Advanced Member FreezeFrame Posted December 7, 2013 Advanced Member Report Share Posted December 7, 2013 (edited) How can I center by joining 2 object along the x plane in symmetry? I find when merging objects that my symmetry plane is not centered and is slighty off from rotating, flipping 180 deg. etc. If I happened to move my x symmetry plane with tab. How do I know if my 2 objects are really centered from the x middle(symmetry), left(object) and right(object)? Or sometimes the symmetry will be at 0 and the left and right identical object will be off. Do I have have to separate the objects and input the coordinates in the transform. Or is there a quicker way when merging in symmertry? Thinking right now...To bound center of the two objects and then transform the left and right coordin...anything quicker? Edited December 7, 2013 by FreezeFrame Quote Link to comment Share on other sites More sharing options...
Advanced Member FreezeFrame Posted December 7, 2013 Author Advanced Member Report Share Posted December 7, 2013 (edited) Well this worked for me anyways. check "move only gizmo" , then " bound center", then un-check "move only gizmo" and center the position at zero... Edited December 7, 2013 by FreezeFrame Quote Link to comment Share on other sites More sharing options...
