Showing results for tags 'improvements'.
    • Resources
    • Marketplace
    • Contest
Found 4 results
  1. @Andrew Shpagin I have some suggestions about, well, pretty much basic functionalities in 3DCoat Ui. Lets start: - Extensions creation - add an option to select multiple presets at once with SHIFT. That's very basic functionality, that is pretty widely implemented in apps and operating systems. Selecting every position separately is pretty annoying and time consuming. - Presets panel - allow to move, export, delete multiple presets at once. Pretty much the same situation as above - really basic functionality. - Shaders/Smart Materials panels - allow to move, delete multiple items at once... - Alphas, models, splines, stencils, etc. - same situation... - Render presets - add separate panel for render presets/camera shortcuts. Presets panel gets pretty messy with all that stored along brush presets and necessity to delete that stored ***** one by one is damn annoying. Also, when it comes to 3DC 2023 - tool panels covering/intersecting with Camera nad Navigation bar or whatever it's called(check screenshot), it's another little annoying glitch/behaviour in 3DC Ui. All the things listed in this post are long standing and never addressed, as far as I'm aware, which is hella weird, as those are really BASIC things.
  2. Hello. I would like to strictly in the modeling room (because I know the sculpt room would take a massive overhaul to implement) have Non destructive booleans. Im not sure about the memory footprint of 3d coat and how heavy it is currently but I did have an idea for implementing this. It would require new features added to the poly groups. Right now the only option you have for poly groups when right clicking is to change the color reference. You also cant parent poly groups. The ideal workflow though should be similar to zbrush where it automatically creates a new "Subtool" for you whenever you want to add more geometry. I know there is a boolean feature when using the primitive tools but this should be something that has to be triggered by the user. For me when I'm blocking out I like to add shapes quickly and I dont want to have to deal with them creating their own booleans by default anyways when I hit the apply button I would rather have something similar to every other program where booleans are something you must explicitly turn on. I do want new geometry to automatically add itself to a new poly group. Now this will require some added functionality written into the polygroups. Something similar to how the sculpt tree works in sculpt mode where you can ctrl or shift drag a layer on top of another to activate a boolean. What I think would be even cooler is if you could make a polygroup a child of another polygroup layer and have right click options on the child layer to set it to "Union, Subtractive, Intersect" This way the parent geo would know that its child is affecting it in a specific way and could render properly based on that. In theory this should allow users to move these children using the transform tools and have an update be triggered on the parent. I should also add that there should be by default no booleans when parenting on only toggled on by a right click menu. This way you could easily merge object together but still keep them housed in there own groups. I wonder if this is possible to try and implement with the scripting api's.
  3. I absolutely despise having to hunt for my files in my labyrinthine PC directories every time I want to export. It takes like 1-3 minutes and I export A LOT. Remove the damn thing and bring back the old file explorer where I can paste the directory to my current working folder! REMOVE THIS!
  4. Just a Brief vision of 3D coat- these are hopefulls : NB: These are my TOP Hopefuls Time Line - For animation and Deformers over time Effectors/Deformers - Allowing Gravity/Wind/Forces to affect your mesh (flapping flag for example) and the Freezing of time to capture geometry Rendering Support - The ease of use with Redshift/V-Ray/KeyShot/I-Ray etc. E - Brush Panel and Symmetry Panel - Allow it to be a popup window or dockable. Smart Windows - When you select a tool, the appropriate windows arrange themselves. Ex - Selecting the Spline or Curves Tool, will load up the Spline Window (this means you can customize the Windows when a tool is used for example), then selecting the CutOff Tool, will bring up the Brush Panel. Smart Tool - From the Above, Customizing the Brush display windows options. Eg Click a Brush, then you can 'customize' what windows will show (tick mark the windows requested) - Ex. Click Tool and Windows A, G and Z are pushed forward or switched too. Live Clay + Surface - Surface tools have a live clay tick-box or universally ON button - allowing Surface tools to AUTO create it's mesh. Bones and Rigs - To allow Deformation in the Mesh and Character rigging in Game Engines and Animation software. Live Training on Twitch.tv - And YouTube streaming. This is an amazingly missed opportunity. Not are you missing on Sales, but Also exposure. 3D Coat still has major advantages over your directly Completion Zbrush - Yet ZBrush is MORE popular and it's not because of Zbrush's ease of use. Auto-Rotate Mesh Keys - Using the Arrow keys on your keyboard - Ex. Press left and the Camera / Model Rotates Left, Hold Ctrl to Move Left - this continues until you push on another Arrow key. I did get suckered into buying a 3D Connection Mouse - it's expensive but it doesn't fit the 3D Coat ecosphere, and I say that because 3D Coat is very much Shortcut key based, I have on hand on my Wacom, another on my keyboard and my third hand on my 3D mouse. There is a lesson to be learned here, which I will put in my next Hopeful. Quick Access One Touch Multi-options - While the Space Key is Awesome, I would love to see it implemented in our own menus and not just the space bar, Right Mouse button and multiple mouse button access. While having the Custom Brush panel is great. I would love to see more such menus that can be accessed via shortcut keys or mouse or controller keys. Curves and Splines - Bright Ideas or Bad Ideas: Better then Voxels and Surfaces? How is a Curve made? It isn't dependent on Resolution, all Sculpts are curves, and Curves are "interpolated" between each other. Could this be the future of Sculpting? No need to worry about Resolution? Ex. The cut off and Vox Hide tools - basically the Curve/Spline version of that would be the same, but instead of cutting into a mesh, you would be creating a tunnel instead, your not removing Polys/Voxels, it would be defining the curve shape to be created. This would mean that a Sphere would be the most simple of objects as it's Curves are uniform in all 3 directions. It would mean, no need for Base voxel counts of 1 Million Tris or more, to get good clean cuts. It would mean no Polygon Stretching as there are no Polygons, only Interpreted Line/Curves. You would retopo it for a High Density Mesh, that can be painted and UV Maped, while making a 'game'/basic mesh for such details to be baked on. Vector Graphics vs Bitmap. I've droned on enough. This is an out-there thought - some other software use only curves, yet they have no Cutoff, Move and Pose Brushes/tools. Conclusion: This is a list of Hopefully's - I may have missed some. Side Note: Blender has become a force of nature for the 3D world, beating Most 3D creation software in Rendering speed, the amount of add-ons make it extremely powerful. Will 3D coat push more towards Blender for Rendering/Animation/Rigging side? I purchased this Software for 2 Reasons: So much easier then ZBrush and because of 2 Youtubers: AlienMindfield and PolyToots - The Perfect demonstration of the Ease of use of 3D Coat. AlienMindfield's 2016 (yes 4 years ago) is still the most up-to date Tool tutorial out there. AlienMindfield - https://www.youtube.com/channel/UCXEHbpkKRdBMdavLQzogyxw and PolyToots https://www.youtube.com/channel/UCGQVeHxXnvjFlU-bnrVv-OA I would love to hear from the DEVS what they have for the future
