1</MaskIconSize> <MtlIconSize>3</MtlIconSize> <ModelsIconSize>2</ModelsIconSize> <RotateAroundYAxis>true</RotateAroundYAxis> <DisableRoll>false</DisableRoll> <RealtimeUVPreview>true</RealtimeUVPreview> <ZoomToVaryRadiusSensitivity>1.000000</ZoomToVaryRadiusSensitivity> <UpDonToVaryDepthSensitivity>1.000000</UpDonToVaryDepthSensitivity> <RLToVaryTransparencySensitivity>1.000000</RLToVaryTransparencySensitivity> <SpinToVaryRotationSensitivity>1.000000</SpinToVaryRotationSensitivity> <TiltToVaryFocalShiftSensitivity>1.000000</TiltToVaryFocalShiftSensitivity> <RollToVarySpecularSensitivity>1.000000</RollToVarySpecularSensitivity> <GeneralPen::Color.x>0.168627</GeneralPen::Color.x> <GeneralPen::Color.y>0.905882</GeneralPen::Color.y> <GeneralPen::Color.z>0.909804</GeneralPen::Color.z> <GeneralPen::Color2.x>0.066667</GeneralPen::Color2.x> <GeneralPen::Color2.y>0.050980</GeneralPen::Color2.y> <GeneralPen::Color2.z>0.643137</GeneralPen::Color2.z> <GeneralPen::PenRadius>15.143344</GeneralPen::PenRadius> <GeneralPen::PenRotation>0.000000</GeneralPen::PenRotation> <GeneralPen::DeepDegree>0.500000</GeneralPen::DeepDegree> <GeneralPen::ColorOpacity>0.939413</GeneralPen::ColorOpacity> <GeneralPen::SpecularDegree>1.000000</GeneralPen::SpecularDegree> <GeneralPen::Falloff>0.000000</GeneralPen::Falloff> <GeneralPen::FocalShift>0.000000</GeneralPen::FocalShift> <HidePenConstantlyInCapsMode>false</HidePenConstantlyInCapsMode> <HidePenConstantly>false</HidePenConstantly> <ShowPenShape>true</ShowPenShape> <ShowPenAlpha>true</ShowPenAlpha> <PenCircleColor>FFFFFF00</PenCircleColor> <PenShapeColor>FFFF0000</PenShapeColor> <PenShapeColorWithCTRL>FF0000FF</PenShapeColorWithCTRL> <PenShapeColorWithSHIFT>FF00FF00</PenShapeColorWithSHIFT> <ShowCentralSpotInCapsMode>true</ShowCentralSpotInCapsMode> <MessageAbovePen>0</MessageAbovePen> <MessageBelowPen>0</MessageBelowPen> <MessagesColor>FFFF0000</MessagesColor> <PickVertMode2>1</PickVertMode2> <RecentFiles> <_str>C:\Users\FamilyPC\Documents\Blender\projects\Characters\Females\Assets\Final\obj\lunch_lady.obj(dp)</_str> <_str>C:\Program Files\3D-Coat-V4.7.06\Samples\dino.4.obj(dp)</_str> <_str>C:\Users\FamilyPC\Documents\Blender\projects\Characters\Females\Assets\Final\obj\lunch_lady-base_body.obj(dp)</_str> <_str>C:\Users\FamilyPC\Documents\Blender\projects\Characters\Females\Assets\Final\obj\lunch_lady-base_body_No-Mole.obj(dp)</_str> <_str>C:\Users\FamilyPC\Documents\Blender\projects\Characters\Females\Assets\Final\obj\lunch_lady-base_body_No-Mole_tiles.obj(dp)</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\UserData\autosave.3b</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\UserData\lunch-lady.3b</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\UserData\new lunch lady.3b</_str> <_str>C:\Users\FamilyPC\Documents\Blender\projects\Characters\Females\Assets\Final\obj\lunch_lady-outfit.obj(dp)</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\UserData\lunch_lady-outfit.3b</_str> <_str>StartMenu/files/preview_sphere.3b</_str> <_str>C:\Users\FamilyPC\Documents\Blender\projects\Hydraulic Excavtor\export\Hydraulic Excavator high-p.fbx(dp)</_str> <_str>C:\Users\FamilyPC\Documents\Blender\projects\Hydraulic Excavtor\export\Hydraulic Excavator uv-mapping.fbx(dp)</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\UserData\Excavator\hub.3b</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub.3b</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub_002.3b</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub_003.3b</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub painting.3b</_str> <_str>C:\Users\FamilyPC\Documents\Blender\projects\Hydraulic Excavtor\export\Prep for 3d Coat voxel\Excavator_Hub_e-loops.fbx(dp)</_str> <_str>C:\Users\FamilyPC\Documents/3D-CoatV47/UserData\autosave.3b</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub_painting.3b</_str> </RecentFiles> </AppOptions> hub_painting.zip
  18. Hello everyone! This my new head sculpture which I've done for customer from Sweden. Sculpting - 3d Coat Texturing - Quixel Suite 2 Rendering - Octane, 3dcoat, Vray You can buy this model here - http://3ddd.ru/3dmodels/show/biust_gierkuliesa
  19. При експорте материала из коата в макс/вирей материал становится совсем не таким, каким он был в 3д коате, как я понял - это из-за того что вирей не поддерживает PBR, но ведь как-то наверняка можно в вирее использовать текстуры и материалы коата... Подскажите как сделать так чтоб в вирее материалы отображались верно и как вообще рендерить модели и материалы с коата, не на коате... например как их рендерить на вирее, или может вообще воспользоваться возможностями рендера на движке вроде анреал енджина?
  20. Hey everyone! I am going to release 8 Apps for iOS and Android from 2016 / 06 / 01 to 2016 / 06 / 08 (each day one app). Promotional videos are being released on the Shushustorm Youtube channel (from 2016/05/25 to 2016/05/31): https://www.youtube.com/user/shushustorm For more information, you can also visit my website: http://www.shushustorm.com Here are some screenshots: Squeaky Toys Throw da Phone One Life The apps will be available on the App Store and on Google Play: App Store developer page: https://itunes.apple.com/us/developer/stefan-dumler/id943994670 Google Play developer page: https://play.google.com/store/apps/developer?id=Stefan+Dumler And some more links for the individual apps (iOS, Android, promo-video): (Please note that, right now, not all the links are working because the videos and apps aren't fully released yet.) Squeaky Toys https://itunes.apple.com/app/squeaky-toys/id1042280182 https://play.google.com/store/apps/details?id=com.shushustorm.squeakytoys https://www.youtube.com/watch?v=NNjaSGOxfOw One Flight https://itunes.apple.com/app/one-flight/id1047858038 https://play.google.com/store/apps/details?id=com.shushustorm.oneflight https://www.youtube.com/watch?v=D_K0vxvdMIo One Life Plus https://itunes.apple.com/app/one-life/id1033008414 https://play.google.com/store/apps/details?id=com.shushustorm.onelifeplus https://www.youtube.com/watch?v=vqUxD7mnEMs Throw da Phone https://itunes.apple.com/app/throw-da-phone/id1039592315 https://play.google.com/store/apps/details?id=com.shushustorm.throwdaphone https://www.youtube.com/watch?v=1LJdsZPRkb4 hardbroken https://itunes.apple.com/app/hardbroken/id1037353659 https://play.google.com/store/apps/details?id=com.shushustorm.hardbroken https://www.youtube.com/watch?v=fBhmMPqiCTM pushle https://itunes.apple.com/app/pushle/id1013617378 https://play.google.com/store/apps/details?id=com.shushustorm.pushle https://www.youtube.com/watch?v=H41nQGTksMc One Life https://itunes.apple.com/app/one-life/id1033007854 https://play.google.com/store/apps/details?id=com.shushustorm.onelife https://www.youtube.com/watch?v=vqUxD7mnEMs Spin A Melon https://itunes.apple.com/app/spin-a-melon/id1098439453 https://play.google.com/store/apps/details?id=com.shushustorm.spinamelon https://www.youtube.com/watch?v=dI5inROmqAw As there is quite some 3D modelling going on in most of the apps, feedback would be great! I used 3D-Coat in many different ways, sometimes even for creating models that I would render in Blender to get textures to use in Unity. Best wishes, Shu
  21. Here is an old gameartisans entry that I never finished. I decided to go the hand painted route. Its still a early WIP. On a side note, whenever I run 3DCoat on my laptop, the computer gets really hot and the fan is working hard. I am afraid I'm going to burn something up. Is there anything I can do to solve this or ease it? My specs are: Windows 10 64Bit Processor: AMD A4-4300M APU with Radeon HD Graphics 2.50GHz RAM: 4.00GB (3.46GB useable) Thanks.
  22. Hello, everyone I am new here. I just started using 3D Coat a few months back and in my opinion it's a fantastic software. Here's a sculpt I did with it. Did the retopology in 3D Coat too and rigged in Maya Hope you like it. Cheers. [/IMG] [][/IMG] [/IMG] [/IMG] [/IMG] [/IMG]
  23. Hello, am I in the right place for the contest?
  24. I'm finding that exporting a displacement map is not getting the results needed. As you can see in the picture from Blender, the displacement map is all pixelated and useless really -- it doesn't add any additional depth or anything. What am I doing wrong in this process? Here is my workflow: 1. Unwrap object 2. Retopo room > file > export retopo object 3. Retopo room > bake > bake into normal map for per pixel 4. Paint room > textures > texture baking tool 5. Input: Choose the .obj exported from step 2. Thanks much in advance! Here is a link to the .3b file.
