Showing results for tags 'low poly'.
Latest tutorial building a basic temple structure in the modelling room. Aimed at beginners, with the modelling room being fairly new in 3DC 2021, this will hopefully help to get started. https://youtu.be/OOpIml3giaM
Hello. I am attempting to do a texture bake from high to low, although the topology and UVs are quite different. I watched through the texture baking tool video several times, but maybe I am missing a step. Or, maybe this is just the limit of the tool? The overall shape and dimension of the two are the same. Ive attached screens of my low poly, high poly and the resulting texture. Low Poly reference mesh.
- 4 replies
- texture bake
- low poly
Hello ! I have this problem at importing a mesh. In rhino is ok shaped and I export it as obj or stl. This is the model in rhino. This happens when I import is as OBJ... mesh is changed... new polygons appears but the details are kept like the initial model. Only mesh is in addition. Why ? AND this is when I import as STL... NO addition but the details are hardly affected and the mesh looks awful.. After the RES+ for STL imported it looks like this... What can I do ? I want to import a clean model for surface detail modelling ? Can anyone help me ? Thank you !
Hi, I want to try to create a hairstyle in sculpt mode using planes. I tried the Curves tool but there is no option to create flat plains. Or is it? Do you have any idea how to achieve something like this (just the hair):
MAR-z0 is 3d low poly model maked in spare time. I had a friend he liked very much “Toki”. MAR-z0 is an acronym that recalls its name. 3D-Coat haved a lot importance for creation model. I have retopogized from hi-poly model, texturized, baked and render. I think about 3D-Coat is one of best software for this. I try now to improve my skills for sculpt but is not simple... I arrive from ZBrush. ;-)
Hi everyone, Here is a tutorial for those who are curious and want to start animating in Blender. You can find the other parts in my channel. Thanks!
Here is the process of creating a low poly skeleton and making sure we get the most important features of each bone. Thanks For Watching!
An Octopus Rig - Part 02 (Eyes Shape Keys)
Gabriel Aguiar posted a topic in CG & Hardware Discussion
Hi everyone, Here is a tutorial for those who are curious and want to start animating in Blender. You can find the part 01 in my channel. Thanks! -
Hello everyone, Here is a tutorial for the more curious ones, that will help to get into animation with a nice Pirate-Chest! Thanks For Watching!
Hello everyone, Here is an easy process to create a nice Lowpoly Skull! Thanks for watching!
- low poly
- game asset
(and 5 more)
I've been working on a car from Mad Max, the War Boys "Elvis". I've got quite a bit of a done already, and posting it on The Foundry forums, now that I'm using 3DC for some of the assets, here we are. I'll try to update this thread when I update the TF thread as well. All modeling done in Modo, except for the seats, which I sculpted in 3DC. Retopologized and baked the normal map in Modo. I'm pretty much done modeling the engine, the body and interior. I am now moving on to the .50 cal..
From the album: "Elvis" War Boys Car/Mad Max
Finished modeling portion of "Elvis"© Javis Jones 2016
- apocalypse car
- fan art
- (and 4 more)
Interior /w Seats and the door ripped for easier viewing.-
- apocalypse car
- fan art
- (and 4 more)
So I merged multiple 3D Coat files into one scene. When I press 6 (low poly on), everything is positioned correctly, but when I press 6 again (low poly off) it changes the position of the objects. I'm trying to get everything positioned correctly for the Render room. Is there a way to get the high poly objects to go to the same position as the low poly ones without moving everything in the transform room part by part?
- importing multiple objects
- render room
(and 3 more)
Another death trap for FFX Runner Undead Rods. Textured in 3D-Coat http://ffxrunner2.ffx.it/rigging-the-disk/
- 1
- ffx runner Undead rods
- low poly
Hello. I have a low poly model and i'm trying to figure out how can i paint in 3D Coat without constantly fix everything in photoshop. I have this model that the uv was made with half the mesh and then applied symmetry, overlapping shells. the problem is that the 3D Coat brush is horrible to paint over any seam, even those that do not overlap have some sort of problem already tried to send one overlapped shell to 1-0 (no overlap, each shell in a UV room) and still the problem persists I am using 2048 texture size what am i doing wrong? how to avoid such problems with this UV type and seams?
- per pixel paint
- seam
(and 3 more)
how would further reduce the poly-count of an already textured and retopoed mesh? its already quite low poly, but how can i make it even more low poly? can i perhaps do a kind of 2nd retopo? if so, how? ty
