Member bytemann Posted June 8, 2013 Member Report Share Posted June 8, 2013 hi all, just a couple of simple yet useful batches.. Paint High Low Voxel batch// Adds two fill layers, first, with foreground color as "Less in cavity", second, with background color as "More in cavity". Smooth all volumes// Apply "Smooth all" to each volume in tree that is NOT in surface mode. have fun PaintHighLow.script.txt SmoothAllVolumes.script.txt Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 20, 2013 Report Share Posted June 20, 2013 WOW WOW AND WOW ! TESTING NOW !!! TY FOR SHARING !!!! Quote Link to comment Share on other sites More sharing options...
Advanced Member wave of light Posted June 21, 2013 Advanced Member Report Share Posted June 21, 2013 Wow, you clever puppy! Quote Link to comment Share on other sites More sharing options...
Member bytemann Posted June 21, 2013 Author Member Report Share Posted June 21, 2013 Great that you like it, a few explanations then ) in the first lines of the script are parameters you might want to tweak a bit every time you use it... smoothing : // change this to change resolution iterationsint resolutionSteps = 1;// change this to change smoothing iterationsint smoothingSteps = 5; painting : // change these values to alter cavity intensity for both passesfloat highFactor = 6.0F;float lowFactor = 6.0F; Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 21, 2013 Report Share Posted June 21, 2013 Hi Using v 4.04B the script crashed 3DC Which version are you using ? ty Quote Link to comment Share on other sites More sharing options...
Member bytemann Posted June 21, 2013 Author Member Report Share Posted June 21, 2013 oops.. sorry I'm on mac, 4.0.0.3 (GL64) can you check in the log.txt file in your 3dCoat data folder? there might be a way to debug that... Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 21, 2013 Report Share Posted June 21, 2013 ============================================================================21.06.2013 09:30:47 : Executing script: C:\Users\user\Documents\3D-CoatV4\Scripts\PaintHighLow.script.txt============================================================================ is not very helpful ------------------------------- I used it over an UV model loaded for PPP at paint room... must be only applied over a surface shape mode from sculpt room ? ty Quote Link to comment Share on other sites More sharing options...
Member bytemann Posted June 21, 2013 Author Member Report Share Posted June 21, 2013 oops, yes, it caused a bad freeze here too... and yes, the script ist meant for volumes, I haven't experimented much with ppp yet, I have to admit I guess it crashed when trying to switch a non existant volume to surface mode. there is another log.txt in your script folder, maybe there are more infos there, but probably not. (here, there where none except my own "print" instructions...) here is a fixed version of the paint script, checking for the first volume's existance before continuing, here it avoids this crash... Thanks for testing! PaintHighLow.script.txt Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted June 21, 2013 Contributor Report Share Posted June 21, 2013 What folder do they go in? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 21, 2013 Report Share Posted June 21, 2013 user\Documents\3D-CoatV4\Scripts so the last one is the upgraded version that cover all rooms ? or i need to use the first for surface mode and the last for paint mode ? this script is a BIG TIME SAVER !!! TYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY !!! Quote Link to comment Share on other sites More sharing options...
