Javis 523 Report post Posted May 16, 2014 I'd like to point out that Andrew told me this round of updates is to focus the Paint room. So get all those paint room bugs, FRs and ERs in asap. Share this post Link to post Share on other sites
PolyHertz 129 Report post Posted May 17, 2014 (edited) Now that layer groups are implemented, the next big change that needs to happen is the ability to select and move multiple layers at the same time. Layer groups are extremely important for organizing large numbers of layers, but the proces itself can be very slow/tedious when it has to be done one layer at a time. Turning on/off multiple layers quickly should also be implemented at some point. New groups should also automatically be labeled as such ie. "Group 1", "Group 2", etc. instead of as Layers. And I think for groups inside of other groups it would be easier to identify them if the arrow was next to the name instead of always in the same position next to the visibility icon, bolding the names of groups could also help when trying to differintiate them at a glance from layers too. Past that, the two big changes left I'd really like to see are PS-compatible layer masks, and an option to turn off forced texture culling/deletion. Layer thumbnails would be great too if possible, though I don't consider them nearly as important as the two formentioned changes. Anyhow, thanks Andrew for listening to us on the need for layer groups, and looking forward to seeing what else is in store for us Paint Room users Edited May 17, 2014 by PolyHertz Share this post Link to post Share on other sites
AbnRanger 1,537 Report post Posted May 17, 2014 Now that layer groups are implemented, the next big change that needs to happen is the ability to select and move multiple layers at the same time. Layer groups are extremely important for organizing large numbers of layers, but the proces itself can be very slow/tedious when it has to be done one layer at a time. Turning on/off multiple layers quickly should also be implemented at some point. Share this post Link to post Share on other sites
JoseConseco 122 Report post Posted May 17, 2014 (edited) +1. And easy way to fill freeze single voxel layer eg. object picker icon. Right now it requires bit many steps, more or less like this: -go to fill tool - check freeze - uncheck color - go to option - freeze by object - then find it on list by name, but it is not easy with many layers, especially if not named correctly. Also show hide freeze (ctrl+f) wont work in vertex paint. Thx. for your work Andrew Edited May 17, 2014 by JoseConseco Share this post Link to post Share on other sites
Andrew Shpagin 1,463 Report post Posted May 18, 2014 Updated to 4.1.07B - realtime preview for Textures->Adjust->... Multithreading optimisation applied to adjust operations. - Improved interaction with photoshop in case of mirrored UV sets - you may paint on both of mirrored sides and they will be merged correctly. - copy clay updated - but still in very beta stage. Pay attendion to bend->Laplacian - Hints over primitives restored - Res+ in surface mode subdivides whole mesh We hired new programmer, some time was spent to coordinate work and introduce some version control system. At all we have 5 programmers in team now. I & Raul are a bit haotic peoples, new programmer should compensate it a bit - he is man of order. 11 Share this post Link to post Share on other sites
BeatKitano 321 Report post Posted May 18, 2014 Goood. Thank you Andrew. Hopefully this will get forward more smoothly now. Take your time,if you need a few more weeks to get everyone up to speed and with proper tools take it. In the end it benefits everyone. 2 Share this post Link to post Share on other sites
artman 185 Report post Posted May 18, 2014 awesome!! Share this post Link to post Share on other sites
jaf 3 Report post Posted May 18, 2014 Not sure why.... I still see 4.1.07A on the 3DC window and "About" after I install 3d-Coat-V4_1-07B-64.exe (I did uninstall 07A first.) Share this post Link to post Share on other sites
JimB 16 Report post Posted May 18, 2014 Not sure why.... I still see 4.1.07A on the 3DC window and "About" after I install 3d-Coat-V4_1-07B-64.exe (I did uninstall 07A first.) Same here. Share this post Link to post Share on other sites
AbnRanger 1,537 Report post Posted May 18, 2014 Updated to 4.1.07B - realtime preview for Textures->Adjust->... Multithreading optimisation applied to adjust operations. - Improved interaction with photoshop in case of mirrored UV sets - you may paint on both of mirrored sides and they will be merged correctly. - copy clay updated - but still in very beta stage. Pay attendion to bend->Laplacian - Hints over primitives restored - Res+ in surface mode subdivides whole mesh We hired new programmer, some time was spent to coordinate work and introduce some version control system. At all we have 5 programmers in team now. I & Raul are a bit haotic peoples, new programmer should compensate it a bit - he is man of order. Thanks Andrew. While you are there in the Paint Room, would you please, please add some kind of color picker bar to the "Hue & Saturation" adjustment Dialog box? The user is flying blind when adjusting the Hue value. Been waiting for this for a long time. Share this post Link to post Share on other sites
Andrew Shpagin 1,463 Report post Posted May 18, 2014 My mistake - 4.1.07A is correct naming. Seems I missed name changing. Share this post Link to post Share on other sites
AbnRanger 1,537 Report post Posted May 18, 2014 Here is how the dialog looks in Photoshop. You can see the difference, and again, in 3D Coat....you have no visual aid to show what Hue/Color value you are selecting. You have to "Wing It"....blindfolded. Can you please fix this? Share this post Link to post Share on other sites
Andrew Shpagin 1,463 Report post Posted May 18, 2014 Thanks Andrew. While you are there in the Paint Room, would you please, please add some kind of color picker bar to the "Hue & Saturation" adjustment Dialog box? The user is flying blind when adjusting the Hue value. Been waiting for this for a long time.For sure adjusts will be improved to be more photoshoppy, it is planned as well in nearest future. Share this post Link to post Share on other sites
digman 1,206 Report post Posted May 18, 2014 Updated to 4.1.07B - realtime preview for Textures->Adjust->... Multithreading optimisation applied to adjust operations. - Improved interaction with photoshop in case of mirrored UV sets - you may paint on both of mirrored sides and they will be merged correctly. - copy clay updated - but still in very beta stage. Pay attendion to bend->Laplacian - Hints over primitives restored - Res+ in surface mode subdivides whole mesh We hired new programmer, some time was spent to coordinate work and introduce some version control system. At all we have 5 programmers in team now. I & Raul are a bit haotic peoples, new programmer should compensate it a bit - he is man of order. Yahoo! the new programmer a " Man of Order" Share this post Link to post Share on other sites
TimmyZDesign 202 Report post Posted May 18, 2014 New programmer is "Man of Order"! Great news! Andrew/Raul's genius combined with someone to quality-check their work! The future is looking good! Share this post Link to post Share on other sites
mercy 6 Report post Posted May 19, 2014 New programmer is great news! More stability, more features, more powerful 3D-Coat. Maybe he will have new ideas about how to make tools more efficient and how to kill long-standing bugs and can implement it too! Share this post Link to post Share on other sites
ajz3d 786 Report post Posted May 19, 2014 Great news indeed! Share this post Link to post Share on other sites
digman 1,206 Report post Posted May 19, 2014 (edited) This has been a long standing issue, The progress bars do not work in the Linux versions of 3DCoat... My question is it IMPOSSBILE for the Linux version to have working progress bars. I will accept that fact if it is indeed impossible to code it in. Please answer one way or the other as it would be appreciated. Edited May 19, 2014 by digman 2 Share this post Link to post Share on other sites
PolyHertz 129 Report post Posted May 21, 2014 Cross post from this thread, because I think it's an issue that probably should get some attention: The smooth feature in the paint room is dependant on pixel count as opposed to brush size, so the higher the resolution of your texture the worse it'll work. It's basically worthless on a 4k texture. To give an example, here's smooth being used with the same brush size and pressure (using a mouse) on a texture across several resolutions. Notice that by 4096 it essentially does nothing: 1 Share this post Link to post Share on other sites
b33nine 21 Report post Posted May 21, 2014 Cross post from this thread, because I think it's an issue that probably should get some attention: I concur, this would be a very welcome change. Share this post Link to post Share on other sites
alvordr 104 Report post Posted May 21, 2014 Your smoothing based on resolution, so yes, it should be tighter on a higher resolution. Seems like it's working as it's supposed to. Share this post Link to post Share on other sites
PolyHertz 129 Report post Posted May 21, 2014 (edited) Your smoothing based on resolution, so yes, it should be tighter on a higher resolution. Seems like it's working as it's supposed to. From a technical perspective, it's not failing, but it's certainly not working the way anyone would actually want it to. I can't imagine any scenario where its current behavior would be desirable. Edit: Added a Mantis report: http://3d-coat.com/mantis/view.php?id=1502 Edited May 21, 2014 by PolyHertz 1 Share this post Link to post Share on other sites
philnolan3d 252 Report post Posted May 21, 2014 Here's a little bug I cam across. I'm using VoxLayer with Steady Stroke turned on. If I switch to another tool, then back. Steady Stroke is now off and I have to turn it on again. Share this post Link to post Share on other sites
Javis 523 Report post Posted May 21, 2014 There's another bug related to smoothing using various ePanel modes. Smoothing doesn't work (by holding SHIFT) and using any of the lasso selection modes. Share this post Link to post Share on other sites
