Showing results for tags 'uv shell'.
    • Basics & Interface
    • Questions & Answers
Found 2 results
  1. Hello. I have a low poly model and i'm trying to figure out how can i paint in 3D Coat without constantly fix everything in photoshop. I have this model that the uv was made with half the mesh and then applied symmetry, overlapping shells. the problem is that the 3D Coat brush is horrible to paint over any seam, even those that do not overlap have some sort of problem already tried to send one overlapped shell to 1-0 (no overlap, each shell in a UV room) and still the problem persists I am using 2048 texture size what am i doing wrong? how to avoid such problems with this UV type and seams?
  2. Hi, I'm creating some tileable road sections and in order to tile nicely, the UV shell should touch the edge of the UV space. Otherwise when you tile it, you will see some gaps. By default 3D-Coat always arranges shells with some space away from the edge. I can manually scale and move the shell but it is not very accurate. . .anways to snap edge of shell to edge of UV space or just automatically make it fill the UV space? Thanks! BTW the fact that the texture UV editor shows the UV's tiled automatically has been a big help in creating tileable UV! I like that feature.
