Showing results for tags 'freezing'.
Hi, I'm trying to freeze some geometry (voxel) but with hard edges, it is possible with brush but when I try to select something with box, circle etc tool it is smoothed out. The same happens with pose tool. Is there a way to disable smoothing? Or this is a bug?
[Solved] Black screen and freezing with in 5 minutes
mrpastabomb posted a topic in SOS! If you need urgent help for 3DCoat
Hey there, Please help! 3DCoat gives me a black screen and locks up my computer usually within 5 minutes of painting. When this happens my computer is still on however, not responsive. The monitors lose its signal and the power button, keyboard, and mouse are not responsive. I have to disconnect the power cable from the computer and reboot to resume functionality. I would say, it may be my project file but the issue occurs even with a clean new project containing one mesh and one layer of paint. Within 5 minutes, computer locks up. None the less, here are my project details to hopefully help troubleshoot: 13 paint layers, one of which was projected. I'm working with 3 objects that have 4k textures each. The total poly count for all objects is 708k. I have zero lag during viewpoint navigation and painting. My computer seems not strain before it crashes. To troubleshoot I've tried these versions of 3DCoat yet I still get the black screen: 3DCoat-V4.8.40(GL64) 3DCoat-V4.8.40(DX64) 3DCoat-V4.9.02(GL64) 3DCoat-V4.9.02(DX64) 3DCoat-V4.9.03(GL64) 3DCoat-V4.9.03(DX64) I'm running the latest update for Windows 10, version 1903. Here are my hardware specs: AMD Ryzen Threadripper 2950X 3.5 GHz 16-Core Processor 64GB RAM G.SKILL GeForce GTX 1080 Ti SC Black Edition 2 1TB M.2 Samsung 970 PRO Series X399 MSI Extended-ATX Motherboard Any help would be appreciated. Thanks!- 4 replies
- black screen
- freezing
(and 3 more)
Hello all, Before I did not have this problem, but now 3d Coat freezes my computer and the only way out is to shut the computer down and start new, this is in surface mode. Both openGL64 and the Dx version 4.7.06 gives me this trouble :-( Even a restart would not work. I attached a screencap of the memory taken by my loaded model. Surely this should not be a problem right? Many thanks, Robert
