Showing results for tags 'paint room'.
  1. Hello, I've been using 3D-Coat for a good while now but I've never run into an issue quite like this. When I import this particular model that I've been given to texture, I noticed that there were these strange diagonal bands in the texture editor. I didn't think much of it at first but when I paint with depth information, the depth gets applied at maximum strength when inside these bands regardless of what the brush strength is. This only seems to happen with this particular model. I've included the .obj version, but I can't figure out what aspect of the model may be causing this. The bands don't seem to correlate with any of the edges on the model. There is only 1 UV set on the mesh (I've checked it in 3ds Max, Blender, and Maya, all showing the same thing). The problem occurs regardless of whether I export it as a .fbx or a .obj. This problem occurs with this model in both 3D-Coat 4.5 and 4.7 regardless of the texture resolution I specify when I import the model for per-pixel painting. Any ideas on what might be causing this? You help is much appreciated! HumanShip01_Arm.obj
  2. Hi, I've been using 3D coat for about a month now, i'm fairly new to 3D modelling in general so i hope i'm running into a newbie issue that can get answered easily. I'm at my wits end. The context is that i'm trying to clean up a 3D model i scanned in. Here is my workflow that pretty much follows the YouTube series: Import into the Paint room Import mesh (obj file) into the Sculpt room as a surface object so that it keeps the texture I clean up the model switching between surface and voxel objects [Issue/Question 1] When i AUTOPO what layers should be visible in the Paint room? The initial layers that appeared on first import still contain all the bumps and edges that i cleaned up so when i AUTOPO for some reason it captures the old model. So i've turned off the original layer other than the UV layer because that keeps the texture... is that correct? After i retopologize, mark out the new UV, unwrap the UVs i bake with Normal map [Issue/Question 2] Here is when things start to fall apart Firstly, I don't understand what all the layers are in the paint room (see screenshot). I'm guessing that some of them are from the original import so can i delete them? Also, what is the Volume4 layer? Secondly, when i switch to a Flat Shader and hide the object in the VoxTree my model looks pixelated. It's only when i use a Smooth Shade it stops being pixelated Thirdly, i can't seem to paint on either the model or the UV consistently. It's as if there is a layer on the model that is stop me from painting on the model or UV... Like i said, i really hope i'm doing something stupid because i do enjoy using 3D coat but i can't seem to find any answers to these issues. Thanks, Gwan
  3. Hi I'm using 3D Coat version 4.7.24. In the paint room when I select the Fill tool and then set it to gradient mode (Tools Options) the control nodes do not show. I can edit the placement by typing numbers in the fields next to Point1 and 2 but unlike before I don't not have access to the nodes in the view port. Is there something I have to unhide, or is it another issue. Thank you
  4. I imported my .obj file as "Model per Pixel Painting" into Paint Room. How can I transform it to onto top of the grid and create a base plane below it to prevent the object from "floating" in the Render Room ? TIA, Oliver.
  5. In Paint Room : When using custom made Alpha Brush able to move center pick point ( the white dot that makes it active ) off center . or be able to pre pick where you want it to be. ( This is alpha brushes mostly when I use a photo) . Also would like the option for it to be square when picked instead of round . I am sure there is a name for the tiny white dot / cursor ??? I don't know it.
  6. I am working in the paint room on my second project, and I have been having nothing but troubles with 3d coat crashing when using the polygonal paint selection brush. I am not sure if this is a bug with the polygonal paint brush, or it is a file corruption, as I did not use this brush in my first project. However, as soon as I make longer polygonal strokes, that is when I would get a warning, stating that the program has become unstable and is recommended in saving your work. Once that is complete the program crashes. Here is my last crash report, and I am including my project file. Version:3D-COAT 4.7.06(DX64) Memory status: OK pointers: 53386 Video: Intel(R) HD Graphics Family Intel(R) HD Graphics Family Intel(R) HD Graphics Family nproc: 4 (1)object: (C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub_painting.3b) vert: 128 poly: 0 rt:256x256 undo: (5) LPUS LPUS LPUS LPUS tool: StdPen NumMeshLoads: 1 Time since mesh loading: 872 s VoxelTool: 0 RetopoTool: 3 UV_Tool: 1 D2ABF11A c:\3dcoat\3d-coat\3d-coatv4\3d-coat\penshape.cpp line 6709 [+25], CurveBuffer::CreateCurveBuffer+2058 D2CDD3DD c:\3dcoat\3d-coat\3d-coatv4\3d-coat\surfacemodificator.cpp line 1246 [+22], SurfaceModificator::CreateRectPick+2653 D2CCD109 c:\3dcoat\3d-coat\3d-coatv4\3d-coat\stdpen.cpp line 127 [+0], StdPenTool::OnRectSelectionEnd+73 D241AD1E c:\3dcoat\3d-coat\3d-coatv4\3d-coat\basictool.cpp line 3182 [+0], BasicTool::ProcessTools+4430 D2B3FCA8 c:\3dcoat\3d-coat\3d-coatv4\3d-coat\polymesh.cpp line 15174 [+0], MainCycle+10584 D300ACEE c:\3dcoat\3d-coat\3d-coatv4\main.cpp line 137 [+5], comms::cMain_OnRender+718 D2FAD7F4 c:\3dcoat\3d-coat\3d-coatv4\comms\cwinmain.cpp line 534 [+0], cWinMain_OnRender+180 D2FB4A07 c:\3dcoat\3d-coat\3d-coatv4\comms\cwinmain.cpp line 2438 [+0], cWinMain_OneIterationOfMessageLoop+199 D2FB68B9 c:\3dcoat\3d-coat\3d-coatv4\comms\cwinmain.cpp line 2720 [+14], WinMain+6521 D30301F8 f:\dd\vctools\crt\crtw32\startup\crt0.c line 251 [+17], __tmainCRTStartup+328 0C348102 line 0 [+0], BaseThreadInitThunk+34 0E60C5B4 line 0 [+0], RtlUserThreadStart+52 0E60C5B4 line 0 [+0], RtlUserThreadStart+52 General information: Exception code:C0000005 3D-COAT 4.7.06(DX64) Memory status before run: Memory load: 36 TotalPhys: 2074238976 AvailPhys: 4020043776 TotalPageFile: 1000497152 AvailPageFile: 2947485696 TotalVirtual: 4294836224 AvailVirtual: 4100616192 Memory status after crash: Memory load: 45 TotalPhys: 2074238976 AvailPhys: 3439591424 TotalPageFile: 1000497152 AvailPageFile: 2285056000 TotalVirtual: 4294836224 AvailVirtual: 3210690560 AvailVirtual: 3210690560 Module found C:\Program Files\3D-Coat-V4.7.06\3D-CoatDX64C.exe (\3D-CoatDX64C.exe) Handle: 00007FF6D17F0000 Base address: 00007FF6D17F0000 Module found C:\WINDOWS\SYSTEM32\ntdll.dll (ntdll.dll) Handle: 00007FFB0E5B0000 Base address: 00007FFB0E5B0000 Module found C:\WINDOWS\system32\KERNEL32.DLL (KERNEL32.DLL) Handle: 00007FFB0C330000 Base address: 00007FFB0C330000 Module found C:\WINDOWS\system32\KERNELBASE.dll (KERNELBASE.dll) Handle: 00007FFB0B400000 Base address: 00007FFB0B400000 Module found C:\WINDOWS\system32\USER32.dll (USER32.dll) Handle: 00007FFB0BB60000 Base address: 00007FFB0BB60000 Module found C:\WINDOWS\system32\GDI32.dll (GDI32.dll) Handle: 00007FFB0CC20000 Base address: 00007FFB0CC20000 Module found C:\WINDOWS\system32\COMDLG32.dll (COMDLG32.dll) Handle: 00007FFB0BA50000 Base address: 00007FFB0BA50000 Module found C:\WINDOWS\system32\msvcrt.dll (msvcrt.dll) Handle: 00007FFB0B9B0000 Base address: 00007FFB0B9B0000 Module found C:\WINDOWS\system32\combase.dll (combase.dll) Handle: 00007FFB0BEB0000 Base address: 00007FFB0BEB0000 Module found C:\WINDOWS\system32\RPCRT4.dll (RPCRT4.dll) Handle: 00007FFB0BD70000 Base address: 00007FFB0BD70000 Module found C:\WINDOWS\system32\bcryptPrimitives.dll (bcryptPrimitives.dll) Handle: 00007FFB0B920000 Base address: 00007FFB0B920000 Module found C:\WINDOWS\system32\shcore.dll (shcore.dll) Handle: 00007FFB0B340000 Base address: 00007FFB0B340000 Module found C:\WINDOWS\system32\SHLWAPI.dll (SHLWAPI.dll) Handle: 00007FFB0CAF0000 Base address: 00007FFB0CAF0000 Module found C:\WINDOWS\system32\SHELL32.dll (SHELL32.dll) Handle: 00007FFB0CE20000 Base address: 00007FFB0CE20000 Module found C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.10586.494_none_a2d8b04ea53e3145\COMCTL32.dll (WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.10586.494_none_a2d8b04ea53e3145\COMCTL32.dll) Handle: 00007FFB000A0000 Base address: 00007FFB000A0000 Module found C:\WINDOWS\system32\cfgmgr32.dll (cfgmgr32.dll) Handle: 00007FFB0B8D0000 Base address: 00007FFB0B8D0000 Module found C:\WINDOWS\system32\windows.storage.dll (windows.storage.dll) Handle: 00007FFB0AC60000 Base address: 00007FFB0AC60000 Module found C:\WINDOWS\system32\advapi32.dll (advapi32.dll) Handle: 00007FFB0BCC0000 Base address: 00007FFB0BCC0000 Module found C:\WINDOWS\system32\sechost.dll (sechost.dll) Handle: 00007FFB0C2D0000 Base address: 00007FFB0C2D0000 Module found C:\WINDOWS\system32\kernel.appcore.dll (kernel.appcore.dll) Handle: 00007FFB0AC50000 Base address: 00007FFB0AC50000 Module found C:\WINDOWS\system32\powrprof.dll (powrprof.dll) Handle: 00007FFB0ABF0000 Base address: 00007FFB0ABF0000 Module found C:\WINDOWS\system32\profapi.dll (profapi.dll) Handle: 00007FFB0ABD0000 Base address: 00007FFB0ABD0000 Module found C:\WINDOWS\system32\FirewallAPI.dll (FirewallAPI.dll) Handle: 00007FFB0B2B0000 Base address: 00007FFB0B2B0000 Module found C:\WINDOWS\system32\NETAPI32.dll (NETAPI32.dll) Handle: 00007FFB0B990000 Base address: 00007FFB0B990000 Module found C:\WINDOWS\system32\ole32.dll (ole32.dll) Handle: 00007FFB0E3B0000 Base address: 00007FFB0E3B0000 Module found C:\WINDOWS\system32\OLEAUT32.dll (OLEAUT32.dll) Handle: 00007FFB0C3E0000 Base address: 00007FFB0C3E0000 Module found C:\WINDOWS\system32\WS2_32.dll (WS2_32.dll) Handle: 00007FFB0CDB0000 Base address: 00007FFB0CDB0000 Module found C:\WINDOWS\SYSTEM32\DAVHLPR.DLL (DAVHLPR.DLL) Handle: 00007FFB05D90000 Base address: 00007FFB05D90000 Module found C:\Program Files\3D-Coat-V4.7.06\tbb.dll (\tbb.dll) Handle: 0000000180000000 Base address: 0000000180000000 Module found C:\WINDOWS\SYSTEM32\VERSION.dll (VERSION.dll) Handle: 00007FFAFEAB0000 Base address: 00007FFAFEAB0000 Module found C:\WINDOWS\SYSTEM32\d3d9.dll (d3d9.dll) Handle: 00007FFAE9460000 Base address: 00007FFAE9460000 Module found C:\Program Files\3D-Coat-V4.7.06\d3dx9_38.dll (\d3dx9_38.dll) Handle: 00000000644A0000 Base address: 00000000644A0000 Module found C:\WINDOWS\SYSTEM32\WININET.dll (WININET.dll) Handle: 00007FFAFA450000 Base address: 00007FFAFA450000 Module found C:\WINDOWS\SYSTEM32\dwmapi.dll (dwmapi.dll) Handle: 00007FFB07F10000 Base address: 00007FFB07F10000 Module found C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9177_none_08e695a3a83b6ce3\MSVCR90.dll (WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9177_none_08e695a3a83b6ce3\MSVCR90.dll) Handle: 00000000655B0000 Base address: 00000000655B0000 Module found C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9177_none_08e695a3a83b6ce3\MSVCP90.dll (WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9177_none_08e695a3a83b6ce3\MSVCP90.dll) Handle: 00000000643C0000 Base address: 00000000643C0000 Module found C:\WINDOWS\system32\IMM32.DLL (IMM32.DLL) Handle: 00007FFB0C130000 Base address: 00007FFB0C130000 Module found C:\WINDOWS\SYSTEM32\fwbase.dll (fwbase.dll) Handle: 00007FFB09A50000 Base address: 00007FFB09A50000 Module found C:\WINDOWS\system32\uxtheme.dll (uxtheme.dll) Handle: 00007FFB09730000 Base address: 00007FFB09730000 Module found C:\WINDOWS\system32\MSCTF.dll (MSCTF.dll) Handle: 00007FFB0C170000 Base address: 00007FFB0C170000 Module found C:\WINDOWS\SYSTEM32\igdumdim64.dll (igdumdim64.dll) Handle: 00007FFADA270000 Base address: 00007FFADA270000 Module found C:\WINDOWS\system32\SETUPAPI.dll (SETUPAPI.dll) Handle: 00007FFB0C4B0000 Base address: 00007FFB0C4B0000 Module found C:\WINDOWS\SYSTEM32\igdusc64.dll (igdusc64.dll) Handle: 00007FFB052F0000 Base address: 00007FFB052F0000 Module found C:\WINDOWS\system32\clbcatq.dll (clbcatq.dll) Handle: 00007FFB0E500000 Base address: 00007FFB0E500000 Module found C:\WINDOWS\system32\dataexchange.dll (dataexchange.dll) Handle: 00007FFAF4400000 Base address: 00007FFAF4400000 Module found C:\WINDOWS\system32\dcomp.dll (dcomp.dll) Handle: 00007FFB08C80000 Base address: 00007FFB08C80000 Module found C:\WINDOWS\system32\d3d11.dll (d3d11.dll) Handle: 00007FFB07C60000 Base address: 00007FFB07C60000 Module found C:\WINDOWS\system32\dxgi.dll (dxgi.dll) Handle: 00007FFB07BB0000 Base address: 00007FFB07BB0000 Module found C:\WINDOWS\system32\twinapi.appcore.dll (twinapi.appcore.dll) Handle: 00007FFB09630000 Base address: 00007FFB09630000 Module found C:\WINDOWS\system32\bcrypt.dll (bcrypt.dll) Handle: 00007FFB0AB00000 Base address: 00007FFB0AB00000 Module found C:\WINDOWS\system32\mswsock.dll (mswsock.dll) Handle: 00007FFB0A4A0000 Base address: 00007FFB0A4A0000 Module found C:\WINDOWS\system32\napinsp.dll (napinsp.dll) Handle: 00007FFAF88D0000 Base address: 00007FFAF88D0000 Module found C:\WINDOWS\system32\pnrpnsp.dll (pnrpnsp.dll) Handle: 00007FFAF88F0000 Base address: 00007FFAF88F0000 Module found C:\WINDOWS\system32\NLAapi.dll (NLAapi.dll) Handle: 00007FFB08BA0000 Base address: 00007FFB08BA0000 Module found C:\WINDOWS\SYSTEM32\DNSAPI.dll (DNSAPI.dll) Handle: 00007FFB09550000 Base address: 00007FFB09550000 Module found C:\WINDOWS\system32\NSI.dll (NSI.dll) Handle: 00007FFB0BEA0000 Base address: 00007FFB0BEA0000 Module found C:\WINDOWS\System32\winrnr.dll (winrnr.dll) Handle: 00007FFAF9B30000 Base address: 00007FFAF9B30000 Module found C:\Program Files\Bonjour\mdnsNSP.dll (Bonjour\mdnsNSP.dll) Handle: 0000000065660000 Base address: 0000000065660000 Module found C:\WINDOWS\SYSTEM32\Iphlpapi.DLL (Iphlpapi.DLL) Handle: 00007FFB083F0000 Base address: 00007FFB083F0000 Module found C:\WINDOWS\System32\fwpuclnt.dll (fwpuclnt.dll) Handle: 00007FFAFFE10000 Base address: 00007FFAFFE10000 Module found C:\Windows\System32\rasadhlp.dll (rasadhlp.dll) Handle: 00007FFAFE770000 Base address: 00007FFAFE770000 Module found C:\WINDOWS\system32\propsys.dll (propsys.dll) Handle: 00007FFB08860000 Base address: 00007FFB08860000 Module found C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll (Common Files\microsoft shared\ink\tiptsf.dll) Handle: 00007FFAF7A30000 Base address: 00007FFAF7A30000 Module found C:\WINDOWS\SYSTEM32\edputil.dll (edputil.dll) Handle: 00007FFAF44C0000 Base address: 00007FFAF44C0000 Module found C:\WINDOWS\SYSTEM32\policymanager.dll (policymanager.dll) Handle: 00007FFAFD510000 Base address: 00007FFAFD510000 Module found C:\WINDOWS\SYSTEM32\msvcp110_win.dll (msvcp110_win.dll) Handle: 00007FFAFD130000 Base address: 00007FFAFD130000 Module found C:\WINDOWS\system32\explorerframe.dll (explorerframe.dll) Handle: 00007FFAF2E40000 Base address: 00007FFAF2E40000 Module found C:\WINDOWS\system32\DUI70.dll (DUI70.dll) Handle: 00007FFAE92A0000 Base address: 00007FFAE92A0000 Module found C:\WINDOWS\system32\DUser.dll (DUser.dll) Handle: 00007FFAF9320000 Base address: 00007FFAF9320000 Module found C:\WINDOWS\SYSTEM32\WindowsCodecs.dll (WindowsCodecs.dll) Handle: 00007FFB076E0000 Base address: 00007FFB076E0000 Module found C:\Windows\System32\thumbcache.dll (thumbcache.dll) Handle: 00007FFAEFDF0000 Base address: 00007FFAEFDF0000 Module found C:\Windows\System32\Windows.Globalization.dll (Windows.Globalization.dll) Handle: 00007FFB00B00000 Base address: 00007FFB00B00000 Module found C:\Windows\System32\Bcp47Langs.dll (Bcp47Langs.dll) Handle: 00007FFB02480000 Base address: 00007FFB02480000 Module found C:\WINDOWS\SYSTEM32\globinputhost.dll (globinputhost.dll) Handle: 00007FFAF7450000 Base address: 00007FFAF7450000 Module found C:\WINDOWS\system32\xmllite.dll (xmllite.dll) Handle: 00007FFB06230000 Base address: 00007FFB06230000 Module found C:\WINDOWS\system32\OLEACC.dll (OLEACC.dll) Handle: 00007FFAFE840000 Base address: 00007FFAFE840000 Module found C:\Windows\System32\uiautomationcore.dll (uiautomationcore.dll) Handle: 00007FFAE9D50000 Base address: 00007FFAE9D50000 Module found C:\Windows\System32\USERENV.dll (USERENV.dll) Handle: 00007FFB0A330000 Base address: 00007FFB0A330000 Module found C:\WINDOWS\SYSTEM32\sxs.dll (sxs.dll) Handle: 00007FFB0AA00000 Base address: 00007FFB0AA00000 Module found C:\WINDOWS\SYSTEM32\atlthunk.dll (atlthunk.dll) Handle: 00007FFB05FA0000 Base address: 00007FFB05FA0000 Module found C:\WINDOWS\System32\StructuredQuery.dll (StructuredQuery.dll) Handle: 00007FFAFC1A0000 Base address: 00007FFAFC1A0000 Module found C:\Windows\System32\ActXPrxy.dll (ActXPrxy.dll) Handle: 00007FFAFAA50000 Base address: 00007FFAFAA50000 Module found C:\WINDOWS\system32\Windows.Storage.Search.dll (Windows.Storage.Search.dll) Handle: 00007FFAFBD80000 Base address: 00007FFAFBD80000 Module found C:\WINDOWS\system32\IconCodecService.dll (IconCodecService.dll) Handle: 00007FFAFC280000 Base address: 00007FFAFC280000 Module found C:\WINDOWS\system32\coml2.dll (coml2.dll) Handle: 00007FFB0CB50000 Base address: 00007FFB0CB50000 Module found C:\WINDOWS\SYSTEM32\MPR.dll (MPR.dll) Handle: 00007FFAFC8E0000 Base address: 00007FFAFC8E0000 Module found C:\WINDOWS\System32\drprov.dll (drprov.dll) Handle: 00007FFAF9B20000 Base address: 00007FFAF9B20000 Module found C:\WINDOWS\System32\WINSTA.dll (WINSTA.dll) Handle: 00007FFB0AAA0000 Base address: 00007FFB0AAA0000 Module found C:\WINDOWS\System32\ntlanman.dll (ntlanman.dll) Handle: 00007FFAF9B00000 Base address: 00007FFAF9B00000 Module found C:\WINDOWS\System32\davclnt.dll (davclnt.dll) Handle: 00007FFAF89A0000 Base address: 00007FFAF89A0000 Module found C:\WINDOWS\SYSTEM32\LINKINFO.dll (LINKINFO.dll) Handle: 00007FFAF6EC0000 Base address: 00007FFAF6EC0000 Module found C:\WINDOWS\System32\wkscli.dll (wkscli.dll) Handle: 00007FFB024F0000 Base address: 00007FFB024F0000 Module found C:\WINDOWS\SYSTEM32\cscapi.dll (cscapi.dll) Handle: 00007FFAFCBE0000 Base address: 00007FFAFCBE0000 Module found C:\WINDOWS\System32\netutils.dll (netutils.dll) Handle: 00007FFB09FE0000 Base address: 00007FFB09FE0000 Module found C:\Windows\System32\twinapi.dll (twinapi.dll) Handle: 00007FFAF5850000 Base address: 00007FFAF5850000 Module found C:\WINDOWS\SYSTEM32\apphelp.dll (apphelp.dll) Handle: 00007FFB093C0000 Base address: 00007FFB093C0000 Module found C:\Windows\System32\dlnashext.dll (dlnashext.dll) Handle: 00007FFAFCA60000 Base address: 00007FFAFCA60000 Module found C:\Windows\System32\PlayToDevice.dll (PlayToDevice.dll) Handle: 00007FFAF7900000 Base address: 00007FFAF7900000 Module found C:\Windows\System32\DevDispItemProvider.dll (DevDispItemProvider.dll) Handle: 00007FFAFC2E0000 Base address: 00007FFAFC2E0000 Module found C:\WINDOWS\System32\MMDevApi.dll (MMDevApi.dll) Handle: 00007FFB00740000 Base address: 00007FFB00740000 Module found C:\WINDOWS\System32\DEVOBJ.dll (DEVOBJ.dll) Handle: 00007FFB09600000 Base address: 00007FFB09600000 Module found C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.10586.545_none_d3c4a617ffcfbffc\gdiplus.dll (WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.10586.545_none_d3c4a617ffcfbffc\gdiplus.dll) Handle: 00007FFB02580000 Base address: 00007FFB02580000 Module found C:\Windows\System32\PortableDeviceApi.dll (PortableDeviceApi.dll) Handle: 00007FFB08A60000 Base address: 00007FFB08A60000 Module found C:\WINDOWS\system32\WINTRUST.dll (WINTRUST.dll) Handle: 00007FFB0B5F0000 Base address: 00007FFB0B5F0000 Module found C:\WINDOWS\system32\MSASN1.dll (MSASN1.dll) Handle: 00007FFB0AC40000 Base address: 00007FFB0AC40000 Module found C:\WINDOWS\system32\CRYPT32.dll (CRYPT32.dll) Handle: 00007FFB0B650000 Base address: 00007FFB0B650000 Module found C:\Windows\System32\EhStorShell.dll (EhStorShell.dll) Handle: 00007FFAEE3B0000 Base address: 00007FFAEE3B0000 Module found C:\Windows\System32\EhStorAPI.dll (EhStorAPI.dll) Handle: 00007FFAFA790000 Base address: 00007FFAFA790000 Module found C:\Windows\System32\WTSAPI32.dll (WTSAPI32.dll) Handle: 00007FFB089F0000 Base address: 00007FFB089F0000 Module found C:\Windows\System32\MrmCoreR.dll (MrmCoreR.dll) Handle: 00007FFB02D40000 Base address: 00007FFB02D40000 Module found C:\Windows\System32\iertutil.dll (iertutil.dll) Handle: 00007FFB010B0000 Base address: 00007FFB010B0000 Module found C:\Windows\System32\Windows.UI.dll (Windows.UI.dll) Handle: 00007FFB02730000 Base address: 00007FFB02730000 Module found C:\WINDOWS\System32\provsvc.dll (provsvc.dll) Handle: 00007FFAEE870000 Base address: 00007FFAEE870000 Module found C:\Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\FileSyncShell64.dll (Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\FileSyncShell64.dll) Handle: 00007FFAEE6D0000 Base address: 00007FFAEE6D0000 Module found C:\Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\MSVCP120.dll (Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\MSVCP120.dll) Handle: 00007FFAEE620000 Base address: 00007FFAEE620000 Module found C:\Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\MSVCR120.dll (Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\MSVCR120.dll) Handle: 00007FFAEE530000 Base address: 00007FFAEE530000 Module found C:\Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\LoggingPlatform64.DLL (Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\LoggingPlatform64.DLL) Handle: 00007FFAEE4F0000 Base address: 00007FFAEE4F0000 Module found C:\WINDOWS\SYSTEM32\WSOCK32.dll (WSOCK32.dll) Handle: 00007FFAF6C00000 Base address: 00007FFAF6C00000 Module found C:\Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\ClientTelemetry.dll (Users\FamilyPC\AppData\Local\Microsoft\OneDrive\17.3.6390.0509\amd64\ClientTelemetry.dll) Handle: 00007FFAEE400000 Base address: 00007FFAEE400000 Module found C:\WINDOWS\system32\mssprxy.dll (mssprxy.dll) Handle: 00007FFAECA50000 Base address: 00007FFAECA50000 Module found C:\WINDOWS\SYSTEM32\ntshrui.dll (ntshrui.dll) Handle: 00007FFAEFEA0000 Base address: 00007FFAEFEA0000 Module found C:\WINDOWS\SYSTEM32\SspiCli.dll (SspiCli.dll) Handle: 00007FFB0A850000 Base address: 00007FFB0A850000 Module found C:\WINDOWS\SYSTEM32\srvcli.dll (srvcli.dll) Handle: 00007FFAFEA10000 Base address: 00007FFAFEA10000 Module found C:\Windows\System32\WorkfoldersShell.dll (WorkfoldersShell.dll) Handle: 00007FFAF9270000 Base address: 00007FFAF9270000 Module found C:\WINDOWS\SYSTEM32\dsreg.dll (dsreg.dll) Handle: 00007FFAFF410000 Base address: 00007FFAFF410000 Module found C:\WINDOWS\SYSTEM32\WINHTTP.dll (WINHTTP.dll) Handle: 00007FFB082B0000 Base address: 00007FFB082B0000 Module found C:\WINDOWS\SYSTEM32\cryptsp.dll (cryptsp.dll) Handle: 00007FFB0A550000 Base address: 00007FFB0A550000 Module found C:\WINDOWS\SYSTEM32\DPAPI.DLL (DPAPI.DLL) Handle: 00007FFB0A220000 Base address: 00007FFB0A220000 Module found C:\WINDOWS\System32\shacct.dll (shacct.dll) Handle: 00007FFB08B10000 Base address: 00007FFB08B10000 Module found C:\WINDOWS\System32\IDStore.dll (IDStore.dll) Handle: 00007FFAF8760000 Base address: 00007FFAF8760000 Module found C:\WINDOWS\System32\SAMLIB.dll (SAMLIB.dll) Handle: 00007FFB08A30000 Base address: 00007FFB08A30000 Module found C:\WINDOWS\System32\wlidprov.dll (wlidprov.dll) Handle: 00007FFAF3480000 Base address: 00007FFAF3480000 Module found C:\WINDOWS\SYSTEM32\samcli.dll (samcli.dll) Handle: 00007FFB05D00000 Base address: 00007FFB05D00000 Module found C:\WINDOWS\system32\igfxOSP.dll (igfxOSP.dll) Handle: 00007FFAEC940000 Base address: 00007FFAEC940000 Module found C:\WINDOWS\system32\igfxDTCM.dll (igfxDTCM.dll) Handle: 00007FFAF78B0000 Base address: 00007FFAF78B0000 Module found C:\WINDOWS\system32\igfxDH.dll (igfxDH.dll) Handle: 00007FFAEF920000 Base address: 00007FFAEF920000 Module found C:\WINDOWS\system32\igfxLHM.dll (igfxLHM.dll) Handle: 00007FFAEF720000 Base address: 00007FFAEF720000 Module found C:\WINDOWS\system32\igfxDI.dll (igfxDI.dll) Handle: 00007FFAEF6C0000 Base address: 00007FFAEF6C0000 Module found C:\WINDOWS\system32\OPENGL32.dll (OPENGL32.dll) Handle: 00007FFAEF590000 Base address: 00007FFAEF590000 Module found C:\WINDOWS\system32\d3d10_1.dll (d3d10_1.dll) Handle: 00007FFAF8040000 Base address: 00007FFAF8040000 Module found C:\WINDOWS\system32\GLU32.dll (GLU32.dll) Handle: 00007FFAEF560000 Base address: 00007FFAEF560000 Module found C:\WINDOWS\system32\DDRAW.dll (DDRAW.dll) Handle: 00007FFAF8640000 Base address: 00007FFAF8640000 Module found C:\WINDOWS\system32\DCIMAN32.dll (DCIMAN32.dll) Handle: 00007FFAF8630000 Base address: 00007FFAF8630000 Module found C:\WINDOWS\system32\d3d10_1core.dll (d3d10_1core.dll) Handle: 00007FFAF7FD0000 Base address: 00007FFAF7FD0000 Module found C:\WINDOWS\system32\PhotoMetadataHandler.dll (PhotoMetadataHandler.dll) Handle: 00007FFAF7820000 Base address: 00007FFAF7820000 Module found C:\WINDOWS\system32\WINMM.dll (WINMM.dll) Handle: 00007FFB08C20000 Base address: 00007FFB08C20000 Module found C:\WINDOWS\system32\WINMMBASE.dll (WINMMBASE.dll) Handle: 00007FFB08BF0000 Base address: 00007FFB08BF0000 Module found C:\WINDOWS\system32\NetworkExplorer.dll (NetworkExplorer.dll) Handle: 00007FFAF89C0000 Base address: 00007FFAF89C0000 Module found C:\Program Files\3D-Coat-V4.7.06\tbbmalloc.dll (\tbbmalloc.dll) Handle: 0000020923000000 Base address: 0000020923000000 Log.txt: Loaded image file "Splash\Background2.jpg" Loaded image file "Splash\0.bmp" Loaded image file "Splash\1.bmp" Loaded image file "Splash\2.bmp" Loaded image file "Splash\3.bmp" Loaded image file "Splash\4.bmp" Loaded image file "Splash\5.bmp" Loaded image file "Splash\6.bmp" Loaded image file "Splash\7.bmp" Loaded image file "Splash\8.bmp" Loaded image file "Splash\9.bmp" Loaded image file "Splash\Dot.bmp" Loaded image file "Splash\Version.bmp" Loading Xml file "Xmls/Settings.xml"... Can't load file "Xmls/Settings.xml" ------------------------------------------------------------ Graphics card and driver info ------------------------------------------------------------ Direct3D Renderer Adapter: Intel(R) HD Graphics Family Driver: igdumdim64.dll Supported: Vertex shaders 3.0 Pixel shaders 3.0 MRT (targets: 4) Non power of two ------------------------------------------------------------ Registering vertex formats... Loaded image file "factures\grass_color1.png" Loaded image file "factures\grass_gloss.jpg" Loaded image file "factures\grass_nmap2.png" Loaded image file "Shaders\PbrShaders\Bone\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Clay\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Clay2\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Copper\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Default\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\FrogSkin\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Gold\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Gold2\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\GreenClay\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\MatCap_Clay\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\MatCap_RedWax\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\OldCopper\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\OldSilver\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\RedWax\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\RustedMetall\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Scratched\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Skin\mcubes_64.tga" Loaded image file "Shaders\PbrShaders\Steel\mcubes_64.tga" cMeshIO::AddCodec(): Added "Obj" mesh codec. cMeshIO::AddCodec(): Added "Lwo" mesh codec. cMeshIO::AddCodec(): Added "Fbx" mesh codec. cMeshIO::AddCodec(): Added "Stl" mesh codec. cMeshIO::AddCodec(): Added "Ply" mesh codec. cMeshIO::AddCodec(): Added "dae" mesh codec. cMeshIO::AddCodec(): Added "wrl" mesh codec. cMeshIO::LoadMesh(): Loaded mesh file "C:\Program Files\3D-Coat-V4.7.06\ToolsPresets\\Sphere.obj". * Loading shader "Shaders/mpreview1.hlsl"... Compiling VS... Compiling PS... cMeshIO::LoadMesh(): Loaded mesh file "C:\Program Files\3D-Coat-V4.7.06\ToolsPresets\\Ring.obj". cMeshIO::LoadMesh(): Loaded mesh file "C:\Program Files\3D-Coat-V4.7.06\ToolsPresets\\Cube.obj". cMeshIO::LoadMesh(): Loaded mesh file "C:\Program Files\3D-Coat-V4.7.06\ToolsPresets\\Sector.obj". cMeshIO::LoadMesh(): Loaded mesh file "C:\Program Files\3D-Coat-V4.7.06\ToolsPresets\\Cone.obj". cMeshIO::LoadMesh(): Loaded mesh file "C:\Program Files\3D-Coat-V4.7.06\ToolsPresets\\Cylinder.obj". cMeshIO::LoadMesh(): Can't open file "C:\Program Files\3D-Coat-V4.7.06\ToolsPresets\icosa240.obj". Added "TIF" image codec. Added "TIFF" image codec. Added "EXR" image codec. Added "HDR" image codec. - Loading font "Calibri 11"... Can't load file "Fonts/Calibri 11.cFont" - Loading font "Calibri 16"... Can't load file "Fonts/Calibri 16.cFont" - Loading font "Calibri B24"... Can't load file "Fonts/Calibri B24.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma B8"... Can't load file "Fonts/Tahoma B8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" Can't load image file "Textures\WindowsStandard\ToolBar.bmp" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" Version : 3D-COAT 4.7.06(DX64) * Loading shader "Shaders/hud2t.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/hud_smooth.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/hud.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/LinesPointsUI.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/Colored.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/RenderSystem.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/RenderSystem.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/text2.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ENV Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ENV #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_COLOR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_RELIEF Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_RELIEF #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPECULAR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPECULAR #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_render_color.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/obj_render_normals.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/obj_render_mrt.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview_nrm.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview_alpha.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview_all.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/obj_preview_pen2.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/inrect.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/obj_preview_pen2.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/preview_rect.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/draw_pic_over_curve.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/draw_pic_over_curve.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/preview_fill.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/uv.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/wires.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/wires.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/sphere.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/obj_preview_pen.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/CurrentMcubes/mcubes.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/mpreview.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/Font.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/mcubes_rt.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/mcubes_nrm.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... ------------------------------------------------------------ WinTab Device Name: Max Pressure: 0 ------------------------------------------------------------ AppLink search path registered: C:\Users\FamilyPC\Documents/AppLinks/3D-Coat/Exchange/ AppLink search path registered: C:\Users\FamilyPC\Documents/3D-CoatV4/Exchange/ AppLink search path registered: C:\Users\FamilyPC\Documents/3D-CoatV3/Exchange/ AppLink search path registered: C:\Users\FamilyPC\Documents/3D-CoatV47/Exchange/ AppLink search path registered: C:\Users\FamilyPC\Documents/3D-CoatV3/Exchange/ Loaded image file "textures\Fasterns\threadsicons.png" Loaded image file "textures\Fasterns\sliticons.png" Loaded image file "textures\Fasterns\headicons.png" Loaded image file "textures\Fasterns\underheadicons.png" Loaded image file "textures\Fasterns\tapheadicons.png" Loaded image file "textures\Fasterns\tapsliticons.png" Loaded image file "textures\Fasterns\tapscrewicons.png" Loaded image file "textures\Fasterns\nuticons.png" Loaded image file "textures\Fasterns\washericons.png" Loaded image file "textures\pens\rock.tga" Loaded image file "textures\icons64\Grow_Vox_02.png" Can't load image file "textures\tooltips\Grow_Vox_02.png" Loaded image file "textures\icons64\smooth_Vox.png" Can't load image file "textures\tooltips\smooth_Vox.png" Loaded image file "textures\icons64\Fill.png" Can't load image file "textures\tooltips\Fill.png" Loaded image file "textures\icons64\Clay_Vox.png" Can't load image file "textures\tooltips\Clay_Vox.png" Loaded image file "textures\icons64\Carve.png" Can't load image file "textures\tooltips\Carve.png" Loaded image file "textures\icons64\Blob_Vox.png" Can't load image file "textures\tooltips\Blob_Vox.png" Loaded image file "textures\icons64\Cutoff_Vox.png" Can't load image file "textures\tooltips\Cutoff_Vox.png" Loaded image file "textures\icons64\Airbrush_Vox.png" Can't load image file "textures\tooltips\Airbrush_Vox.png" Loaded image file "textures\icons64\Build_Vox_02.png" Can't load image file "textures\tooltips\Build_Vox_02.png" Loaded image file "textures\icons64\Extrude_Vox.png" Can't load image file "textures\tooltips\Extrude_Vox.png" Loaded image file "textures\icons64\Sphere_Vox.png" Can't load image file "textures\tooltips\Sphere_Vox.png" Loaded image file "textures\icons64\2D_Piant_Vox.png" Can't load image file "textures\tooltips\2D_Piant_Vox.png" Loaded image file "textures\icons64\Plane_Vox.png" Can't load image file "textures\tooltips\Plane_Vox.png" Loaded image file "textures\icons64\Scrape_Vox.png" Can't load image file "textures\tooltips\Scrape_Vox.png" Loaded image file "textures\icons64\Pinch_Vox.png" Can't load image file "textures\tooltips\Pinch_Vox.png" Loaded image file "textures\icons64\Smudge_Vox.png" Can't load image file "textures\tooltips\Smudge_Vox.png" Loaded image file "textures\icons64\Measure.png" Can't load image file "textures\tooltips\Measure.png" Loaded image file "textures\icons64\Pick.png" Can't load image file "textures\tooltips\Pick.png" Loaded image file "textures\icons64\Pose.png" Can't load image file "textures\tooltips\Pose.png" Loaded image file "textures\icons64\Move.png" Can't load image file "textures\tooltips\Move.png" Loaded image file "textures\icons64\Hide.png" Can't load image file "textures\tooltips\Hide.png" Loaded image file "textures\icons64\Cell.png" Can't load image file "textures\tooltips\Cell.png" Loaded image file "textures\icons64\Copy.png" Can't load image file "textures\tooltips\Copy.png" Loaded image file "textures\icons64\Transform.png" Can't load image file "textures\tooltips\Transform.png" Loaded image file "textures\icons64\Instancer.png" Can't load image file "textures\tooltips\Instancer.png" Loaded image file "textures\icons64\Warp.png" Can't load image file "textures\tooltips\Warp.png" Loaded image file "textures\icons64\Axial.png" Can't load image file "textures\tooltips\Axial.png" Loaded image file "textures\icons64\Bass-Releif.png" Can't load image file "textures\tooltips\Bass-Releif.png" Loaded image file "textures\icons64\Vox_Layer.png" Can't load image file "textures\tooltips\Vox_Layer.png" Loaded image file "textures\icons64\LOGO.png" Can't load image file "textures\tooltips\LOGO.png" Loaded image file "textures\icons64\Clone_Copy.png" Can't load image file "textures\tooltips\Clone_Copy.png" Loaded image file "textures\icons64\Clone_VOX.png" Can't load image file "textures\tooltips\Clone_VOX.png" Loaded image file "textures\icons64\Split_Vox.png" Can't load image file "textures\tooltips\Split_Vox.png" Loaded image file "textures\icons64\Merge.png" Can't load image file "textures\tooltips\Merge.png" Loaded image file "textures\icons64\Sketch_Tool.png" Can't load image file "textures\tooltips\Sketch_Tool.png" Loaded image file "textures\icons64\curves.png" Can't load image file "textures\tooltips\curves.png" Loaded image file "textures\icons64\Snake.png" Can't load image file "textures\tooltips\Snake.png" Loaded image file "textures\icons64\Spkie.png" Can't load image file "textures\tooltips\Spkie.png" Loaded image file "textures\icons64\toothPaste.png" Can't load image file "textures\tooltips\toothPaste.png" Loaded image file "textures\icons64\Muscle.png" Can't load image file "textures\tooltips\Muscle.png" Loaded image file "textures\icons64\Primatives.png" Can't load image file "textures\tooltips\Primatives.png" Loaded image file "textures\icons64\Text.png" Can't load image file "textures\tooltips\Text.png" Loaded image file "textures\icons64\Cloth.png" Can't load image file "textures\tooltips\Cloth.png" Loaded image file "textures\icons64\Draw_Surf.png" Can't load image file "textures\tooltips\Draw_Surf.png" Loaded image file "textures\icons64\Pinch_Surf.png" Can't load image file "textures\tooltips\Pinch_Surf.png" Loaded image file "textures\icons64\Shift_Surf.png" Can't load image file "textures\tooltips\Shift_Surf.png" Loaded image file "textures\icons64\Flatten_Surf.png" Can't load image file "textures\tooltips\Flatten_Surf.png" Loaded image file "textures\icons64\Clay_Surf.png" Can't load image file "textures\tooltips\Clay_Surf.png" Loaded image file "textures\icons64\Rapid_Surf.png" Can't load image file "textures\tooltips\Rapid_Surf.png" Loaded image file "textures\icons64\Increase_Res.png" Can't load image file "textures\tooltips\Increase_Res.png" Loaded image file "textures\icons64\Resample.png" Can't load image file "textures\tooltips\Resample.png" Loaded image file "textures\icons64\Clear.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Smooth_All.png" Can't load image file "textures\tooltips\Smooth_All.png" Loaded image file "textures\icons64\Chisel_Surf.png" Can't load image file "textures\tooltips\Chisel_Surf.png" Can't load image file "textures\tooltips\Build_Vox_02.png" Can't load image file "textures\tooltips\Fill.png" Loaded image file "textures\icons64\Inflate_Clay_LC.png" Can't load image file "textures\tooltips\Inflate_Clay_LC.png" Loaded image file "textures\icons64\Extrude_Surf.png" Can't load image file "textures\tooltips\Extrude_Surf.png" Loaded image file "textures\icons64\Gum.png" Can't load image file "textures\tooltips\Gum.png" Loaded image file "textures\icons64\Absolute.png" Can't load image file "textures\tooltips\Absolute.png" Loaded image file "textures\icons64\Freeze_Surf.png" Can't load image file "textures\tooltips\Freeze_Surf.png" Loaded image file "textures\icons64\Hide_Surf.png" Can't load image file "textures\tooltips\Hide_Surf.png" Loaded image file "textures\icons64\Rapid1_Surf.png" Can't load image file "textures\tooltips\Rapid1_Surf.png" Loaded image file "textures\icons64\Rapid2_Surf.png" Can't load image file "textures\tooltips\Rapid2_Surf.png" Loaded image file "textures\icons64\Scratches1_Surf.png" Can't load image file "textures\tooltips\Scratches1_Surf.png" Loaded image file "textures\icons64\Scratches2_Surf.png" Can't load image file "textures\tooltips\Scratches2_Surf.png" Loaded image file "textures\icons64\Mud1_surf.png" Can't load image file "textures\tooltips\Mud1_surf.png" Loaded image file "textures\icons64\Mud2_surf.png" Can't load image file "textures\tooltips\Mud2_surf.png" Loaded image file "textures\icons64\Decimate.png" Can't load image file "textures\tooltips\Decimate.png" Loaded image file "textures\icons64\TSmooth_LC.png" Can't load image file "textures\tooltips\TSmooth_LC.png" Can't load image file "textures\tooltips\Draw_Surf.png" Can't load image file "textures\tooltips\Build_Vox_02.png" Loaded image file "textures\icons64\CreaseClay_LC.png" Can't load image file "textures\tooltips\CreaseClay_LC.png" Loaded image file "textures\icons64\Reduce_Clay_LC.png" Can't load image file "textures\tooltips\Reduce_Clay_LC.png" Loaded image file "textures\icons64\Extrude_Clay_LC.png" Can't load image file "textures\tooltips\Extrude_Clay_LC.png" Loaded image file "textures\icons64\Snake_Clay_LC.png" Can't load image file "textures\tooltips\Snake_Clay_LC.png" Loaded image file "textures\icons64\Tube_Clay_LC.png" Can't load image file "textures\tooltips\Tube_Clay_LC.png" Loaded image file "textures\icons64\Smudge_Clay_LC.png" Can't load image file "textures\tooltips\Smudge_Clay_LC.png" Can't load image file "textures\tooltips\Inflate_Clay_LC.png" Loaded image file "textures\icons64\Swirl_Clay_LC.png" Can't load image file "textures\tooltips\Swirl_Clay_LC.png" Loaded image file "textures\icons64\Ripple_LC.png" Can't load image file "textures\tooltips\Ripple_LC.png" Can't load image file "textures\tooltips\Flatten_Surf.png" Loaded image file "textures\icons64\Wrincle_Clay_LC.png" Can't load image file "textures\tooltips\Wrincle_Clay_LC.png" Loaded image file "textures\icons64\Remove_Clay_LC.png" Can't load image file "textures\tooltips\Remove_Clay_LC.png" Loaded image file "textures\icons64\General_LC.png" Can't load image file "textures\tooltips\General_LC.png" Loaded image file "textures\icons64\Add_Clusters.png" Can't load image file "textures\tooltips\Add_Clusters.png" Loaded image file "textures\icons64\Mark_Seams.png" Can't load image file "textures\tooltips\Mark_Seams.png" Loaded image file "textures\icons64\Mark_Seams_Edge_Loop.png" Can't load image file "textures\tooltips\Mark_Seams_Edge_Loop.png" Loaded image file "textures\icons64\Select_Path.png" Can't load image file "textures\tooltips\Select_Path.png" Loaded image file "textures\icons64\Clear_Clusters.png" Can't load image file "textures\tooltips\Clear_Clusters.png" Loaded image file "textures\icons64\Clear_Seams.png" Can't load image file "textures\tooltips\Clear_Seams.png" Loaded image file "textures\icons64\Auto_Seams.png" Can't load image file "textures\tooltips\Auto_Seams.png" Loaded image file "textures\icons64\Sharp_Seams.png" Can't load image file "textures\tooltips\Sharp_Seams.png" Can't load image file "textures\tooltips\Sharp_Seams.png" Loaded image file "textures\icons64\Unwrap.png" Can't load image file "textures\tooltips\Unwrap.png" Loaded image file "textures\icons64\Pack1.png" Can't load image file "textures\tooltips\Pack1.png" Loaded image file "textures\icons64\Pack2.png" Can't load image file "textures\tooltips\Pack2.png" Loaded image file "textures\icons64\Auto_Scale.png" Can't load image file "textures\tooltips\Auto_Scale.png" Loaded image file "textures\icons64\Update_Islands.png" Can't load image file "textures\tooltips\Update_Islands.png" Loaded image file "textures\icons64\Restore_UV.png" Can't load image file "textures\tooltips\Restore_UV.png" Loaded image file "textures\icons64\Apply_UV.png" Can't load image file "textures\tooltips\Apply_UV.png" Loaded image file "textures\icons64\Export.png" Can't load image file "textures\tooltips\Export.png" Loaded image file "textures\icons64\Import.png" Can't load image file "textures\tooltips\Import.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Invert.png" Can't load image file "textures\tooltips\Invert.png" Loaded image file "textures\icons64\Rotate_Clock.png" Can't load image file "textures\tooltips\Rotate_Clock.png" Loaded image file "textures\icons64\Rotate_AnitClock.png" Can't load image file "textures\tooltips\Rotate_AnitClock.png" Loaded image file "textures\icons64\Flip_U.png" Can't load image file "textures\tooltips\Flip_U.png" Loaded image file "textures\icons64\Flip_V.png" Can't load image file "textures\tooltips\Flip_V.png" Loaded image file "textures\icons64\Relax_UV.png" Can't load image file "textures\tooltips\Relax_UV.png" Can't load image file "textures\tooltips\Relax_UV.png" Loaded image file "textures\icons64\ABF.png" Can't load image file "textures\tooltips\ABF.png" Loaded image file "textures\icons64\LSCM.png" Can't load image file "textures\tooltips\LSCM.png" Loaded image file "textures\icons64\Planar.png" Can't load image file "textures\tooltips\Planar.png" Loaded image file "textures\icons64\Hide_UV.png" Can't load image file "textures\tooltips\Hide_UV.png" Loaded image file "textures\icons64\Invert_Hidden.png" Can't load image file "textures\tooltips\Invert_Hidden.png" Loaded image file "textures\icons64\UnHide.png" Can't load image file "textures\tooltips\UnHide.png" Loaded image file "textures\icons64\Unhide_All.png" Can't load image file "textures\tooltips\Unhide_All.png" Loaded image file "textures\icons64\Copy_UV.png" Can't load image file "textures\tooltips\Copy_UV.png" Loaded image file "textures\icons64\Paste.png" Can't load image file "textures\tooltips\Paste.png" Loaded image file "textures\icons64\Add_Split.png" Can't load image file "textures\tooltips\Add_Split.png" Loaded image file "textures\icons64\Select.png" Can't load image file "textures\tooltips\Select.png" Can't load image file "textures\tooltips\Mark_Seams.png" Loaded image file "textures\icons64\Quad.png" Can't load image file "textures\tooltips\Quad.png" Loaded image file "textures\icons64\Pointand_Faces.png" Can't load image file "textures\tooltips\Pointand_Faces.png" Loaded image file "textures\icons64\Cap.png" Can't load image file "textures\tooltips\Cap.png" Loaded image file "textures\icons64\Strokes.png" Can't load image file "textures\tooltips\Strokes.png" Loaded image file "textures\icons64\Brush.png" Can't load image file "textures\tooltips\Brush.png" Loaded image file "textures\icons64\Delete_Polygons.png" Can't load image file "textures\tooltips\Delete_Polygons.png" Loaded image file "textures\icons64\Delete_Edges.png" Can't load image file "textures\tooltips\Delete_Edges.png" Loaded image file "textures\icons64\Collapse_Edge.png" Can't load image file "textures\tooltips\Collapse_Edge.png" Loaded image file "textures\icons64\Split_Ring.png" Can't load image file "textures\tooltips\Split_Ring.png" Loaded image file "textures\icons64\Select_Verts.png" Can't load image file "textures\tooltips\Select_Verts.png" Loaded image file "textures\icons64\Slide_Edge.png" Can't load image file "textures\tooltips\Slide_Edge.png" Can't load image file "textures\tooltips\Mark_Seams.png" Can't load image file "textures\tooltips\Mark_Seams_Edge_Loop.png" Loaded image file "textures\icons64\Retopo_Transform.png" Can't load image file "textures\tooltips\Retopo_Transform.png" Can't load image file "textures\tooltips\Import.png" Can't load image file "textures\tooltips\Export.png" Loaded image file "textures\icons64\Snap.png" Can't load image file "textures\tooltips\Snap.png" Loaded image file "textures\icons64\Subdivide.png" Can't load image file "textures\tooltips\Subdivide.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Relax.png" Can't load image file "textures\tooltips\Relax.png" Loaded image file "textures\icons64\Symmetry.png" Can't load image file "textures\tooltips\Symmetry.png" Loaded image file "textures\icons64\Sculpt_Move.png" Can't load image file "textures\tooltips\Sculpt_Move.png" Loaded image file "textures\icons64\Sculpt_Select_Move.png" Can't load image file "textures\tooltips\Sculpt_Select_Move.png" Loaded image file "textures\icons64\Sculpt_Drag_Points.png" Can't load image file "textures\tooltips\Sculpt_Drag_Points.png" Loaded image file "textures\icons64\Sculpt_Collapse.png" Can't load image file "textures\tooltips\Sculpt_Collapse.png" Loaded image file "textures\icons64\Sculpt_Expand.png" Can't load image file "textures\tooltips\Sculpt_Expand.png" Loaded image file "textures\icons64\Sculpt_Smudge.png" Can't load image file "textures\tooltips\Sculpt_Smudge.png" Loaded image file "textures\icons64\Sculpt_Smooth.png" Can't load image file "textures\tooltips\Sculpt_Smooth.png" Can't load image file "textures\tooltips\Sculpt_Move.png" Can't load image file "textures\tooltips\Sculpt_Select_Move.png" Can't load image file "textures\tooltips\Sculpt_Drag_Points.png" Loaded image file "textures\icons64\Sculpt_Draw.png" Can't load image file "textures\tooltips\Sculpt_Draw.png" Can't load image file "textures\tooltips\Sculpt_Collapse.png" Can't load image file "textures\tooltips\Sculpt_Expand.png" Can't load image file "textures\tooltips\Sculpt_Smudge.png" Can't load image file "textures\tooltips\Sculpt_Smudge.png" Loaded image file "textures\icons64\Sculpt_Flatten.png" Can't load image file "textures\tooltips\Sculpt_Flatten.png" Can't load image file "textures\tooltips\Sculpt_Smooth.png" Loaded image file "textures\icons64\Spin.png" Can't load image file "textures\tooltips\Spin.png" Loaded image file "textures\icons64\Spin_back.png" Can't load image file "textures\tooltips\Spin_back.png" Loaded image file "textures\icons64\Extrude.png" Can't load image file "textures\tooltips\Extrude.png" Loaded image file "textures\icons64\Split.png" Can't load image file "textures\tooltips\Split.png" Can't load image file "textures\tooltips\Collapse_Edge.png" Can't load image file "textures\tooltips\Clear.png" Can't load image file "textures\tooltips\Mark_Seams_Edge_Loop.png" Loaded image file "textures\icons64\Edge_Ring.png" Can't load image file "textures\tooltips\Edge_Ring.png" Can't load image file "textures\tooltips\Sharp_Seams.png" Loaded image file "textures\icons64\Bevel.png" Can't load image file "textures\tooltips\Bevel.png" Can't load image file "textures\tooltips\Apply_UV.png" Can't load image file "textures\tooltips\Clear_Seams.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Clone.png" Can't load image file "textures\tooltips\Clone.png" Loaded image file "textures\icons64\sfCutnClone.png" Can't load image file "textures\tooltips\sfCutnClone.png" Can't load image file "textures\tooltips\Subdivide.png" Can't load image file "textures\tooltips\Hide_UV.png" Can't load image file "textures\tooltips\Invert_Hidden.png" Can't load image file "textures\tooltips\Unhide.png" Loaded image file "textures\icons64\ExtrudeNormal.png" Can't load image file "textures\tooltips\ExtrudeNormal.png" Loaded image file "textures\icons64\ExtrudeFree.png" Can't load image file "textures\tooltips\ExtrudeFree.png" Loaded image file "textures\icons64\Undercuts.png" Can't load image file "textures\tooltips\Undercuts.png" Loaded image file "textures\icons64\PaintHoleTool.png" Can't load image file "textures\tooltips\PaintHoleTool.png" Loaded image file "textures\icons64\CloseHole.png" Can't load image file "textures\tooltips\CloseHole.png" Loaded image file "textures\icons64\Fit.png" Can't load image file "textures\tooltips\Fit.png" Can't load image file "textures\tooltips\Decimate.png" Loaded image file "textures\icons64\PinHoles2.png" Can't load image file "textures\tooltips\PinHoles2.png" Loaded image file "textures\icons64\Reconstruct.png" Can't load image file "textures\tooltips\Reconstruct.png" Loaded image file "textures\icons64\Bridge.png" Can't load image file "textures\tooltips\Bridge.png" Loaded image file "textures\icons64\VoxExtrude.png" Can't load image file "textures\tooltips\VoxExtrude.png" Loaded image file "textures\icons64\VoxIndent.png" Can't load image file "textures\tooltips\VoxIndent.png" Loaded image file "textures\icons64\ToLine.png" Can't load image file "textures\tooltips\ToLine.png" Loaded image file "textures\icons64\Equidistant.png" Can't load image file "textures\tooltips\Equidistant.png" Loaded image file "textures\icons64\Horizontal.png" Can't load image file "textures\tooltips\Horizontal.png" Loaded image file "textures\icons64\Vertical.png" Can't load image file "textures\tooltips\Vertical.png" Loaded image file "textures\icons64\Edgeloop.png" Can't load image file "textures\tooltips\Edgeloop.png" Loaded image file "textures\icons64\Edgering.png" Can't load image file "textures\tooltips\Edgering.png" Loaded image file "textures\icons64\ShuffleUV.png" Can't load image file "textures\tooltips\ShuffleUV.png" Loaded image file "textures\icons64\settings.png" Can't load image file "textures\tooltips\settings.png" Loaded image file "textures\icons64\SplitNJoints.png" Can't load image file "textures\tooltips\SplitNJoints.png" Loaded image file "textures\icons64\Lute.png" Can't load image file "textures\tooltips\Lute.png" Loaded image file "textures\icons64\SuperPinch.png" Can't load image file "textures\tooltips\SuperPinch.png" Loaded image file "textures\icons64\SubdivideVoxSurf.png" Can't load image file "textures\tooltips\SubdivideVoxSurf.png" Loaded image file "textures\icons64\InfSmooth.png" Can't load image file "textures\tooltips\InfSmooth.png" Loaded image file "textures\icons64\CopyClay64.png" Can't load image file "textures\tooltips\CopyClay64.png" Can't load image file "textures\tooltips\Relax_UV.png" Loaded image file "textures\icons64\GU.png" Can't load image file "textures\tooltips\GU.png" Loaded image file "textures\icons64\Noise.png" Can't load image file "textures\tooltips\Noise.png" Loaded image file "textures\icons64\ScaleCL.png" Can't load image file "textures\tooltips\ScaleCL.png" Loaded image file "textures\icons64\StoreSel.png" Can't load image file "textures\tooltips\StoreSel.png" Loaded image file "textures\icons64\RecallSel.png" Can't load image file "textures\tooltips\RecallSel.png" Loaded image file "textures\icons64\ClearSel.png" Can't load image file "textures\tooltips\ClearSel.png" Loaded image file "textures\icons64\PixelArt.png" Can't load image file "textures\tooltips\PixelArt.png" Loaded image file "textures\icons64\QuickPose.png" Can't load image file "textures\tooltips\QuickPose.png" Loaded image file "textures\icons64\FillHoles.png" Can't load image file "textures\tooltips\FillHoles.png" Loaded image file "textures\icons64\VoXRay.png" Can't load image file "textures\tooltips\VoXRay.png" Loaded image file "textures\icons64\Supports.png" Can't load image file "textures\tooltips\Supports.png" Loaded image file "textures\icons64\hdExpand.png" Can't load image file "textures\tooltips\hdExpand.png" Loaded image file "textures\icons64\hdContract.png" Can't load image file "textures\tooltips\hdContract.png" Loaded image file "textures\icons64\MeshDoctor.png" Can't load image file "textures\tooltips\MeshDoctor.png" Loaded image file "textures\icons64\AutoMap.png" Can't load image file "textures\tooltips\AutoMap.png" Can't load image file "textures\tooltips\Measure.png" Loaded image file "textures\icons64\rtFlipFaces.png" Can't load image file "textures\tooltips\rtFlipFaces.png" Loaded image file "textures\icons64\rtClearPoints.png" Can't load image file "textures\tooltips\rtClearPoints.png" Loaded image file "textures\icons64\SmoothLines.png" Can't load image file "textures\tooltips\SmoothLines.png" Loaded image file "textures\icons64\DelStroke.png" Can't load image file "textures\tooltips\DelStroke.png" Loaded image file "textures\icons64\ClearLines.png" Can't load image file "textures\tooltips\ClearLines.png" Loaded image file "textures\icons64\Lazer.png" Can't load image file "textures\tooltips\Lazer.png" Loaded image file "textures\icons64\ExtrudeVerts.png" Can't load image file "textures\tooltips\ExtrudeVerts.png" Loaded image file "textures\icons64\ExtrudeFaces.png" Can't load image file "textures\tooltips\ExtrudeFaces.png" Loaded image file "textures\icons64\Intrude.png" Can't load image file "textures\tooltips\Intrude.png" Loaded image file "textures\icons64\RtpShell.png" Can't load image file "textures\tooltips\RtpShell.png" Loaded image file "textures\icons64\SelExpand.png" Can't load image file "textures\tooltips\SelExpand.png" Loaded image file "textures\icons64\SelContract.png" Can't load image file "textures\tooltips\SelContract.png" Loaded image file "textures\icons64\CutEdges.png" Can't load image file "textures\tooltips\CutEdges.png" Loaded image file "textures\icons64\ConnectVerts.png" Can't load image file "textures\tooltips\ConnectVerts.png" Can't load image file "textures\masks\Arrow_01_prv.tga" Loaded image file "Temp\Arrow_0135782.tga" Can't load image file "textures\masks\fr_prv.tga" Loaded image file "Temp\fr23483.tga" Can't load image file "textures\masks\Grid_prv.tga" Loaded image file "Temp\Grid27501.tga" Can't load image file "textures\masks\honeycomb_prv.tga" Loaded image file "Temp\honeycomb41697.tga" Can't load image file "textures\masks\Misk_01_prv.tga" Loaded image file "Temp\Misk_0132829.tga" Can't load image file "textures\masks\Misk_02_prv.tga" Loaded image file "Temp\Misk_0232851.tga" Can't load image file "textures\masks\Misk_03_prv.tga" Loaded image file "Temp\Misk_0332873.tga" Can't load image file "textures\masks\Noise_01_prv.tga" Loaded image file "Temp\Noise_0135493.tga" Can't load image file "textures\masks\Noise_02_prv.tga" Loaded image file "Temp\Noise_0235516.tga" Can't load image file "textures\masks\Noise_03_prv.tga" Loaded image file "Temp\Noise_0335539.tga" Can't load image file "textures\masks\Noise_04_prv.tga" Loaded image file "Temp\Noise_0435562.tga" Can't load image file "textures\masks\Noise_05_prv.tga" Loaded image file "Temp\Noise_0535585.tga" Can't load image file "textures\masks\Rhombs_prv.tga" Loaded image file "Temp\Rhombs32885.tga" Can't load image file "textures\masks\Triangle_prv.tga" Loaded image file "Temp\Triangle38162.tga" Can't load image file "textures\masks\Cracks_prv.tga" Loaded image file "Temp\Cracks32689.tga" Can't load image file "textures\masks\OT_DiagGrid_straight01_prv.tga" Loaded image file "Temp\OT_DiagGrid_straight0182532.tga" Can't load image file "textures\masks\OT_DiagGrid_straight02_prv.tga" Loaded image file "Temp\OT_DiagGrid_straight0282569.tga" Can't load image file "textures\masks\OT_DiagGrid_straight03_prv.tga" Loaded image file "Temp\OT_DiagGrid_straight0382606.tga" Can't load image file "textures\masks\OT_mask_dented01_prv.tga" Loaded image file "Temp\OT_mask_dented0160138.tga" Can't load image file "textures\masks\OT_mask_dirt02_prv.tga" Loaded image file "Temp\OT_mask_dirt0253715.tga" Can't load image file "textures\masks\OT_mask_dirt03_prv.tga" Loaded image file "Temp\OT_mask_dirt0353744.tga" Can't load image file "textures\masks\OT_mask_dirt04_prv.tga" Loaded image file "Temp\OT_mask_dirt0453773.tga" Can't load image file "textures\masks\OT_textureFX_dirt13_prv.tga" Loaded image file "Temp\OT_textureFX_dirt1371421.tga" Can't load image file "textures\masks\OT_textureFX_dirt14_prv.tga" Loaded image file "Temp\OT_textureFX_dirt1471455.tga" Can't load image file "textures\masks\OT_textureFX_dirt15_prv.tga" Loaded image file "Temp\OT_textureFX_dirt1571489.tga" Can't load image file "textures\masks\OT_textureFX_fingerprints03_prv.tga" Loaded image file "Temp\OT_textureFX_fingerprints03107056.tga" Can't load image file "textures\masks\OT_textureFX_grimy01_prv.tga" Loaded image file "Temp\OT_textureFX_grimy0175631.tga" Can't load image file "textures\masks\OT_textureFX_scratches05_prv.tga" Loaded image file "Temp\OT_textureFX_scratches0592168.tga" Can't load image file "textures\masks\OT_vents05_prv.tga" Loaded image file "Temp\OT_vents0541613.tga" Can't load image file "textures\masks\SkinCracks_prv.tga" Loaded image file "Temp\SkinCracks43680.tga" Can't load image file "textures\masks\SkinCracks1_prv.tga" Loaded image file "Temp\SkinCracks145321.tga" Can't load image file "textures\masks\StoneDirt1_prv.tga" Loaded image file "Temp\StoneDirt142742.tga" Can't load image file "textures\masks\OT_dirt_prv.tga" Loaded image file "Temp\OT_dirt35306.tga" Can't load image file "textures\masks\OT_dirt02_prv.tga" Loaded image file "Temp\OT_dirt0238352.tga" Can't load image file "textures\masks\OT_dirt_bulletHolesDepth01_8_prv.tga" Loaded image file "Temp\OT_dirt_bulletHolesDepth01_8107726.tga" Can't load image file "textures\masks\OT_mask_rust01_prv.tga" Loaded image file "Temp\OT_mask_rust0154470.tga" Can't load image file "textures\masks\OT_random6_prv.tga" Loaded image file "Temp\OT_random642608.tga" Can't load image file "textures\masks\OT_tech3_prv.tga" Loaded image file "Temp\OT_tech336495.tga" Can't load image file "textures\masks\OT_texturefx_dirtmask01_prv.tga" Loaded image file "Temp\OT_texturefx_dirtmask0189802.tga" Can't load image file "textures\masks\OT_texturefx_dirtmask02_prv.tga" Loaded image file "Temp\OT_texturefx_dirtmask0289840.tga" Can't load image file "textures\masks\OT_texturefx_riddled_prv.tga" Loaded image file "Temp\OT_texturefx_riddled80237.tga" Can't load image file "textures\masks\OT_textureFX_scratches05_nmap_prv.tga" Loaded image file "Temp\OT_textureFX_scratches05_nmap116172.tga" Can't load image file "textures\masks\StoneDirt1_nmap_prv.tga" Loaded image file "Temp\StoneDirt1_nmap59368.tga" Loaded image file "patterns\auto_mtl_preview_01D146FE.png" Loaded image file "patterns\auto_mtl_preview_0F7812D6.png" Loaded image file "patterns\auto_mtl_preview_1E13B66C.png" Loaded image file "patterns\auto_mtl_preview_59D42B5F.png" Loaded image file "patterns\auto_mtl_preview_72531A71.png" Loaded image file "patterns\auto_mtl_preview_1A7D71ED.png" Loaded image file "patterns\auto_mtl_preview_02D37DBF.png" Loaded image file "patterns\auto_mtl_preview_27F28888.png" Loaded image file "patterns\auto_mtl_preview_4EFD75C1.png" Loaded image file "patterns\auto_mtl_preview_4BBBF90A.png" Loaded image file "patterns\auto_mtl_preview_3983605C.png" Loaded image file "VoxStamps\Objects\Capsule_preview.png" Loaded image file "VoxStamps\Objects\column_preview.png" Loaded image file "VoxStamps\Objects\Cone_preview.png" Loaded image file "VoxStamps\Objects\Cube_preview.png" Loaded image file "VoxStamps\Objects\Cylinder_preview.png" Loaded image file "VoxStamps\Objects\dodecahedron_preview.png" Loaded image file "VoxStamps\Objects\Icosahedron_preview.png" Loaded image file "VoxStamps\Objects\Sphere_preview.png" Loaded image file "VoxStamps\Objects\Star_preview.png" Loaded image file "VoxStamps\Objects\Torus_preview.png" Loaded image file "VoxStamps\Splines\chain_preview.png" Loaded image file "VoxStamps\Splines\Dragon1_preview.png" Loaded image file "VoxStamps\Splines\Dragon2_preview.png" Loaded image file "VoxStamps\Splines\Dragon3_preview.png" Loaded image file "VoxStamps\Splines\Dragon4_preview.png" Loaded image file "VoxStamps\Splines\Dragon5_preview.png" Loaded image file "VoxStamps\Splines\pipe_segment_preview.png" Loaded image file "VoxStamps\Splines\shlang_preview.png" Loaded image file "VoxStamps\Splines\spring_preview.png" Loaded image file "VoxStamps\Splines\spring2_preview.png" Loaded image file "VoxStamps\Splines\spring3_preview.png" Loaded image file "VoxStamps\Splines\Tentacle_preview.png" Loaded image file "VoxStamps\Splines\WildTeeth_preview.png" Loaded image file "VoxStamps\RtpModels\C_Extension_preview.png" Loaded image file "VoxStamps\RtpModels\Capsule_LowPoly_preview.png" Loaded image file "VoxStamps\RtpModels\Capsule_MidPoly_preview.png" Loaded image file "VoxStamps\RtpModels\Cone_preview.png" Loaded image file "VoxStamps\RtpModels\Cube_01_preview.png" Loaded image file "VoxStamps\RtpModels\Cube_Chamfer_preview.png" Loaded image file "VoxStamps\RtpModels\Cube_Fillet_01_preview.png" Loaded image file "VoxStamps\RtpModels\Cube_Fillet_02_preview.png" Loaded image file "VoxStamps\RtpModels\Cube_Fillet_03_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_01_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_Capped_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_Chamfer_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_Chamfer_Hollow_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_Fillet_01_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_Fillet_02_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_Short_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_Short_Fillet_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_Short_Rounded_preview.png" Loaded image file "VoxStamps\RtpModels\Disc_01_preview.png" Loaded image file "VoxStamps\RtpModels\Disc_02_preview.png" Loaded image file "VoxStamps\RtpModels\GeoSphere_01_preview.png" Loaded image file "VoxStamps\RtpModels\Hedra_01_preview.png" Loaded image file "VoxStamps\RtpModels\Hedra_02_preview.png" Loaded image file "VoxStamps\RtpModels\Hedra_03_preview.png" Loaded image file "VoxStamps\RtpModels\Hedra_04_preview.png" Loaded image file "VoxStamps\RtpModels\Hose_Ribbed_preview.png" Loaded image file "VoxStamps\RtpModels\L_Extension_01_preview.png" Loaded image file "VoxStamps\RtpModels\NGon_01_preview.png" Loaded image file "VoxStamps\RtpModels\NGon_02_preview.png" Loaded image file "VoxStamps\RtpModels\Patch_Rounded_preview.png" Loaded image file "VoxStamps\RtpModels\Patch_Square_preview.png" Loaded image file "VoxStamps\RtpModels\Pyramid001_preview.png" Loaded image file "VoxStamps\RtpModels\Sphere_preview.png" Loaded image file "VoxStamps\RtpModels\Torus_preview.png" Loaded image file "VoxStamps\RtpModels\Torus_Knot_02_preview.png" Loaded image file "VoxStamps\RtpModels\Torus_Knot_02_01_preview.png" Loaded image file "VoxStamps\RtpModels\Torus_Thick_preview.png" Loaded image file "VoxStamps\RtpModels\Tube_preview.png" Loaded image file "VoxStamps\RtpModels\Tube_02_preview.png" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Can't load image file "textures\preview_pen0.tga" Can't load image file "textures\preview_pen5.tga" Can't load image file "Shape1" Can't load image file "Shape1" Can't load image file "Shape1" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Can't load image file "Shape" Can't load image file "Shape" Can't load image file "Shape1" Can't load image file "Shape1" Can't load image file "Shape1" Can't load image file "Shape" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_artman greeble2 strip_HardSurface_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_artman greeble2 strip_HardSurface_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_manyspots_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_manyspots_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_manyscratches_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_manyscratches_mclp.dds" Loaded image file "Unicode\Font00.dds" Locale: English_United States.1252 Loaded image file "Textures\stdimage.dds" Loaded image file "Temp\pano4.dds" Loaded image file "Temp\pano4d.dds" Loaded image file "textures\white.dds" Loaded image file "textures\light\baseicons.tga" Can't load image file "textures\default.dds" Loaded image file "textures\2knopki.tga" Loaded image file "textures\smallwhiteicons.dds" Loaded image file "textures\dark\property.tga" Loaded image file "textures\RightArrow.dds" Loaded image file "Textures\light\Navigation.tga" Loaded image file "textures\icons\newfolder.png" Can't load image file "textures\preview_pen1.tga" Can't load image file "textures\preview_pen2.tga" Can't load image file "textures\preview_pen3.tga" Can't load image file "textures\preview_pen4.tga" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_000_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_000_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_capsula_118D_horizontal_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_capsula_118D_horizontal_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Can't load image file "Levels\Uv\Uv_d" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_chain_227B_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_chain_227B_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_cheshuja_7BF3_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_cheshuja_7BF3_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_003_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_003_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_004_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_004_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_005_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_005_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_007_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_007_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_008_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_008_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Fabric0001_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Fabric0001_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Gem1_70C8_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Gem1_70C8_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Gem1_EC21_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Gem1_EC21_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_hair03_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_hair03_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_hair14_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_hair14_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_knopka_03_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_knopka_03_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_kosichka_20A7_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_kosichka_20A7_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_OT_corroded_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_OT_corroded_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_OT_Speckled03_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_OT_Speckled03_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_OT_Speckled04_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_OT_Speckled04_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Patron_C89D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Patron_C89D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_pen4_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_pen4_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_pen5_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_pen5_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Piramida_8AF9_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Piramida_8AF9_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_pugovka_CC7C_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_pugovka_CC7C_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_quad_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_quad_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_randomscratches_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_randomscratches_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Ringmail2_3BD4_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Ringmail2_3BD4_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Ringmail_0C3E_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Ringmail_0C3E_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rings_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rings_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_003_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_003_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_007_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_007_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_011_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_011_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_013_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_013_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_014_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_014_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_005_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_005_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_008_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_008_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_009_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_009_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_sq_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_sq_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_sqgrad_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_sqgrad_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_sqgradstrip_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_sqgradstrip_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_taty_2_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_taty_2_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_004_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_004_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_009_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_009_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_012_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_012_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_wire_9832_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_wire_9832_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Blob2_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Blob2_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Blob_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Blob_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Cloth_Fabric01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Cloth_Fabric01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Cloth_Fabric02_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Cloth_Fabric02_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Fissure2_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Fissure2_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Fissure5_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Fissure5_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Gear06_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Gear06_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Skin01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Skin01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Skin02_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Skin02_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Skin08_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Skin08_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Tech02_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Tech02_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Tech_Circle01_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Tech_Circle01_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Tech_Circle06_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Tech_Circle06_D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Wrinkles01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Wrinkles01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Wrinkles02_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_XMD_Wrinkles02_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_Capsule_A87D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_Capsule_A87D_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_chain_BE26_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_chain_BE26_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_Edge1_8F5C_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_Edge1_8F5C_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_fabr_kromka_01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_fabr_kromka_01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_Patron_09C2_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_Patron_09C2_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_pen4_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_pen4_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_strip1_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_strip1_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_strip3_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_strip3_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_strip5_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_strip5_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_wire_44D3_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_wire_44D3_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_XMD_Cloth_Zipper01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_XMD_Cloth_Zipper01_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_XMD_Cloth_Zipper02_mclp.dds" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_strips_XMD_Cloth_Zipper02_mclp.dds" Loaded image file "PickData\sky.jpg" Loaded image file "PickData\sky.jpg" Loaded image file "PickData\sky.jpg" Loaded image file "textures\grey3.dds" Loaded image file "textures\dark\stdbutton.tga" Loaded image file "Textures\dark\Navigation.tga" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Loaded image file "textures\enum\LrCondition\Always.png" Loaded image file "textures\enum\LrCondition\MoreOnConcave.png" Loaded image file "textures\enum\LrCondition\MoreOnConvex.png" Loaded image file "textures\enum\LrCondition\LessOnConcave.png" Loaded image file "textures\enum\LrCondition\LessOnConvex.png" Loaded image file "textures\enum\LrCondition\MoreOnFlat.png" Loaded image file "textures\enum\LrCondition\MoreOnCurved.png" Loaded image file "textures\enum\LrCondition\MoreOnLit.png" Loaded image file "textures\enum\LrCondition\MoreInShadow.png" Loaded image file "textures\enum\LrCondition\MoreOnTop.png" Loaded image file "textures\enum\LrCondition\MoreOnBottom.png" Loaded image file "textures\enum\LrCondition\MoreOnSides.png" Loaded image file "textures\enum\LrCondition\MoreOnBright.png" Loaded image file "textures\enum\LrCondition\MoreOnMidtone.png" Loaded image file "textures\enum\LrCondition\MoreOnDark.png" Loaded image file "textures\enum\LrCondition\MoreOnCurrent.png" Loaded image file "textures\enum\LrCondition\MoreOnHigh.png" Loaded image file "textures\enum\LrCondition\MoreOnDeep.png" Loaded image file "textures\dark\Icons16.tga" Loaded image file "Textures\dark\Locks.tga" Loaded image file "textures\taper32.png" Loaded image file "StartMenu\images\MainLogo4.png" Loaded image file "textures\icons64\Blob_Vox.png" Loaded image file "textures\icons64\Sketch_Tool.png" Loaded image file "textures\icons64\Repair.png" Loaded image file "textures\icons64\im2mesh.png" Loaded image file "textures\icons64\vertexpaint.png" Loaded image file "textures\icons64\ppp.png" Loaded image file "textures\icons64\mv.png" Loaded image file "textures\icons64\ptex.png" Loaded image file "textures\icons64\Cap.png" Loaded image file "textures\icons64\Mark_Seams.png" Loaded image file "textures\icons64\Bass-releif.png" Loaded image file "textures\icons64\Recent.png" Loaded image file "Temp\panoramas_ggx2\1969697_thumb.tga" Loaded image file "textures\dark\Navigation_ext.tga" Loaded image file "Temp\panoramas_ggx2\25A3A386_thumb.tga" Loaded image file "Temp\panoramas_ggx2\2FFFFFD_thumb.tga" Loaded image file "Temp\panoramas_ggx2\3848487_thumb.tga" Loaded image file "Temp\panoramas_ggx2\3B383803_thumb.tga" Loaded image file "Temp\panoramas_ggx2\3FD2D2ED_thumb.tga" Loaded image file "Temp\panoramas_ggx2\499091D9_thumb.tga" Loaded image file "Temp\panoramas_ggx2\51A9A9F8_thumb.tga" Loaded image file "Temp\panoramas_ggx2\5C0C0C5_thumb.tga" Loaded image file "Temp\panoramas_ggx2\95E5E57_thumb.tga" Loaded image file "textures\dark\LayersIcons.tga" Loaded image file "textures\dark\stdbutton2.tga" * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_ALL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ENV Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ENV #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_ENV Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_COLOR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_COLOR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_RELIEF Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_RELIEF #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_RELIEF Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPECULAR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPECULAR #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_SPECULAR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ROUGH Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ROUGH #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_ROUGH Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPCOLOR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPCOLOR #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_SPCOLOR Compiling VS... Compiling PS... * Loading shader "Shaders/shadow_sel.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/shadow_tbn.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL #define SHADOWS Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL #define VERT_NORMAL #define SHADOWS Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_ALL #define SHADOWS Compiling VS... Compiling PS... Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Loaded image file "textures\chess.dds" Loaded image file "textures\black.dds" Loaded image file "textures\dashes.dds" Loaded image file "textures\dashes2.dds" Loaded image file "textures\snow.dds" Loaded image file "textures\borders\viewport.tga" * Loading shader "Shaders/hud_smooth.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... Loaded image file "textures\borders\input_field.tga" Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Loaded image file "Textures\icons\arrowright.tga" Loaded image file "Textures\icons\arrowdown.tga" Loaded image file "textures\icons\move_area_16.tga" Loaded image file "textures\borders\dock_delimiter.tga" Loaded image file "textures\light\tabbutton_line.tga" Loaded image file "textures\dark\tabbutton_inactive.tga" Loaded image file "textures\dark\tabbutton.tga" Loaded image file "textures\borders\buttons.tga" Loaded image file "textures\dark\checkers.tga" Loaded image file "textures\BothSideArrows.tga" Loaded image file "textures\vista3.dds" Loaded image file "Textures\dark\DownArrow.tga" Loaded image file "textures\borders\combo_inner_frame.tga" Loaded image file "textures\borders\combo_arrow_frame.tga" Loaded image file "textures\borders\dialog_header.tga" Loaded image file "textures\borders\dialogs.tga" Loaded image file "textures\borders\toolset_internal_buttons.tga" Loaded image file "textures\\light\\Navigation_ext.tga" Loaded image file "textures\light\Navigation_ext.tga" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Loaded image file "textures\icons\larrow.tga" Loaded image file "textures\switchcolors.tga" Loaded image file "textures\borders\docked.tga" Loaded image file "textures\icons\wicons.png" Loaded image file "textures\borders\top_menu_highlight.tga" Loaded image file "textures\borders\menu.tga" Loaded image file "textures\dark\dock_header_plane.tga" Loaded image file "textures\borders\menu_highlight.tga" Loading file: C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub_painting.3b 00000000 : RNDR : 8 bytes 00000010 : NSYZ : 0 bytes 00000018 : NBLN : 0 bytes 00000020 : NWCL : 0 bytes 00000028 : MSSK : 20 bytes 00000044 : PAUV : 16 bytes C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub_painting.3b: Unknown block found in 3DB file: VUAP! 0000005C : MEAS : 8 bytes 0000006C : CAM1 : 88 bytes 000000CC : LNRM : 4 bytes 000000D8 : SSPC : 0 bytes 000000E0 : VERS : 21 bytes C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub_painting.3b: Unknown block found in 3DB file: SREV! 000000FD : LR01 : 1936 bytes 00000895 : MTLS : 341 bytes 000009F2 : MTEX : 129 bytes 00000A7B : OBJS : 227 bytes 00000B66 : RNTS : 372 bytes 00000CE2 : UVST : 368 bytes 00000E5A : SUBD : 0 bytes 00000E62 : VMAP : 4 bytes 00000E6E : VMTP : 49 bytes 00000EA7 : POS0 : 1536 bytes 000014AF : UVS0 : 8 bytes 000014BF : SAR8 : 27133 bytes Faces: done SetupUVIds: done SetAllDirty: done 00007EC4 : MAQ3 : 2462616 bytes 00:00.079 PreCreateFromMesh: 0 00261264 : CMSC : 61 bytes 002612A9 : STIL : 2295 bytes Loaded image file "..\..\Users\FamilyPC\Downloads\Hydraulic Excavtor.jpg" 00261BA8 : RTP1 : 185 bytes 00261C69 : SYMM : 8 bytes 00261C79 : UVM1 : 177 bytes 00261D32 : METU : 16 bytes 00261D4A : VOL3 : 4 bytes 00261D56 : VCSH : 4 bytes 00261D62 : WMSV : 10 bytes 00261D74 : EXOP : 2510 bytes 0026274A : GRIS : 56 bytes 0026278A : SSTR : 20 bytes 002627A6 : MVSV : 4 bytes 002627B2 : CVSV : 4 bytes 002627BE : EСS1 : 12 bytes 002627D2 : OLCO : 4 bytes 002627DE : RFSV : 4194388 bytes 0066283A : FITT : 116 bytes 006628B6 : MSRT : 452 bytes 00662A82 : SCPT : 52 bytes 00662ABE : SP&J : 1077 bytes 00662EFB : VOSS : 4 bytes 00662F07 : HLSV : 4 bytes 00662F13 : RTGV : 4 bytes 00662F1F : OBJV : 4 bytes 00662F2B : MATV : 4 bytes 00662F37 : BPSS : 343 bytes 00663096 : VCUR : 29 bytes 006630BB : SELP : 120 bytes 0066313B : REND : 1130 bytes 006635AD : PTEX : 944 bytes 00663965 : URC1 : 20 bytes 00663981 : APSV : 12 bytes 00663995 : SYNP : 430 bytes 00:00.157 CreateBackEdges2: 0 00:00.157 InitFace: 0 PutFacesInCells: done * Loading shader "Shaders/rt_copy.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... UpdateDirtyFaces: done Loaded image file "Textures\grey.dds" Loaded image file "Textures\whitet.dds" Loaded image file "Textures\emptygrey.dds" CreateMeshes: done CreatePaddingInfo: done CreatePointsCorrespondence: done CreateTangentSpaceFromBasicNormals: done Loading: done Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Undocked: Undocked: Undocked: Undocked: Deleted: Pen Deleted: PenOpt Deleted: STRIPS Deleted: Blending Deleted: Layers Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "textures\borders\layers.tga" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" * Loading shader "Shaders/tex_preview.hlsl"... #define SCREEN_SPACE #define FORDP Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview_nrm.hlsl"... #define SCREEN_SPACE #define FORDP Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview_alpha.hlsl"... #define SCREEN_SPACE #define FORDP Compiling VS... Compiling PS... Loaded image file "textures\borders\combo_dropdown_frame.tga" Loaded image file "textures\dark\dock_header.tga" Loaded image file "textures\borders\undocked.tga" Can't load image file "textures\enum\SoftwarePreset\Unknown.png" Can't load image file "textures\enum\SoftwarePreset\3D-Max.png" Can't load image file "textures\enum\SoftwarePreset\Blender.png" Can't load image file "textures\enum\SoftwarePreset\Maya_2013_and_later.png" Can't load image file "textures\enum\SoftwarePreset\Maya_2015_and_later.png" Can't load image file "textures\enum\SoftwarePreset\Maya_prior_2013.png" Can't load image file "textures\enum\SoftwarePreset\Substance Designer & Painter.png" Can't load image file "textures\enum\SoftwarePreset\Unity.png" Can't load image file "textures\enum\SoftwarePreset\UnrealEngine.png" Can't load image file "textures\enum\SoftwarePreset\ZBrush.png" Can't load image file "textures\enum\SoftwarePreset\Add_preset.png" Can't load image file "textures\enum\NORMMETHOD\Coat_normals.png" Can't load image file "textures\enum\NORMMETHOD\Maya_normals.png" Can't load image file "textures\enum\NORMMETHOD\nm_AngleWeighed.png" Can't load image file "textures\enum\NORMMETHOD\nm_SquareWeighed.png" Can't load image file "textures\enum\NORMMETHOD\nm_AngleSquareWeighed.png" Can't load image file "textures\enum\NMAPEXPORT_ENUM\NM_3DMAX.png" Can't load image file "textures\enum\NMAPEXPORT_ENUM\NM_MAYA.png" Can't load image file "textures\enum\TRIMETHOD\DelaunayTriangulation.png" Can't load image file "textures\enum\TRIMETHOD\NaiveTriangulation.png" Can't load image file "textures\enum\TBNMETHOD\MikkTSpace.png" Can't load image file "textures\enum\TBNMETHOD\LengyelSpace.png" Can't load image file "textures\enum\TBNMETHOD\LengyelAngleWeightedSpace.png" Can't load image file "textures\enum\TBNMETHOD\LengyelAreaAngleWeightedSpace.png" Can't load image file "textures\enum\TBNMETHOD\Maya.png" Can't load image file "textures\enum\RT_PADDING\InterpolatedColorPadding.png" Can't load image file "textures\enum\RT_PADDING\NearestPixelPadding.png" Can't load image file "textures\enum\RT_PADDING\NaivePadding.png" Can't load image file "textures\enum\FILLBORDER_ENUM\FILLB_ASK.png" Can't load image file "textures\enum\FILLBORDER_ENUM\FILLB_FILL.png" Can't load image file "textures\enum\FILLBORDER_ENUM\FILLB_NOFILL.png" Loaded image file "textures\borders\class_tab_passive.tga" Loaded image file "textures\borders\class_tab_active.tga" Can't load image file "textures\stdbutton.tga" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Undocked: Undocked: Undocked: Undocked: Deleted: Pen Deleted: PenOpt Deleted: STRIPS Deleted: Blending Deleted: Layers Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "textures\close.tga" Loaded image file "textures\borders\hints.tga" Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "FillPatterns\leather2.bmp" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Undocked: Undocked: Undocked: Undocked: Deleted: Pen Deleted: PenOpt Deleted: STRIPS Deleted: Blending Deleted: Layers Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Undocked: Undocked: Undocked: Undocked: Deleted: Pen Deleted: PenOpt Deleted: STRIPS Deleted: Blending Deleted: Layers Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Can't load image file "textures\enum\SoftwarePreset\Unknown.png" Can't load image file "textures\enum\SoftwarePreset\3D-Max.png" Can't load image file "textures\enum\SoftwarePreset\Blender.png" Can't load image file "textures\enum\SoftwarePreset\Maya_2013_and_later.png" Can't load image file "textures\enum\SoftwarePreset\Maya_2015_and_later.png" Can't load image file "textures\enum\SoftwarePreset\Maya_prior_2013.png" Can't load image file "textures\enum\SoftwarePreset\Substance Designer & Painter.png" Can't load image file "textures\enum\SoftwarePreset\Unity.png" Can't load image file "textures\enum\SoftwarePreset\UnrealEngine.png" Can't load image file "textures\enum\SoftwarePreset\ZBrush.png" Can't load image file "textures\enum\SoftwarePreset\Add_preset.png" Can't load image file "textures\enum\NORMMETHOD\Coat_normals.png" Can't load image file "textures\enum\NORMMETHOD\Maya_normals.png" Can't load image file "textures\enum\NORMMETHOD\nm_AngleWeighed.png" Can't load image file "textures\enum\NORMMETHOD\nm_SquareWeighed.png" Can't load image file "textures\enum\NORMMETHOD\nm_AngleSquareWeighed.png" Can't load image file "textures\enum\NMAPEXPORT_ENUM\NM_3DMAX.png" Can't load image file "textures\enum\NMAPEXPORT_ENUM\NM_MAYA.png" Can't load image file "textures\enum\TRIMETHOD\DelaunayTriangulation.png" Can't load image file "textures\enum\TRIMETHOD\NaiveTriangulation.png" Can't load image file "textures\enum\TBNMETHOD\MikkTSpace.png" Can't load image file "textures\enum\TBNMETHOD\LengyelSpace.png" Can't load image file "textures\enum\TBNMETHOD\LengyelAngleWeightedSpace.png" Can't load image file "textures\enum\TBNMETHOD\LengyelAreaAngleWeightedSpace.png" Can't load image file "textures\enum\TBNMETHOD\Maya.png" Can't load image file "textures\enum\RT_PADDING\InterpolatedColorPadding.png" Can't load image file "textures\enum\RT_PADDING\NearestPixelPadding.png" Can't load image file "textures\enum\RT_PADDING\NaivePadding.png" Can't load image file "textures\enum\FILLBORDER_ENUM\FILLB_ASK.png" Can't load image file "textures\enum\FILLBORDER_ENUM\FILLB_FILL.png" Can't load image file "textures\enum\FILLBORDER_ENUM\FILLB_NOFILL.png" Loaded image file "..\..\Users\FamilyPC\Documents\3D-CoatV47\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Undocked: Undocked: Undocked: Undocked: Deleted: Pen Deleted: PenOpt Deleted: STRIPS Deleted: Blending Deleted: Layers Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "Shaders\ViewModes\GGX\brdf.dds" Loaded image file "Shaders\ViewModes\GGX_Marmoset\brdf.dds" Loaded image file "Shaders\ViewModes\CompatibilityShader\brdf.dds" Can't load image file "textures\enum\WMapType\wmNone.png" Can't load image file "textures\enum\WMapType\wmUnsignedWeightmap.png" Can't load image file "textures\enum\WMapType\wmSignedWeightmap.png" Can't load image file "textures\enum\$LRLINKAGELIST\NO_LINK.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 0.png" Can't load image file "textures\enum\$LRLINKAGELIST\Layer 1.png" Loaded image file "textures\lineprofile.png" Loaded image file "textures\spot12.png" Loaded image file "textures\spot12_empty.png" Options.xml: <AppOptions> <PenInterface::DisplaceObject>false</PenInterface::DisplaceObject> <RtpObj>true</RtpObj> <SoftwarePreset>Unknown</SoftwarePreset> <NormalsCalculationMethod>Maya_normals</NormalsCalculationMethod> <TriangulationMethod>DelaunayTriangulation</TriangulationMethod> <TBNMethod>MikkTSpace</TBNMethod> <SwapTB>false</SwapTB> <DenormalizedTB>false</DenormalizedTB> <NMAP_EXPORT_TYPE>NM_MAYA</NMAP_EXPORT_TYPE> <FlipPtexQuads>false</FlipPtexQuads> <ShowFocalShift>false</ShowFocalShift> <ShowFalloff>true</ShowFalloff> <StorePenShapeForTools>true</StorePenShapeForTools> <StorePenRadiusForTools>true</StorePenRadiusForTools> <WHEEL_ACTION>WHEEL_CHANGE_RADIUS</WHEEL_ACTION> <CTRL_WHEEL_ACTION>WHEEL_CHANGE_PRESSURE</CTRL_WHEEL_ACTION> <SHIFT_WHEEL_ACTION>WHEEL_CHANGE_SMOOTH</SHIFT_WHEEL_ACTION> <ALT_WHEEL_ACTION>WHEEL_CHANGE_OPACITY</ALT_WHEEL_ACTION> <WheelZoomPerspSpeed>1.000000</WheelZoomPerspSpeed> <WheelZoomOrthoSpeed>1.000000</WheelZoomOrthoSpeed> <WheelZoomUVSpeed>1.000000</WheelZoomUVSpeed> <MainColor>FFE8E72B</MainColor> <BackColor>FFA40D11</BackColor> <EnableChannels[0]>true</EnableChannels[0]> <EnableChannels[1]>false</EnableChannels[1]> <EnableChannels[3]>false</EnableChannels[3]> <NearPlane>1.000000</NearPlane> <PivotType>1</PivotType> <PenInterface::SaveSpecInNM>false</PenInterface::SaveSpecInNM> <PenInterface::SaveDispInNM>false</PenInterface::SaveDispInNM> <PenInterface::DontUseAnphaInNM>false</PenInterface::DontUseAnphaInNM> <PenInterface::DontUseAnphaAtAll>false</PenInterface::DontUseAnphaAtAll> <SymmSnapValue>0.400000</SymmSnapValue> <SnappingMethod2>1</SnappingMethod2> <Global_DontSnapSubdVertices>true</Global_DontSnapSubdVertices> <ProjectionThrough>false</ProjectionThrough> <FreezeViewMode>0</FreezeViewMode> <FreezePScrollSpeed>1.000000</FreezePScrollSpeed> <UsingProcessors>32</UsingProcessors> <UseMultiCore>true</UseMultiCore> <UseMulticoreForSaving>true</UseMulticoreForSaving> <UseMRT>true</UseMRT> <PickFromAllLayers1>true</PickFromAllLayers1> <PickDepthToo>true</PickDepthToo> <PickFromCentralPoint>true</PickFromCentralPoint> <PivotType>1</PivotType> <SwapYZ>false</SwapYZ> <EditorPath>photoshop.exe</EditorPath> <MeshViewQuality>0</MeshViewQuality> <Choose></Choose> <RealtimePaddingMode>InterpolatedColorPadding</RealtimePaddingMode> <FILL_BORDERS_MODE>FILLB_FILL</FILL_BORDERS_MODE> <BorderEdgesWidth>256</BorderEdgesWidth> <LightDirX>-0.562900</LightDirX> <LightDirY>-0.279500</LightDirY> <LightDirZ>0.279500</LightDirZ> <MillionsOfPolygons>1.000000</MillionsOfPolygons> <TexSizeX>2048</TexSizeX> <TexSizeY>2048</TexSizeY> <LightContrast>0.000000</LightContrast> <ShowThumbs>true</ShowThumbs> <ShowIThumbs>true</ShowIThumbs> <ImgPath> <_str>PickData\sky.jpg</_str> </ImgPath> <PickerType>2</PickerType> <PickColorMode>0</PickColorMode> <PenSensivity>1.000000</PenSensivity> <Symmetry_point_opacity>40.000000</Symmetry_point_opacity> <CamZoomSpeed>1.000000</CamZoomSpeed> <CamRotSpeed>1.000000</CamRotSpeed> <SlidersStates> <SliderState> <ID>SMOOTH_STROKE</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_RADIUS</ID> <State>true</State> </SliderState> <SliderState> <ID>FALLOFF</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_DEPTH</ID> <State>true</State> </SliderState> <SliderState> <ID>SMOOTH_DEG</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_MASK</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_SPEC</ID> <State>true</State> </SliderState> <SliderState> <ID>Roughness</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_METAL</ID> <State>true</State> </SliderState> <SliderState> <ID>ERASE_DEGREE</ID> <State>true</State> </SliderState> <SliderState> <ID>$preset_section_Surface</ID> <State>true</State> </SliderState> <SliderState> <ID>MASK_OPACITY</ID> <State>true</State> </SliderState> <SliderState> <ID>*VoxelTools4</ID> <State>true</State> </SliderState> <SliderState> <ID>*Adjust4</ID> <State>true</State> </SliderState> <SliderState> <ID>*Objects4</ID> <State>true</State> </SliderState> <SliderState> <ID>*Surface4</ID> <State>true</State> </SliderState> <SliderState> <ID>*Commands4</ID> <State>true</State> </SliderState> <SliderState> <ID>*Sculpt1</ID> <State>true</State> </SliderState> <SliderState> <ID>RetopoExtrusion</ID> <State>true</State> </SliderState> <SliderState> <ID>ViewBias</ID> <State>true</State> </SliderState> <SliderState> <ID>RtpOpacity</ID> <State>true</State> </SliderState> <SliderState> <ID>SymmSnapValue</ID> <State>true</State> </SliderState> <SliderState> <ID>*Basic2</ID> <State>true</State> </SliderState> <SliderState> <ID>*Tweak2</ID> <State>true</State> </SliderState> <SliderState> <ID>*UV2</ID> <State>false</State> </SliderState> <SliderState> <ID>*Commands2</ID> <State>true</State> </SliderState> <SliderState> <ID>*LC4</ID> <State>false</State> </SliderState> <SliderState> <ID>SegmentsNum</ID> <State>true</State> </SliderState> <SliderState> <ID>*Modes3</ID> <State>true</State> </SliderState> <SliderState> <ID>*Commands3</ID> <State>true</State> </SliderState> <SliderState> <ID>*Selected3</ID> <State>true</State> </SliderState> <SliderState> <ID>FREEZE_DIFF</ID> <State>true</State> </SliderState> <SliderState> <ID>FREEZE_DETAILS</ID> <State>true</State> </SliderState> <SliderState> <ID>FREEZE_SM_DEGREE</ID> <State>true</State> </SliderState> <SliderState> <ID>FREEZE_SMOOTH</ID> <State>true</State> </SliderState> <SliderState> <ID>SplitBorderWidth</ID> <State>true</State> </SliderState> <SliderState> <ID>PlaneSoftness</ID> <State>true</State> </SliderState> <SliderState> <ID>NrmSampling</ID> <State>true</State> </SliderState> <SliderState> <ID>MoveDegree</ID> <State>true</State> </SliderState> </SlidersStates> <FoldersStates> <FolderState> <ID>OPENOBJ</ID> <Folder>C:\Users\FamilyPC\Documents\Blender\projects\Hydraulic Excavtor\export\Prep for 3d Coat voxel\</Folder> </FolderState> <FolderState> <ID>ObjLwoStlPlydaewrl</ID> <Folder>C:\Users\FamilyPC\Documents\Blender\projects\Hydraulic Excavtor\export\Prep for 3d Coat voxel\</Folder> </FolderState> <FolderState> <ID>ObjLwoStlPlydaewrl3b</ID> <Folder>C:\Users\FamilyPC\Documents\Blender\projects\Hydraulic Excavtor\export\Prep for 3d Coat voxel\</Folder> </FolderState> <FolderState> <ID>LOADTEX</ID> <Folder>C:\Users\FamilyPC\Documents\Blender\projects\Characters\Females\Assets\</Folder> </FolderState> <FolderState> <ID>tgabmppngjpgddstiftiffexrhdr</ID> <Folder>C:\Users\FamilyPC\Downloads\</Folder> </FolderState> <FolderState> <ID>SAVEMESH</ID> <Folder>C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\</Folder> </FolderState> <FolderState> <ID>3b</ID> <Folder>C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\</Folder> </FolderState> <FolderState> <ID>SAVETEX</ID> <Folder>C:\Users\FamilyPC\Documents/3D-CoatV47/UserData/</Folder> </FolderState> <FolderState> <ID>psd</ID> <Folder>C:\Users\FamilyPC\Documents\Adobe\Excavator\</Folder> </FolderState> <FolderState> <ID>3b3b.jpg</ID> <Folder>C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\</Folder> </FolderState> <FolderState> <ID>save:*.Obj;*.Lwo;*.Fbx;*.Stl;*.Ply;*.dae;*.wrl;</ID> <Folder>C:\Users\FamilyPC\Documents\Blender\projects\Characters\Females\Assets\Final\3dCoat export\outfit\</Folder> </FolderState> <FolderState> <ID>MASKSHAPEDIR</ID> <Folder>C:\Users\FamilyPC\Pictures\cg_textures\metal\</Folder> </FolderState> <FolderState> <ID>tgabmppngjpgabrtiftiffexrobjlwo</ID> <Folder>C:\Users\FamilyPC\Pictures\cg_textures\metal\</Folder> </FolderState> <FolderState> <ID>PENSHAPEDIR</ID> <Folder>C:\Users\FamilyPC\Pictures\cg_textures\metal\</Folder> </FolderState> <FolderState> <ID>tgabmppngjpgabrobjlwopsdmclptif</ID> <Folder>C:\Users\FamilyPC\Pictures\cg_textures\metal\</Folder> </FolderState> <FolderState> <ID></ID> <Folder>C:\Users\FamilyPC\Documents\3D-CoatV47\patterns\</Folder> </FolderState> <FolderState> <ID>tgabmppngjpgddstiftiffexr</ID> <Folder>C:\Users\FamilyPC\Documents\3D-CoatV47\patterns\</Folder> </FolderState> <FolderState> <ID>SEL_TEXT</ID> <Folder>C:\Users\FamilyPC\Downloads\</Folder> </FolderState> <FolderState> <ID>exrhdr</ID> <Folder></Folder> </FolderState> <FolderState> <ID>save:*.tga;*.bmp;*.png;*.jpg;*.tif;*.tiff</ID> <Folder></Folder> </FolderState> <FolderState> <ID>tgabmppngjpgtiftiff</ID> <Folder></Folder> </FolderState> <FolderState> <ID>*.obj;*.fbx,*.lwo</ID> <Folder></Folder> </FolderState> <FolderState> <ID>objfbxlwo</ID> <Folder></Folder> </FolderState> <FolderState> <ID>SAVEOBJ</ID> <Folder>C:\Users\FamilyPC\Documents\Blender\projects\Hydraulic Excavtor\export\</Folder> </FolderState> <FolderState> <ID>tgabmppngjpgdds</ID> <Folder>C:\Users\FamilyPC\Downloads\</Folder> </FolderState> <FolderState> <ID>PICKIMG</ID> <Folder>C:\Users\FamilyPC\Downloads\</Folder> </FolderState> </FoldersStates> <AllowRmbProp>true</AllowRmbProp> <AllowMaterialNavigaion>false</AllowMaterialNavigaion> <LockPanorama>false</LockPanorama> <PanoRotation>1.750000</PanoRotation> <PanoBlurEx>3.880000</PanoBlurEx> <ShadersPreviewSize>1</ShadersPreviewSize> <GreyscalePano>false</GreyscalePano> <RareGrid>false</RareGrid> <NormalGrid>true</NormalGrid> <DenseGrid>false</DenseGrid> <CustomGrid>false</CustomGrid> <GridStep3D>1.000000</GridStep3D> <GridSubSections>1</GridSubSections> <GridStepsCount>10</GridStepsCount> <ShowAxisX>true</ShowAxisX> <ShowAxisY>true</ShowAxisY> <ShowAxisZ>true</ShowAxisZ> <MovementSensitivity>1.000000</MovementSensitivity> <ZoomModulator>1.000000</ZoomModulator> <PanUDModulator>1.000000</PanUDModulator> <PanRLModulator>1.000000</PanRLModulator> <RotationSensitivity>1.000000</RotationSensitivity> <SpinModulator>1.000000</SpinModulator> <TiltModulator>1.000000</TiltModulator> <RollModulator>1.000000</RollModulator> <M3D_ActivationKey>Key 1</M3D_ActivationKey> <PenIconSize>1</PenIconSize> <StripIconSize>1</StripIconSize> <MaskIconSize>1</MaskIconSize> <MtlIconSize>3</MtlIconSize> <ModelsIconSize>2</ModelsIconSize> <RotateAroundYAxis>true</RotateAroundYAxis> <DisableRoll>false</DisableRoll> <RealtimeUVPreview>true</RealtimeUVPreview> <ZoomToVaryRadiusSensitivity>1.000000</ZoomToVaryRadiusSensitivity> <UpDonToVaryDepthSensitivity>1.000000</UpDonToVaryDepthSensitivity> <RLToVaryTransparencySensitivity>1.000000</RLToVaryTransparencySensitivity> <SpinToVaryRotationSensitivity>1.000000</SpinToVaryRotationSensitivity> <TiltToVaryFocalShiftSensitivity>1.000000</TiltToVaryFocalShiftSensitivity> <RollToVarySpecularSensitivity>1.000000</RollToVarySpecularSensitivity> <GeneralPen::Color.x>0.168627</GeneralPen::Color.x> <GeneralPen::Color.y>0.905882</GeneralPen::Color.y> <GeneralPen::Color.z>0.909804</GeneralPen::Color.z> <GeneralPen::Color2.x>0.066667</GeneralPen::Color2.x> <GeneralPen::Color2.y>0.050980</GeneralPen::Color2.y> <GeneralPen::Color2.z>0.643137</GeneralPen::Color2.z> <GeneralPen::PenRadius>15.143344</GeneralPen::PenRadius> <GeneralPen::PenRotation>0.000000</GeneralPen::PenRotation> <GeneralPen::DeepDegree>0.500000</GeneralPen::DeepDegree> <GeneralPen::ColorOpacity>0.939413</GeneralPen::ColorOpacity> <GeneralPen::SpecularDegree>1.000000</GeneralPen::SpecularDegree> <GeneralPen::Falloff>0.000000</GeneralPen::Falloff> <GeneralPen::FocalShift>0.000000</GeneralPen::FocalShift> <HidePenConstantlyInCapsMode>false</HidePenConstantlyInCapsMode> <HidePenConstantly>false</HidePenConstantly> <ShowPenShape>true</ShowPenShape> <ShowPenAlpha>true</ShowPenAlpha> <PenCircleColor>FFFFFF00</PenCircleColor> <PenShapeColor>FFFF0000</PenShapeColor> <PenShapeColorWithCTRL>FF0000FF</PenShapeColorWithCTRL> <PenShapeColorWithSHIFT>FF00FF00</PenShapeColorWithSHIFT> <ShowCentralSpotInCapsMode>true</ShowCentralSpotInCapsMode> <MessageAbovePen>0</MessageAbovePen> <MessageBelowPen>0</MessageBelowPen> <MessagesColor>FFFF0000</MessagesColor> <PickVertMode2>1</PickVertMode2> <RecentFiles> <_str>C:\Users\FamilyPC\Documents\Blender\projects\Characters\Females\Assets\Final\obj\lunch_lady.obj(dp)</_str> <_str>C:\Program Files\3D-Coat-V4.7.06\Samples\dino.4.obj(dp)</_str> <_str>C:\Users\FamilyPC\Documents\Blender\projects\Characters\Females\Assets\Final\obj\lunch_lady-base_body.obj(dp)</_str> <_str>C:\Users\FamilyPC\Documents\Blender\projects\Characters\Females\Assets\Final\obj\lunch_lady-base_body_No-Mole.obj(dp)</_str> <_str>C:\Users\FamilyPC\Documents\Blender\projects\Characters\Females\Assets\Final\obj\lunch_lady-base_body_No-Mole_tiles.obj(dp)</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\UserData\autosave.3b</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\UserData\lunch-lady.3b</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\UserData\new lunch lady.3b</_str> <_str>C:\Users\FamilyPC\Documents\Blender\projects\Characters\Females\Assets\Final\obj\lunch_lady-outfit.obj(dp)</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\UserData\lunch_lady-outfit.3b</_str> <_str>StartMenu/files/preview_sphere.3b</_str> <_str>C:\Users\FamilyPC\Documents\Blender\projects\Hydraulic Excavtor\export\Hydraulic Excavator high-p.fbx(dp)</_str> <_str>C:\Users\FamilyPC\Documents\Blender\projects\Hydraulic Excavtor\export\Hydraulic Excavator uv-mapping.fbx(dp)</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\UserData\Excavator\hub.3b</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub.3b</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub_002.3b</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub_003.3b</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub painting.3b</_str> <_str>C:\Users\FamilyPC\Documents\Blender\projects\Hydraulic Excavtor\export\Prep for 3d Coat voxel\Excavator_Hub_e-loops.fbx(dp)</_str> <_str>C:\Users\FamilyPC\Documents/3D-CoatV47/UserData\autosave.3b</_str> <_str>C:\Users\FamilyPC\Documents\3D-CoatV47\projects\Excavator\hub_painting.3b</_str> </RecentFiles> </AppOptions> hub_painting.zip
  7. I was just watching a few PBR tutorials and I'm finding myself, as ever, out of the picture... In the first few minutes of the tuts, I come up against words that mean nothing to me. So as ever I appreciate everyone's patients as I leave the real world and try to comprehend the world of CGI. I have so many questions I don't know where to start... Is creating a new smart material the (simplest) way of getting an image file( ie: jpeg,png etc) onto a model? What is the meaning of ambient occlusion and what is it used for? What is the meaning of curvature map and what is that used for? I'll leave it at that for now! Please remember I have not used a 3d modeling software before I am a newbie newbie, but enthusiastic to learn. Thanks!
  8. Paint Room Import model for PPP When i import a model all the materials are listed as UV set names The original exported model have 6 meshes and 11 materials After import i have 6 paint objects but 11 uv sets. The original model have only 1 uvset by mesh. Total = 6 uv sets - File format export dont matter, obj, fbx, dae... - Preferences > Treat retopo objects as Paint Object dont matter, this option on/off change anything When exporting textures i have 11 normal maps, 11 reflections maps, etc What workflow i need ? Be able to import a model made by different meshes, and to use for every mesh their own original UVset. To have automatic group layer created by mesh, but inside every layer group to have for every material a layer created and named. Export only texture maps by paint objects, not for every material Whats im doing wrong ? cant achieve this workflow Any help is appreciated. ty
  9. Hello! There is probably an easy fix to this, but I can't figure it out by myself.. I import my uv'ed model into the paint room, per pixel painting method. I fill the model with white color (fill tool) and start painting in black areas. In those black areas I then see reflections of the environment map. Naturally, when I choose "flat shade" in menu > view the reflections disappear. How can I make those reflections disappear? ..or.. How can I influence the amount of reflectiveness of the blinn-phong or any other shader, which are selectable in menu > view? How do I change the properties of those shaders, e.g. no reflection in general? Cheers Michael
  10. I have run into something confusing within the paint room. Irrespective of which pen alpha I enable, the paint stroke seems to be locked to a "pen 4" alpha type...a hairy blob if you will. This seems to be in effect whether painting a UV map or vertex painting. As always any suggestions appreciated. bk
  11. For some reason, whenever I paint with a metal smart material, it paints black. What is going on?
  12. I'm using the latest stable version of 3D-Coat. Regardless of what model I am working on. . the menus will not be accessable when I have color palette open. . everything else besides the color palette is frozen until I close the color palette. I do have an image open inside the palette to pick color from if that makes any difference. Thanks Daniel
  13. I have two problems. First one is as I add layers of paint to my model or even just paint for a long time, the screen and light effects become lighter and lighter until I can hardly see the colour of the paint on the object. Any ideas what is causing this? Ambient Occlusion - when I move the light sources or even the intensity, i cannot get the light in the right position over the object no matter how hard I try. Any tips for that? I am using the new beta version. thank you
  14. Hey Guys! This might be a fairly basic question, but I've noticed that switching layer visibility on/off seems to take quite some time in the paint room. I get similar performance issues when it comes to merging layers as well. I should mention that I generally use multiple 4k UV tiles for my objects, because I tend to render with udim textures. Is there a way to speed this issue up a bit? I've had a really good experience with everything else in 3dcoat. The ability to paint deep displacement/ diffuse/ spec with different map projections at the same time is simply amazing. This particular issue though, slows the whole workflow down quite a lot. Especially when it comes to testing new overlay layers with different design patterns etc... -Luke
  15. sometimes (seemingly random) the large array of brushes is reduced to only 11. why is this and how do i change it back in the paint room
  16. Hi, I've been working with the Spline tool in the Paint Room today and I want to insert a few points within an existing spline. On-screen help says "Use RMB to resize points, and to insert new points with an interpolated radius," but when I click on a segment of the spline using the RMB, a point is not created there. I also tried different modifer key combos but no luck so far. Thanks in advance for any useful tips. G.
  17. Hello everyone! Is there a way to create folders or groups in the Paint Room for the layers? This would be nice, because organizing layers could be easier sometimes. Right now, having several layers would look something like this: head_color head_normals head_spec body_color body_normals_01 body_normals_02 body_spec arms_color arms_normals legs_color legs_normals But with groups: head head_color head_normals head_spec body body_color body_normals_01 body_normals_02 body_spec arms arms_color arms_normals legs legs_color legs_normals So one could collapse different parts and hide\unhide complete groups.
  18. Please, consider the following scenario. 1. If you import this .obj file to 3D Coat for laying out UVs, you get: - Materials named: ->materialA - containing objects A-D, ->materialB - containing objects E-F, ->materialC - containing object G. - UV-sets named: ->materialA - containing UVs of objects A-D, ->materialB - containing UVs of objects E-F, ->materialC - containing UVs of object G. This is very convenient and I like it. 2. Let's see what happens if you import the same model to PPP. What you get is: - Materials: ->materialA - containing objects A-D, ->materialB - containing objects E-F, ->materialC - containing object G. - Objects: ->objectA, ->objectB, (...) ->objectG. So again, it's very convenient. You can hide, fill, etc. multiple subobjects sharing a certain material, but you can also do the same with individual subobjects. 3. When imported to Voxel Room, the model is separated into subobjects and each subobject receives its own layer. Perfect. BUT... 4. If you import the model to Retopo Room, here things look a bit different. - Groups: ->materialA - contains objects A-D, ->materialB - contains objects E-F, ->materialC - contains object G. - UV-sets: -> NO UV-SETS ARE CREATED! This can be good or bad, depending on what you want to do. If baking with names correspondence is your goal, than it's damn awful, because you now have to: ->create a Group for each subobject and name it correctly (using former subobject name that was lost when you imported the model to Retopo Room, ->move each subobject from a group that it shares with other subobjects, to its individual group you have just created. ->recreate UV-sets and move objects according to their former UV-set linkage. Let's say, you're done with this additional work and are ready for baking with names correspondence selected. The result is: 5. Paint Room: - Materials: ->objectA_materialA - contains objectA, ->objectB_materialA - contains objectB, ->objectC_materialA - contains objectC, ->objectD_materialA - contains objectD, ->objectE_materialB - contains objectE, ->objectF_materialB - contains objectF, ->objectG_materialC - contains objectG. - Objects: ->objectA_objectB_objectC_objectD_objectE_objectF (a combination of all object names, up to 50 characters) - contains ALL SUBOBJECTS(!). So it goes completely bananas here when compared to how it worked in point #2. Is this behaviour intentional or is it a bug?
  19. There's Textures->Adjust->Color to Specular command. But is there an opposite command for that, like Specular to Color? I'm struggling with the inability to paint 0% specularity on a layer that is over another layer with some specularity info. I thought about using a workaround with which I'd simply copy specularity to color and create a separate layer out of it, but it seems there's no easy way of doing it without exporting specularity information to a file. And this is broken when it comes to exporting specularity from a currently selected layer only. A tooltip for Layers->Export->Specularity states: The thing is, it exports specularity from all visible layers, so any other layer from which I don't want to export specularity should be hidden. And if I have 50 layers? Also, what's even worse, the alpha mask in exported specularity files is not working properly (see: image)! So it's useless to perform any mathematical operations on both exported images merged into one. It's driving me bananas. Or maybe my workflow is completely wrong? Perhaps it's supposed to be like that: only allow user to add specularity to stacked layers, and never ever subtract from it? So if an underlying layer has 100% specularity, it will remain 100% no matter what kind of specularity information layers that are above it contain? Why always additive? Help!
  20. I purchased 3D coat last week after using the trial version. Here's a character I'm working. This is the "cartoon cute" version of the Ucides cordatus Painted in 3D coat <3 (diffuse and specular) [model made in 3ds max] the texture is still a wip, missing alot of details and better spec Here you can see the crab with some animations i'm doing (unity web player)
  21. Hi there, I wanted to ask if there were a way add edges to your mesh in the tweak room? It seems like it should be there but I don't see it. I also was wondering if while you moved verts around, it relaxed that vert in your uvs to maintain their integrity so when you're back painting you don't have stretching. (though 3dc seems to compensate for that awesomely anyway) Just two questions. Thanks all.
  22. Hello folks. Does anyone know how to create multiple UV tiles in the UV Room and how to prepare the model for seamless texture painting when multiple UV tiles are present? Is it possible in 3D Coat?
  23. dont laugh yall. here it goes. how do I go from a voxel object to the paint room. I can make some nice sculpts but I cant or at least dont know how to paint it
  24. Hello. I've just purchased 3D Coat after my trail ended. I have to say I tried the hell out of it and I'm very impressed with the software. Sculpting with voxels is something I've been looking for for a long, long time, ever since I saw Ken Silverman's Voxlap engine. While not directly related to 3D modelling or sculpting, it showed how powerful voxels might be. I never quite understood why nobody picked up the idea of using voxels for volume shaping and model detailing. And then there was light - I've stumbled upon 3D Coat! But enough of praising the app. I've been doing a hero character in 3D Coat lately and I'm a bit puzzled about the some aspects of the workflow. I would like to address a couple of questions to more experienced 3D Coat users. My character consists of several parts (body, tongue, a pair of tendons and two groups of teeth, each on a different VoxTree layer), so I'll be using several different materials after I import the retopologised model into Maya). I need those parts to stay on separate UV spaces and maintain proportions in relation to each other. I have already retopologised the volume and placed each part of the character on a different retopo layer. Unfortunately UVs from each one of them are bunched up together on a single UV space and I can't seem to find a way to separate them to different UV spaces. How do I do this? Does a voxel shader affect textures in Paint Room in any way, or is it completely ignored? There's a Layer 0 in the Paint Room. What does it contain? Looks like a geometry, but other layers (that were created with the Merge with NM command from Retopo Room) seem to contain geometry as well? Layer 0 can't be deleted. UV Room most of the time stays completely empty, even after I unwrap UVs in Retopo Room. It fills with content after I Merge with NM. Is it normal? Paint Room has me completely puzzled.
