Member IMX - Michael Posted July 23, 2013 Member Share Posted July 23, 2013 Hi there While tinkering around with 3D Coat V4, I encountered what seems to be an issue with the update of uv set names when changed in the UV room. There are two issues: 1. When renaming an UV-set in the "choose an UV set" field (upper left on the screenshot), changes to names are sometimes not reflected and default back to, well, "default" 2. When renaming the UV sets in the materials sections (right on the screenshot), the uv sets are sometimes not updated in the choose an UV set field (see 1) I am not completely sure what the thinking is behind these two UI areas, but my logic would indicate that they're the same thing and should mutually update name changes, i.e. be consistent. Right? Let me know your thoughts... Cheers, Michael Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 23, 2013 Share Posted July 23, 2013 3DC add "materials" to any new UVset created. Is your request related to this ? http://3d-coat.com/mantis/view.php?id=277 Quote Link to comment Share on other sites More sharing options...
Member IMX - Michael Posted July 23, 2013 Author Member Share Posted July 23, 2013 Hi, yes that could be related. just to make sure that I understand the logic correctly: Should the material names get updated if I change the name of the UV sets? or are they unrelated? Quote Link to comment Share on other sites More sharing options...
