Showing results for tags 'strokes tool'.
Found 2 results
  1. I have this problem since the last version of 3D Coat, When I tried using the curves, most os the time they fail to stroke all the way around. Like the example below: I'm missing some settings? Or doing something wrong? Most od the time I just need to create loops (both painted or sculpted) this is the best way to do it? Cheers! Thank you!
  2. What is the workflow to use the Strokes Tool on cylindrical forms when the symmetry plane goes down the middle of the cylindrical form? I have tried drawing straight through from outside to outside and it appeared that I had doubled up geometry. I tried just drawing from the outside of one half towards the center and that looked messed up too.
