Reputable Contributor Popular Post AbnRanger Posted April 12, 2014 Reputable Contributor Popular Post Report Share Posted April 12, 2014 I tried to upload some brush-packs to the DOWNLOAD > RESOURCE section of the mainpage, but it has not been a successful venture. Wasted a lot of time trying to do so....so I guess I'll just try to share them here. 1) 3DC Brushes Random collection of brush alpha's containing cracks, wrinkles, reptile scales, etc. https://drive.google.com/file/d/0B5zx7iMKxeu5Z016VFZGR3FYQ00/edit?usp=sharing 2) Cracks & Wrinkles https://drive.google.com/file/d/0B5zx7iMKxeu5SHRValA5Qk9iWTQ/edit?usp=sharing 3) Reptile Skin/Scales https://drive.google.com/file/d/0B5zx7iMKxeu5bC1JNGYwbGgyRjA/edit?usp=sharing 10 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted April 12, 2014 Author Reputable Contributor Report Share Posted April 12, 2014 Here are the thumbnails of the brushes in their respective brush alpha packs Quote Link to comment Share on other sites More sharing options...
Contributor TimmyZDesign Posted April 12, 2014 Contributor Report Share Posted April 12, 2014 Nice! Thanks! Quote Link to comment Share on other sites More sharing options...
New Member junker404 Posted April 12, 2014 New Member Report Share Posted April 12, 2014 thanks for sharing Quote Link to comment Share on other sites More sharing options...
Advanced Member stusutcliffe Posted April 12, 2014 Advanced Member Report Share Posted April 12, 2014 Wow! thank you! This will make a change from the usual four I normally use! Now I just need to make something... Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted April 12, 2014 Author Reputable Contributor Report Share Posted April 12, 2014 Glad to share. Hope it helps. Here is a small group of Sci-Fi brushes. Maybe others can add to them by using some of their Hard Surface objects to create some 3D Brush alpha's, as they go. Sci Fi Brush pack: https://drive.google.com/file/d/0B5zx7iMKxeu5LXFreUNHamN0cmc/edit?usp=sharing 4 Quote Link to comment Share on other sites More sharing options...
Advanced Member Denis Posted April 12, 2014 Advanced Member Report Share Posted April 12, 2014 Extensive brush sets. Thanks for sharing!! Quote Link to comment Share on other sites More sharing options...
New Member griff Posted April 14, 2014 New Member Report Share Posted April 14, 2014 Thank you very much for these, they're fantastic! Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted April 14, 2014 Contributor Report Share Posted April 14, 2014 Thanx!! Quote Link to comment Share on other sites More sharing options...
Member jamdalu Posted May 10, 2014 Member Report Share Posted May 10, 2014 Thanks!!! Quote Link to comment Share on other sites More sharing options...
Member AlphaGrunt Posted June 26, 2014 Member Report Share Posted June 26, 2014 (edited) Really awesome thank you for the share! Only one question where do I put them so that I can use them? Edited June 26, 2014 by AlphaGrunt Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 26, 2014 Author Reputable Contributor Report Share Posted June 26, 2014 You can download them to whichever directory you want to store the .3dcpacks, and from within the App, go to FILE > INSTALL EXTENSION. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 26, 2014 Author Reputable Contributor Report Share Posted June 26, 2014 BTW, take note of the single-stitch brush alpha toward the end of the "3DC Brushes" set. That will surely come in handy anytime you need to create stitches on your garments, shoes, etc. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 26, 2014 Author Reputable Contributor Report Share Posted June 26, 2014 ...you can RMB click on the brush alpha > choose "EDIT IN EXTERNAL EDITOR" > 3D Coat will open it up in Photoshop for you > Save to MyDocs/3D Coat V4/Textures/Strips if you want to use that same alpha as a Strip, as it's a lot easier to work with than having to fiddle with spacing and all (in the Brush Options Panel) as just a brush alpha. Figured that might save a little frustration. Quote Link to comment Share on other sites More sharing options...
Member AlphaGrunt Posted June 26, 2014 Member Report Share Posted June 26, 2014 Ranger, I created a folder C:\Users\Grunt\Documents\3D-CoatV4\ToolsPresets\CustomBrush. I put your brushes in the custom brush folder and installed as you suggested above. I do not see these brushes anywhere and I restarted the app after each install? Sorry, I'm new to Coat. Thanks Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 26, 2014 Author Reputable Contributor Report Share Posted June 26, 2014 Ranger, I created a folder C:\Users\Grunt\Documents\3D-CoatV4\ToolsPresets\CustomBrush. I put your brushes in the custom brush folder and installed as you suggested above. I do not see these brushes anywhere and I restarted the app after each install? Sorry, I'm new to Coat. Thanks Ok, with those installed, you can go to the Brush Pallet and find a little menu list toggle in the upper right portion of that pallet. Click on that and under the FOLDER option, see if you cannot see those folders (3DC Brushes, etc.) listed there. If not, when you click that toggle, you can choose ADD EXISTING FOLDER. Just point to the MyDocs/3D Coat V4/Textures/Patterns directory and see if 3D Coat didn't create folders named accordingly, for you, there. 1 Quote Link to comment Share on other sites More sharing options...
Member AlphaGrunt Posted June 27, 2014 Member Report Share Posted June 27, 2014 Ok, I got them to show up but why do I have to do that for every brush? Meaning, when I click the build brush all those brushes no longer show but if I jump back to the airbrush where I imported them the first time they are still there? Is this a workflow thing I don't understand why all those custom brushes would not show for every tool? Awesome brushes by the way, think I just lost an hour playing with them Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 28, 2014 Author Reputable Contributor Report Share Posted June 28, 2014 Ok, I got them to show up but why do I have to do that for every brush? Meaning, when I click the build brush all those brushes no longer show but if I jump back to the airbrush where I imported them the first time they are still there? Is this a workflow thing I don't understand why all those custom brushes would not show for every tool? Awesome brushes by the way, think I just lost an hour playing with them If you go to the EDIT menu > Preferences > General tab....about midway down, uncheck "Remember Brush Shape for every tool." 3D Coat tries to remember the brush alpha you last used with a given tool, by default. Sometimes that's useful...sometimes it's a PITA. Quote Link to comment Share on other sites More sharing options...
Advanced Member ScrotieFlapWack Posted January 10, 2016 Advanced Member Report Share Posted January 10, 2016 Hi AbnRanger thanks for sharing this massive library of brushes. I know this post is a couple of years old but are these brushes tileable? I haven't tried downloading them yet so I don't know if the links still work (currently at work, unable to try). Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 10, 2016 Author Reputable Contributor Report Share Posted January 10, 2016 Hi AbnRanger thanks for sharing this massive library of brushes. I know this post is a couple of years old but are these brushes tileable? I haven't tried downloading them yet so I don't know if the links still work (currently at work, unable to try). I'm not sure what you mean by tileabe. If you are trying to project a tileable texture onto your model, then brushes aren't really what you want to use, A blank Smart Material, using Camera projection is basically the same as using the old Materials panel and you can turn tiling on to project tiled images. You could also start from the splash screen > Paint on UV map mesh > choose one of the tiled plane presets and experiment with one of those to see if that is what you are looking for Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 10, 2016 Author Reputable Contributor Report Share Posted January 10, 2016 This might help: 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member ScrotieFlapWack Posted January 10, 2016 Advanced Member Report Share Posted January 10, 2016 Ahh cool I didn't know this was possible. Thanks again! Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 11, 2016 Author Reputable Contributor Report Share Posted January 11, 2016 Ahh cool I didn't know this was possible. Thanks again! Glad to help. Stencils are similar, except as the name implies, it uses grayscale images to mask as you paint/sculpt, just like a stencil would in the real world. There is a button called TILING in the upper left part of that Preview Options panel. It lets you toggle tiling of the image on and off. Quote Link to comment Share on other sites More sharing options...
Member y077er Posted June 15, 2016 Member Report Share Posted June 15, 2016 Thanks for these brushes, my first time adding to the brush library. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 15, 2016 Author Reputable Contributor Report Share Posted June 15, 2016 8 hours ago, y077er said: Thanks for these brushes, my first time adding to the brush library. Very welcome. Hope they help you do some cool work with them. Quote Link to comment Share on other sites More sharing options...
New Member Wizatron Posted August 4, 2016 New Member Report Share Posted August 4, 2016 Very nice collection big thanks Quote Link to comment Share on other sites More sharing options...
Member metrons Posted August 6, 2016 Member Report Share Posted August 6, 2016 much appreciated. cheers Quote Link to comment Share on other sites More sharing options...
New Member dany667 Posted November 21, 2017 New Member Report Share Posted November 21, 2017 i am new to 3d coat. when i am downloading the file from provided link. its in .3dpack format how can i convert it to .xml or .mclp format.. which 3d coat can read...?? please help me Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted November 21, 2017 Report Share Posted November 21, 2017 3DCPack files are the extension for 3D-Coat. There's no reason to convert it. Just go to File > Install Extension and load the file. Quote Link to comment Share on other sites More sharing options...
Member walter_sullivan Posted October 9, 2021 Member Report Share Posted October 9, 2021 On 4/12/2014 at 6:48 AM, AbnRanger said: I tried to upload some brush-packs to the DOWNLOAD > RESOURCE section of the mainpage, but it has not been a successful venture. Wasted a lot of time trying to do so....so I guess I'll just try to share them here. 1) 3DC Brushes Random collection of brush alpha's containing cracks, wrinkles, reptile scales, etc. https://drive.google.com/file/d/0B5zx7iMKxeu5Z016VFZGR3FYQ00/edit?usp=sharing 2) Cracks & Wrinkles https://drive.google.com/file/d/0B5zx7iMKxeu5SHRValA5Qk9iWTQ/edit?usp=sharing 3) Reptile Skin/Scales https://drive.google.com/file/d/0B5zx7iMKxeu5bC1JNGYwbGgyRjA/edit?usp=sharing I always envied the brushes that could be seen during your tutorials. Incredible that those are available! Thanks a lot! 1 Quote Link to comment Share on other sites More sharing options...
