Member Dennis Nikolaidis Posted September 8, 2013 Member Report Share Posted September 8, 2013 I'm trying to pick myself through the voxel sculpting, and I just noticed that the transform tool ignores the symmetry plane completely. I take it its transforming the whole layer, not the polygons/voxels themselves. Is there any workaround to this? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted September 8, 2013 Reputable Contributor Report Share Posted September 8, 2013 Flying blind without a screengrab of some kind. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted September 8, 2013 Contributor Report Share Posted September 8, 2013 I'm trying to pick myself through the voxel sculpting, and I just noticed that the transform tool ignores the symmetry plane completely. I take it its transforming the whole layer, not the polygons/voxels themselves. Is there any workaround to this? Use Pose tool with "select object" mode. Quote Link to comment Share on other sites More sharing options...
Contributor TimmyZDesign Posted September 8, 2013 Contributor Report Share Posted September 8, 2013 Use Pose tool with "select object" mode. WOW! That's genius Artman! THANK YOU for that! I had no idea how to do that until you explained it! @Dennis: Thanks for asking about this, I had been wondering the same thing for a long time. Artman's solution works perfectly. But you need to make sure that the "border width" setting in the E panel is set to "0" otherwise you will get a gradient selection across the form and it won't move all together as a whole (if you are using any of the marquee-type selection methods). Also, take note that only the Default shader will show the effects of your selections. Selections will be totally red for full selection (border width set to "0" in the e panel), or a gradient from blue-green-yellow-orange-red (border width anywhere above 0). The other shaders will not show this kind of colored selection; it appears on those shaders as a sort of faint grey color instead. Quote Link to comment Share on other sites More sharing options...
Advanced Member Pix Jigsaw Posted September 10, 2013 Advanced Member Report Share Posted September 10, 2013 Great thread! I was wondering why I got the colorful selection sometimes and the faint grey others. Mystery solved. Quote Link to comment Share on other sites More sharing options...
