Light Color opposite in render viewport
In the render viewport when you select a light colour it gives you the exact opposite of the colour you choose. This is using the HSL1 colour picker. I have tried others and they all give the same value. However it's not quite so simple as that. If you choose pink at the NE setting of the hue wheel you get the correct colour. Equally if you choose green in the SW quadrant it seems to be correct. Other positions are not the colour you choose.
I am using 4.0.04A on a Mac Pro with Mavericks 10.9.1
