Showing results for tags 'locks up'.
Found 2 results
  1. Hey there, Please help! 3DCoat gives me a black screen and locks up my computer usually within 5 minutes of painting. When this happens my computer is still on however, not responsive. The monitors lose its signal and the power button, keyboard, and mouse are not responsive. I have to disconnect the power cable from the computer and reboot to resume functionality. I would say, it may be my project file but the issue occurs even with a clean new project containing one mesh and one layer of paint. Within 5 minutes, computer locks up. None the less, here are my project details to hopefully help troubleshoot: 13 paint layers, one of which was projected. I'm working with 3 objects that have 4k textures each. The total poly count for all objects is 708k. I have zero lag during viewpoint navigation and painting. My computer seems not strain before it crashes. To troubleshoot I've tried these versions of 3DCoat yet I still get the black screen: 3DCoat-V4.8.40(GL64) 3DCoat-V4.8.40(DX64) 3DCoat-V4.9.02(GL64) 3DCoat-V4.9.02(DX64) 3DCoat-V4.9.03(GL64) 3DCoat-V4.9.03(DX64) I'm running the latest update for Windows 10, version 1903. Here are my hardware specs: AMD Ryzen Threadripper 2950X 3.5 GHz 16-Core Processor 64GB RAM G.SKILL GeForce GTX 1080 Ti SC Black Edition 2 1TB M.2 Samsung 970 PRO Series X399 MSI Extended-ATX Motherboard Any help would be appreciated. Thanks!
  2. Hi Guys, I'm not sure if anyone has had the same issue i was recently suffering from, which was 3d Coat Failing to load after being executed more than once. White screen program hang. After 48 hrs of investigation into the problem it turns out the program got stuck in a Wait Chain, something with the Network I/O. Disabling my LAN by passed the problem and 3d Coat loads everytime without fail. Hopefully this will help others with this potential problem, and a future fix! (I'm using Windows 7 x64) Cheers, Alex
