error when starting 3DCoat!! (0xc000007b)
Hello!
I get an error when the program starts when I run the application. I installed version 3d-Coat-V4_0-04B1-64 and it gives me
an error : (0xc000007b) the same version OpenGL version works!!!
I have DirectX 11
system: Windows 8 - 64bits
processor : Intel Core i7-3770 CPU 3.40Ghz (8CPUs) 3.4Ghz
memory : 16 Go
video card : NVIDIA Geforce GTX 660
memory : 4044 MB
can you help me?
thanks
++Chris
thanks Tony, I'll try it soon.
so 3dcoat works well with DirectX 11 ? or it must with DirectX 9 ?
maybe the error comes from that??!
++Chris
yes I think it is this, it is rather annoying!! because I use DirectX 11 engine with Marmoset Toolbag engine...
I hope a fix will be done in the future. For now I'm using OpenGL version.
++Chris
  • 3 weeks later...
I installed the version 4.0.05 I would like to know if it works with DirectX 11?
I'd like to know if any versions that work with DirectX 11 or 9 ?...
++Chris
it would be nice to score somewhere the minimum and optimum configuration, I still don't know if 3DCoat works with DirectX 11 or DirectX 9 only?!
then if it works with DirectX 11, I have a problem with the latest version available online! this version works only with OpenGL! DirectX version doesn't work
if this is a problem with the Cuda version, I don't know which version I have, but I think it is 5...
thank you for feedback.
infos:
memory : 16 Go
memory : 4044 MB
> 3dcoat version 4.0.05  stable version
++Chris
Edited by chris_solo
I'm using 4.0.06A. CUDA DX     It runs fine on my windows8 -64bit system with DX11.  The file name for the version I'm using is 3d-CoatDX64C.exe.   I think the C at the end of the file name tells that it is CUDA.
Our systems specifications look almost identical, except I have a GTX 660ti video card.
Edited by Pix Jigsaw
so I downloaded, I installed this version and not this still doesn't work! :mad:
I don't understand...
My NVDIA Driver: 320.49
Driver Dll Version 5.50 (8.17.13.2049)
Runtime Dll version 5.0(6.14.11.5000)
I think I'll have to work with OpenGL!
++Chris
