That's an interesting and original approach. What were you doing with the orange paint there?
I take it those snake tool sketches were made with the spline tool? How did you fill in those snake voxel sketches?
https://3dcoat.com/forum/index.php?/topic/11439-earth-dragon/#findComment-88167
to L'Ancien Regime san
Thank you for your comment. :)
I've mainly drawn with snake brush in the free hand.
I selected from E-Pane menu "affects draw depth" and snake brush's tool option is "Tube / Hemisphere"
If filling space of the many thickness, I select the "Grow or Clay Brush" + "Paint with drawn contour" in E-Pane menu or simply fill by snake brush.
If don't need a thickness, I select the "Fill Brush" + "Paint with drawn contour" in E-Pane menu.
post-2462-0-83118700-1362221157_thumb.jp
post-2462-0-30139400-1362221172_thumb.jp
https://3dcoat.com/forum/index.php?/topic/11439-earth-dragon/#findComment-88180
to chris_solo san
to artman san
to Garagarape san
Thank you for your comment ! I'm happy that you like this work. :)
And This is my new images.
As well as create the whole body by drawn line with snake brush and fill by grow brush in the free hand.
post-2462-0-51491900-1362229073_thumb.jp
post-2462-0-05639400-1362230512_thumb.jp
https://3dcoat.com/forum/index.php?/topic/11439-earth-dragon/#findComment-88191
I like working with sphere snake brush tool in voxel mode too, reminds me of the old days with amapi and laying out a spline cage before getting into the actual polygon creation :)
It's really fun to work like that but it takes and awful lot of time, it's nice to see someone using that technic and getting good results.
https://3dcoat.com/forum/index.php?/topic/11439-earth-dragon/#findComment-88212
to BeatKitano san
Thank you for your warm comment !
3D-Coat is very interesting that can drawn in many unique way. :)
I tried using "Pose" for adjust the arm angle.
Bend from masked by "Select with pen" is it useful.
And if combined with E-Pane "Paint with drawn contour", I was able more easily fill bend mask.
post-2462-0-82706800-1362282628_thumb.jp
https://3dcoat.com/forum/index.php?/topic/11439-earth-dragon/#findComment-88236
Oh, I have a small question. :ph34r:
I found the "Save selection" in the Pose Tool Options,
I have tried using it immediately but an error will be displayed.
"Mesh structure was changed and stored selection can't be applied to the mesh."
.....What I wrong ?
I don't edit anything while select the Save selection > Clear selection > Load selection.
post-2462-0-98481600-1362287164_thumb.jp
https://3dcoat.com/forum/index.php?/topic/11439-earth-dragon/#findComment-88237
Are your running the latest beta ? I just tried (without editing anything) and it worked. You need to not touch anything that modify the topology (no removestretching tool, no liveclay tool).
Thank you for your advise !
I've tested with a simple model in 3.7.18F, And I was able to get a good result in this version.
I will continue to work back to 3.7.18F.
Thanks.
https://3dcoat.com/forum/index.php?/topic/11439-earth-dragon/#findComment-88247
Unless you want to stick with 3.x cycle I suggest you get the v4 beta, 12b is particularly fast (and seems somewhat reliable sculpting-wise) which would help you with surface sculpting. Those betas are updated quite often and you can have both 3x and 4x installed on your machine without any issue.
[Edit] I'm confused looking at your sig you already know about v4...
https://3dcoat.com/forum/index.php?/topic/11439-earth-dragon/#findComment-88248
to BeatKitano san
Thank you for your advise. :)
Yes, I found V4 BETA11 OSX in this thread.
3D-Coat V4 Beta testing thread
But 3D-Coat can install separately 4 Beta and 3.7.x,
I will using more stable 3.7.x with check on "ShowBetaTools" until release of the 12b.
Thanks.
https://3dcoat.com/forum/index.php?/topic/11439-earth-dragon/#findComment-88270
