Showing results for tags 'uv'.
Trying to import an object with textures and uv. Yes I can do this through the uv room by importing there, the uv's, textures are there and I go to the paint room also. I would like to go to voxel or surface mode with the uv and texture still on it while editing. This can be done in Blender 3D btw. A low poly with textures can be used in sculpt with the multi-resolution modifier. I have poor performance with Blender though. Can this be done in 3D Coat. If not I would have to use Blender or take a quick render and use as sketch's in 3D Coat.
Is there a way to pack mirrored UVs with rotation and scaling but without un-mirroring the UVs and making them unique? I know you can make correctly mirrored UVs with Copy and Paste UVs, but it looks like there's no way to pack them without rotation that makes all the UVs unique, and I'd love to be proven wrong. It would also work out OK if there were a way to pack just selected UVs, because then I could just move one mirrored half off of the UV space, pack the UVs that are still on the 0..1 UV space, then copy and paste the other islands back.
I Havant used 3dcoat much and ive been trying to retopologize and uv map without success. ou As you can see i'm wanting a very lowpoly model, if anyonne knows of someresources that would help me with this I'd like to know The UV's are a disaster and I Dont know how to tweak the uv's so I can get rid of these nasty seems. These look like the most important things for me to learn, so if anyone can help me out, that'd be great
Help please..? Need to export retopo UV's as separate to each mesh
SanguineJackal posted a topic in General 3DCoat
Hey all! I'm having a bit of a hard time here so perhaps I could maybe get some help in here..... I hope this is the right forum. I just don't want to keep wasting time if I'm not getting anywhere! So, here's what I have- I have a dragon I have modeled, separate layers/objects for the eyes, teeth, horns, body and wings. I retopologized all of them, marked all UV seams, etc. in the Retopo room. I also painted it, and exports all work well (though I find Normals worked better in Voxel mode instead of Surface, and my paint is in Surface mode, sooooo.... I have to export separately. but that's not the big problem). Here's the problem: Being that I need them all as separate objects, I want to export all the retopologized UV's with their proper meshes. I.e., horn retopo and mapping only with horn .fbx, and so on. HOWEVER the mapping is all on one big map, and I can't get it to separate! I can get the OBJECTS separately, but all their maps- not so much. I tried importing the retopo mesh into PTEX so I could get it in the UV room and... oh my goodness. It's so glitchy. Also it deleted all my seams! The only thing I can think of is exporting each mesh, high res and low poly retopo, and baking normals that way. But would it transfer my paint data as well separately? I've attached what the PTEX error mess looks like, as well as what the current Retopo room looks like with the packed UV of all the objects. Thanks guys for any advice. -SJ -
Hi There, I used 3DC to UV map a model ( .obj). Then I did export it in Blender. Everything is perfect and it works well. Except, I can't get the seams appear on the mesh. I mean, the mesh is unwrapped in the UV window in Blender. But nothing "drawn" on the mesh. Could someone give an hand about this please ? Thx
Hi I'm buildings several stones in the same scene, and I've a problem when uvmapping because all uv map are together on the same map. The only way to avoid this seems deleting the objects i don't want to see on the uvmap before to merge into the paint room. but this mean I have to rebuild them later. is there an other way?
[SOLVED] Merging NM from high poly (sculpted) mesh to low poly
worldcrafter posted a topic in General 3DCoat
Hello. I am trying to make low ply objects for games (as a hobbyist and beginner) but i cant seem to find how i can merge the normal map from the sculpted mesh on to my retopoed version without the ugly result i get shown bellow -
Can someone tell me how i auto uv map an object which currently has no uvs, on 3.7 i could just select the auto map finction but now ive no idea... by the way whenm i click the uv tab i cant see the model this may be a problem or it may be how its meant to be. thanks
A little confused with paint. Per-pixel paints on the uv map but is projected on the 3d model? Low to medium to high quality depnding on uv map size? Microvertex paints on the vertices of the high poly and then projects onto the low poly? Quality depends on vertices(and uv map size)? So, what if I had a great machine and I was painting on a model with super high polys. Would this be the best quality? Can the high poly model be painted in P.P. and/or M.V. and then project the texture to low poly for export? Actually even with a super high vertice count. The textures on the uv map would end up per pixel on the screen?
Hello guys, I have used 3D-coat for a year now, but haven't actually tried out a lot of stuff. Mainly i have only revolve around the voxel room. I have recently downloaded and tried Blender, and it was amazing to me. But I wasn't going to give up 3D-coat, and looked for ways to link them. For the first few times, I have just imported the object straight from Voxel room, (usually 1 500 000 poly or above), and it is terrible to work with in Blender. I found out that i should autopo the model before hand, which i tried, but though the model turn out fine in the paint room, after exporting into Blender it was horrible. I tried UV mapping the model myself, but it didn't change a thing. What am I doing wrong? Really appreciate some help... T_T Model in the paint room which looks fine I only got the default and i didnt save the UV map i did, cuz it made no difference Model in Blender with the deformed mesh circled
Hello folks. Does anyone know how to create multiple UV tiles in the UV Room and how to prepare the model for seamless texture painting when multiple UV tiles are present? Is it possible in 3D Coat?
- uv room
- paint room
- (and 4 more)
[Solved] Can 3DCoat project a texture from one UV to another ?
Distortoise posted a topic in General 3DCoat
Let's say I had two copies of the same model, but with two vastly different UV sets applied to each. If I had a texture designed for one model's UV set, is there a way in which 3DCoat could look at this model with this texture and then use that information to paint the second model and its UV set to look as identical as possible to the first? -
Hi! I want to use 3D coat to post process high polygone (>1 mil) 3D scan data with UV maps. I need the sculpturing tools from the voxel room to cut bridges and smooth the scans. This works superb, but I loose the UV data. What is the right workflow to load the 3d model, optimize it and fix the UV map? Thank you! Best, Bernhard www.virtumake.com
Hi there While tinkering around with 3D Coat V4, I encountered what seems to be an issue with the update of uv set names when changed in the UV room. There are two issues: 1. When renaming an UV-set in the "choose an UV set" field (upper left on the screenshot), changes to names are sometimes not reflected and default back to, well, "default" 2. When renaming the UV sets in the materials sections (right on the screenshot), the uv sets are sometimes not updated in the choose an UV set field (see 1) I am not completely sure what the thinking is behind these two UI areas, but my logic would indicate that they're the same thing and should mutually update name changes, i.e. be consistent. Right? Let me know your thoughts... Cheers, Michael
Hello, all. I created this bread yesterday and put it into the UDK. It looks fine in most applications, and even in UDK's Static Mesh preview, it looks fine (see image 1). However, when I put it in a scene, I can see where the UV seams are on the model (see image 2). I exported with Smoothing Groups on from 3ds Max to try to fix this, but no use. Anyone have any ideas on why this is happening and/or how to fix it?
Hi, Is there a way for me to freeze parts of a mesh based off their UV patches? Cheers
Well, the thread title is pretty clear, but for the life of me I can not figure out how to properly manage multiple objects while uv mapping. For example, I have a ship consisting of multiple objects (in my case 66), and was really hoping to pick and choose the object to work on, or solo everything but the selected. ZBrush has its solo feature, Maya (and many others) have Hide Unselected Object features, but I can't seem to find anything similar within 3D Coat. Any help would be greatly appreciated. Currently I am going through my giant list of objects and manually hiding each one. This really can't be the only way can it? :P Thanks!
Hi evryone! Not quite getting the cloth out of 3dc as i'd like to, maybe you can give me a hint what i am doing wrong: I try to make a cloth drape from an imported .obj I do have UVs on the imported object that i would like to keep, but I don't see how to retain them, as they are always missing when I export the finished cloth from retopo as .obj I also tried to import to retopo first, (here i can see the original uvs) and them "pick from retopo" which works, but again after the simulation uvs seem lost. is there any possibility to retain the original UV for cloth objects? thanks, daniel
Pressing "Unwrap" button crashes 3D-coat
yaschan posted a topic in SOS! If you need urgent help for 3DCoat
I need urgent help. I have a fairly simple all-quad model I am trying to UV unwrap. If I manually mark the seams and hit Unwrap, 3D Coat crashes and I get forever spinning beachball. I am not using symmetry although the model itself is symmetrical. It is impossible to use 3D coat for unwrapping when this issue exists. I'm under deadline and I would need urgent help for this issue. I'm running 3D-Coat (3.7.08B (GL64) under Snow Leopard. My machine is Quad Core Mac Pro with 8 gigs of ram. Show screenshot of the model I try to unwrap. -
A few questions from a new user. Mostly Paint Room and related stuff.
ajz3d posted a topic in General 3DCoat
Hello. I've just purchased 3D Coat after my trail ended. I have to say I tried the hell out of it and I'm very impressed with the software. Sculpting with voxels is something I've been looking for for a long, long time, ever since I saw Ken Silverman's Voxlap engine. While not directly related to 3D modelling or sculpting, it showed how powerful voxels might be. I never quite understood why nobody picked up the idea of using voxels for volume shaping and model detailing. And then there was light - I've stumbled upon 3D Coat! But enough of praising the app. I've been doing a hero character in 3D Coat lately and I'm a bit puzzled about the some aspects of the workflow. I would like to address a couple of questions to more experienced 3D Coat users. My character consists of several parts (body, tongue, a pair of tendons and two groups of teeth, each on a different VoxTree layer), so I'll be using several different materials after I import the retopologised model into Maya). I need those parts to stay on separate UV spaces and maintain proportions in relation to each other. I have already retopologised the volume and placed each part of the character on a different retopo layer. Unfortunately UVs from each one of them are bunched up together on a single UV space and I can't seem to find a way to separate them to different UV spaces. How do I do this? Does a voxel shader affect textures in Paint Room in any way, or is it completely ignored? There's a Layer 0 in the Paint Room. What does it contain? Looks like a geometry, but other layers (that were created with the Merge with NM command from Retopo Room) seem to contain geometry as well? Layer 0 can't be deleted. UV Room most of the time stays completely empty, even after I unwrap UVs in Retopo Room. It fills with content after I Merge with NM. Is it normal? Paint Room has me completely puzzled.- 19 replies
- paint room
- uvs
(and 3 more)
Hi, another question probably leads to either a really simple answer or a bug. I'm still getting a hang of how to manage different oject and unwrap them separately, so far success to the point I can go to paint room and open UV Texture Editor and see different UVs for different objects. BUT, when I click to UV Room, one object is missing. My workflow is as following. 1. Voxel sculpt 2. put 2 object into 2 different layer.(just cube and cylinder) 3. go to retopo room and start unwrap cube. 4. create a new uv set, and use new uv set to unwrap cylinder 5. merge them to scene one by one. 6. in paint room I can do everything properly. 7. click to UV room I can only see cylinder. ( what ever merge to scene later?) In default uv set(cube) I see nothing, no model and no UVs. Am I missing something?
