Showing results for tags 'crash on start up'.
  1. dcortez96
    Virtual Memory Issue
    Hello! I'm encountering an issue with 3D Coat where I am unable to even start the program before I get a message claiming that I'm out of virtual memory and that I should increase the amount of virtual memory in my system settings. It's weird because I wasn't getting this error before when I used the program last month. Now all of the sudden it appears out of nowhere. So I uninstalled the current version I was using, and I went and installed the latest version of Coat, but I still got the same result. I even went and tried to increase the amount of virtual memory like the error message suggested, but that didn't work either. Does anyone have a possible solution to this issue? Thanks in advance. A couple pointers: I'm not using the Steam version of 3DCoat I'm making sure to use the 64 bit DX version I tried the OpenGL version too, still got the same "out of virtual memory" error message The message appears immediately after the splash screen when starting up the program, I'm not opening a file or anything My gpu is an Nvidia Geforce 1060 6gb I have 16gb of ram, and an intel i7 6700 processor
