Contributor Tony Nemo Posted February 4, 2014 Contributor Share Posted February 4, 2014 I tried to smooth an area and created holes instead. I tried other tools with the Shift key and also created holes. This is in voxel mode.Broken_Smooth.zip Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 4, 2014 Share Posted February 4, 2014 The file compressed is: Broken_Smooth.swf Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted February 5, 2014 Author Contributor Share Posted February 5, 2014 Yeah, I used Jing to make a video showing how the Smooth tool and any other using Shift key make holes in the object in Voxel mode. In Surface mode, it works normally. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 5, 2014 Share Posted February 5, 2014 testing but no holes here Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted February 6, 2014 Author Contributor Share Posted February 6, 2014 I'm using the latest build 14B and in voxel mode, smoothing by any means makes holes. The first image shows a bit of Grow: The next image shows the holes created by the Smooth tool and Grow with Shift: This does not occur in Surface mode. I deleted the Options.XML file to see if outcomes were different, but no luck. I am using the latest video driver for my GTX560 TI so maybe that has something to do with it. Quote Link to comment Share on other sites More sharing options...
