Advanced Member worldcrafter Posted April 12, 2014 Advanced Member Share Posted April 12, 2014 How can I uv map both sides of one polygon in the retopo room? also how can i paint transparency from a material on a layer (although that isn't the main aim of the topic) thanks Quote Link to comment Share on other sites More sharing options...
Advanced Member worldcrafter Posted April 12, 2014 Author Advanced Member Share Posted April 12, 2014 I found transparency does work just not with the format i was using, png transparency works fine Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 12, 2014 Share Posted April 12, 2014 i usually do transparency erasing layer0 -layer0 its used by internal 3DC operations- Quote Link to comment Share on other sites More sharing options...
Advanced Member worldcrafter Posted April 12, 2014 Author Advanced Member Share Posted April 12, 2014 So is it not possible to uvmap both sides of a polygon in 3dcoat? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 12, 2014 Share Posted April 12, 2014 uvmap both sides ? in which program is this possible ? ... do you mean View Backface culling ? Quote Link to comment Share on other sites More sharing options...
Advanced Member worldcrafter Posted April 13, 2014 Author Advanced Member Share Posted April 13, 2014 No, i mean being able to paint a diffferent texture on each side of the polygon Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 13, 2014 Share Posted April 13, 2014 in which program is this possible ? never saw this before, sorry Quote Link to comment Share on other sites More sharing options...
Advanced Member worldcrafter Posted April 13, 2014 Author Advanced Member Share Posted April 13, 2014 Sry, i jus thought it was possible - Ive never seen it done in modelling software, but have seen cloth and large leaves with different textures on each side in games. "metasequoia" (modelling software) can make a one sided face, or double sided face - i thought, on this principle, it was possible, but I Havant found a way yet. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 13, 2014 Share Posted April 13, 2014 googling i found some info http://forums.epicgames.com/archive/index.php/t-965936.html Ghostdance 06-10-2013, 04:33 AM Yes it is possible, There is a Material Function Called TwoSidedTexturing with separate inputs for side a and b...But I would not advise using it as a way to avoid modeling the inside of the mouth, If that's what your thinking?It would work well for other things. Like making a two sided flag for example. madaboutagmes 06-12-2013, 12:02 PM Yeah that is 2 sided mats, the same mat but on both sides. Duplicate the plane, and flip the normals, then assign the new texture to that plane. Attach planes and export. Then in UDK you should have 2 different mat tabs where you can assign a mat to each plane ----------------------------------------------------------------------------------- Alden http://blender.stackexchange.com/questions/1032/uv-mapping-plane-single-side It isn't possible to create a double sided UV map for a plane. The only thing you can do to get around it is duplicate the mesh and move it just behind the plane.You can't texture both sides because of normals- a plane only has one normal on one side, and double sided normals are not possible. Blender is one of the few programs that chooses to render both sides of the normal. In another program, you would probably only be able to see one side in edit mode or a render.Hope I helpedAlden ----------------------------------------------------------------------------------- http://blender.stackexchange.com/questions/1032/uv-mapping-plane-single-side To the best of my knowledge, Blender does not have a built-in setting for one-sided UV mapping. However, you can trick Blender into thinking that your plane has two distinct sides, which you can then UV unwrap independently. To do this, add a Solidify modifier, set the 'Thickness' value to 0, and hit 'Apply'. Now, when you go to UV unwrap, you will have two sides to map, one of which you can set to an image and leave the other blank by arranging them in the UV/Image Editor. Quote Link to comment Share on other sites More sharing options...
