How to select short edges for UV seam?
madno
Hi,
I can't manage to select the short edges in the UV editor.
Whatever I do it is always one of the longer edges that gets the focus.
Is there a trick or setting which I am missing?
post-6900-0-94048200-1395161193_thumb.pn
The geometry is a box which I made in Lightwave and opened as lwo in 3D-Coat.
In LW the box was made as 1 meter in size and the edge radius was set to 1 millimeter.
Thanks for help.
Good idea, but I tried it already with no luck.
More testing showed that it does not like long distance edges and short distance onces being in the same mesh.
With a more balanced mesh it worked.
post-6900-0-70287300-1395175745_thumb.pn
post-6900-0-72261400-1395175761_thumb.pn
But nevermind I can switch to another software for creating UVs.
I am not sure if I do it right. Lasso or rectagle are the ones I can select in the E panel, right?
If that is the case it still does not like the short edges.
I have attached the box which I saved from 4.0.11A.
Maybe you can have a look?
BOX-for-UV.zip
Please ignore the little sphere in there. I placed it for use with UVLayout, because that software does not have an xyz indicator. If you load a mesh into UVLayout you never know where the front, back etc. is.
I made a new box.
It is still one meter in size but the smoothing edges are one cm instead of one millimeter this time.
With those settings it works. I can now select the short edges.
Seems so that 3D-Coat's UV room really does not like a very long and very short edges being together.
Should I make a ticket out of this?
I believe you found a bug... I tested your box and had the same problem...
Windows beta version 4.0.17A
Link below to sign up for a Mantis account to post the bug report...
http://3d-coat.com/mantis/signup_page.php
Edited by digman
  • 1 year later...
