Carlosan Posted May 19, 2013 Share Posted May 19, 2013 Hello I need to sculpt using stamp mode with some brushes but changing ELEVATION. Where is the option ? i cant find it :P Sorry im linking for this docs, but cant explain the question in a better way http://docs.pixologic.com/reference-guide/brush/depth/ The Brush Placement allows you to control the embed of selected brush by moving the sphere up or down. The black line defines the surface and the Sphere represents the Inner and Outer Depth of a Brush. When Depth Brush Masking is enabled a black dot will specify the Outer Depth and Inner Depth of your brush. The OuterDepth slider will control now much the brush radius will affect the surface peaks when sculpting along a surface that has several plain changes. Ty Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 22, 2013 Author Share Posted May 22, 2013 Mantis feature request open http://3d-coat.com/mantis/view.php?id=1153 Quote Link to comment Share on other sites More sharing options...
