[SOLVED] Import collada with multiple UV-maps
dragon
Yes it is generally possible. 3DC doesn't support UV tiles natively. What it does is when it sees multiple UV tiles in use is it will have an option upon import (and thus upon export as well), is it gives you an option to import UV tiles as UV maps and then assigns a number to each tile section. Also when you export you need to make sure to tick the option for export UV maps (or sets I believe it's called on the option) as UV tiles.
great model
will you please assign a different material for every UV-maps ?
post-10142-0-18638400-1395223491_thumb.j
3DC use same Lightwave philosophy, UV islands are split by materials.
Very handy if you works with ddo or surface designer combo.
