Showing results for tags 'uv'.
I have this weird UV island anomaly that I'm unable to paint on top of. What's that all about?
Hi, Guys. I'm experiencing some problems here on my workflow. I have a model separeted in various objects. Each one have its proper UVs and everything is on place, no UDIM (despite using UDIM would be good. But when I do import with Importing Titles as UV Sets all my UVs are stacked on each other). When I import OBJ file to PPP workflow, 3D Coat shows this screen. T The problem is: I have 12 objects with UVs but it only shows 6 UV sets on the importing options. When I click OK, suddenly 3D Coat shows 6 UV sets and 6 surface materials (of 12 objects) and the result is some UVs stacked on each other, also my UV names are not the same as I created, as you can see on the image: When I try to import a FBX file instead of a OBJ file, it shows ALL of my UVs on the importing screen and PRESERVING the UVS names, which is really good. However, the problem with FBX importing is this. While all my UVs are absolutely perfect, the model itself isn't as you can see on the image. If I try to subdivide de model on importing screen, the result is: Some additional info: Tested with 3D Coat 4.5.19 (trough Steam) and 4.5.29. UVs are created on MODO 902. Thanks in advance.
Is there a way for objects in the voxtree to have individual UV maps? In the attached picture, you can see that all three uv maps are in the same 2d image -- is there a way to have them each be on their own? Thanks much in advance!
Hi! Ive recently started using 3D-coat and so far its been working like a charm. But it is also my first real endavour into the quite complex world of 3D-modeling and so i stand here with some questions regarding importing objects for texturing and freezing when doing certain things. When i try to import an object for per pixel painting that isnt too big och complex it takes a really long time for it to load it. But when its done, if it doesnt freeze, everything is working as it should. But if i try to import one of my mechs for example it just freezes and eats all my ram. I have tried leaving it loading the model for up to 3 hours just to see if its just loading extremely slow or if it freezes but no results. TLDR: Tips for importing bigger models for UV and texturing without breaking your computer?
Hello, I'm hurry, so sorry if I'm bothering you with these newbie questions. I'm using 3DCoat to paint textures on low poly mesh as you can see from the picture. I started my painting with Blender, then I had some projection problem so I switched to 3DCoat. BUT! What I want to know is: a. why cannot I paint over the UV Island in the Texture Editor? Because I find very useful to work the area around the island in order to prevent bleeding effect, or simply I put some colors in no important part of images in order to have a palette (ok, I know I can create a layer in 3DCoat for that, but I'd like to have that colors in image too) b. Blender has an option to do edge padding during paiting: has 3DCoat something similar? c. after importing the obj mesh and the initial texture, I noticed there was a bleeding between all islands: does 3DCoat automatically create edge padding while importing? In fact I'm correcting with less success the bleeding of blue pants over shoes and the brown color of shoes over blue pants. And that brought me to point a. d. I just noticed 3DCoat make an edge padding in automatic between islands: how can I disable it? Thank you very much for any suggestion. Michele
Im Not sure if this is a BUG or Im doing something in the wrong way, help please
ozukaru posted a topic in General 3DCoat
I'm mirroring uv by first making upper retopo mesh then assigning uv's then mirroring top to down geometry, but the final result show some imperfections that show that the mirroring process is not much precise. Could that be related to the fact 3d-coat is not mirroring the exact underlying triangle topology? note that in the upper the two triangles that conform the quad are not equally positioned as the bottom ones (btw the stretched checker patter is intentionally set that way in order to see the underlying triangle better). In the second image Im painting depth as an example of the problem, compare upper to lower. Is that correct? is the problem related to the underlying triangle topology? if this is a BUG will be fixed or is not that relevant? I tried mirroring using "general case", "Local Space", etc all give the same result PLEASE help, Im relying so much in mirroring uv in order to save resources because my models are for a game! THANKS. Edit: added a third image to show what (I think) could solve the problem, an exact replica of the geometry (at a triangle level) -
is there a way to input the exact uv coordinate for a vertex?
Im trying to export a texture that would be a square, I mean not typical uv islands of an unrwapped model but just a square (the only island is a square) that uses 100% of texture space, so in summary I need to give to the 4 vertex the exact uv textures (I tried to adjust manually (see attached image) but since when you pass the corner in the uv preview window there is not limit you con go further you cannot give precise position). So upper left vertex should be 0,0, upper right vertex should have 0,1, etc got the idea? (sorry for my bad english) Is there a way to do that?, now I just can select a vertex an move it, but how to give it and exact vector (x,y)? THANKS! edit: attached image to explain better- 1 reply
- unwrapp
- uv coordinates
Hi I uved a model in 3d-Coat then exported the mesh(with applied uvs) to Zbrush. In Zbrush I opened the uv plugin open the model copy the uvs. Then paste the uvs to the real Ztool mesh. The uvs looks normal as they do in 3dCoat but they are actually assigned to totally wrong polygons, they all look like jumbled but the look of the uvs are identical to the way look in 3dC. At this poitn the uv set is useless to me. I am wondering if 3dC exports the mesh with messed up vertex order? I could not figure out why I get that issue. thanks
I'm a new user to 3D Coat and I've been wrestling with an issue for about 3 days regarding painting with mirrored UV's on a model. When using a brush along the mirrored UV border I get these weird splotchy glitches that look pretty ugly. My version of 3D-Coat is version 4.5.03(GL64), and is for a Mac. It should also be mentioned it is a trial version. I've done some research into this issue and apparrenntly this used to affect older versions of 3D coat but was patched. http://3d-coat.com/mantis/view.php?id=1608 Having tried this solution I wasn't able to solve my issue. Turning symmetry on or off doesn't stop the glitches. Has anyone else run into this problem before or is there simply no way to paint with mirrored UV's in 3D coat?
Hi Guys, I'm a newbie user to 3d Coat v4.5 and I was wondering on how to paint on just particular UV island ? Is there a way to lock the current selection ? Or perhaps 'separate object' function ? Because when you have objects stacking on top of another one, It's difficult to paint without spilling to the other objects/parts. I've searched the forum but no luck. Thank you.
place uv mapped models by brush?
worldcrafter posted a topic in SOS! If you need urgent help for 3DCoat
Is there something similar to the "on brush" tool for placing objects, but that keeps the uv's of the model. I want to import textures for the models placed - This would be brilliant for adding textured details (I.E grass, tiny stones, small weeds) to a scene. -
Making UV shells fill UV space to edge
Daniel Tynan posted a topic in SOS! If you need urgent help for 3DCoat
Hi, I'm creating some tileable road sections and in order to tile nicely, the UV shell should touch the edge of the UV space. Otherwise when you tile it, you will see some gaps. By default 3D-Coat always arranges shells with some space away from the edge. I can manually scale and move the shell but it is not very accurate. . .anways to snap edge of shell to edge of UV space or just automatically make it fill the UV space? Thanks! BTW the fact that the texture UV editor shows the UV's tiled automatically has been a big help in creating tileable UV! I like that feature. -
Anyway I bought Modo and was constructing a base model to sculpt on in it. Mostly I just wanted to see how it works and how a subdivision surface model would compare to a voxel model. So I went to UV my model in Modo. You have to do this if you are going to use an open exr file for sculpting. Also it will subdivide your UV's for you if you have them laid out ahead of time for subdivision modeling. I must say the first couple of tries I made to UV my model in Modo left me sadly disappointed. Maybe it is just the fact that 3d Coat does UV's quicker and more efficiently than any other program I have ever used. I kept working at it till I got a decent set of UV's in Modo. I was just curious if anyone else uses Modo and how they go about doing their UVs. I really wish you could just add seams like in 3d Coat and hit unwrap. Would be so much easier.
Hi Is there a way i can pack the uvs and textures of multiple models and texture maps into one texture map? (within 3DC) if not, could someone suggest a program that can? (price doesn't matter)
Hi there! I've created a model within 3D Coat, and have been trying to find ways to export it to Substance Painter for about 3-4 weeks on and off. It's hard surface, so the AUTOPO tool has been little use (when it doesn't crash the program), and I'm purely using it for a still image, not a game model, so the number of polys isn't all that important. When I export it using 3D Coat, it doesn't have a UV already associated with it, so the program won't accept it. Therefore, I need to export it as a model, open it in Blender (which I really don't get along with), and then run a smart UV on it, and finally export that into Substance Painter. I was wondering if there was a way in which I could skip out Blender, and just have my ship export from 3D Coat into Substance Painter without a lot of extra steps. For example, I do not really want to spend the time having to retopo my model, seeing as I already know I can skip this stage with Blender in the equation. Also, I assume it has a UV associated with it already, seeing as when I move it into the Paint Room, I can paint directly onto the surface. In addition, ideally I'd like to export a Quad Mesh, but it doesn't have a poly reduction tool with that, meaning I have to export a triangle mesh, which is a nightmare to work with. Any advice? Oh, I should point out that I will be using the Steam version, but it's very buggy at the moment, so I have to use this month demo from this site
3D Coat crashing when using UV Tools!
AgeTDev posted a topic in SOS! If you need urgent help for 3DCoat
Hello, I am pretty desperate. I really like 3dcoat so far but it is always crashing on me. While I use the UV tools, it simply crashes at random times. I did manage to get my seaming done tough, and now when i try to unwrap, i crashes. I did try another machine too, it crashes aswell. The model i try to UV is made in Blender My Pc is running Win 8.1 Pro 64-Bit Intel Core i5 4670K @3.40 GHz 8GB Ram Saphhire 7870XT with Boost I recreated the crash and here is the error log Version:3D-COAT 4.1.17(DX64) Memory status: OK pointers: 47553 Video: AMD Radeon HD 7800 Series AMD Radeon HD 7800 Series AMD Radeon HD 7800 Series AMD Radeon HD 7800 Series AMD Radeon HD 7800 Series AMD Radeon HD 7800 Series iDisplay (Microsoft Corporation - WDDM v1.1) nproc: 4 (1)object: (E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\UV-3.3b) vert: 13881 poly: 0 rt:256x256 undo: (1) tool: uv_mapper_tool NumMeshLoads: 1 Time since mesh loading: 10 s VoxelTool: 0 RetopoTool: 3 UV_Tool: 1 40BC082C c:\3dcoat\3d-coat\3d-coatv4\3d-coat\abf\abf_core.cpp line 1187 [+0], UnwrapCluster::ExportUV+588 405A5137 c:\3dcoat\3d-coat\3d-coatv4\3d-coat\uv_mapper.cpp line 7769 [+0], ClusteredMesh::Unwrap+567 405BAC71 c:\3dcoat\3d-coat\3d-coatv4\3d-coat\uv_mapper.cpp line 10252 [+0], UV_map_Tool::Unwrap+33 404114AA c:\3dcoat\3d-coat\3d-coatv4\3d-coat\uv_mapper.h line 1308 [+0], UV_map_Tool::ActivateExtraCommandTemp+346 402A73D2 c:\3dcoat\3d-coat\3d-coatv4\3d-coat\peninterface.cpp line 18568 [+0], PenInterface::ActivateEnumMode+66 4046503B c:\3dcoat\3d-coat\3d-coatv4\3d-coat\simplewidgets.cpp line 1067 [+12], BaseWidget::CallCallbacks+395 4046D9BE c:\3dcoat\3d-coat\3d-coatv4\3d-coat\simplewidgets.cpp line 2868 [+14], sp_click+78 4046E4B6 c:\3dcoat\3d-coat\3d-coatv4\3d-coat\simplewidgets.cpp line 3041 [+0], SPLBUp+134 4006098C c:\3dcoat\3d-coat\3d-coatv4\3d-coat\simplewidgets.h line 603 [+0], wpcallback<PenInterface>::call+892 4046503B c:\3dcoat\3d-coat\3d-coatv4\3d-coat\simplewidgets.cpp line 1067 [+12], BaseWidget::CallCallbacks+395 40467976 c:\3dcoat\3d-coat\3d-coatv4\3d-coat\simplewidgets.cpp line 1690 [+5], Widgets::ProcessWindowsMessages+758 40481F12 c:\3dcoat\3d-coat\3d-coatv4\3d-coat\simplewidgets.cpp line 6839 [+0], IntfWidget1::OnButtonUp+130 407A9D86 c:\3dcoat\3d-coat\3d-coatv4\comms\cwidget.cpp line 486 [+26], comms::cWidgets::HandleInputEvents+1110 40E7EEAA c:\3dcoat\3d-coat\3d-coatv4\main.cpp line 114 [+0], comms::cMain_OnRender+74 407C1690 c:\3dcoat\3d-coat\3d-coatv4\comms\cwinmain.cpp line 616 [+0], cWinMain_OnRender+176 407C6807 c:\3dcoat\3d-coat\3d-coatv4\comms\cwinmain.cpp line 2064 [+0], cWinMain_OneIterationOfMessageLoop+247 407C971C c:\3dcoat\3d-coat\3d-coatv4\comms\cwinmain.cpp line 2344 [+15], WinMain+10460 40F3DC93 f:\dd\vctools\crt_bld\self_64_amd64\crt\src\crt0.c line 263 [+33], __tmainCRTStartup+391 314616AD line 0 [+0], BaseThreadInitThunk+13 33AB4409 line 0 [+0], RtlUserThreadStart+29 33AB4409 line 0 [+0], RtlUserThreadStart+29 General information: Exception code:C0000005 3D-COAT 4.1.17(DX64) Memory status before run: Memory load: 31 TotalPhys: 4216586240 AvailPhys: 1535922176 TotalPageFile: 4216586240 AvailPageFile: 1307389952 TotalVirtual: 4294836224 AvailVirtual: 4092317696 Memory status after crash: Memory load: 35 TotalPhys: 4216586240 AvailPhys: 1175879680 TotalPageFile: 4216586240 AvailPageFile: 891506688 TotalVirtual: 4294836224 AvailVirtual: 3596349440 AvailVirtual: 3596349440 Module found D:\Program Files\3D-Coat-V4\3d-CoatDX64S.exe (\3d-CoatDX64S.exe) Handle: 0000000140000000 Base address: 0000000140000000 Module found C:\WINDOWS\SYSTEM32\ntdll.dll (ntdll.dll) Handle: 00007FFA33A60000 Base address: 00007FFA33A60000 Module found C:\WINDOWS\system32\KERNEL32.DLL (KERNEL32.DLL) Handle: 00007FFA31460000 Base address: 00007FFA31460000 Module found C:\WINDOWS\system32\KERNELBASE.dll (KERNELBASE.dll) Handle: 00007FFA30F40000 Base address: 00007FFA30F40000 Module found C:\WINDOWS\system32\apphelp.dll (apphelp.dll) Handle: 00007FFA2F9F0000 Base address: 00007FFA2F9F0000 Module found C:\WINDOWS\AppPatch\AppPatch64\AcLayers.DLL (C:\WINDOWS\AppPatch\AppPatch64\AcLayers.DLL) Handle: 00007FFA033D0000 Base address: 00007FFA033D0000 Module found C:\WINDOWS\system32\msvcrt.dll (msvcrt.dll) Handle: 00007FFA31D00000 Base address: 00007FFA31D00000 Module found C:\WINDOWS\system32\USER32.dll (USER32.dll) Handle: 00007FFA33650000 Base address: 00007FFA33650000 Module found C:\WINDOWS\system32\SHLWAPI.dll (SHLWAPI.dll) Handle: 00007FFA31390000 Base address: 00007FFA31390000 Module found C:\WINDOWS\SYSTEM32\sfc.dll (sfc.dll) Handle: 00007FFA1E2F0000 Base address: 00007FFA1E2F0000 Module found C:\WINDOWS\SYSTEM32\WINSPOOL.DRV (WINSPOOL.DRV) Handle: 00007FFA2C6E0000 Base address: 00007FFA2C6E0000 Module found C:\WINDOWS\system32\GDI32.dll (GDI32.dll) Handle: 00007FFA337D0000 Base address: 00007FFA337D0000 Module found C:\WINDOWS\SYSTEM32\combase.dll (combase.dll) Handle: 00007FFA317F0000 Base address: 00007FFA317F0000 Module found C:\WINDOWS\system32\RPCRT4.dll (RPCRT4.dll) Handle: 00007FFA33920000 Base address: 00007FFA33920000 Module found C:\WINDOWS\SYSTEM32\sfc_os.DLL (sfc_os.DLL) Handle: 00007FFA287E0000 Base address: 00007FFA287E0000 Module found C:\WINDOWS\SYSTEM32\SortWindows61.dll (SortWindows61.dll) Handle: 00007FFA1DBB0000 Base address: 00007FFA1DBB0000 Module found C:\WINDOWS\system32\IMM32.DLL (IMM32.DLL) Handle: 00007FFA31410000 Base address: 00007FFA31410000 Module found C:\WINDOWS\system32\MSCTF.dll (MSCTF.dll) Handle: 00007FFA33510000 Base address: 00007FFA33510000 Module found C:\WINDOWS\system32\WS2_32.dll (WS2_32.dll) Handle: 00007FFA31330000 Base address: 00007FFA31330000 Module found C:\WINDOWS\system32\COMDLG32.dll (COMDLG32.dll) Handle: 00007FFA31DB0000 Base address: 00007FFA31DB0000 Module found C:\WINDOWS\system32\ADVAPI32.dll (ADVAPI32.dll) Handle: 00007FFA31B90000 Base address: 00007FFA31B90000 Module found C:\WINDOWS\system32\SHELL32.dll (SHELL32.dll) Handle: 00007FFA32100000 Base address: 00007FFA32100000 Module found C:\WINDOWS\system32\ole32.dll (ole32.dll) Handle: 00007FFA31F80000 Base address: 00007FFA31F80000 Module found C:\WINDOWS\system32\OLEAUT32.dll (OLEAUT32.dll) Handle: 00007FFA31C40000 Base address: 00007FFA31C40000 Module found D:\Program Files\3D-Coat-V4\tbbmalloc.dll (\tbbmalloc.dll) Handle: 0000000180000000 Base address: 0000000180000000 Module found D:\Program Files\3D-Coat-V4\tbb.dll (\tbb.dll) Handle: 0000000000270000 Base address: 0000000000270000 Module found C:\WINDOWS\SYSTEM32\VERSION.dll (VERSION.dll) Handle: 00007FFA2E8D0000 Base address: 00007FFA2E8D0000 Module found C:\WINDOWS\SYSTEM32\NETAPI32.dll (NETAPI32.dll) Handle: 00007FFA2EA70000 Base address: 00007FFA2EA70000 Module found C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.9600.16384_none_34a8918f959016ea\COMCTL32.dll (C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.9600.16384_none_34a8918f959016ea\COMCTL32.dll) Handle: 00007FFA30E90000 Base address: 00007FFA30E90000 Module found C:\WINDOWS\SYSTEM32\d3d9.dll (d3d9.dll) Handle: 00007FFA1BD60000 Base address: 00007FFA1BD60000 Module found C:\WINDOWS\SYSTEM32\d3dx9_38.dll (d3dx9_38.dll) Handle: 000000006D3C0000 Base address: 000000006D3C0000 Module found C:\WINDOWS\SYSTEM32\WININET.dll (WININET.dll) Handle: 00007FFA29620000 Base address: 00007FFA29620000 Module found C:\WINDOWS\system32\NSI.dll (NSI.dll) Handle: 00007FFA31600000 Base address: 00007FFA31600000 Module found C:\WINDOWS\SYSTEM32\sechost.dll (sechost.dll) Handle: 00007FFA315A0000 Base address: 00007FFA315A0000 Module found C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.8387_none_08e793bfa83a89b5\MSVCR90.dll (C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.8387_none_08e793bfa83a89b5\MSVCR90.dll) Handle: 000000006FC80000 Base address: 000000006FC80000 Module found C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.8387_none_08e793bfa83a89b5\MSVCP90.dll (C:\WINDOWS\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.8387_none_08e793bfa83a89b5\MSVCP90.dll) Handle: 000000006D2E0000 Base address: 000000006D2E0000 Module found C:\WINDOWS\SYSTEM32\netutils.dll (netutils.dll) Handle: 00007FFA30070000 Base address: 00007FFA30070000 Module found C:\WINDOWS\SYSTEM32\srvcli.dll (srvcli.dll) Handle: 00007FFA30B90000 Base address: 00007FFA30B90000 Module found C:\WINDOWS\SYSTEM32\wkscli.dll (wkscli.dll) Handle: 00007FFA2EA30000 Base address: 00007FFA2EA30000 Module found C:\WINDOWS\SYSTEM32\dwmapi.dll (dwmapi.dll) Handle: 00007FFA2E4A0000 Base address: 00007FFA2E4A0000 Module found C:\WINDOWS\SYSTEM32\iertutil.dll (iertutil.dll) Handle: 00007FFA29860000 Base address: 00007FFA29860000 Module found C:\WINDOWS\SYSTEM32\USERENV.dll (USERENV.dll) Handle: 00007FFA30430000 Base address: 00007FFA30430000 Module found C:\WINDOWS\SYSTEM32\SHCORE.DLL (SHCORE.DLL) Handle: 00007FFA2E670000 Base address: 00007FFA2E670000 Module found C:\WINDOWS\SYSTEM32\profapi.dll (profapi.dll) Handle: 00007FFA30DC0000 Base address: 00007FFA30DC0000 Module found C:\WINDOWS\SYSTEM32\kernel.appcore.dll (kernel.appcore.dll) Handle: 00007FFA2FC40000 Base address: 00007FFA2FC40000 Module found C:\WINDOWS\SYSTEM32\CRYPTBASE.dll (CRYPTBASE.dll) Handle: 00007FFA30C90000 Base address: 00007FFA30C90000 Module found C:\WINDOWS\SYSTEM32\bcryptPrimitives.dll (bcryptPrimitives.dll) Handle: 00007FFA30C30000 Base address: 00007FFA30C30000 Module found C:\WINDOWS\system32\uxtheme.dll (uxtheme.dll) Handle: 00007FFA2FAC0000 Base address: 00007FFA2FAC0000 Module found C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll (C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll) Handle: 00007FFA2C350000 Base address: 00007FFA2C350000 Module found C:\WINDOWS\SYSTEM32\oleacc.dll (oleacc.dll) Handle: 00007FFA2C670000 Base address: 00007FFA2C670000 Module found C:\WINDOWS\SYSTEM32\clbcatq.dll (clbcatq.dll) Handle: 00007FFA31ED0000 Base address: 00007FFA31ED0000 Module found C:\WINDOWS\SYSTEM32\aticfx64.dll (aticfx64.dll) Handle: 00007FFA2E8E0000 Base address: 00007FFA2E8E0000 Module found C:\WINDOWS\SYSTEM32\atiu9p64.dll (atiu9p64.dll) Handle: 00007FFA08CD0000 Base address: 00007FFA08CD0000 Module found C:\WINDOWS\SYSTEM32\atiumd64.dll (atiumd64.dll) Handle: 00007FFA081F0000 Base address: 00007FFA081F0000 Module found C:\WINDOWS\SYSTEM32\atiumd6a.dll (atiumd6a.dll) Handle: 000000006DC60000 Base address: 000000006DC60000 Module found C:\WINDOWS\SYSTEM32\Wintab32.dll (Wintab32.dll) Handle: 00007FFA07050000 Base address: 00007FFA07050000 Module found C:\WINDOWS\SYSTEM32\WTSAPI32.dll (WTSAPI32.dll) Handle: 00007FFA2F9D0000 Base address: 00007FFA2F9D0000 Module found C:\WINDOWS\SYSTEM32\Pen_Tablet.dll (Pen_Tablet.dll) Handle: 00007FFA2C100000 Base address: 00007FFA2C100000 Module found C:\WINDOWS\SYSTEM32\CRYPTSP.dll (CRYPTSP.dll) Handle: 00007FFA306E0000 Base address: 00007FFA306E0000 Module found C:\WINDOWS\system32\rsaenh.dll (rsaenh.dll) Handle: 00007FFA30320000 Base address: 00007FFA30320000 Module found C:\WINDOWS\SYSTEM32\bcrypt.dll (bcrypt.dll) Handle: 00007FFA30910000 Base address: 00007FFA30910000 Log.txt: Loading Xml file "Xmls/Settings.xml"... Can't load file "Xmls/Settings.xml" ------------------------------------------------------------ Graphics card and driver info ------------------------------------------------------------ Direct3D Renderer Adapter: AMD Radeon HD 7800 Series Driver: aticfx64.dll Supported: Vertex shaders 3.0 Pixel shaders 3.0 MRT (targets: 4) Non power of two ------------------------------------------------------------ Registering vertex formats... Added "TIF" image codec. Added "TIFF" image codec. Added "EXR" image codec. - Loading font "Calibri 11"... Can't load file "Fonts/Calibri 11.cFont" - Loading font "Calibri 16"... Can't load file "Fonts/Calibri 16.cFont" - Loading font "Calibri B24"... Can't load file "Fonts/Calibri B24.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma B8"... Can't load file "Fonts/Tahoma B8.cFont" Can't load image file "Textures\WindowsStandard\ToolBar.bmp" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" - Loading font "Tahoma 8"... Can't load file "Fonts/Tahoma 8.cFont" Version : 3D-COAT 4.1.17(DX64) * Loading shader "Shaders/hud2t.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/hud_smooth.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/hud.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/LinesPointsUI.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/Colored.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/RenderSystem.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/RenderSystem.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/text2.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ENV Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ENV #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_COLOR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_RELIEF Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_RELIEF #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPECULAR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPECULAR #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_render_color.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/obj_render_normals.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/obj_render_mrt.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview_nrm.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview_alpha.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/tex_preview_all.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/obj_preview_pen2.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/inrect.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/obj_preview_pen2.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/preview_rect.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/draw_pic_over_curve.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/draw_pic_over_curve.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/preview_fill.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/uv.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/wires.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/wires.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/sphere.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/obj_preview_pen.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... * Loading shader "Shaders/mcubes.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/mpreview.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/mpreview1.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/Font.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/mcubes_rt.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/mcubes_nrm.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... ------------------------------------------------------------ WinTab Device Name: WACOM Tablet Max Pressure: 1023 ------------------------------------------------------------ Can't load image file "Levels\Uv\Uv_d" AppLink search path registered: D:\Libraries\Documents/3D-CoatV4/Exchange/ AppLink search path registered: D:\Libraries\Documents/3D-CoatV3/Exchange/ cMeshIO::AddCodec(): Added "Obj" mesh codec. cMeshIO::AddCodec(): Added "Lwo" mesh codec. cMeshIO::AddCodec(): Added "Fbx" mesh codec. cMeshIO::AddCodec(): Added "Stl" mesh codec. cMeshIO::AddCodec(): Added "Ply" mesh codec. cMeshIO::AddCodec(): Added "dae" mesh codec. cMeshIO::AddCodec(): Added "wrl" mesh codec. cMeshIO::LoadMesh(): Loaded mesh file "D:\Program Files\3D-Coat-V4\ToolsPresets\\Sphere.obj". cMeshIO::LoadMesh(): Loaded mesh file "D:\Program Files\3D-Coat-V4\ToolsPresets\\Ring.obj". cMeshIO::LoadMesh(): Loaded mesh file "D:\Program Files\3D-Coat-V4\ToolsPresets\\Cone.obj". cMeshIO::LoadMesh(): Loaded mesh file "D:\Program Files\3D-Coat-V4\ToolsPresets\\Cylinder.obj". cMeshIO::LoadMesh(): Loaded mesh file "D:\Program Files\3D-Coat-V4\ToolsPresets\\Cube.obj". cMeshIO::LoadMesh(): Loaded mesh file "D:\Program Files\3D-Coat-V4\ToolsPresets\\Sector.obj". Loaded image file "textures\pens\rock.tga" Can't load file "D:\Libraries\Documents/3D-CoatV4/license.dat" Can't load file "license.dat" Loaded image file "textures\icons64\Grow_Vox_02.png" Can't load image file "textures\tooltips\Grow_Vox_02.png" Loaded image file "textures\icons64\smooth_Vox.png" Can't load image file "textures\tooltips\smooth_Vox.png" Loaded image file "textures\icons64\Fill.png" Can't load image file "textures\tooltips\Fill.png" Loaded image file "textures\icons64\Clay_Vox.png" Can't load image file "textures\tooltips\Clay_Vox.png" Loaded image file "textures\icons64\Carve.png" Can't load image file "textures\tooltips\Carve.png" Loaded image file "textures\icons64\Blob_Vox.png" Can't load image file "textures\tooltips\Blob_Vox.png" Loaded image file "textures\icons64\Cutoff_Vox.png" Can't load image file "textures\tooltips\Cutoff_Vox.png" Loaded image file "textures\icons64\Airbrush_Vox.png" Can't load image file "textures\tooltips\Airbrush_Vox.png" Loaded image file "textures\icons64\Build_Vox_02.png" Can't load image file "textures\tooltips\Build_Vox_02.png" Loaded image file "textures\icons64\Extrude_Vox.png" Can't load image file "textures\tooltips\Extrude_Vox.png" Loaded image file "textures\icons64\Sphere_Vox.png" Can't load image file "textures\tooltips\Sphere_Vox.png" Loaded image file "textures\icons64\2D_Piant_Vox.png" Can't load image file "textures\tooltips\2D_Piant_Vox.png" Loaded image file "textures\icons64\Plane_Vox.png" Can't load image file "textures\tooltips\Plane_Vox.png" Loaded image file "textures\icons64\Scrape_Vox.png" Can't load image file "textures\tooltips\Scrape_Vox.png" Loaded image file "textures\icons64\Pinch_Vox.png" Can't load image file "textures\tooltips\Pinch_Vox.png" Loaded image file "textures\icons64\Smudge_Vox.png" Can't load image file "textures\tooltips\Smudge_Vox.png" Loaded image file "textures\icons64\Measure.png" Can't load image file "textures\tooltips\Measure.png" Loaded image file "textures\icons64\Pick.png" Can't load image file "textures\tooltips\Pick.png" Loaded image file "textures\icons64\Pose.png" Can't load image file "textures\tooltips\Pose.png" Loaded image file "textures\icons64\Move.png" Can't load image file "textures\tooltips\Move.png" Loaded image file "textures\icons64\Hide.png" Can't load image file "textures\tooltips\Hide.png" Loaded image file "textures\icons64\Cell.png" Can't load image file "textures\tooltips\Cell.png" Loaded image file "textures\icons64\Copy.png" Can't load image file "textures\tooltips\Copy.png" Loaded image file "textures\icons64\Transform.png" Can't load image file "textures\tooltips\Transform.png" Loaded image file "textures\icons64\Instancer.png" Can't load image file "textures\tooltips\Instancer.png" Loaded image file "textures\icons64\Warp.png" Can't load image file "textures\tooltips\Warp.png" Loaded image file "textures\icons64\Axial.png" Can't load image file "textures\tooltips\Axial.png" Loaded image file "textures\icons64\Bass-Releif.png" Can't load image file "textures\tooltips\Bass-Releif.png" Loaded image file "textures\icons64\Vox_Layer.png" Can't load image file "textures\tooltips\Vox_Layer.png" Loaded image file "textures\icons64\LOGO.png" Can't load image file "textures\tooltips\LOGO.png" Loaded image file "textures\icons64\Clone_Copy.png" Can't load image file "textures\tooltips\Clone_Copy.png" Loaded image file "textures\icons64\Clone_VOX.png" Can't load image file "textures\tooltips\Clone_VOX.png" Loaded image file "textures\icons64\Split_Vox.png" Can't load image file "textures\tooltips\Split_Vox.png" Loaded image file "textures\icons64\Merge.png" Can't load image file "textures\tooltips\Merge.png" Loaded image file "textures\icons64\Sketch_Tool.png" Can't load image file "textures\tooltips\Sketch_Tool.png" Loaded image file "textures\icons64\curves.png" Can't load image file "textures\tooltips\curves.png" Loaded image file "textures\icons64\Snake.png" Can't load image file "textures\tooltips\Snake.png" Loaded image file "textures\icons64\Spkie.png" Can't load image file "textures\tooltips\Spkie.png" Loaded image file "textures\icons64\toothPaste.png" Can't load image file "textures\tooltips\toothPaste.png" Loaded image file "textures\icons64\Muscle.png" Can't load image file "textures\tooltips\Muscle.png" Loaded image file "textures\icons64\Primatives.png" Can't load image file "textures\tooltips\Primatives.png" Loaded image file "textures\icons64\Text.png" Can't load image file "textures\tooltips\Text.png" Loaded image file "textures\icons64\Cloth.png" Can't load image file "textures\tooltips\Cloth.png" Loaded image file "textures\icons64\Draw_Surf.png" Can't load image file "textures\tooltips\Draw_Surf.png" Loaded image file "textures\icons64\Pinch_Surf.png" Can't load image file "textures\tooltips\Pinch_Surf.png" Loaded image file "textures\icons64\Shift_Surf.png" Can't load image file "textures\tooltips\Shift_Surf.png" Loaded image file "textures\icons64\Flatten_Surf.png" Can't load image file "textures\tooltips\Flatten_Surf.png" Loaded image file "textures\icons64\Clay_Surf.png" Can't load image file "textures\tooltips\Clay_Surf.png" Loaded image file "textures\icons64\Rapid_Surf.png" Can't load image file "textures\tooltips\Rapid_Surf.png" Loaded image file "textures\icons64\Increase_Res.png" Can't load image file "textures\tooltips\Increase_Res.png" Loaded image file "textures\icons64\Resample.png" Can't load image file "textures\tooltips\Resample.png" Loaded image file "textures\icons64\Clear.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Smooth_All.png" Can't load image file "textures\tooltips\Smooth_All.png" Loaded image file "textures\icons64\Chisel_Surf.png" Can't load image file "textures\tooltips\Chisel_Surf.png" Loaded image file "textures\icons64\Build_Vox_02.png" Can't load image file "textures\tooltips\Build_Vox_02.png" Loaded image file "textures\icons64\Fill.png" Can't load image file "textures\tooltips\Fill.png" Loaded image file "textures\icons64\Inflate_Clay_LC.png" Can't load image file "textures\tooltips\Inflate_Clay_LC.png" Loaded image file "textures\icons64\Extrude_Surf.png" Can't load image file "textures\tooltips\Extrude_Surf.png" Loaded image file "textures\icons64\Gum.png" Can't load image file "textures\tooltips\Gum.png" Loaded image file "textures\icons64\Absolute.png" Can't load image file "textures\tooltips\Absolute.png" Loaded image file "textures\icons64\Freeze_Surf.png" Can't load image file "textures\tooltips\Freeze_Surf.png" Loaded image file "textures\icons64\Hide_Surf.png" Can't load image file "textures\tooltips\Hide_Surf.png" Loaded image file "textures\icons64\Rapid1_Surf.png" Can't load image file "textures\tooltips\Rapid1_Surf.png" Loaded image file "textures\icons64\Rapid2_Surf.png" Can't load image file "textures\tooltips\Rapid2_Surf.png" Loaded image file "textures\icons64\Scratches1_Surf.png" Can't load image file "textures\tooltips\Scratches1_Surf.png" Loaded image file "textures\icons64\Scratches2_Surf.png" Can't load image file "textures\tooltips\Scratches2_Surf.png" Loaded image file "textures\icons64\Mud1_surf.png" Can't load image file "textures\tooltips\Mud1_surf.png" Loaded image file "textures\icons64\Mud2_surf.png" Can't load image file "textures\tooltips\Mud2_surf.png" Loaded image file "textures\icons64\Decimate.png" Can't load image file "textures\tooltips\Decimate.png" Loaded image file "textures\icons64\TSmooth_LC.png" Can't load image file "textures\tooltips\TSmooth_LC.png" Loaded image file "textures\icons64\Draw_Surf.png" Can't load image file "textures\tooltips\Draw_Surf.png" Loaded image file "textures\icons64\Build_Vox_02.png" Can't load image file "textures\tooltips\Build_Vox_02.png" Loaded image file "textures\icons64\CreaseClay_LC.png" Can't load image file "textures\tooltips\CreaseClay_LC.png" Loaded image file "textures\icons64\Reduce_Clay_LC.png" Can't load image file "textures\tooltips\Reduce_Clay_LC.png" Loaded image file "textures\icons64\Extrude_Clay_LC.png" Can't load image file "textures\tooltips\Extrude_Clay_LC.png" Loaded image file "textures\icons64\Snake_Clay_LC.png" Can't load image file "textures\tooltips\Snake_Clay_LC.png" Loaded image file "textures\icons64\Tube_Clay_LC.png" Can't load image file "textures\tooltips\Tube_Clay_LC.png" Loaded image file "textures\icons64\Smudge_Clay_LC.png" Can't load image file "textures\tooltips\Smudge_Clay_LC.png" Loaded image file "textures\icons64\Inflate_Clay_LC.png" Can't load image file "textures\tooltips\Inflate_Clay_LC.png" Loaded image file "textures\icons64\Swirl_Clay_LC.png" Can't load image file "textures\tooltips\Swirl_Clay_LC.png" Loaded image file "textures\icons64\Ripple_LC.png" Can't load image file "textures\tooltips\Ripple_LC.png" Loaded image file "textures\icons64\Flatten_Surf.png" Can't load image file "textures\tooltips\Flatten_Surf.png" Loaded image file "textures\icons64\Wrincle_Clay_LC.png" Can't load image file "textures\tooltips\Wrincle_Clay_LC.png" Loaded image file "textures\icons64\Remove_Clay_LC.png" Can't load image file "textures\tooltips\Remove_Clay_LC.png" Loaded image file "textures\icons64\General_LC.png" Can't load image file "textures\tooltips\General_LC.png" Loaded image file "textures\icons64\Add_Clusters.png" Can't load image file "textures\tooltips\Add_Clusters.png" Loaded image file "textures\icons64\Mark_Seams.png" Can't load image file "textures\tooltips\Mark_Seams.png" Loaded image file "textures\icons64\Mark_Seams_Edge_Loop.png" Can't load image file "textures\tooltips\Mark_Seams_Edge_Loop.png" Loaded image file "textures\icons64\Select_Path.png" Can't load image file "textures\tooltips\Select_Path.png" Loaded image file "textures\icons64\Clear_Clusters.png" Can't load image file "textures\tooltips\Clear_Clusters.png" Loaded image file "textures\icons64\Clear_Seams.png" Can't load image file "textures\tooltips\Clear_Seams.png" Loaded image file "textures\icons64\Auto_Seams.png" Can't load image file "textures\tooltips\Auto_Seams.png" Loaded image file "textures\icons64\Sharp_Seams.png" Can't load image file "textures\tooltips\Sharp_Seams.png" Loaded image file "textures\icons64\Sharp_Seams.png" Can't load image file "textures\tooltips\Sharp_Seams.png" Loaded image file "textures\icons64\Unwrap.png" Can't load image file "textures\tooltips\Unwrap.png" Loaded image file "textures\icons64\Pack1.png" Can't load image file "textures\tooltips\Pack1.png" Loaded image file "textures\icons64\Pack2.png" Can't load image file "textures\tooltips\Pack2.png" Loaded image file "textures\icons64\Auto_Scale.png" Can't load image file "textures\tooltips\Auto_Scale.png" Loaded image file "textures\icons64\Update_Islands.png" Can't load image file "textures\tooltips\Update_Islands.png" Loaded image file "textures\icons64\Restore_UV.png" Can't load image file "textures\tooltips\Restore_UV.png" Loaded image file "textures\icons64\Apply_UV.png" Can't load image file "textures\tooltips\Apply_UV.png" Loaded image file "textures\icons64\Export.png" Can't load image file "textures\tooltips\Export.png" Loaded image file "textures\icons64\Import.png" Can't load image file "textures\tooltips\Import.png" Loaded image file "textures\icons64\Clear.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Invert.png" Can't load image file "textures\tooltips\Invert.png" Loaded image file "textures\icons64\Rotate_Clock.png" Can't load image file "textures\tooltips\Rotate_Clock.png" Loaded image file "textures\icons64\Rotate_AnitClock.png" Can't load image file "textures\tooltips\Rotate_AnitClock.png" Loaded image file "textures\icons64\Flip_U.png" Can't load image file "textures\tooltips\Flip_U.png" Loaded image file "textures\icons64\Flip_V.png" Can't load image file "textures\tooltips\Flip_V.png" Loaded image file "textures\icons64\Relax_UV.png" Can't load image file "textures\tooltips\Relax_UV.png" Loaded image file "textures\icons64\Relax_UV.png" Can't load image file "textures\tooltips\Relax_UV.png" Loaded image file "textures\icons64\ABF.png" Can't load image file "textures\tooltips\ABF.png" Loaded image file "textures\icons64\LSCM.png" Can't load image file "textures\tooltips\LSCM.png" Loaded image file "textures\icons64\Planar.png" Can't load image file "textures\tooltips\Planar.png" Loaded image file "textures\icons64\Hide_UV.png" Can't load image file "textures\tooltips\Hide_UV.png" Loaded image file "textures\icons64\Invert_Hidden.png" Can't load image file "textures\tooltips\Invert_Hidden.png" Loaded image file "textures\icons64\UnHide.png" Can't load image file "textures\tooltips\UnHide.png" Loaded image file "textures\icons64\Unhide_All.png" Can't load image file "textures\tooltips\Unhide_All.png" Loaded image file "textures\icons64\Copy_UV.png" Can't load image file "textures\tooltips\Copy_UV.png" Loaded image file "textures\icons64\Paste.png" Can't load image file "textures\tooltips\Paste.png" Loaded image file "textures\icons64\Add_Split.png" Can't load image file "textures\tooltips\Add_Split.png" Loaded image file "textures\icons64\Select.png" Can't load image file "textures\tooltips\Select.png" Loaded image file "textures\icons64\Mark_Seams.png" Can't load image file "textures\tooltips\Mark_Seams.png" Loaded image file "textures\icons64\Quad.png" Can't load image file "textures\tooltips\Quad.png" Loaded image file "textures\icons64\Pointand_Faces.png" Can't load image file "textures\tooltips\Pointand_Faces.png" Loaded image file "textures\icons64\Cap.png" Can't load image file "textures\tooltips\Cap.png" Loaded image file "textures\icons64\Strokes.png" Can't load image file "textures\tooltips\Strokes.png" Loaded image file "textures\icons64\Brush.png" Can't load image file "textures\tooltips\Brush.png" Loaded image file "textures\icons64\Delete_Polygons.png" Can't load image file "textures\tooltips\Delete_Polygons.png" Loaded image file "textures\icons64\Delete_Edges.png" Can't load image file "textures\tooltips\Delete_Edges.png" Loaded image file "textures\icons64\Collapse_Edge.png" Can't load image file "textures\tooltips\Collapse_Edge.png" Loaded image file "textures\icons64\Split_Ring.png" Can't load image file "textures\tooltips\Split_Ring.png" Loaded image file "textures\icons64\Select_Verts.png" Can't load image file "textures\tooltips\Select_Verts.png" Loaded image file "textures\icons64\Slide_Edge.png" Can't load image file "textures\tooltips\Slide_Edge.png" Loaded image file "textures\icons64\Mark_Seams.png" Can't load image file "textures\tooltips\Mark_Seams.png" Loaded image file "textures\icons64\Mark_Seams_Edge_Loop.png" Can't load image file "textures\tooltips\Mark_Seams_Edge_Loop.png" Loaded image file "textures\icons64\Retopo_Transform.png" Can't load image file "textures\tooltips\Retopo_Transform.png" Loaded image file "textures\icons64\Import.png" Can't load image file "textures\tooltips\Import.png" Loaded image file "textures\icons64\Export.png" Can't load image file "textures\tooltips\Export.png" Loaded image file "textures\icons64\Snap.png" Can't load image file "textures\tooltips\Snap.png" Loaded image file "textures\icons64\Subdivide.png" Can't load image file "textures\tooltips\Subdivide.png" Loaded image file "textures\icons64\Clear.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Relax.png" Can't load image file "textures\tooltips\Relax.png" Loaded image file "textures\icons64\Symmetry.png" Can't load image file "textures\tooltips\Symmetry.png" Loaded image file "textures\icons64\Sculpt_Move.png" Can't load image file "textures\tooltips\Sculpt_Move.png" Loaded image file "textures\icons64\Sculpt_Select_Move.png" Can't load image file "textures\tooltips\Sculpt_Select_Move.png" Loaded image file "textures\icons64\Sculpt_Drag_Points.png" Can't load image file "textures\tooltips\Sculpt_Drag_Points.png" Loaded image file "textures\icons64\Sculpt_Collapse.png" Can't load image file "textures\tooltips\Sculpt_Collapse.png" Loaded image file "textures\icons64\Sculpt_Expand.png" Can't load image file "textures\tooltips\Sculpt_Expand.png" Loaded image file "textures\icons64\Sculpt_Smudge.png" Can't load image file "textures\tooltips\Sculpt_Smudge.png" Loaded image file "textures\icons64\Sculpt_Smooth.png" Can't load image file "textures\tooltips\Sculpt_Smooth.png" Loaded image file "textures\icons64\Sculpt_Move.png" Can't load image file "textures\tooltips\Sculpt_Move.png" Loaded image file "textures\icons64\Sculpt_Select_Move.png" Can't load image file "textures\tooltips\Sculpt_Select_Move.png" Loaded image file "textures\icons64\Sculpt_Drag_Points.png" Can't load image file "textures\tooltips\Sculpt_Drag_Points.png" Loaded image file "textures\icons64\Sculpt_Draw.png" Can't load image file "textures\tooltips\Sculpt_Draw.png" Loaded image file "textures\icons64\Sculpt_Collapse.png" Can't load image file "textures\tooltips\Sculpt_Collapse.png" Loaded image file "textures\icons64\Sculpt_Expand.png" Can't load image file "textures\tooltips\Sculpt_Expand.png" Loaded image file "textures\icons64\Sculpt_Smudge.png" Can't load image file "textures\tooltips\Sculpt_Smudge.png" Loaded image file "textures\icons64\Sculpt_Smudge.png" Can't load image file "textures\tooltips\Sculpt_Smudge.png" Loaded image file "textures\icons64\Sculpt_Flatten.png" Can't load image file "textures\tooltips\Sculpt_Flatten.png" Loaded image file "textures\icons64\Sculpt_Smooth.png" Can't load image file "textures\tooltips\Sculpt_Smooth.png" Loaded image file "textures\icons64\Spin.png" Can't load image file "textures\tooltips\Spin.png" Loaded image file "textures\icons64\Spin_back.png" Can't load image file "textures\tooltips\Spin_back.png" Loaded image file "textures\icons64\Extrude.png" Can't load image file "textures\tooltips\Extrude.png" Loaded image file "textures\icons64\Split.png" Can't load image file "textures\tooltips\Split.png" Loaded image file "textures\icons64\Collapse_Edge.png" Can't load image file "textures\tooltips\Collapse_Edge.png" Loaded image file "textures\icons64\Clear.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Mark_Seams_Edge_Loop.png" Can't load image file "textures\tooltips\Mark_Seams_Edge_Loop.png" Loaded image file "textures\icons64\Edge_Ring.png" Can't load image file "textures\tooltips\Edge_Ring.png" Loaded image file "textures\icons64\Sharp_Seams.png" Can't load image file "textures\tooltips\Sharp_Seams.png" Loaded image file "textures\icons64\Bevel.png" Can't load image file "textures\tooltips\Bevel.png" Loaded image file "textures\icons64\Apply_UV.png" Can't load image file "textures\tooltips\Apply_UV.png" Loaded image file "textures\icons64\Clear_Seams.png" Can't load image file "textures\tooltips\Clear_Seams.png" Loaded image file "textures\icons64\Clear.png" Can't load image file "textures\tooltips\Clear.png" Loaded image file "textures\icons64\Clone.png" Can't load image file "textures\tooltips\Clone.png" Loaded image file "textures\icons64\Subdivide.png" Can't load image file "textures\tooltips\Subdivide.png" Loaded image file "textures\icons64\Hide_UV.png" Can't load image file "textures\tooltips\Hide_UV.png" Loaded image file "textures\icons64\Invert_Hidden.png" Can't load image file "textures\tooltips\Invert_Hidden.png" Loaded image file "textures\icons64\Unhide.png" Can't load image file "textures\tooltips\Unhide.png" Loaded image file "textures\icons64\ExtrudeNormal.png" Can't load image file "textures\tooltips\ExtrudeNormal.png" Loaded image file "textures\icons64\ExtrudeFree.png" Can't load image file "textures\tooltips\ExtrudeFree.png" Loaded image file "textures\icons64\Undercuts.png" Can't load image file "textures\tooltips\Undercuts.png" Loaded image file "textures\icons64\PaintHoleTool.png" Can't load image file "textures\tooltips\PaintHoleTool.png" Loaded image file "textures\icons64\CloseHole.png" Can't load image file "textures\tooltips\CloseHole.png" Loaded image file "textures\icons64\Fit.png" Can't load image file "textures\tooltips\Fit.png" Loaded image file "textures\icons64\Decimate.png" Can't load image file "textures\tooltips\Decimate.png" Loaded image file "textures\icons64\PinHoles2.png" Can't load image file "textures\tooltips\PinHoles2.png" Loaded image file "textures\icons64\Reconstruct.png" Can't load image file "textures\tooltips\Reconstruct.png" Loaded image file "textures\icons64\Bridge.png" Can't load image file "textures\tooltips\Bridge.png" Loaded image file "textures\icons64\VoxExtrude.png" Can't load image file "textures\tooltips\VoxExtrude.png" Loaded image file "textures\icons64\VoxIndent.png" Can't load image file "textures\tooltips\VoxIndent.png" Loaded image file "textures\icons64\ToLine.png" Can't load image file "textures\tooltips\ToLine.png" Loaded image file "textures\icons64\Equidistant.png" Can't load image file "textures\tooltips\Equidistant.png" Loaded image file "textures\icons64\Horizontal.png" Can't load image file "textures\tooltips\Horizontal.png" Loaded image file "textures\icons64\Vertical.png" Can't load image file "textures\tooltips\Vertical.png" Loaded image file "textures\icons64\Edgeloop.png" Can't load image file "textures\tooltips\Edgeloop.png" Loaded image file "textures\icons64\Edgering.png" Can't load image file "textures\tooltips\Edgering.png" Loaded image file "textures\icons64\ShuffleUV.png" Can't load image file "textures\tooltips\ShuffleUV.png" Loaded image file "textures\icons64\settings.png" Can't load image file "textures\tooltips\settings.png" Loaded image file "textures\icons64\SplitNJoints.png" Can't load image file "textures\tooltips\SplitNJoints.png" Loaded image file "textures\icons64\Lute.png" Can't load image file "textures\tooltips\Lute.png" Loaded image file "textures\icons64\SuperPinch.png" Can't load image file "textures\tooltips\SuperPinch.png" Loaded image file "textures\icons64\SubdivideVoxSurf.png" Can't load image file "textures\tooltips\SubdivideVoxSurf.png" Loaded image file "textures\icons64\InfSmooth.png" Can't load image file "textures\tooltips\InfSmooth.png" Loaded image file "textures\icons64\CopyClay64.png" Can't load image file "textures\tooltips\CopyClay64.png" Loaded image file "textures\icons64\Relax_UV.png" Can't load image file "textures\tooltips\Relax_UV.png" Loaded image file "textures\icons64\GU.png" Can't load image file "textures\tooltips\GU.png" Loaded image file "textures\icons64\Noise.png" Can't load image file "textures\tooltips\Noise.png" Loaded image file "textures\icons64\ScaleCL.png" Can't load image file "textures\tooltips\ScaleCL.png" Loaded image file "textures\icons64\StoreSel.png" Can't load image file "textures\tooltips\StoreSel.png" Loaded image file "textures\icons64\RecallSel.png" Can't load image file "textures\tooltips\RecallSel.png" Loaded image file "textures\icons64\ClearSel.png" Can't load image file "textures\tooltips\ClearSel.png" Loaded image file "textures\icons64\PixelArt.png" Can't load image file "textures\tooltips\PixelArt.png" Loaded image file "textures\icons64\QuickPose.png" Can't load image file "textures\tooltips\QuickPose.png" Loaded image file "textures\icons64\FillHoles.png" Can't load image file "textures\tooltips\FillHoles.png" Can't load image file "textures\masks\Arrow_01_prv.tga" Loaded image file "Temp\Arrow_0135782.tga" Can't load image file "textures\masks\fr_prv.tga" Loaded image file "Temp\fr23483.tga" Can't load image file "textures\masks\Grid_prv.tga" Loaded image file "Temp\Grid27501.tga" Can't load image file "textures\masks\honeycomb_prv.tga" Loaded image file "Temp\honeycomb41697.tga" Can't load image file "textures\masks\Misk_01_prv.tga" Loaded image file "Temp\Misk_0132829.tga" Can't load image file "textures\masks\Misk_02_prv.tga" Loaded image file "Temp\Misk_0232851.tga" Can't load image file "textures\masks\Misk_03_prv.tga" Loaded image file "Temp\Misk_0332873.tga" Can't load image file "textures\masks\Noise_01_prv.tga" Loaded image file "Temp\Noise_0135493.tga" Can't load image file "textures\masks\Noise_02_prv.tga" Loaded image file "Temp\Noise_0235516.tga" Can't load image file "textures\masks\Noise_03_prv.tga" Loaded image file "Temp\Noise_0335539.tga" Can't load image file "textures\masks\Noise_04_prv.tga" Loaded image file "Temp\Noise_0435562.tga" Can't load image file "textures\masks\Noise_05_prv.tga" Loaded image file "Temp\Noise_0535585.tga" Can't load image file "textures\masks\Rhombs_prv.tga" Loaded image file "Temp\Rhombs32885.tga" Can't load image file "textures\masks\Triangle_prv.tga" Loaded image file "Temp\Triangle38162.tga" Can't load image file "textures\masks\Cracks_prv.tga" Loaded image file "Temp\Cracks32689.tga" Can't load image file "textures\masks\OT_DiagGrid_straight01_prv.tga" Loaded image file "Temp\OT_DiagGrid_straight0182532.tga" Can't load image file "textures\masks\OT_DiagGrid_straight02_prv.tga" Loaded image file "Temp\OT_DiagGrid_straight0282569.tga" Can't load image file "textures\masks\OT_DiagGrid_straight03_prv.tga" Loaded image file "Temp\OT_DiagGrid_straight0382606.tga" Can't load image file "textures\masks\OT_mask_dented01_prv.tga" Loaded image file "Temp\OT_mask_dented0160138.tga" Can't load image file "textures\masks\OT_mask_dirt02_prv.tga" Loaded image file "Temp\OT_mask_dirt0253715.tga" Can't load image file "textures\masks\OT_mask_dirt03_prv.tga" Loaded image file "Temp\OT_mask_dirt0353744.tga" Can't load image file "textures\masks\OT_mask_dirt04_prv.tga" Loaded image file "Temp\OT_mask_dirt0453773.tga" Can't load image file "textures\masks\OT_textureFX_dirt13_prv.tga" Loaded image file "Temp\OT_textureFX_dirt1371421.tga" Can't load image file "textures\masks\OT_textureFX_dirt14_prv.tga" Loaded image file "Temp\OT_textureFX_dirt1471455.tga" Can't load image file "textures\masks\OT_textureFX_dirt15_prv.tga" Loaded image file "Temp\OT_textureFX_dirt1571489.tga" Can't load image file "textures\masks\OT_textureFX_fingerprints03_prv.tga" Loaded image file "Temp\OT_textureFX_fingerprints03107056.tga" Can't load image file "textures\masks\OT_textureFX_grimy01_prv.tga" Loaded image file "Temp\OT_textureFX_grimy0175631.tga" Can't load image file "textures\masks\OT_textureFX_scratches05_prv.tga" Loaded image file "Temp\OT_textureFX_scratches0592168.tga" Can't load image file "textures\masks\OT_vents05_prv.tga" Loaded image file "Temp\OT_vents0541613.tga" Can't load image file "textures\masks\SkinCracks_prv.tga" Loaded image file "Temp\SkinCracks43680.tga" Can't load image file "textures\masks\SkinCracks1_prv.tga" Loaded image file "Temp\SkinCracks145321.tga" Can't load image file "textures\masks\StoneDirt1_prv.tga" Loaded image file "Temp\StoneDirt142742.tga" Can't load image file "textures\masks\OT_dirt_prv.tga" Loaded image file "Temp\OT_dirt35306.tga" Can't load image file "textures\masks\OT_dirt02_prv.tga" Loaded image file "Temp\OT_dirt0238352.tga" Can't load image file "textures\masks\OT_dirt_bulletHolesDepth01_8_prv.tga" Loaded image file "Temp\OT_dirt_bulletHolesDepth01_8107726.tga" Can't load image file "textures\masks\OT_mask_rust01_prv.tga" Loaded image file "Temp\OT_mask_rust0154470.tga" Can't load image file "textures\masks\OT_random6_prv.tga" Loaded image file "Temp\OT_random642608.tga" Can't load image file "textures\masks\OT_tech3_prv.tga" Loaded image file "Temp\OT_tech336495.tga" Can't load image file "textures\masks\OT_texturefx_dirtmask01_prv.tga" Loaded image file "Temp\OT_texturefx_dirtmask0189802.tga" Can't load image file "textures\masks\OT_texturefx_dirtmask02_prv.tga" Loaded image file "Temp\OT_texturefx_dirtmask0289840.tga" Can't load image file "textures\masks\OT_texturefx_riddled_prv.tga" Loaded image file "Temp\OT_texturefx_riddled80237.tga" Loaded image file "materials\default\Mattress_prv.tga" Loaded image file "materials\default\Fabric_prv.tga" Loaded image file "materials\default\Paper_prv.tga" Loaded image file "materials\default\Kalshuga_prv.tga" Loaded image file "materials\default\Fabric_2_prv.tga" Loaded image file "materials\default\leather_prv.tga" Loaded image file "materials\default\leopard_prv.tga" Loaded image file "materials\default\Elefant_prv.tga" Loaded image file "VoxStamps\Objects\Capsule_preview.png" Loaded image file "VoxStamps\Objects\column_preview.png" Loaded image file "VoxStamps\Objects\Cone_preview.png" Loaded image file "VoxStamps\Objects\Cube_preview.png" Loaded image file "VoxStamps\Objects\Cylinder_preview.png" Loaded image file "VoxStamps\Objects\dodecahedron_preview.png" Loaded image file "VoxStamps\Objects\Icosahedron_preview.png" Loaded image file "VoxStamps\Objects\Sphere_preview.png" Loaded image file "VoxStamps\Objects\Star_preview.png" Loaded image file "VoxStamps\Objects\Torus_preview.png" Loaded image file "VoxStamps\Splines\chain_preview.png" Loaded image file "VoxStamps\Splines\Dragon1_preview.png" Loaded image file "VoxStamps\Splines\Dragon2_preview.png" Loaded image file "VoxStamps\Splines\Dragon3_preview.png" Loaded image file "VoxStamps\Splines\Dragon4_preview.png" Loaded image file "VoxStamps\Splines\Dragon5_preview.png" Loaded image file "VoxStamps\Splines\pipe_segment_preview.png" Loaded image file "VoxStamps\Splines\shlang_preview.png" Loaded image file "VoxStamps\Splines\spring_preview.png" Loaded image file "VoxStamps\Splines\spring2_preview.png" Loaded image file "VoxStamps\Splines\spring3_preview.png" Loaded image file "VoxStamps\Splines\Tentacle_preview.png" Loaded image file "VoxStamps\Splines\WildTeeth_preview.png" Loaded image file "VoxStamps\RtpModels\Capsule_preview.png" Loaded image file "VoxStamps\RtpModels\Cube_preview.png" Loaded image file "VoxStamps\RtpModels\Cylinder_preview.png" Loaded image file "VoxStamps\RtpModels\GeoSphere_preview.png" Loaded image file "VoxStamps\RtpModels\Patch1_preview.png" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Can't load image file "textures\preview_pen0.tga" Can't load image file "textures\preview_pen5.tga" Can't load image file "Shape1" Can't load image file "Shape1" Can't load image file "Shape1" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_artman penpack_Cylinder_DF61_mclp.dds" Can't load image file "Shape" Can't load image file "Shape" Can't load image file "Shape1" Can't load image file "Shape1" Can't load image file "Shape1" Can't load image file "Shape" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_artman greeble2 strip_HardSurface_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_artman greeble2 strip_HardSurface_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_manyspots_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_manyspots_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_manyscratches_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_manyscratches_mclp.dds" Loaded image file "Unicode\eu\Font00.dds" Locale: German_Luxembourg.1252 Loaded image file "Textures\stdimage.dds" Loaded image file "Temp\pano.dds" Loaded image file "textures\white.dds" Loaded image file "textures\light\baseicons.tga" Can't load image file "textures\default.dds" Loaded image file "textures\2knopki.tga" Loaded image file "textures\smallwhiteicons.dds" Loaded image file "textures\dark\property.tga" Loaded image file "textures\RightArrow.dds" Loaded image file "Textures\light\Navigation.tga" Can't load image file "textures\preview_pen0.tga" Can't load image file "textures\preview_pen1.tga" Can't load image file "textures\preview_pen2.tga" Can't load image file "textures\preview_pen3.tga" Can't load image file "textures\preview_pen4.tga" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_000_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_000_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Capsule_118D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_chain_227B_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_chain_227B_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_cheshuja_7BF3_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_cheshuja_7BF3_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_003_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_003_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_004_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_004_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_005_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_005_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_007_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_007_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_008_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_crack1_brushes_by_hawksmont_008_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Cylinder_DF61_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Fabric0001_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Fabric0001_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Gem1_70C8_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Gem1_70C8_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Gem1_EC21_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Gem1_EC21_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_hair03_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_hair03_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_hair14_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_hair14_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_knopka_03_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_knopka_03_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_kosichka_20A7_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_kosichka_20A7_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_OT_corroded_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_OT_corroded_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_OT_Speckled03_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_OT_Speckled03_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_OT_Speckled04_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_OT_Speckled04_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Patron_C89D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Patron_C89D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_pen4_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_pen4_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_pen5_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_pen5_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Piramida_8AF9_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Piramida_8AF9_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_pugovka_CC7C_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_pugovka_CC7C_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_randomscratches_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_randomscratches_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Ringmail2_3BD4_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Ringmail2_3BD4_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Ringmail_0C3E_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Ringmail_0C3E_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rings_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rings_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_003_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_003_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_007_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_007_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_011_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_011_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_013_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_013_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_014_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_rust-grunge-brushes-jonaskr_014_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_005_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_005_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_008_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_008_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_009_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Seu_Davi_009_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_sq_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_sq_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_sqgrad_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_sqgrad_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_sqgradstrip_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_sqgradstrip_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_taty_2_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_taty_2_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_004_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_004_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_009_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_009_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_012_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_Valley of the Dry Bones 2_012_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_wire_9832_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_wire_9832_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Blob2_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Blob2_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Blob_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Blob_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Cloth_Fabric01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Cloth_Fabric01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Cloth_Fabric02_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Cloth_Fabric02_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Fissure2_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Fissure2_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Fissure5_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Fissure5_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Gear06_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Gear06_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Skin01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Skin01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Skin02_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Skin02_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Skin08_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Skin08_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Tech02_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Tech02_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Tech_Circle01_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Tech_Circle01_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Tech_Circle06_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Tech_Circle06_D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Wrinkles01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Wrinkles01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Wrinkles02_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_patterns_XMD_Wrinkles02_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_Capsule_A87D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_Capsule_A87D_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_chain_BE26_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_chain_BE26_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_Edge1_8F5C_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_Edge1_8F5C_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_fabr_kromka_01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_fabr_kromka_01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_Patron_09C2_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_Patron_09C2_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_pen4_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_pen4_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_strip1_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_strip1_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_strip3_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_strip3_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_strip5_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_strip5_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_wire_44D3_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_wire_44D3_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_XMD_Cloth_Zipper01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_XMD_Cloth_Zipper01_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_XMD_Cloth_Zipper02_mclp.dds" Loaded image file "..\..\Libraries\Documents\3D-CoatV4\Temp\Thumbs\pr2_textures_strips_XMD_Cloth_Zipper02_mclp.dds" Loaded image file "PickData\sky.jpg" Loaded image file "PickData\sky.jpg" Loaded image file "PickData\sky.jpg" Loaded image file "textures\grey3.dds" Loaded image file "textures\dark\stdbutton.tga" Loaded image file "Textures\dark\Navigation.tga" Loaded image file "textures\dark\Icons16.tga" Loaded image file "Textures\dark\Locks.tga" Loaded image file "textures\taper32.png" Loaded image file "StartMenu\images\MainLogo3.png" Loaded image file "textures\icons64\Blob_Vox.png" Loaded image file "textures\icons64\Sketch_Tool.png" Loaded image file "textures\icons64\Repair.png" Loaded image file "textures\icons64\im2mesh.png" Loaded image file "textures\icons64\vertexpaint.png" Loaded image file "textures\icons64\ppp.png" Loaded image file "textures\icons64\mv.png" Loaded image file "textures\icons64\ptex.png" Loaded image file "textures\icons64\Cap.png" Loaded image file "textures\icons64\Mark_Seams.png" Loaded image file "textures\icons64\Bass-releif.png" Loaded image file "textures\icons64\Recent.png" Can't load image file "textures\preview_pen0.tga" Loaded image file "StartMenu\images\MainLogo3.png" Loaded image file "textures\icons64\Blob_Vox.png" Loaded image file "textures\icons64\Sketch_Tool.png" Loaded image file "textures\icons64\Repair.png" Loaded image file "textures\icons64\im2mesh.png" Loaded image file "textures\icons64\vertexpaint.png" Loaded image file "textures\icons64\ppp.png" Loaded image file "textures\icons64\mv.png" Loaded image file "textures\icons64\ptex.png" Loaded image file "textures\icons64\Cap.png" Loaded image file "textures\icons64\Mark_Seams.png" Loaded image file "textures\icons64\Bass-releif.png" Loaded image file "textures\icons64\Recent.png" Undocked: Undocked: Undocked: Deleted: Pen Deleted: PenOpt Deleted: STRIPS Deleted: Materials Loaded image file "materials\default\Mattress_prv.tga" Loaded image file "materials\default\Fabric_prv.tga" Loaded image file "materials\default\Paper_prv.tga" Loaded image file "materials\default\Kalshuga_prv.tga" Loaded image file "materials\default\Fabric_2_prv.tga" Loaded image file "materials\default\leather_prv.tga" Loaded image file "materials\default\leopard_prv.tga" Loaded image file "materials\default\Elefant_prv.tga" * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_ALL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ENV Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ENV #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_ENV Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_COLOR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_COLOR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_RELIEF Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_RELIEF #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_RELIEF Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPECULAR Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_SPECULAR #define VERT_NORMAL Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_SPECULAR Compiling VS... Compiling PS... * Loading shader "Shaders/shadow_sel.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/shadow_tbn.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL #define SHADOW Compiling VS... Compiling PS... * Loading shader "Shaders/obj_sel.hlsl"... #define VIEW_ALL #define VERT_NORMAL #define SHADOW Compiling VS... Compiling PS... * Loading shader "Shaders/obj_tbn.hlsl"... #define VIEW_ALL #define SHADOW Compiling VS... Compiling PS... Loaded image file "textures\chess.dds" Loaded image file "textures\black.dds" Loaded image file "textures\dashes.dds" Loaded image file "textures\dashes2.dds" Loaded image file "textures\snow.dds" Loaded image file "textures\dark\LayersIcons.tga" Loaded image file "textures\dark\stdbutton2.tga" Loaded image file "textures\borders\viewport.tga" * Loading shader "Shaders/hud_smooth.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... Loaded image file "textures\icons\wicons.png" Loaded image file "textures\borders\input_field.tga" Loaded image file "Textures\icons\arrowright.tga" Loaded image file "Textures\icons\arrowdown.tga" Loaded image file "textures\icons\move_area_16.tga" Loaded image file "textures\borders\dock_delimiter.tga" Loaded image file "textures\light\tabbutton_line.tga" Loaded image file "textures\dark\tabbutton.tga" Loaded image file "textures\dark\tabbutton_inactive.tga" Loaded image file "textures\dark\checkers.tga" Loaded image file "textures\BothSideArrows.tga" Loaded image file "textures\vista3.dds" Loaded image file "Textures\dark\DownArrow.tga" Loaded image file "textures\borders\combo_inner_frame.tga" Loaded image file "textures\borders\combo_arrow_frame.tga" Loaded image file "textures\borders\dialog_header.tga" Loaded image file "textures\borders\dialogs.tga" Loaded image file "textures\borders\toolset_internal_buttons.tga" Loaded image file "textures\icons\larrow.tga" Loaded image file "textures\switchcolors.tga" Loaded image file "textures\borders\docked.tga" Can't load image file "textures\stdbutton.tga" Loaded image file "textures\close.tga" Loaded image file "textures\borders\buttons.tga" Interpreting command: recent3b(); Loading file: E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\UV-3.3b 00000000 : RNDR : 8 bytes 00000010 : NSYZ : 0 bytes 00000018 : NBLN : 0 bytes 00000020 : MSSK : 20 bytes 0000003C : PAUV : 16 bytes E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\UV-3.3b: Unknown block found in 3DB file: VUAP! 00000054 : MEAS : 8 bytes 00000064 : CAM1 : 88 bytes 000000C4 : LNRM : 4 bytes 000000D0 : SSPC : 0 bytes 000000D8 : LR01 : 1662 bytes 0000075E : MTLS : 328 bytes 000008AE : MTEX : 129 bytes 00000937 : OBJS : 558 bytes 00000B6D : RNTS : 373 bytes 00000CEA : UVST : 365 bytes 00000E5F : SUBD : 0 bytes 00000E67 : VMAP : 4 bytes 00000E73 : VMTP : 49 bytes 00000EAC : POS0 : 166572 bytes 00029960 : UVS0 : 8 bytes 00029970 : SAR7 : 3140096 bytes Faces: done SetupUVIds: done SetAllDirty: done 00328378 : MAQ2 : 2689652 bytes 005B8DF4 : CMSC : 61 bytes 005B8E39 : STIL : 2237 bytes 005B96FE : RTP1 : 240 bytes 005B97F6 : SYMM : 8 bytes 005B9806 : UVM1 : 1395030 bytes 0070E164 : METU : 16 bytes 0070E17C : VOL3 : 4 bytes 0070E188 : VCSH : 4 bytes 0070E194 : GRIS : 56 bytes 0070E1D4 : MVSV : 4 bytes 0070E1E0 : CVSV : 4 bytes 0070E1EC : OLCO : 4 bytes 0070E1F8 : RFSV : 30 bytes 0070E21E : FITT : 116 bytes 0070E29A : SCPT : 52 bytes 0070E2D6 : SP&J : 1077 bytes 0070E713 : VOSS : 4 bytes 0070E71F : HLSV : 4 bytes 0070E72B : RTGV : 4 bytes 0070E737 : OBJV : 4 bytes 0070E743 : MATV : 4 bytes 0070E74F : BPSS : 358 bytes 0070E8BD : VCUR : 29 bytes 0070E8E2 : SELP : 120 bytes 0070E962 : REND : 1239 bytes 0070EE41 : PTEX : 110136 bytes 00729C81 : URC1 : 20 bytes 00729C9D : APSV : 12 bytes 00729CB1 : SYNP : 403 bytes PutFacesInCells: done * Loading shader "Shaders/rt_copy.hlsl"... #define SCREEN_SPACE Compiling VS... Compiling PS... UpdateDirtyFaces: done Loaded image file "Textures\grey.dds" Loaded image file "Textures\whitet.dds" Loaded image file "Textures\emptygrey.dds" CreateMeshes: done CreatePaddingInfo: done CreatePointsCorrespondence: done CreateTangentSpaceFromBasicNormals: done Loading: done Can't load image file "textures\preview_pen0.tga" Undocked: Undocked: Undocked: Deleted: Pen Deleted: PenOpt Deleted: STRIPS Deleted: Materials Deleted: Layers Deleted: Blending Loaded image file "textures\borders\top_menu_highlight.tga" Undocked: Undocked: Undocked: Loaded image file "FillPatterns\leather2.bmp" Loaded image file "textures\icons\texticon.tga" Loaded image file "textures\DownArrow.dds" Loaded image file "textures\borders\tool_select_buttons.tga" * Loading shader "Shaders/uvpreview.hlsl"... Compiling VS... Compiling PS... * Loading shader "Shaders/uv.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... Loaded image file "textures\checker0.tga" Loaded image file "textures\checker1.tga" Loaded image file "textures\checker2.tga" * Loading shader "Shaders/wires.hlsl"... #define WORLD_SPACE Compiling VS... Compiling PS... Loaded image file "textures\borders\undocked.tga" Loaded image file "textures\borders\hints.tga" Can't load image file "textures\preview_pen0.tga" Options.xml: <AppOptions> <PenInterface::DisplaceObject>false</PenInterface::DisplaceObject> <RtpObj>true</RtpObj> <SoftwarePreset>Unknown</SoftwarePreset> <NormalsCalculationMethod>Maya_normals</NormalsCalculationMethod> <TriangulationMethod>DelaunayTriangulation</TriangulationMethod> <TBNMethod>MikkTSpace</TBNMethod> <NMAP_EXPORT_TYPE>NM_3DMAX</NMAP_EXPORT_TYPE> <FlipPtexQuads>false</FlipPtexQuads> <ShowFocalShift>false</ShowFocalShift> <ShowFalloff>true</ShowFalloff> <StorePenShapeForTools>true</StorePenShapeForTools> <StorePenRadiusForTools>true</StorePenRadiusForTools> <WHEEL_ACTION>WHEEL_CHANGE_RADIUS</WHEEL_ACTION> <CTRL_WHEEL_ACTION>WHEEL_CHANGE_PRESSURE</CTRL_WHEEL_ACTION> <SHIFT_WHEEL_ACTION>WHEEL_CHANGE_SMOOTH</SHIFT_WHEEL_ACTION> <ALT_WHEEL_ACTION>WHEEL_CHANGE_OPACITY</ALT_WHEEL_ACTION> <WheelZoomPerspSpeed>1.000000</WheelZoomPerspSpeed> <WheelZoomOrthoSpeed>1.000000</WheelZoomOrthoSpeed> <WheelZoomUVSpeed>1.000000</WheelZoomUVSpeed> <MainColor>FF40CC40</MainColor> <BackColor>FF000000</BackColor> <EnableChannels[0]>true</EnableChannels[0]> <EnableChannels[1]>true</EnableChannels[1]> <EnableChannels[3]>false</EnableChannels[3]> <NearPlane>1.000000</NearPlane> <PivotType>0</PivotType> <PenInterface::SaveSpecInNM>false</PenInterface::SaveSpecInNM> <PenInterface::SaveDispInNM>false</PenInterface::SaveDispInNM> <PenInterface::DontUseAnphaInNM>false</PenInterface::DontUseAnphaInNM> <PenInterface::DontUseAnphaAtAll>false</PenInterface::DontUseAnphaAtAll> <SymmSnapValue>0.400000</SymmSnapValue> <SnappingMethod2>1</SnappingMethod2> <Global_DontSnapSubdVertices>true</Global_DontSnapSubdVertices> <ProjectionThrough>false</ProjectionThrough> <FreezeViewMode>0</FreezeViewMode> <FreezePScrollSpeed>1.000000</FreezePScrollSpeed> <UsingProcessors>32</UsingProcessors> <UseMultiCore>true</UseMultiCore> <UseMulticoreForSaving>true</UseMulticoreForSaving> <UseMRT>true</UseMRT> <PickFromAllLayers1>true</PickFromAllLayers1> <PickDepthToo>true</PickDepthToo> <PickFromCentralPoint>true</PickFromCentralPoint> <PivotType>0</PivotType> <SwapYZ>false</SwapYZ> <EditorPath>photoshop.exe</EditorPath> <MeshViewQuality>0</MeshViewQuality> <Choose></Choose> <FILL_BORDERS_MODE>FILLB_ASK</FILL_BORDERS_MODE> <BorderEdgesWidth>64</BorderEdgesWidth> <LightDirX>-0.562900</LightDirX> <LightDirY>-0.279500</LightDirY> <LightDirZ>0.279500</LightDirZ> <MillionsOfPolygons>1.000000</MillionsOfPolygons> <TexSizeX>1024</TexSizeX> <TexSizeY>1024</TexSizeY> <LightAmbient>0.000000</LightAmbient> <ShowThumbs>true</ShowThumbs> <ShowIThumbs>true</ShowIThumbs> <ImgPath> <_str>PickData\sky.jpg</_str> </ImgPath> <PickerType>1</PickerType> <PickColorMode>0</PickColorMode> <PenSensivity>1.000000</PenSensivity> <Symmetry_point_opacity>40.000000</Symmetry_point_opacity> <CamZoomSpeed>1.000000</CamZoomSpeed> <CamRotSpeed>1.000000</CamRotSpeed> <SlidersStates> <SliderState> <ID>SMOOTH_STROKE</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_RADIUS</ID> <State>true</State> </SliderState> <SliderState> <ID>FALLOFF</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_DEPTH</ID> <State>true</State> </SliderState> <SliderState> <ID>SMOOTH_DEG</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_MASK</ID> <State>true</State> </SliderState> <SliderState> <ID>PEN_SPEC</ID> <State>true</State> </SliderState> <SliderState> <ID>ERASE_DEGREE</ID> <State>true</State> </SliderState> <SliderState> <ID>RetopoExtrusion</ID> <State>true</State> </SliderState> <SliderState> <ID>ViewBias</ID> <State>true</State> </SliderState> <SliderState> <ID>RtpOpacity</ID> <State>true</State> </SliderState> <SliderState> <ID>SymmSnapValue</ID> <State>true</State> </SliderState> <SliderState> <ID>*Basic2</ID> <State>true</State> </SliderState> <SliderState> <ID>*Tweak2</ID> <State>true</State> </SliderState> <SliderState> <ID>*UV2</ID> <State>true</State> </SliderState> <SliderState> <ID>*Commands2</ID> <State>true</State> </SliderState> <SliderState> <ID>*Surface4</ID> <State>true</State> </SliderState> <SliderState> <ID>*LC4</ID> <State>true</State> </SliderState> <SliderState> <ID>*Adjust4</ID> <State>true</State> </SliderState> <SliderState> <ID>*Objects4</ID> <State>true</State> </SliderState> <SliderState> <ID>*Commands4</ID> <State>true</State> </SliderState> <SliderState> <ID>SegmentsNum</ID> <State>true</State> </SliderState> <SliderState> <ID>*Modes3</ID> <State>true</State> </SliderState> <SliderState> <ID>*Commands3</ID> <State>true</State> </SliderState> <SliderState> <ID>*Selected3</ID> <State>true</State> </SliderState> <SliderState> <ID>*Selected2</ID> <State>true</State> </SliderState> <SliderState> <ID>*Sculpt1</ID> <State>true</State> </SliderState> </SlidersStates> <FoldersStates> <FolderState> <ID>OPENOBJ</ID> <Folder>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\</Folder> </FolderState> <FolderState> <ID>ObjLwoStlPlydaewrl</ID> <Folder>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\</Folder> </FolderState> <FolderState> <ID>SAVEMESH</ID> <Folder>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\</Folder> </FolderState> <FolderState> <ID>3b</ID> <Folder>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\</Folder> </FolderState> <FolderState> <ID>3b3b.jpg</ID> <Folder>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\</Folder> </FolderState> </FoldersStates> <AllowRmbProp>true</AllowRmbProp> <PanoRotation>0.000000</PanoRotation> <PanoBlur>0.000000</PanoBlur> <ShadersPreviewSize>1</ShadersPreviewSize> <RareGrid>false</RareGrid> <NormalGrid>true</NormalGrid> <DenseGrid>false</DenseGrid> <CustomGrid>false</CustomGrid> <GridStep3D>1.000000</GridStep3D> <GridSubSections>1</GridSubSections> <GridStepsCount>10</GridStepsCount> <ShowAxisX>true</ShowAxisX> <ShowAxisY>true</ShowAxisY> <ShowAxisZ>true</ShowAxisZ> <MovementSensitivity>1.000000</MovementSensitivity> <ZoomModulator>1.000000</ZoomModulator> <PanUDModulator>1.000000</PanUDModulator> <PanRLModulator>1.000000</PanRLModulator> <RotationSensitivity>1.000000</RotationSensitivity> <SpinModulator>1.000000</SpinModulator> <TiltModulator>1.000000</TiltModulator> <RollModulator>1.000000</RollModulator> <M3D_ActivationKey>Key 1</M3D_ActivationKey> <PenIconSize>1</PenIconSize> <StripIconSize>1</StripIconSize> <MaskIconSize>1</MaskIconSize> <MtlIconSize>1</MtlIconSize> <ModelsIconSize>2</ModelsIconSize> <RotateAroundYAxis>true</RotateAroundYAxis> <DisableRoll>false</DisableRoll> <RealtimeUVPreview>true</RealtimeUVPreview> <ZoomToVaryRadiusSensitivity>1.000000</ZoomToVaryRadiusSensitivity> <UpDonToVaryDepthSensitivity>1.000000</UpDonToVaryDepthSensitivity> <RLToVaryTransparencySensitivity>1.000000</RLToVaryTransparencySensitivity> <SpinToVaryRotationSensitivity>1.000000</SpinToVaryRotationSensitivity> <TiltToVaryFocalShiftSensitivity>1.000000</TiltToVaryFocalShiftSensitivity> <RollToVarySpecularSensitivity>1.000000</RollToVarySpecularSensitivity> <GeneralPen::Color.x>0.250980</GeneralPen::Color.x> <GeneralPen::Color.y>0.800000</GeneralPen::Color.y> <GeneralPen::Color.z>0.250980</GeneralPen::Color.z> <GeneralPen::Color2.x>0.000000</GeneralPen::Color2.x> <GeneralPen::Color2.y>0.000000</GeneralPen::Color2.y> <GeneralPen::Color2.z>0.000000</GeneralPen::Color2.z> <GeneralPen::PenRadius>0.767960</GeneralPen::PenRadius> <GeneralPen::PenRotation>0.000000</GeneralPen::PenRotation> <GeneralPen::DeepDegree>0.414515</GeneralPen::DeepDegree> <GeneralPen::ColorOpacity>1.000000</GeneralPen::ColorOpacity> <GeneralPen::SpecularDegree>1.000000</GeneralPen::SpecularDegree> <GeneralPen::Falloff>0.000000</GeneralPen::Falloff> <GeneralPen::FocalShift>0.000000</GeneralPen::FocalShift> <HidePenConstantlyInCapsMode>false</HidePenConstantlyInCapsMode> <HidePenConstantly>false</HidePenConstantly> <ShowPenShape>true</ShowPenShape> <ShowPenAlpha>true</ShowPenAlpha> <PenCircleColor>FFFFFF00</PenCircleColor> <PenShapeColor>FFFF0000</PenShapeColor> <PenShapeColorWithCTRL>FF0000FF</PenShapeColorWithCTRL> <PenShapeColorWithSHIFT>FF00FF00</PenShapeColorWithSHIFT> <ShowCentralSpotInCapsMode>true</ShowCentralSpotInCapsMode> <MessageAbovePen>0</MessageAbovePen> <MessageBelowPen>0</MessageBelowPen> <MessagesColor>FFFF0000</MessagesColor> <PickVertMode2>1</PickVertMode2> <RecentFiles> <_str>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\SimpleChar.fbx</_str> <_str>D:\Libraries\Documents/3D-CoatV4/UserData\autosave.3b</_str> <_str>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\SimpleChar.fbx(dp)</_str> <_str>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\SimpleChar.ply(dp)</_str> <_str>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\Easy.obj(dp)</_str> <_str>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\UV.3b</_str> <_str>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\UV-2.3b</_str> <_str>E:\SkyDrive\Bilder\Digital Art\Char\CharacterModel\UV-3.3b</_str> </RecentFiles> </AppOptions> Can anyone help ? Please -AgeTDev -
Almost all objects I make that have edges that are not round come out jagged after retopology or uv room. Everything looks great until I bring it into the paint room or render it.
If you unwrapped in the Retopo room but then made changes, how do you get those changes to update in the UV room?
I have a mesh that some how a couple verts are not welded and have split ends. Not sure where it happened, in Blender 3D or 3D Coat after unwrapping? I had some issues in Blender with unwelded verts after deleting faces and adding new faces/loops. Anyways.... Can I weld vertices within the UV template preview window, from the retopo or UV room? It's a very tiny area on the mesh and there's no way in the viewport. I could use the applink back to Blender to weld. Just wondering........
How do I get what I have done in the Retopo room to apply to the UV room? They are completely different.
So I have run into some issues. I don't know what I am missing. I have created a model in Silo 2, something very simple. I would like to UV it in 3D - Coat, however. When I go to mark the seams 3D - Coat isn't allowing me to select most of the edges of my model to mark the seams I don't know if it is an option I have missed, or whether there has been some slight change to the UV room since I last used 3D - Coat.
any tips on how i might remove these nasty white bits on the low poly bake
The uv tools are easy enough. I've seen many character uv's and basically know the idea behind it, to do my first unwrapping for an animation character anyways. I ran into a problem where when marking the seams on my characters head area. I used the autopo because of a pain area! Worked great. For some reason though when placing my seams in certain spots and unwrapping, my mesh part would be off of unwrapping symmetrically. All other islands were ok. I noticed some spirally loops(not spirally seams) in a couple areas on that part of the mesh. Could this cause the pull of out of symmetry islands? I also have few triangles in this part of the mesh I wasn't worried about, but may try and rmove them. All quads next time!! Basically I found a sweet spot for this mesh part with the seams and it was close anyways and no overlaps except one spirally loop area around a tooth joined to the mesh(.. So I may stick with it or edit those spiral loops and see the result.....tomorrow. Just curious what it could be so I can avoid it in the future.
Hi, i used the auto seams feature and unwrapped... the uvs turned out to be incredibly disproportionate. The only reason I can see for this is that I have made an incredibly large tri/polygon... but the twist is i cant find this polygon. If there were an invert selection function for the retopo room i could test if this idea is correct but i cant see this function, whut should i do?
