Showing results for tags 'bridge'.
Found 4 results
  1. From the album: Wojtek Kapusta - finished works
    My another work with 'ugly guys and ancient mech' story. They sneakly conquered him and now are returning home greeted by the headman and whole tribe. Special thanks to Jacek Babinski for some valuable tips to this art.
  2. If you have a hole that is not a usual hole shape(eg an L or U, a line shape hole if you will) these seem to have problems closing, especially so if you have a ring shape hole with outer and inner surface(within the same volume) and you want to merge/connect them as a single mesh, understandably this is something tools like fill holes and poly remove(with remesh after) seem to struggle with. In addition to that, if I have a surface with the edge chipped of, like... ___n___ where the n is missing data, I have noticed poly remove with remesh enabled also can struggle here. How do you go about closing/extending? I have tried booleans in the past with varied success, the muscle brush has worked the best requiring some extra cleanup work after, but struggles in some situations giving failed boolean operation often.
  3. In the sculpt room with Surface mode, I imported a mesh(too high for retopo room), there is a long line that is pretty much like a ring cut out, like a hole but with a surface within that hole. Close hole and other tools that would usually work in this case have trouble due to the extra surface within the "hole", how does one repair this? I have not had much luck with bringing the vertices together and welding/merging them. Some sort of way to pull verts/edges(pose tool or move seem to sort of work for this) then get the edges from both sides connecting(doesn't seem to be a snap/weld verts that works?) and flattening them in some way that they could combine into a planar surface, then repeating this to manually repair? Most of the approaches seem possible in the retopo room, any reason they're not available for Sculpt room? I noticed some brushes/tools have a real-time detection merge option but this didn't seem to work. My current solution has been adding a primitive cube that's been scaled and positioned to bridge the two sides, boolean add, tangent smooth to flatten it, deleting the sides of the bridged surface, and relaxing/remeshing the bridging surface(start/end have denser topology from flattened sides). If I repeat that process I can have better luck with tools for closing/patching the holes as it is more recognizable as a hole(doesn't handle it well if there are angles to the hole).
  4. Wojtek Kapusta
    the Fall
    Personal piece done for Jama Jurabaev's Intro to 3D Concept Design course. I'm trying to establish most productive workflow for myself. I left any external renders out... I started from pure 3d-Coat render as a base for my scene.
