philnolan3d Posted June 27, 2014 Share Posted June 27, 2014 I'm excited to try this axial symmetry. It should be great for making really detailed designs like sculptures on architecture. Link to comment Share on other sites More sharing options...
Member mercy Posted June 27, 2014 Member Share Posted June 27, 2014 (edited) Radial Stamp in Zbrush is super slow. Maybe 3D-Coat programmers can create a faster Radial Stamp?1. It must rotate each stamp on their own center-pivot when moving the mouse2. It must "SHIFT horizontal snap" the rotation of each stamp on their own center-pivot to any 90° degrees it is closer to (if angle = 249 then snap to 270° ) when pressing SHIFT. Snap Angle should be configurable: like snap to every 45°, etc..3. Each stamp must rotate as mouse is moved and stamps must be at 100% opacity, or radial fade per stamp if you feel like coding. Edited June 27, 2014 by mercy Link to comment Share on other sites More sharing options...
Contributor BeatKitano Posted June 27, 2014 Contributor Share Posted June 27, 2014 Is the titlebar bug fixed in 4.1.09c ? I've 4.1.09 (don't know the letter as I can't see it): Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted June 27, 2014 Contributor Share Posted June 27, 2014 It looks good on my side: Link to comment Share on other sites More sharing options...
Contributor BeatKitano Posted June 27, 2014 Contributor Share Posted June 27, 2014 Yep,fixed in C, I think I had 4.1.09 (not even a). It's actually a bug and not fixed in 4.1.09c, I can't really pinpoint the cause but I would say it's related to autosave kicking in or iterative save in certain conditions. It's weird. Link to comment Share on other sites More sharing options...
Contributor Malo Posted July 2, 2014 Contributor Share Posted July 2, 2014 (edited) Version 4.1.09c Every Usage of the Curve Tool in Surface Mode creates a new Preset of the Curve Tool on the next startup. Could anybody confirm that? How to. 1. Start in Surface Mode 2. Make a curve with the Curve Tool 3. Apply 4. Close and restart 3d Coat and you see a new Preset from that curve Edited July 2, 2014 by Malo 1 Link to comment Share on other sites More sharing options...
Contributor Malo Posted July 3, 2014 Contributor Share Posted July 3, 2014 Same with Merge Tool in Voxel Room and all tools that are involved with the Merge Tool like Clone and Cut&Clone Am i the only one that notice that new behavior? 1 Link to comment Share on other sites More sharing options...
Advanced Member GeneralAce55 Posted July 5, 2014 Advanced Member Share Posted July 5, 2014 Same with Merge Tool in Voxel Room and all tools that are involved with the Merge Tool like Clone and Cut&Clone Am i the only one that notice that new behavior? I can confirm this as well! 1 Link to comment Share on other sites More sharing options...
Contributor Malo Posted July 5, 2014 Contributor Share Posted July 5, 2014 Thanks. 1 Link to comment Share on other sites More sharing options...
Contributor Malo Posted July 5, 2014 Contributor Share Posted July 5, 2014 Mantis Request is open for everybody who have the same Bug. http://3d-coat.com/mantis/view.php?id=1534 Link to comment Share on other sites More sharing options...
Advanced Member moska Posted July 6, 2014 Advanced Member Share Posted July 6, 2014 hi there i would like to know where Carlosan is getting the axial symmetry? I'm with 4.1 v8c on OSX thanks Link to comment Share on other sites More sharing options...
Carlosan Posted July 6, 2014 Share Posted July 6, 2014 info about here http://3d-coat.com/forum/index.php?showtopic=4372&p=110232 is in development, im only posting the news from Andrew tweeter site. Link to comment Share on other sites More sharing options...
philnolan3d Posted July 8, 2014 Share Posted July 8, 2014 Anyone else seeing this. You can press 1 to see Relief Only. Pressing 7 should get you back to Low Smooth shade but for some reason I can't just hit 7, I have to click empty space first, then hit 7. This is on a Surface mode model, not sure if that matters. Link to comment Share on other sites More sharing options...
Taros Posted July 8, 2014 Share Posted July 8, 2014 I thought always the 6 key was for low smooth shading? Now I see... Nothing happen here too. Link to comment Share on other sites More sharing options...
Member pgson Posted July 8, 2014 Member Share Posted July 8, 2014 (edited) I'm having a major problem with the retopo room in 4.1.09c. I'm only doing some tiny nails for a character's hand. A few polygons each. It not only won't break into uv islands right, it crashes 3D-Coat when trying to add seams/unwrap every time. I've tried this three different times, in three different, simpler ways. Same problem: Uvs attempted to be applied: Only one pair of them looks remotely right. The checkerboard island breakdown on the model shows the others are all screwed: Even floating the mouse around in the menu causes crashes: Adding seams eventually crashes fully it: Pretty crazy. I've retopoed similar tiny/thin pieces before without any issue on previous versions, like multiple buttons and rivets. I just tested again adding seams to another mesh and unwrapping and it worked fine. Windows 8.1 AMD 6300 processor ram 12 gb Radeon 7700 Edited July 8, 2014 by pgson Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted July 8, 2014 Reputable Contributor Share Posted July 8, 2014 Try using the DX version, then go to MyDocs/3D Coat V4 and delete the "options.xml" file. That can sometimes get a little buggered up and cause bug-like issues. Link to comment Share on other sites More sharing options...
Member pgson Posted July 8, 2014 Member Share Posted July 8, 2014 (edited) Same result. For a moment there, it seemed like it might be working better; 3D-Coat didn't crash, but the uvs were still screwed up. A second attempt at opening it and unwrapping caused it to immediately crash. I was thinking maybe the reference mesh was the problem. But, it happens when I bring in just the retopoed mesh by itself. Edited July 8, 2014 by pgson Link to comment Share on other sites More sharing options...
Advanced Member alvordr Posted July 8, 2014 Advanced Member Share Posted July 8, 2014 (edited) Try reinstalling 3D Coat? Have you had any driver (particularly graphics driver) updates, lately? Edited July 8, 2014 by alvordr Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted July 8, 2014 Reputable Contributor Share Posted July 8, 2014 Same result. For a moment there, it seemed like it might be working better; 3D-Coat didn't crash, but the uvs were still screwed up. A second attempt at opening it and unwrapping caused it to immediately crash. I was thinking maybe the reference mesh was the problem. But, it happens when I bring in just the retopoed mesh by itself. Use the MOVE VERTICES (should be Move Elements, because it moves edges, faces, loops and rings, too) to move some of the Verts around and see if you don't have some overlapping verts somewhere, that's wreaking havoc. Sounds like it might be that mesh. Another way to inspect it is to go to the Retopo Menu and choose "Select Faces" > If you have overlapping verts or some stray verts, it will create a triangle or ngon. That tool will highlight any of those. Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted July 8, 2014 Reputable Contributor Share Posted July 8, 2014 If you want, you can PM me with a link to file, and I can see if I can spot the issue Link to comment Share on other sites More sharing options...
Member pgson Posted July 9, 2014 Member Share Posted July 9, 2014 (edited) Try reinstalling 3D Coat? Have you had any driver (particularly graphics driver) updates, lately? No to both. Haven't had any issues with retopology prior to this. Thanks for the suggestion, though. Use the MOVE VERTICES (should be Move Elements, because it moves edges, faces, loops and rings, too) to move some of the Verts around and see if you don't have some overlapping verts somewhere, that's wreaking havoc. Sounds like it might be that mesh. Another way to inspect it is to go to the Retopo Menu and choose "Select Faces" > If you have overlapping verts or some stray verts, it will create a triangle or ngon. That tool will highlight any of those. Thanks. I've sent you a pm with an obj of one of the tries at this. I've gone ahead, though, and taken the retopoed mesh into 3Ds Max to uv it. No issues there. In 3D-Coat, I was able to select the faces with no problems. I am thinking it might be due to the vertices being so close together, even if they aren't directly overlapping, as this is a tiny mesh with a very tiny edge to those nails, since they are fingernails, and it's that edge that's been the issue in adding seams. I know 3D-Coat (at least it used to) had issues with making really thin meshes. Maybe it's just having a hard time with that edge. Edit: I should add, the mesh I sent doesn't have polygons for under the nail like my other tries did, which would be why I would need to add a seam to separate that portion. However, if you add a a seam anyway along the edge, the crash should eventually happen, and unwrapping the mesh, with or without seams, should still show the utter mess it becomes. Edited July 9, 2014 by pgson Link to comment Share on other sites More sharing options...
PolyHertz Posted July 9, 2014 Share Posted July 9, 2014 Quick question; Is it possible to set the wireframe opacity in 3DC (not just the color)? Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted July 9, 2014 Reputable Contributor Share Posted July 9, 2014 Quick question; Is it possible to set the wireframe opacity in 3DC (not just the color)? No, it's not, I'm afraid. Link to comment Share on other sites More sharing options...
Carlosan Posted July 11, 2014 Share Posted July 11, 2014 Andrew Shpagin @AndrewShpagin · 7h Support of general symmetry done for all rooms. Making final cleanup ------------------------------------------------------ I guess the development of Layers masks ala PS will be begin next. For questions about, or to make suggestions for review, please be welcome to share or discuss them here. thank you very much Link to comment Share on other sites More sharing options...
Advanced Member GeneralAce55 Posted July 11, 2014 Advanced Member Share Posted July 11, 2014 I can't wait to test out the radial symmetry! Congratulations Andrew Link to comment Share on other sites More sharing options...
Contributor artman Posted July 12, 2014 Contributor Share Posted July 12, 2014 Andrew i posted to mantis a very major issue about Transform tool gizmo and switching room on 4.1.09A hope you find time to fix it before releasing beta build with axial sym as I would really like to test it. Probably easy to fix issue. http://3d-coat.com/mantis/view.php?id=1537 Also could it be possible to have to "To main axis","To Center mass"and "To bound Center" inside Pose tool too. Right now there is only "align to view",which makes it very diificult to work sometimes. Especially when scaling "to main axis" and "to center mass" are very important to preserve uniformity on the axis. thanx Also another issue,when using Transform tool, "To main axis" do not work correctly when voxel volume is empty(ex:empty parent layer), Link to comment Share on other sites More sharing options...
Javis Posted July 12, 2014 Share Posted July 12, 2014 Andrew Shpagin @AndrewShpagin · 7h Support of general symmetry done for all rooms. Making final cleanup ------------------------------------------------------ I guess the development of Layers masks ala PS will be begin next. For questions about, or to make suggestions for review, please be welcome to share or discuss them here. thank you very much After Layer Masks (or before preferred), UDIM support for real UV tiles, and no crazy work arounds or fenageling. Discussion was HERE but should be in this thread. Link to comment Share on other sites More sharing options...
PolyHertz Posted July 12, 2014 Share Posted July 12, 2014 (edited) After Layer Masks (or before preferred), UDIM support for real UV tiles, and no crazy work arounds or fenageling. Discussion was HERE but should be in this thread. Do we have a roadmap for 3DC? There's a lot of little changes that should happen in the paint room after layer masks, but in terms of major improvements UV tiles and the issue I brought up last page should definitely be among the top priorities. Edited July 12, 2014 by PolyHertz Link to comment Share on other sites More sharing options...
PolyHertz Posted July 13, 2014 Share Posted July 13, 2014 Also, this deserves to get some attention too: http://3d-coat.com/mantis/view.php?id=1522 1 Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted July 13, 2014 Author Share Posted July 13, 2014 Updated to 4.1.10 - general case of symmetry introduced. All tools but Autopo support new symmetry. Autopo support for miltiple mirrors expeted in next build. - fixed gizmo problem in transform tool. - fixed stamp mode problem in vxelmode. This is first beta related to symmetry, so it is possible that you will find something that is not covered by new symetry. Please report to me. 5 Link to comment Share on other sites More sharing options...
