I'm getting a crash when UVing upon hitting the 'unwrap' button; it doesn't happen with all geo, but there seems to be no manifold or problematic geometry with the pieces that do cause a crash.  Figured I'd bring some attention to it.  Below is the crash log.
 post-2039-0-17220000-1413485542_thumb.jp
Also I get an exploding vertices error when importing into zbrush even if use all the geometry cleaning tools in 3dc; see the pic below
post-2039-0-53557900-1413486687_thumb.jp
about crash
do you have another retopo group/s without seams and not unwraped before perform a bake ?
exploding
weld vertices before export helps
on my side its day and night. Really killer Undo speed. :)
Undo is rather zippy for me, too.
Gang, it's cool that it improved your undo speeds, but I don't see any undo speed improvements on my side. I'm currently working on an isolated 3.5M surface layer (total scene's tris-count is 48M), but each Move Tool undo takes about 4 seconds* (CPU power and HD access is barely utilised during the operation). Oh, why I always have to be the guy experiencing most of the problems... :(
* - the radius of the brush I used is very small and I get the same timings in proxy x16...
Edited by ajz3d
move still have a lag after release
and move with conform retopo mesh on (and mesh in retopo room)... more lag
comments feeling a bit "Demanding" here...
Keep up the Great work Andrew! Really appreciating it all!
:D
anybody is having issue deleting a hotkey using backspace?.....3Dcoat keeps assign the hotkey to "Back" instead of deleting it.
It happens 90% of the time now.....
Hey Christian! I'm seeing that as well. Unfortunately it appears there is no way to clear a hotkey without redefining it entirely, at the moment.
Updated to 17C (NO PBR there, only minor fixes!)
- Tweak room select works correctly
- Topo symm works correctly, it copies regardless on previous stamp mode usage
Update with PBR will be later, there is still too much work woth materials, preview, baking, export etc
Mac&Linux will be updaed to 17C soon as well
Thanks for the fixes, Andrew. :good:
:D
Not really. The PBR stuff is still being worked on. Andrew just fixed a few important things in the current build. Tweak room was practically useless with selection being broken (seemed to happen when Axial Symmetry was introduced). If you cannot select your object, then you cannot apply any transforms to them.
17C
crash exporting baked model from paint room
Any1 ?
ty
Bug fix action is good! Any chance for a fix to the depth export bug? I'll post a mantis link a little later, mobile atm.
Ver: 4.1.17 (CUDA), not sure if this has been fixed or noticed, yet, but when I go into full screen mode (Alt + Enter), it won't let me change the name of layers in the Voxel Room.
Also, I know it's been a while since I've used 3D Coat, due to other things on my plate, but I can't get the Stencils or Stamps to overlay as I paint.  Well, stamps are doing nothing and stencils are sporadically working.  This is after I just upgraded to 4.1.17D.  When I can't get stencils to work, I have to change color using X and then paint over it and it seems to work then.
Edited by alvordr
I have this issue as well but only in GL builds.
It happens with any input boxes .
I already reported but nobody confirmed...probably because evrybody is using DX.
(actually you can change the name but the box is hidden...you cannot see it)
I just noticed a problem with UNDO while sculpting in the SCULPT room. It would take several seconds per undo. Surface mode or Voxel, it was the same. But as soon as I closed the app and re-started it, the problem went away. Not sure why that would occur, but I thought I should mention it for anyone here who had issues with UNDO earlier .
Into full screen mode (Alt + Enter), it won't let me change the name of layers
confirmed. Popup is blocked
UNDO issue
confirmed
UNDO issue
confirmed
Yeah, the UNDO issue is still recurring frequently, but once in a while it stops acting up like that. Strange.
PBR in 3DCoat will be interesting, how the renderer will handle PBR materials. The old renderer is pretty good and fast, I liked it a lot years ago.
Thank you Andrew for the wonderful program! It is so nice to be able to do ( almost ) everything in one piece of software, claying, painting, building, still it feels like playing around, so easy.
