Member Alco3d Posted August 25, 2015 Member Report Share Posted August 25, 2015 One more feature what wanted and i can't find - increase density (unsubdivide) selected. We have the subdivide tool in the Surface mode but haven't unsubdivide. I hope that will be good solution. Thanks! Quote Link to comment Share on other sites More sharing options...
Taros Posted August 25, 2015 Report Share Posted August 25, 2015 One more feature what wanted and i can't find - increase density (unsubdivide) selected. We have the subdivide tool in the Surface mode but haven't unsubdivide. I hope that will be good solution. Thanks! Is decimate not good? Or Clean Clay? Quote Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted August 25, 2015 Contributor Report Share Posted August 25, 2015 Or Resample? Quote Link to comment Share on other sites More sharing options...
Member Alco3d Posted August 28, 2015 Member Report Share Posted August 28, 2015 Is decimate not good? Or Clean Clay? Or Resample? Sorry for my english. I did mistake. I told you about REDUCING density of selected area. That will be cool if user could control density on the model at any time. Decimate and Resample surface works on whole surface, and they increases density. Quote Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted August 29, 2015 Contributor Report Share Posted August 29, 2015 Clean Clay works locally. You can set it to reduction or decimation. Quote Link to comment Share on other sites More sharing options...
Contributor TimmyZDesign Posted August 29, 2015 Contributor Report Share Posted August 29, 2015 You can brush local density on the mesh at any time while holding SHIFT. Set the SHIFT function to reduce. You can see the results in wireframe mode. Quote Link to comment Share on other sites More sharing options...
Advanced Member RabenWulf Posted October 1, 2015 Advanced Member Report Share Posted October 1, 2015 Time to vent a little bit... I have been fighting with 3d coat painting for awhile now, specifically how 3D Coat works with my tablet and pressure. I am getting to the point where I just want to stop using it altogether. Its inconsistent, sometimes the full pressure effect even though im putting little to no pressure at all, this makes blending a nightmare (hand painted textures), other times the quality of the strokes are just not very good (or sharp). I dont know if its also due to 8 bit imagery from 3d coat but the lack of smooth value blending also becomes very noticeable. So what I am forced to do is go back and forth to Krita (via external editor feature) and paint there (where the strokes, values, blending, its all consistent and accurate). I dont want to have to do this... so I guess you can say the resolved feature I am requesting is... really polish up and fine tune the texture painting. Something is just off about it which is really ruining the quality of my hand painted textures.(just to add, I have a dual set up with a cintiq and an intuos. Due two a beefy machine I can go up pretty high with the texture resolution, UVs are not tiny). Outside of 2d editors behaving properly/consistently, Mari Indie has also given good results. This is definitely something with 3d coat.) Quote Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted October 1, 2015 Contributor Report Share Posted October 1, 2015 (edited) Time to vent a little bit... I have been fighting with 3d coat painting for awhile now, specifically how 3D Coat works with my tablet and pressure. I am getting to the point where I just want to stop using it altogether. Its inconsistent, sometimes the full pressure effect even though im putting little to no pressure at all, this makes blending a nightmare (hand painted textures), other times the quality of the strokes are just not very good (or sharp). I dont know if its also due to 8 bit imagery from 3d coat but the lack of smooth value blending also becomes very noticeable. So what I am forced to do is go back and forth to Krita (via external editor feature) and paint there (where the strokes, values, blending, its all consistent and accurate). I dont want to have to do this... so I guess you can say the resolved feature I am requesting is... really polish up and fine tune the texture painting. Something is just off about it which is really ruining the quality of my hand painted textures. (just to add, I have a dual set up with a cintiq and an intuos. Due two a beefy machine I can go up pretty high with the texture resolution, UVs are not tiny). Outside of 2d editors behaving properly/consistently, Mari Indie has also given good results. This is definitely something with 3d coat.) Are you by any chance experiencing the problem I described here: http://3d-coat.com/forum/index.php?showtopic=18337 ? Edited October 1, 2015 by ajz3d Quote Link to comment Share on other sites More sharing options...
Advanced Member RabenWulf Posted October 2, 2015 Advanced Member Report Share Posted October 2, 2015 Are you by any chance experiencing the problem I described here: http://3d-coat.com/forum/index.php?showtopic=18337 ? Yep, thats the latest issue to plague me with 3D Coat. Always having to restart 3D Coat. Reinstalled intuos drivers. Even before this new issue the quality of the strokes felt a bit inconsistent, just not so extreme as with now. Quote Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted October 2, 2015 Contributor Report Share Posted October 2, 2015 Then the only advice I can give is to keep looking for a driver that works for you. For me it was 6.3.11w3 and my problems stopped after installing it. The driver that will work for you might be different though. Quote Link to comment Share on other sites More sharing options...
Advanced Member RabenWulf Posted October 2, 2015 Advanced Member Report Share Posted October 2, 2015 Then the only advice I can give is to keep looking for a driver that works for you. For me it was 6.3.11w3 and my problems stopped after installing it. The driver that will work for you might be different though. Thanks, I'll try rolling that far back... or hold off for a 3dc update and just use Mari for now. Just too many problems with 3DC in general, really makes it hard to enjoy using the software. Quote Link to comment Share on other sites More sharing options...
PolyHertz Posted October 2, 2015 Report Share Posted October 2, 2015 (edited) Feature wise, everyone already knows that I really want changes to the paint room. Layer groups, transferable layer masks, and the removal of the 'feature' that deletes and makes it impossible to have paint outside UV shell borders, all being at the top of that list. So it's been two years since I last commented in this topic, and things really haven't changed that much it seems. We got layer groups, but the other two things I mentioned still haven't been addressed I've actually been using ye olde BodyPaint3D again just so get access to PS compatible layer masks (I also like having layer thumbnails and optional true projection painting directly in the viewport). It's fine for hand painted textures, even if it took me several days to get around all the bugs. Layer groups and PBR getting added were cool, but past that I'm feeling rather disappointed in 3DC's development after all this time. Edited October 2, 2015 by PolyHertz Quote Link to comment Share on other sites More sharing options...
Member Equiso Posted October 2, 2015 Member Report Share Posted October 2, 2015 Trackball rotation a la Modo. Once you get used to it, there is no way back. Also, the smart material preview tends to reopen too much often. It can be frustrating to be closing it every time it's pop up. A fill by connected and some basic loop selection for masking would be very welcome. 2 Quote Link to comment Share on other sites More sharing options...
Advanced Member Ballistic_Tension Posted October 2, 2015 Advanced Member Report Share Posted October 2, 2015 yeah I hope we will be able to just close/get it off the screen soon having to keep closing and move it to the bottom of screen is frustrating it opens by itself from time to time as I never use the smart mat. preview. Quote Link to comment Share on other sites More sharing options...
Advanced Member JoseConseco Posted October 3, 2015 Advanced Member Report Share Posted October 3, 2015 +1 to block automatic opening of smart material preview. 3 Quote Link to comment Share on other sites More sharing options...
Advanced Member do lo Posted January 22, 2016 Advanced Member Report Share Posted January 22, 2016 i would like to be able to change the number of undos available. and a clear undos from memory. Quote Link to comment Share on other sites More sharing options...
Member Equiso Posted May 6, 2016 Member Report Share Posted May 6, 2016 Referenced fbx import. Sometimes, having this will make things so much easier. Example,Exporting an "exploded morphed" mesh,bake,export unmorphed.DoneThe good thing about this, would be having several fbx. Marmoset, Max, Modo have this so i thing this may help to have a cleaner pipeline. Quote Link to comment Share on other sites More sharing options...
Advanced Member Kargall Posted July 12, 2016 Advanced Member Report Share Posted July 12, 2016 It would be interesting to see the different color in groups of objects in the VoxTree. As the photoshop layers. Quote Link to comment Share on other sites More sharing options...
Advanced Member Vipera Posted November 10, 2016 Advanced Member Report Share Posted November 10, 2016 I am really missing Smooth Shade view with the wireframe on top in Sculpt room. I need to see shade view and wireframe together when I work on model with textures. The color of the wireframe needs to be adjustable. Quote Link to comment Share on other sites More sharing options...
Member Cless_Aurion Posted July 1, 2021 Member Report Share Posted July 1, 2021 There is this very annoying but somewhat specific problem I get from time to time. When I finish retopologizing a symmetric model with symmetric UVs, and when later I move it into the paint room and select triangulate, the triangulation WON'T be symmetric. This will mess up completely the bake later (I bake in Marmoset). I hope that could be fixed, since also, shape wise, in lowpoly characters a flipped differently triangle can make the model obviously less symmetric. 1 Quote Link to comment Share on other sites More sharing options...
Member Frimasson Posted July 12, 2021 Member Report Share Posted July 12, 2021 (edited) I've got a display issue on UV seams in paint room (parasite pixels that i can't rid of ) And this bug wasn't in 3dc 4.5 The texture was baked in Zbrush, touched up in 3d coat 2021 ( i wasn't able to get rid of white pixels ) And, when i load the model in 3d coat 4.5, white pixels are gone Edited July 12, 2021 by Frimasson 1 Quote Link to comment Share on other sites More sharing options...
Member Frimasson Posted July 12, 2021 Member Report Share Posted July 12, 2021 And if i open the model with white parasite pixels in 3dcoat 4.5 or 3d coat 4.9, the parasite pixels are gone If i load in 3d coat 2021 the model previously saved in 3dcaot 4.9, the parasite pixels dosen't show up anymore. Quote Link to comment Share on other sites More sharing options...
Member nickloong Posted July 12, 2021 Member Report Share Posted July 12, 2021 I hope the old version of the curve lasso tool can coexist with the new version Instead of removing The old version of the curve tool is much easier to use than the new version. Very convenient for quick styling 1 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member L'Ancien Regime Posted July 12, 2021 Advanced Member Report Share Posted July 12, 2021 5 hours ago, nickloong said: I hope the old version of the curve lasso tool can coexist with the new version Instead of removing The old version of the curve tool is much easier to use than the new version. Very convenient for quick styling I agree... 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member tokikake Posted July 22, 2021 Advanced Member Report Share Posted July 22, 2021 I still hope to separate material from UV set . At current I make some cloghings mat.. each clothings have 5 or 6 sections as different material group (or shader group or mat slot, call as you like) but all material are gathered as one UV unit. (no over wrapping), about this case. I need to decide work flow A or B A simply gather as one UV set, so it remove all material group = I really hastle again to make section for each material in 3d coat (but in original app, they have material group) B use material group as UV set, it means, each mesh will generate 5 or 6 UV sets then 3d coat generate all textures for each UV set. as different name. (get huge data) So we need type C 3d coat use material group as material section, but it keep to use same UV of original mesh. so one UV set may contain 2 or 3 or 5 material as group. Quote Link to comment Share on other sites More sharing options...
Member milhouzz Posted July 22, 2021 Member Report Share Posted July 22, 2021 please fix the extrude/build,..... in voxels mode really wish this will be working again soon as it s such a basic function thanks guys Quote Link to comment Share on other sites More sharing options...
Advanced Member sprayer Posted July 22, 2021 Advanced Member Report Share Posted July 22, 2021 (edited) 1 hour ago, milhouzz said: please fix the extrude/build,..... in voxels mode really wish this will be working again soon as it s such a basic function thanks guys Can you describe? To me voxel work fine but in surface extrude partly working with alphas Edited July 22, 2021 by sprayer Quote Link to comment Share on other sites More sharing options...
Member milhouzz Posted July 22, 2021 Member Report Share Posted July 22, 2021 1 hour ago, sprayer said: Can you describe? To me voxel work fine but in surface extrude partly working with alphas my problem is extrude,build and any tool in the same "category", i cannot extrude using either lasso, rectangle or any of the selection tools, doesn't seem to work. I also don t see the direction menu when i want to extrude at the top Quote Link to comment Share on other sites More sharing options...
Advanced Member sprayer Posted July 22, 2021 Advanced Member Report Share Posted July 22, 2021 7 minutes ago, milhouzz said: my problem is extrude,build and any tool in the same "category", i cannot extrude using either lasso, rectangle or any of the selection tools, doesn't seem to work. I also don t see the direction menu when i want to extrude at the top Please report about that here. And you may report other bugs, Andrew now focused on bug fixing. build tool work with lasso by the way Quote Link to comment Share on other sites More sharing options...
Member milhouzz Posted July 22, 2021 Member Report Share Posted July 22, 2021 30 minutes ago, sprayer said: Please report about that here. And you may report other bugs, Andrew now focused on bug fixing. build tool work with lasso by the way reported it here thanks. really odd i tried latest update from yesterday and none of those tools work with the lasso...hope this will be fixed soon! 2 Quote Link to comment Share on other sites More sharing options...
