Shu
[SOLVED] Incredibly slow AUTOPO (3DC 4.1)
Hello everyone!
To be honest, I'm not positive if I only missed some setting that will turn off complex calculations I don't need. But, after having updated to version 4.1, the AUTOPO function will take a very long time.
I did not measure the time, but I'd say it takes about 10 times longer than it used to in version 4.0.
Even if I set the quality to "Draft quality - fastest", there will not be a major difference.
Also, when AUTOPO is finally finished, the mesh will not have the polycount I chose in the dialogue window (difference of about 1000 polys). If I remember correctly, in 4.0, the resulting meshes used to have differences of about 50 polygons.
I am using the Mac OS version of 3D-Coat on Mac OS 10.7.5.
Many thanks in advance for any help!
Greetings,
Shu
Edited by Shu
Hi!
Sounds like a bug, I would file a Mantis report on this for certain.
Hello Javis!
Thank you for your answer!
You are talking about
http://3d-coat.com/mantis/my_view_page.php , right?
Also, while this problem occurs, is there a way I can use both, version 4.0 and 4.1 at the same time?
So that I can use the new features of 4.1 and still get retopo done in 4.0?
Because right now, if I understand this correctly, I have to uninstall the license, register it on the other version and restart my computer each time I want to use a different version.
For safety\anti-piracy reasons that's probably not possible, though, is it?
EDIT:
I have reported this problem:
http://3d-coat.com/mantis/view.php?id=1463
Edited by Shu
Alright, these problems have been solved.
"DecimateIfAbove" has to be used and there has to be set a moderate number.
"Setting big value of decimation limit will lead to quality degradation and drastical slowdown.
Best value - 40. If it destroys details - try 50 or 60, but anything above 100 is not good" (Andrew)
http://3d-coat.com/mantis/view.php?id=1464 )
