Carlosan Posted October 16, 2014 Share Posted October 16, 2014 about crash do you have another retopo group/s without seams and not unwraped before perform a bake ? exploding weld vertices before export helps Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/319/#findComment-113960 Share on other sites More sharing options...
Contributor ajz3d Posted October 18, 2014 Contributor Share Posted October 18, 2014 (edited) on my side its day and night. Really killer Undo speed. Undo is rather zippy for me, too. Gang, it's cool that it improved your undo speeds, but I don't see any undo speed improvements on my side. I'm currently working on an isolated 3.5M surface layer (total scene's tris-count is 48M), but each Move Tool undo takes about 4 seconds* (CPU power and HD access is barely utilised during the operation). Oh, why I always have to be the guy experiencing most of the problems... * - the radius of the brush I used is very small and I get the same timings in proxy x16... Edited October 18, 2014 by ajz3d Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/319/#findComment-114046 Share on other sites More sharing options...
Carlosan Posted October 18, 2014 Share Posted October 18, 2014 move still have a lag after release and move with conform retopo mesh on (and mesh in retopo room)... more lag Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/319/#findComment-114047 Share on other sites More sharing options...
Advanced Member Tser Posted October 20, 2014 Advanced Member Share Posted October 20, 2014 Still no Linux update? How long does it take to move from one version of CentOS to another? T. Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/319/#findComment-114090 Share on other sites More sharing options...
Advanced Member ebitz Posted October 21, 2014 Advanced Member Share Posted October 21, 2014 How 'bout an ETA? Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/319/#findComment-114141 Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted October 21, 2014 Reputable Contributor Share Posted October 21, 2014 How 'bout an ETA? https://twitter.com/AndrewShpagin/status/523385302459908096 ETA on the PBR build. Not sure about Linux Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/319/#findComment-114142 Share on other sites More sharing options...
Advanced Member ebitz Posted October 22, 2014 Advanced Member Share Posted October 22, 2014 Nice. Hope linux hits at same time. Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/319/#findComment-114164 Share on other sites More sharing options...
Advanced Member Aleksey Posted October 22, 2014 Advanced Member Share Posted October 22, 2014 comments feeling a bit "Demanding" here... Keep up the Great work Andrew! Really appreciating it all! 1 Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/319/#findComment-114166 Share on other sites More sharing options...
Contributor artman Posted October 22, 2014 Contributor Share Posted October 22, 2014 anybody is having issue deleting a hotkey using backspace?.....3Dcoat keeps assign the hotkey to "Back" instead of deleting it. It happens 90% of the time now..... Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/319/#findComment-114167 Share on other sites More sharing options...
Javis Posted October 23, 2014 Share Posted October 23, 2014 Hey Christian! I'm seeing that as well. Unfortunately it appears there is no way to clear a hotkey without redefining it entirely, at the moment. Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/319/#findComment-114192 Share on other sites More sharing options...
Andrew Shpagin Posted October 25, 2014 Author Share Posted October 25, 2014 Updated to 17C (NO PBR there, only minor fixes!) - Tweak room select works correctly - Topo symm works correctly, it copies regardless on previous stamp mode usage Update with PBR will be later, there is still too much work woth materials, preview, baking, export etc Mac&Linux will be updaed to 17C soon as well 1 Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/319/#findComment-114250 Share on other sites More sharing options...
Member bocs Posted October 25, 2014 Member Share Posted October 25, 2014 Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/319/#findComment-114251 Share on other sites More sharing options...
Javis Posted October 25, 2014 Share Posted October 25, 2014 Thanks Andrew! Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/319/#findComment-114253 Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted October 25, 2014 Reputable Contributor Share Posted October 25, 2014 Updated to 17C (NO PBR there, only minor fixes!) - Tweak room select works correctly - Topo symm works correctly, it copies regardless on previous stamp mode usage Update with PBR will be later, there is still too much work woth materials, preview, baking, export etc Mac&Linux will be updaed to 17C soon as well Thanks for the fixes, Andrew. Not really. The PBR stuff is still being worked on. Andrew just fixed a few important things in the current build. Tweak room was practically useless with selection being broken (seemed to happen when Axial Symmetry was introduced). If you cannot select your object, then you cannot apply any transforms to them. Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/319/#findComment-114256 Share on other sites More sharing options...
Carlosan Posted October 25, 2014 Share Posted October 25, 2014 17C crash exporting baked model from paint room Any1 ? ty Link to comment https://3dcoat.com/forum/index.php?/topic/10395-v41-beta-experimental-4117d/page/319/#findComment-114260 Share on other sites More sharing options...
