Member Schoening Posted October 21, 2012 Member Share Posted October 21, 2012 Hi, I am working on a Knight, I would like to cut the Visor and Place it on its own layer so that I don't deform it to much. I made the basic mesh in blender, that's why its on one layer at the moment. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 21, 2012 Share Posted October 21, 2012 hmmm... hard to cut may be is better to separate the model in blender first, and then merge 2 .objs Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted October 21, 2012 Reputable Contributor Share Posted October 21, 2012 Voxel Mode Use the split tool with a spline from the e-panel. It will will place the visor on it's own layer. Be sure to set your e-panel border width to "0" Also you could use the hide tool and then under the voxel menu select "separate hidden part" That will place the visor on it's own layer has well. You can choose orthographic mode to make splitting or hiding easier if necessary. Quote Link to comment Share on other sites More sharing options...
