Advanced Member worldcrafter Posted December 28, 2013 Advanced Member Report Share Posted December 28, 2013 Does anyone know if there is a way to adjust how More in cavity and less in cavity work when painting a normal mapped model, If not this would certainly be an improvement for 3d coat, its very handy for making things look worn and eroded but depending on your model you may want to adjust the allowance between what is classed as a cavity thanks. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted December 28, 2013 Reputable Contributor Report Share Posted December 28, 2013 Have you tried adjusting the Cavity scale (upper portion of the UI)? You can enter a value numerically that is higher than what you can reach with the slider. When those modes are enabled, you should see a preview window you can drag over the object, to see how it looks...before you start painting Quote Link to comment Share on other sites More sharing options...
Advanced Member worldcrafter Posted December 30, 2013 Author Advanced Member Report Share Posted December 30, 2013 (edited) Go to this thread http://3d-coat.com/forum/index.php?showtopic=15592&hl= to answer this question please... i did not say what i meant here - sorry Edited December 30, 2013 by worldcrafter Quote Link to comment Share on other sites More sharing options...
Advanced Member alvordr Posted January 9, 2014 Advanced Member Report Share Posted January 9, 2014 (edited) I believe all you're after is depth settings. I work with normal maps all the time now, and have found that either by setting the depth (usually from around 1-27, as anything above that seems too powerful) or adjusting the depth modulation in the Blending Tab, just to beside the Layers Tab in the Paint Room. You can also either hold Cntl + Left Click to paint inversely or toggle the Invert Tool Action option near the top of the UI, under the menu. Same works for Specularity (E.g. Specular Modulation, Specular Intensity, etc.). This + a good set of Materials and/or Masks and brush settings can knock out a decent stone or rock in no time. Edited January 9, 2014 by alvordr Quote Link to comment Share on other sites More sharing options...
