Member 3DTutorial Posted May 30, 2013 Member Report Share Posted May 30, 2013 (edited) Hi, I've been trying to use the bas relief tool but I'm having some problems. To be specific, after applying the tool some areas are being filled in and obliterated, but the thing is that I don't want these areas to be affected. For example, I don't want the jaw line to be wiped out like this... is there anyway to avoid this? Any help/advice would be appreciated. Thanks! Joe Edited May 30, 2013 by 3DTutorial Quote Link to comment Share on other sites More sharing options...
Moderator Daniel Posted May 30, 2013 Moderator Report Share Posted May 30, 2013 Hi! you can't if you want the bottom of the sculpture to be bas-reliefed from its closest point. As possible solution try to split it into two parts and do Bas-relief for both, and then combine them together 1 Quote Link to comment Share on other sites More sharing options...
Member 3DTutorial Posted May 30, 2013 Author Member Report Share Posted May 30, 2013 Hi! you can't if you want the bottom of the sculpture to be bas-reliefed from its closest point. As possible solution try to split it into two parts and do Bas-relief for both, and then combine them together Ok, makes sense. Actually, this is an excellent suggestion... I will give it a go. Thanks a lot for your help! Cheers, Joe Quote Link to comment Share on other sites More sharing options...
Moderator Daniel Posted May 30, 2013 Moderator Report Share Posted May 30, 2013 np, Joe! Give it a try! Quote Link to comment Share on other sites More sharing options...
