an alien ship?
michalis
i was testing same procedure using 3dc....
Voxel room
Sculpt an object
Retopo Room
Retopo the voxel object
Merge into scene MicroVerts
Paint Room
Import a picture .exr from Textures, Import, Displacement map
how can i set displacement height ?
UVroom
Make some UVset face tweaks
At menu top right: choose checker, select custom texture...
because we cant open the .exr... just convert the .exr to .jpeg to use the jpeg for image reference.
Apply UV-set
finally
Paint Room
File, Export, select High Polymesh
The workflow Cycle begin again
Voxel room
Merge without voxelizing the High Polumesh exported from paint Room
the new mesh is loaded, and we can continue adding details with LC :D
great technique ! ty for sharing ! :)
You can use a 16 bit tif. Though 32 bit exr is much better.
Keep in mind that exr32 is a linear color space file.
The above last ~4M model, now at ~30k + normal maps. It took me a few clicks to directly bake it. Just UVunwrapped once more, as the previous UVs were for modeling purposes only.
You are making some awesome stuff there, It is eye catching, including the chair... :drinks:
My brain is so full of doing other things, plus 2D painting and 3DCoat, I think the old brain would burst if I tried one more thing but I promise Michalis, to get around to looking at this....
Thanks David.
Thanks Garagarape.
Searching for more clever and interesting panels. (voxels are great on this). Exporting a 2-3M decimated mesh in blender is a PITA. A depth map rendering? ( exr 32bit of course)
A support of such map in painting room?
Here, using a combination of two maps. One for real displacement, a second for bumps. It is a 400 faces only base. Displacement isn't much, sends ~500K in the render engine. The secondary bumpMap does the trick.
ahahaha final approach, Oops sorry for such a scene. but space Odysseys have an end, sometimes. LOL
Had some time to play with this . Lots of possiblities. Still need to learn a bit more on follow active quads..just not getting this yet.
@Britain
thanks, I also learned active quads because of this. I had tried them in the past, good results, but never thought they are a so powerful tool.
Something very blrendish, just for fun. Though the famous suzanne monkey of blender is very old and has bad topology. Just to see if I can manage bad topology too. There're a few tricks. Another great tip to handle displacement on specific areas (where mesh is thin for instance) is weight painting in blender. Use it as value under the displacement panel there.
Funny when saying that blender has an awful UI. Everything is there, waiting to use them. There's a unique logic, behind everything. And, it's not the 3dmax logic, for sure.
Spent more time with the follow the quads. I think I have this down now. In my line of work I do film over molding. The film gets stretched when the plastic rolls over it when it hits a high or low spot . So we start with a grid checked pattern to see low and high spots on the steel. I will create the same and learn this UV .
Your ships (and even the Blender monkey!) would be great assets for the next Alien film. I like the way in which you combine organic, round shapes with technology. Very impressive and unique. Great technique.
Thank you, all.
This is the essence of this workaround. There are no round shapes on such a panel-relief. What comes curved is because the topology curves. Follow topology.
On my last post, it's a 280K (resulting, after displacement, on the render engine only). It can go up to millions with no problems. But, it can go down to 70k, with similar results. It can be exported with UVs and bumps anywhere. Being a multires mesh, it can be down to a few hundred faces and bake normal maps directly from multires.
I mean, it's fully compatible with any workflow you have in mind.
Had some time to spend on the burning of the exr. Not as good as yours actually not really good at all but it did work. Need more practice there.
I can only guess what issues you're facing.
Have in mind, this operation is scale sensitive. So, apply scale changes first (ctrl+a/scale), select both target and source meshes, reduce scale (or enlarge) and bake again. A tip! LOL
  • 2 weeks later...
Here's another one, I really don't know what it supposed to be. LOL
And, a video tut from a friend, just the basics, I could say much more on the blender UV editor, on how to control displacement value via a vertex painting set, for instance (very important)
But, you have the basic idea behind this workaround.
Wow, finally a video tutorial! I have been very interested in this thread but quite a bit confused by it because I am not an experienced Blender user.
But in any case I want to thank you Michalis for sharing this! It is very kind of you. I am also enjoying the great thread you have going at Blender Artists!
And,,,
Mealea Ying's thread over at Zbrush is a wonderful treasure too! This has been some of the coolest stuff I have seen in a long while! Thank you!
Thanks, the video tutorial explains just the basics.
Much more to say on UV editing, on how these panels have to be... How to curve horizontal-vertical patterns.
My new experiments, psychonautic masonry.
And, a doodle, just to keep things in trunk. LOL
  • Like 3
