Member MkIII Posted September 30, 2008 Member Report Share Posted September 30, 2008 Apologies if this has come up before: The transparency setting is really the wrong way around, with higher settings equalling less rather than more transparency. perhaps this would be more correctly named Opacity? Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted October 1, 2008 Report Share Posted October 1, 2008 Apologies if this has come up before:The transparency setting is really the wrong way around, with higher settings equalling less rather than more transparency. perhaps this would be more correctly named Opacity? Right, that is better to change. Quote Link to comment Share on other sites More sharing options...
