Showing results for tags 'link'.
Found 3 results
  1. Hi, can anyone help?! So I've been working on a character for a while and I've just finished texturing it in 3DCoat. I have had to work on it in 3 different 3Dcoat files (Body, Armour and Boot) so my machine can handle it. I've wanted to move it in to blender to start rigging and add hair particles, so I've been using the 3DCoat Blender app link. For the most part it works perfectly accept for some certain objects. As you can see from the photos I've uploaded below in blender, the knuckle guards parts of the skin and the belt have weird texture errors. However when you look at them in 3dCoat there doesn't seem to be any errors. I've uploaded images of my export to blender settings to see if that could be the issue. Can anyone see what's causing this error and how to fix?! Much Appreciated
  2. Hey everyone, I have 3 doubts: 1) Saving a mesh or object from VoxTree in 3b format. Can this 3b object keep all the work done on layers of sculpture related to it? In the test I did, the 3B file does not save sculpt layers relating to the mesh of the VoxTree layer that I saved in .3b when I import this .3b file. With you, do the same thing happen? ---------------------------------------------------------------------- 2) I was thinking of separating objects from VoxTree (dismember the project into mini projects) where the main file could be lighter and smaller ( just a container for the mini files .3b files that are part of the same project ). An example would be a sculpture of a character. I separated in the Vox tree : * Character Container |_ character mesh |_ Clothes |_ Accessories. I would like to do something similar to what happens in the Blender program. Having a main file and in it I would use the Append or Link method as needed. When I worked on a 3b mesh and saved, it would automatically modify file 3b. and in the main project this file would be updated and modified. Could I do something like that? ------------------------------------------------------- 3) You could kindly indicate to me an open source or free program so that I can fully organize myself in my private projects in the sense of task and asset management, calendar and etc (preferably it is just a single program for better usability). The program I was testing was Redmine, but it's complicated in upgrades and stuff. I also saw an opensource program called Tactic, but I did not understand anything, very complicated and I did not find any video that would explain the running beginner users like me. thank you
  3. Please consider adding a report bug link from the help menu in 3DC. I realized this today, as I was looking for the Mantis page again. If this is the preferred method for reporting bugs, it should be linked from the program, the same way the manual is.
