How do straighten an edge loop ?
Randy
In softimage, i would select the edge loop and COG scale it in on a global axis.
How do you folks do it ?
Select the loop (using Select tool in Retopo Room), I would switch to Verts, but you might be able to stay in edges mode > click on the Transform tool and scale them along either the world axis or local (option for local in the Transform tool options panel), just as you would in Softimage, Max or Maya.
