Advanced Member alvordr Posted January 10, 2013 Advanced Member Share Posted January 10, 2013 There appears to be no way to invert the cutoff tool, except by pressing shift. However, that also makes it draw a perfect circle (if you're using a circle spline) and I would rather use an oblong, inverted cutoff. How do you do this? Quote Link to comment Share on other sites More sharing options...
Psmith Posted January 10, 2013 Share Posted January 10, 2013 At this point, I think you will have to use the spline tool and approximate an ellipsoid - and use the "Shift" key. Not ideal, but it may produce the result you need. Greg Smith Quote Link to comment Share on other sites More sharing options...
Moderator Daniel Posted January 10, 2013 Moderator Share Posted January 10, 2013 Try Extrude tool for creating pieces with circles, rectangles, etc Quote Link to comment Share on other sites More sharing options...
Psmith Posted January 10, 2013 Share Posted January 10, 2013 The "Extrude" tool does not perform a "boolean" function like the "Cutoff" tool does. But, it had totally escaped my notice that we now have a dedicated "Ellipse" tool in the "E" panel. Try that one in conjunction with the "Shift" modifier. I tested this, also, with symmetry - but using "Shift" causes the entire object to disappear (Mac version). I'll let Andrew and Sergy know. Greg Smith Quote Link to comment Share on other sites More sharing options...
Advanced Member alvordr Posted January 11, 2013 Author Advanced Member Share Posted January 11, 2013 Greg, Yes, that's the functionality I saw, as well. This is what brought this up. I think it's just an unintended lack of function or bug. Quote Link to comment Share on other sites More sharing options...
Contributor TimmyZDesign Posted January 11, 2013 Contributor Share Posted January 11, 2013 Use carve tool with e panel elipse mode. Quote Link to comment Share on other sites More sharing options...
Advanced Member alvordr Posted January 11, 2013 Author Advanced Member Share Posted January 11, 2013 Sounds like the way to go, but you can't get it to add to the same thickness without a bunch of trial and error. I already went down that road. Good thought though. Quote Link to comment Share on other sites More sharing options...
Member Exsulator Posted February 9, 2018 Member Share Posted February 9, 2018 Perhaps this is a good place to mention it, when you use CTRL + SHIFT with the cut off tool IN SYMETRY MODE, it just deletes everything. The symmetry is leaking into the functionality in an unwanted way. This should be fixed to work as expected (all though I get why it deletes everything but it`s obviously not what you want) Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 14, 2018 Share Posted February 14, 2018 Bug reported. Thx ! //edit solved on latest version Quote Link to comment Share on other sites More sharing options...
