Showing results for tags 'automap'.
    • Basics & Interface
    • Questions & Answers
Found 2 results
  1. Automap UV feature is fantastic, very impressive results in testing. Only issue similar to other automap softwares is small islands, sometimes these are single triangles. This usually seems to be because algorithm does not take into account size, only other metrics like angles? A min triangle or cluster radius would help. This could be separate from automap and just another uv tool that looks over existing seams/islands and merges/welds small island to neighbouring ones. This is useful for avoid many islands on small noisy areas of mesh. Maybe it will need some cuts and islands in areas like this, however main advantage of automatic uv feature for me is making UV islands of the bigger broader shapes/volumes. Provides a good starting point. Presently either do manually or have to cleanup hundreds of islands. One mesh have 3k islands but only about 200-500 are reasonable size the rest need to be removed/merged. EDIT, sorry just notice on mobile there is feature request section, could this thread be relocated there please? http://3dcoat.com/forum/index.php?/forum/14-feature-requests/
  2. This auto uv map feature 3D coat looks very good! One small issue was in noisy areas of mesh it made many small islands, I am wanting to just uv unwrap the broader/bigger surfaces automatically as a starting point. Is there anyway to control the result so that islands must be of a min size/cluster? Or must I go through afterwards and find all these tiny islands to merge/weld them back manually afterwards?
