Showing results for tags 'planes'.
Found 3 results
  1. ebitz
    Mighty Wings
    Been a while since posting. Model was done and rendered in Blender as well as smoke FX. All texturing was done in 3D Coat.
  2. Hi, I want to try to create a hairstyle in sculpt mode using planes. I tried the Curves tool but there is no option to create flat plains. Or is it? Do you have any idea how to achieve something like this (just the hair):
  3. The plane carving tool for in Voxel sculpting could be VERY useful. .however it is tricky to use because you have to select 3 or 4 points on the surface and cross your fingers and hope the resulting plane will be where you want it and and the right angle. It would be MUCH easier to just have an actual preview. . semi transparent plane that you can rotate and move in any direction and get the perfect placement. and scale. . lock it and start carving away those planes. Anyone else agree?
