Showing results for tags 'glass'.
Hello! These are free glass materials, 3 options. They are very simple, do not judge strictly. I will accept constructive criticism! Have fun! Free Glass Materials
my first glass attempts in 3D-Coat: ClearGlass.3dcpack IMPORTANT: Make sure Layer 0 opacity - 25% or lower! then on layer one (or any other layer above 0) use the glass material. make sure the material is on 100% opacity but the layer opacity is on a low % (me = typically choose 15% or less) --- message me if you = need any help sorting it out :]
- 15 replies
- 4
- glass
- transparent
- (and 10 more)
Hi, can someone tell me what is wrong with 3D-Coat transparent/translucent shaders? Trying to use glass like shader and allways get some weird view issues, no matter if it's a viewport or render room. 3D-Coat doesn't show layer/object that is directly behind glass, instead it shows layer that is behind the layer that is directly behind glass!?
- 4 replies
- 3dc
- translucent
Hello! How can i make glass PBR smart matterial>? Can anybody share it with me?
Hi guys! I am losing the will to live with my potion bottles. The model was created in 3DS Max, I have the outer model which is the bottle and an inner model which is the liquid. To see through the bottle, I have been creating a glass layer with a chrome texture, lowering the opacity of the layer to 20% and then hiding layer 0. It works, but also comes with an immense amount of problems, (see below). As shown in the images, the potion bottles seem to make other parts of the model transparent when looking through at certain angles, it clips out the majority of the inside model (the liquid), and just looks completely messed up. Any help is appreciated! Thanks so much.
- 12 replies
Anybody know how to make glass? Tansparent glass but with a visible edge.
Sladus posted a topic in General 3DCoat
I want to make a globe for a lamp I made. So I need it transparent but with visible surface. -
From the album: glass art
done with Andrews new radial symmytry feature and Andrews perfect glass and made with the help of Andrews 3d fly camera Andrew you are ..........aw----some!© Public-Domain (because opensource rocks)
- 3 comments
- radial symmetry
- glass
(and 3 more)
From the album: Pix Jigsaw
Modeled and painted and rendered in 3D Coat. All the shapes were formed initially with the lathe and move tools. A little post work to add some mood and interest to the render.© Pix Jigsaw
a glass tree made with 3dcoats internal render thanks to the new bug fix in version 4.005 this fix allows all transparency faces to be sorted thus giving good artifact free transparency© public domain
- glasswork
- transparency
The current opacity setting in the shaders relies on a blocky face sorting method witch introduces square artifacts into glass with undercuts see atached The thing is this would be fine except there are some models to big for any program other than 3d coat to open, that means this program is the best in the world and has to be held to a very high standard please comment if you would like to see this fixed too emailing Andrew wont hurt either
- glass
- transparency
