Carlosan Posted October 16, 2014 Report Share Posted October 16, 2014 about crash do you have another retopo group/s without seams and not unwraped before perform a bake ? exploding weld vertices before export helps Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted October 18, 2014 Contributor Report Share Posted October 18, 2014 (edited) on my side its day and night. Really killer Undo speed. Undo is rather zippy for me, too. Gang, it's cool that it improved your undo speeds, but I don't see any undo speed improvements on my side. I'm currently working on an isolated 3.5M surface layer (total scene's tris-count is 48M), but each Move Tool undo takes about 4 seconds* (CPU power and HD access is barely utilised during the operation). Oh, why I always have to be the guy experiencing most of the problems... * - the radius of the brush I used is very small and I get the same timings in proxy x16... Edited October 18, 2014 by ajz3d Link to comment Share on other sites More sharing options...
Carlosan Posted October 18, 2014 Report Share Posted October 18, 2014 move still have a lag after release and move with conform retopo mesh on (and mesh in retopo room)... more lag Link to comment Share on other sites More sharing options...
Advanced Member Tser Posted October 20, 2014 Advanced Member Report Share Posted October 20, 2014 Still no Linux update? How long does it take to move from one version of CentOS to another? T. Link to comment Share on other sites More sharing options...
Advanced Member ebitz Posted October 21, 2014 Advanced Member Report Share Posted October 21, 2014 How 'bout an ETA? Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted October 21, 2014 Reputable Contributor Report Share Posted October 21, 2014 How 'bout an ETA? https://twitter.com/AndrewShpagin/status/523385302459908096 ETA on the PBR build. Not sure about Linux Link to comment Share on other sites More sharing options...
Advanced Member ebitz Posted October 22, 2014 Advanced Member Report Share Posted October 22, 2014 Nice. Hope linux hits at same time. Link to comment Share on other sites More sharing options...
Advanced Member Aleksey Posted October 22, 2014 Advanced Member Report Share Posted October 22, 2014 comments feeling a bit "Demanding" here... Keep up the Great work Andrew! Really appreciating it all! 1 Link to comment Share on other sites More sharing options...
Contributor artman Posted October 22, 2014 Contributor Report Share Posted October 22, 2014 anybody is having issue deleting a hotkey using backspace?.....3Dcoat keeps assign the hotkey to "Back" instead of deleting it. It happens 90% of the time now..... Link to comment Share on other sites More sharing options...
Javis Posted October 23, 2014 Report Share Posted October 23, 2014 Hey Christian! I'm seeing that as well. Unfortunately it appears there is no way to clear a hotkey without redefining it entirely, at the moment. Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted October 25, 2014 Author Report Share Posted October 25, 2014 Updated to 17C (NO PBR there, only minor fixes!) - Tweak room select works correctly - Topo symm works correctly, it copies regardless on previous stamp mode usage Update with PBR will be later, there is still too much work woth materials, preview, baking, export etc Mac&Linux will be updaed to 17C soon as well 1 Link to comment Share on other sites More sharing options...
Member bocs Posted October 25, 2014 Member Report Share Posted October 25, 2014 Link to comment Share on other sites More sharing options...
Javis Posted October 25, 2014 Report Share Posted October 25, 2014 Thanks Andrew! Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted October 25, 2014 Reputable Contributor Report Share Posted October 25, 2014 Updated to 17C (NO PBR there, only minor fixes!) - Tweak room select works correctly - Topo symm works correctly, it copies regardless on previous stamp mode usage Update with PBR will be later, there is still too much work woth materials, preview, baking, export etc Mac&Linux will be updaed to 17C soon as well Thanks for the fixes, Andrew. Not really. The PBR stuff is still being worked on. Andrew just fixed a few important things in the current build. Tweak room was practically useless with selection being broken (seemed to happen when Axial Symmetry was introduced). If you cannot select your object, then you cannot apply any transforms to them. Link to comment Share on other sites More sharing options...
Carlosan Posted October 25, 2014 Report Share Posted October 25, 2014 17C crash exporting baked model from paint room Any1 ? ty Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted October 26, 2014 Author Report Share Posted October 26, 2014 Updated to 17D due to problem of often crashing. 2 Link to comment Share on other sites More sharing options...
Javis Posted October 26, 2014 Report Share Posted October 26, 2014 Bug fix action is good! Any chance for a fix to the depth export bug? I'll post a mantis link a little later, mobile atm. Link to comment Share on other sites More sharing options...
Advanced Member alvordr Posted October 27, 2014 Advanced Member Report Share Posted October 27, 2014 (edited) Ver: 4.1.17 (CUDA), not sure if this has been fixed or noticed, yet, but when I go into full screen mode (Alt + Enter), it won't let me change the name of layers in the Voxel Room. Also, I know it's been a while since I've used 3D Coat, due to other things on my plate, but I can't get the Stencils or Stamps to overlay as I paint. Well, stamps are doing nothing and stencils are sporadically working. This is after I just upgraded to 4.1.17D. When I can't get stencils to work, I have to change color using X and then paint over it and it seems to work then. Edited October 27, 2014 by alvordr Link to comment Share on other sites More sharing options...
Contributor artman Posted October 27, 2014 Contributor Report Share Posted October 27, 2014 Ver: 4.1.17 (CUDA), not sure if this has been fixed or noticed, yet, but when I go into full screen mode (Alt + Enter), it won't let me change the name of layers in the Voxel Room. I have this issue as well but only in GL builds. It happens with any input boxes . I already reported but nobody confirmed...probably because evrybody is using DX. (actually you can change the name but the box is hidden...you cannot see it) Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted October 27, 2014 Reputable Contributor Report Share Posted October 27, 2014 I just noticed a problem with UNDO while sculpting in the SCULPT room. It would take several seconds per undo. Surface mode or Voxel, it was the same. But as soon as I closed the app and re-started it, the problem went away. Not sure why that would occur, but I thought I should mention it for anyone here who had issues with UNDO earlier . Link to comment Share on other sites More sharing options...
Carlosan Posted October 27, 2014 Report Share Posted October 27, 2014 Into full screen mode (Alt + Enter), it won't let me change the name of layers confirmed. Popup is blocked UNDO issue confirmed Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted October 28, 2014 Reputable Contributor Report Share Posted October 28, 2014 Into full screen mode (Alt + Enter), it won't let me change the name of layers confirmed. Popup is blocked UNDO issue confirmed Yeah, the UNDO issue is still recurring frequently, but once in a while it stops acting up like that. Strange. Link to comment Share on other sites More sharing options...
Member mercy Posted October 28, 2014 Member Report Share Posted October 28, 2014 PBR in 3DCoat will be interesting, how the renderer will handle PBR materials. The old renderer is pretty good and fast, I liked it a lot years ago. Link to comment Share on other sites More sharing options...
Advanced Member spacepainter Posted November 5, 2014 Advanced Member Report Share Posted November 5, 2014 Thank you Andrew for the wonderful program! It is so nice to be able to do ( almost ) everything in one piece of software, claying, painting, building, still it feels like playing around, so easy. Link to comment Share on other sites More sharing options...
Member CyBorge Posted November 5, 2014 Member Report Share Posted November 5, 2014 (edited) Yes, Spacepainter is exactly right! Some praise for how ambitiously great 3D-Coat, Andrew, and the community here, have been. PBR will just be more "Awesome"! - In fact, Andrew has been such a good boy, maybe he should be posting his Christmas list! Edited November 5, 2014 by CyBorge 4 Link to comment Share on other sites More sharing options...
Advanced Member spacepainter Posted November 6, 2014 Advanced Member Report Share Posted November 6, 2014 (edited) what boy? Edited November 6, 2014 by spacepainter Link to comment Share on other sites More sharing options...
Advanced Member Marc Wakefield Posted November 6, 2014 Advanced Member Report Share Posted November 6, 2014 what boy? He is talking about Andrew being a good boy for providing us with such awesome, artist friendly tools. Link to comment Share on other sites More sharing options...
Advanced Member spacepainter Posted November 6, 2014 Advanced Member Report Share Posted November 6, 2014 (edited) he's not a boy he is a father. Is the smile with teeth meant to make words more popular? I guess this forum is about showing off your giant computer and being cynical. Used to be a more friendly place. Edited November 6, 2014 by spacepainter Link to comment Share on other sites More sharing options...
Advanced Member Grimm Posted November 6, 2014 Advanced Member Report Share Posted November 6, 2014 spacepainter, calling Andrew a good boy is, in english speaking countries, a term of endearment. It comes from the stories children are told about Santa Claus and how "good boys" get presents and "bad boys" do not. Look up "colloquialism" if your interested. In other words it is a friendly and benign statement. Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted November 6, 2014 Contributor Report Share Posted November 6, 2014 I am positive that there was no intention to denigrate Andrew. Chief on Andrew's "wish list" would perhaps include a rash of new sales. Tell your friends! Link to comment Share on other sites More sharing options...
