Decimate keeping UVset and textures ?
Carlosan
Hi
Its possible ?
i have done a 55K faces model, with UVset and textures
Now... I need the same model with 18K faces.
Im merging without voxelizing at Voxel room... and Decimate the model 66%,
its looks ok... but after the process the UVset and textures are lost :(
Is there any way to decimate a model keeping UVset and textures ?
cant find the way :unsure:
ty in advance and regards :)
I'm relatively new to 3D Coat, but I know you can save both your UV set and your textures. Can you not just load them back in? I suppose the UV set might be an issue, as it's based on your new topology...but it depends on how the decimation is done. I would think that if this is a problem, redoing the UV set shouldn't be too hard. It's one of the easiest programs I've found for UV work.
Ty alvordr:
I cant find the way... so opened a Mantis Feature Request
Feel free to add a +1 :D
http://3d-coat.com/mantis/view.php?id=830
0000830: Export model - add Reduction Tool Option preserving the UVset
When you export the model from Voxel room, there is a windows popup:
The Reduction Tool allows you to reduce the polycount before export to obj.
But at Paint Room... export model only have 2 Export Resolution options:
Export low-poly mesh
Export mid-poly mesh
Its possible to add a 3rd option:
The Reduction Tool
So we dont worry if we paint a high dense mesh... always we can decimate the final model at export.
But please is very important
- To preserve the UVset.
The edges marked as seams cant be altered/moved.
- To bake the paint layers from high dense mesh to the new decimated low mesh.
- An option to triangulate/quadrangulate the model before export to obj.
TY !!
