ebitz 105 Report post Posted October 20, 2012 Just a starter project as a new user of 3d coat. A fantastic tool. Can't wait for a stable V4. 2 Share this post Link to post Share on other sites
digman 1,206 Report post Posted October 20, 2012 All right, good work... I noticed in the bottom of your interface in the picture that you have in red "NonUniform. Voxels are based on a uniform space known as marching cubes. That red is a warning... It will cause major problems. It also effects surface mode (true polygons) Somewhere you transposed (stretched along one axis) your voxels or surface mode polygons. To fix the problem right click on the voxtree tab select either global space or uniform space. Sometimes we want to transpose along one axis but whenever you do that, just use the above to convert your voxel or surface mode space back to being uniform. Share this post Link to post Share on other sites
ebitz 105 Report post Posted October 20, 2012 All right, good work... I noticed in the bottom of your interface in the picture that you have in red "NonUniform. Voxels are based on a uniform space known as marching cubes. That red is a warning... It will cause major problems. It also effects surface mode (true polygons) Somewhere you transposed (stretched along one axis) your voxels or surface mode polygons. To fix the problem right click on the voxtree tab select either global space or uniform space. Sometimes we want to transpose along one axis but whenever you do that, just use the above to convert your voxel or surface mode space back to being uniform. Thank you so much for that. I had no idea. It was effecting how my scene was rendering. I still have a hard time on understanding how 3d coat works. All I understand is objects are essentially volumes or filled with cubes. As far as understanding why these options like(uniform and global space) are even there and what issues they are supposed to correct is still a mystery to me. I just don't know how 3d Coat works under the hood and why I need these certain commands. Is there any documentation on that sort of thing. Maybe I missed it in the Manual? Share this post Link to post Share on other sites
ebitz 105 Report post Posted October 21, 2012 Nearing final of Rhino. Standing at about 16 million tris. Used masking and brush alphas for most of detailing. 1 Share this post Link to post Share on other sites
chris_solo 39 Report post Posted October 21, 2012 Nice work ebitz! ...don't forget that you can make the creations of some details in the paint room! ++Chris Share this post Link to post Share on other sites
ebitz 105 Report post Posted October 21, 2012 Your right I did forget that part of 3D Coat. Guess I was having too much fun in the Voxel room. I'll use that to clean up any textures from here on though. Thanks for the comment as well. Share this post Link to post Share on other sites
ebitz 105 Report post Posted October 30, 2012 Update on Rhino. Retopology and painting all done in 3D Coat. Used Applink to blender and assembled and lit my character here. Done with the low poly I think (11345 tris). Onto rigging and animation for turntable... I think. Share this post Link to post Share on other sites
digman 1,206 Report post Posted October 30, 2012 Looking real good there, waiting to see the turntable animation... By the way nice lighting of your model, using the Blender internal renderer. Share this post Link to post Share on other sites
Carlosan 2,497 Report post Posted October 30, 2012 cool will you please attach the wire screen capture ? are using normal map ? Which settings do you use to export its ? Share this post Link to post Share on other sites
Garagarape 414 Report post Posted October 30, 2012 Marvelous! I wonder if this one will be used in a movie. Share this post Link to post Share on other sites
ebitz 105 Report post Posted October 30, 2012 Looking real good there, waiting to see the turntable animation... By the way nice lighting of your model, using the Blender internal renderer. Thanks for the comment digman. Yes just using Blender Render. Using spotlights and environment lighting. Fairly simple setup. cool will you please attach the wire screen capture ? are using normal map ? Which settings do you use to export its ? Thanks Carlosa. Yes I am using a Normal Map. Also using Diffuse, AO(Cavity Map pretty much) and Spec. All done in 3D coat. 2 k textures. To setup Blender I simply turned on the addon under preferences. In 3D Coat as well I made sure under preferences to use blender,Maya normals. In the paint room I simply export to under file menu and Blender. All my objects from the paint room come into blender seamlessly along with my texture maps(Color,Normal,Spec) already applied to a shader and applied to my objects. Awesome feature. I did adjust the scale of my objects after that but all I had to do was light the scene and render. Done. Screen shots of wireframe below. Marvelous! I wonder if this one will be used in a movie. Thanks for the comment Garagarape. I don't know about a movie but maybe a game.... 1 Share this post Link to post Share on other sites
stusutcliffe 171 Report post Posted October 31, 2012 Very nice work! Looking forward to a finished render. Share this post Link to post Share on other sites
AbnRanger 1,540 Report post Posted October 31, 2012 Looks really good. Nice work. Share this post Link to post Share on other sites
Carlosan 2,497 Report post Posted October 31, 2012 ty ebitz can i ask too about local space normalization settings in your preferences ? The retopo was manual ?... amazing detailed work ! Share this post Link to post Share on other sites
ebitz 105 Report post Posted November 1, 2012 ty ebitz can i ask too about local space normalization settings in your preferences ? The retopo was manual ?... amazing detailed work ! My local space normalization setting is set to B by T. All of the retopo was manual yes. Used alot of the strokes brush there. Can be just as fast with more control then autopo. Good practice as well. I find that autopo is better suited for objects that won't deform or just getting down poly quick and then going in afterwards and editing them. Thanks for the comment as well. Share this post Link to post Share on other sites
AbnRanger 1,540 Report post Posted November 1, 2012 My local space normalization setting is set to B by T. All of the retopo was manual yes. Used alot of the strokes brush there. Can be just as fast with more control then autopo. Good practice as well. I find that autopo is better suited for objects that won't deform or just getting down poly quick and then going in afterwards and editing them. Thanks for the comment as well. That's a good observation. I've always felt that the Strokes tool was something of an Auto Retopology tool in it's own right. You essentially sketch your topology, hit ENTER and you have your mesh. Share this post Link to post Share on other sites
ebitz 105 Report post Posted January 6, 2013 Well, I though I would finally post my turntable idle pose animation for the Rhino. High poly, texturing, and retopology were done in 3d Coat. Rigging, Animation, Rendering, Compositing and video editing done in Blender. Share this post Link to post Share on other sites
AbnRanger 1,540 Report post Posted January 6, 2013 Mucho Good'o. Share this post Link to post Share on other sites
m8nkey 2 Report post Posted January 6, 2013 Nice work. Slick presentation in your turnaround video too. Share this post Link to post Share on other sites
ebitz 105 Report post Posted January 6, 2013 Marvels Rhino (click to view in 3D) You can interactively view in Sketchfab. Sorry for the image, I will adjust at some other time. 1 Share this post Link to post Share on other sites
Tony Nemo 398 Report post Posted January 6, 2013 I hope the poachers don't spot him! Share this post Link to post Share on other sites
