Member Voxelapocalypse Posted February 14, 2013 Member Report Share Posted February 14, 2013 I noticed the surface of the model is getting what can only be described as a very, very slight "oatmeal" texture. Little spec sized imperfections almost like specs of sand under a silk sheet to use another analogy. This is horrible... Smoothing does not help. It's as if voxels under the surface have hardened and will not yield to smoothing like they used to. I still have the trial version. I'm waiting for version 4. Anyone else noticing this? It's really discouraging. I don't ever recall seeing this "texture" before. Any helpful insight is really appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
Moderator Daniel Posted February 14, 2013 Moderator Report Share Posted February 14, 2013 several screenshots please! what mode: voxels? surface? Quote Link to comment Share on other sites More sharing options...
Advanced Member alvordr Posted February 15, 2013 Advanced Member Report Share Posted February 15, 2013 This is something that I personally feel could use more improvement. However, I do understand that the last few updates have really pushed smooth into better effectiveness. I suggest trying to use Smooth All under the Voxel menu at the top. You might use it a few times before you really see a difference. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 15, 2013 Report Share Posted February 15, 2013 i think that post can help... time ago i had some similar troubles: http://3d-coat.com/forum/index.php?showtopic=11157&view=findpost&p=86447 Quote Link to comment Share on other sites More sharing options...
Member Voxelapocalypse Posted August 16, 2013 Author Member Report Share Posted August 16, 2013 Thanks for the help everyone. V4 to the rescue! Quote Link to comment Share on other sites More sharing options...
